查看: 741|回复: 3
error C187: not an lvalue不知道咋改,很急,求解
发表于 2023-3-15 14:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电子琴2.C(163): error C187: not an lvalue) T) L* Y. u  V2 c
主程序第一行,不明白为什么会错,咋改,很急,求解+ P$ H4 Y; j9 g2 r
: \* E1 v" E; {5 [8 Q! r# X
#include                  //调用单片机头文件
* N1 @# e$ Y$ q#define uchar unsigned char  //无符号字符型 宏定义        变量范围0~2558 X! H- L# b, {: i5 L9 H
#define uint  unsigned int         //无符号整型 宏定义        变量范围0~65535
/ X8 P) n$ y5 {' Z0 z
! |) ^8 e' y- r) o1 G& P
/ O9 U  o6 \4 i) \# J***it beep  = P1^5;           //蜂鸣器定义2 k, O+ S8 e) C1 }& V
. S' C3 x+ v1 D* R4 F' _) X: F; Y/ `* W% Z, S
***it K1=P3^2;//音乐播放按键
, c7 \3 q. P0 F" y5 T; l* P- [uchar flag_en = 0;           //开始放歌/ R' r( G' v, g* Y9 S
uchar flag_i = 0;5 p+ M; j: H4 u% @
. h' K4 L* O; v, z$ g* w
: K+ z; _! Q. k) juchar num=0;//初始化num,用于控制数1码管显示的字符$ ^9 z, c4 W' ^
6 S6 W! M* j  I# W0 X
% F8 S, V" H+ R$ j  i& l- F//数码管段选定义       0    1    2    3   4           5        6         7          8           9
$ N2 Y! q$ o6 Juchar code smg_du[]={0x28,0xee,0x34,0xa4,0xe2,0xa1,0x21,0xec,0x20,0xa0,
0 n1 y8 y' o$ d0 v+ V6 t//                                           A        B         C          D           E   F        不显示
8 [8 A0 ~0 ?/ K; A8 ^: _6 R4 P& [                                           0x60,0x23,0x39,0x26,0x31,0x71,0xbf};         //断码
1 g5 L# u9 t6 S# g( ~                                         2 S3 F+ i+ f5 d* ]
3 h1 `3 i' a, G& n) @
, K0 H! s! M) ~/ w: l. p
uchar m,n; 9 I5 h: I. s! B) w0 a, r4 L2 P
uchar code T[49][2]={{0,0},
# \# _* `6 O* X' k7 D5 Z4 c{0xF8,0x8B},{0xF8,0xF2},{0xF9,0x5B},{0xF9,0xB7},{0xFA,0x14},{0xFA,0x66},{0xFA,0xB9},{0xFB,0x03},3 o1 L" ?# O: m% S3 u/ t
{0xFB,0x4A},{0xFB,0x8F},{0xFB,0xCF},{0xFC,0x0B},{0xFC,0x43},{0xFC,0x78},{0xFC,0xAB},{0xFC,0xDB},
* D& f8 r( p' l- u! E" S{0xFD,0x08},{0xFD,0x33},{0xFD,0x5B},{0xFD,0x81},{0xFD,0xA5},{0xFD,0xC7},{0xFD,0xE7},{0xFE,0x05},
3 P3 |1 E( J# M# M. L1 `6 E7 T- j! c{0xFE,0x21},{0xFE,0x3C},{0xFE,0x55},{0xFE,0x6D},{0xFE,0x84},{0xFE,0x99},{0xFE,0xAD},{0xFE,0xC0},
3 n9 O6 ~; q: z" O{0xFE,0x02},{0xFE,0xE3},{0xFE,0xF3},{0xFF,0x02},{0xFF,0x10},{0xFF,0x1D},{0xFF,0x2A},{0xFF,0x36},3 Q7 K0 ^# f' u  V
{0xFF,0x42},{0xFF,0x4C},{0xFF,0x56},{0xFF,0x60},{0xFF,0x69},{0xFF,0x71},{0xFF,0x79},{0xFF,0x81}
% G% W7 A" W6 m! Z5 z};$ F3 j) _9 C3 |3 j
uchar code music1[][2]={{0,4},           //两只蝴蝶 . e, G5 h/ U% P* W
{23,4},{21,4},{23,16},{23,4},{21,4},{23,4},{21,4},{19,16},{16,4},{19,4},{21,8},{21,4},{23,4},{21,4},{19,4},{16,4},{19,4},{14,24},
& o+ \' y3 N$ k9 G; A: S/ k9 b{23,4},{21,4},{23,16},{23,4},{21,4},{23,4},{21,4},{19,24},{16,4},{19,4},{21,8},{21,4},{23,4},{21,4},{19,4},{16,4},{19,4},{21,24},
, j1 _6 |% j5 K1 Q: Q$ r+ T8 @' ]) L9 t0 t: ?
