设备-20到50度,kernel都能正常起来,升温到55度的时候,有个别板子会出现校验异常,这种可能是什么原因导致的* z5 `4 k2 g9 H
DRAM: 128 MiB
1 y( c% ?9 ]7 x H% FTop of RAM usable for U-Boot at: 88000000
+ g( J8 m, J$ N% }1 iReserving 0k for LCDC at: 877ff000: q/ X3 u3 z+ ~& s8 j
Reserving 245k for U-Boot at: 877c0000$ U. h$ s3 H) J; f) j
Reserving 65568k for malloc() at: 837b80002 J, r+ s8 o3 E5 X3 @8 V8 Z
Reserving 32 Bytes for Board Info at: 837b7fe0
7 g4 q3 e+ C r3 [+ }$ L$ MReserving 128 Bytes for Global Data at: 837b7f60; M+ p7 f2 I c
Reserving 128k for boot params() at: 83797f601 h/ _: D# A& T J+ R9 t
Stack Pointer at: 83797f48! B' |# T# K) P! G' L$ r
Now running in RAM - U-Boot at: 877c0000: D. X6 n2 l: G3 W5 q0 V+ w
MMC: msc: 0! G& v" ^' ~$ O/ Y) o; o5 h
pixel_clock = 30004000
4 F. F5 C) ~9 ^" l& M; o+ U" r' y% bvideo configure is ok! ~. U2 \- M2 C4 b
dump_lcdc_registers
$ h L/ P7 O0 b6 G6 IIn: serial
/ h; V. b9 m) B" D$ ZOut: lcd
) f8 |2 V' K( { _Err: lcd
( e) ^0 k \. `- E7 RHit any key to stop autoboot: 0
# Z7 A$ C+ b" C- b# I0 Y## Booting kernel from Legacy Image at 80f00000 ...
2 H: u# r! j; A4 }5 O6 r S Image Name: Linux-3.10.14. E G, i0 ?6 F
Image Type: MIPS Linux Kernel Image (gzip compressed)+ F: s! }( J) x+ H+ \' U
Data Size: 5160677 Bytes = 4.9 MiB
! n* P( o5 l$ c& X$ M( x( i' Z Load Address: 80001000% N) t& V, q! G/ S7 K I+ I" K
Entry Point: 8063d060
8 B' \7 y) g& P" G) L9 H* _ Verifying Checksum ... Bad Data CRC5 H% r9 e" n2 K7 I
ERROR: can't get kernel image!( @ x( h' C5 ^/ L, W2 c6 K- {0 r
halley2_plus#6 g; F* O( ]; V% f
# ~4 o* F9 c$ j: v* C5 G |