" \7 y) X; o& t8 Z" l& n{23,4},{21,4},{23,16},{23,4},{21,4},{23,4},{21,4},{19,16},{16,4},{19,4},{21,8},{21,4},{23,4},{21,4},{19,4},{16,4},{19,4},{14,24},
- a0 h5 c. x4 m; E( j{23,4},{26,4},{26,16},{26,4},{28,4},{26,4},{23,24},{21,4},{23,4},{21,8},{21,4},{23,4},{21,4},{19,4},{16,4},{16,2},{19,2},{19,24},{0,20},
7 F0 Z$ F  K% ?: E1 U- h6 a{26,4},{26,4},{28,4},{31,4},{30,4},{30,4},{28,4},{23,4},{21,4},{21,4},{23,16},{0,4},{23,4},{23,4},{26,4},{28,8},{28,12},{16,4},{23,4},{21,4},# N; D- K' g4 X: K7 k/ d4 g9 I& C
{21,24},{23,4},{26,4},{26,4},{23,4},{26,8},{0,4},{31,8},{30,4},{28,4},{30,4},{23,8},{0,4},{28,4},{28,4},{30,4},{28,4},{26,4},{23,4},{21,8},{23,4},{21,4},{23,4},{26,16},
, U9 B* K4 C8 ]. S9 C{0xFF,0xFF}};
  P2 s. N% S' g3 ]
& v: C" X# k/ b' i* w4 R. Y2 D1 ?% n
% ^% g( b- q8 n" Q5 R( i( f5 F3 O, J' @6 F* Z: A) R! N$ Q: G& H
uchar code music2[][2]={{0,4},          //生日快乐0 t& a! A, M8 {. S3 z( ~  R
{17,6},{17,2},{19,8},{17,8},{22,8},{21,16},
- ?/ R$ J, L) g* M- k0 C* q{17,6},{17,2},{19,8},{17,8},{24,8},{22,16},{17,6},{17,2},{29,8},{26,8},{22,8},{21,8},{19,8},{27,6},{27,2},{26,8},{22,8},{24,8},{22,16},) C! w. X/ I4 Q( T# _/ r+ Z" R' b
{0xFF,0xFF}};& Y9 i( _% h9 R. d, w1 H
. {/ z& i# I. q+ ^; R
6 @: U- K& |6 N& ]; {uchar code music3[][2]={{0,4},         //爱情买卖
. j: f/ a8 n: s; z2 |{22,4},{22,4},{17,4},{15,4},{15,4},{17,12},
- X' t  A, _" f" h' w0 u8 Z/ A  `{15,4},{15,2},{17,2},{15,4},{13,4},{13,4},{15,12},{0,4},
9 @/ a. \1 e) `* G{20,4},{20,4},{20,4},{17,4},{20,4},{20,4},{20,4},{17,4},
  U" n( }5 A* I9 `* A+ G1 j{22,4},{17,4},{17,4},{15,4},{15,4},{17,12},% |  }" n1 ?; g% f0 x
{22,4},{22,4},{17,4},{15,4},{15,4},{17,12},! u/ U3 ^! ^1 F( q
{15,4},{15,2},{17,2},{15,4},{13,4},{13,4},{15,12},) `' L8 ^2 m! V  r% ]9 [, y3 v, F& }. [
{20,4},{20,4},{20,2},{17,2},{17,4},{20,4},{20,4},{20,2},{17,2},{17,2},{17,2},# O& r4 h7 i% U+ `. r! K
{24,4},{20,4},{20,2},{17,2},{17,4},{20,4},{22,12},' k( \7 }3 T, w' \+ S
{17,4},{22,4},{25,4},{25,4},{17,4},{22,4},{25,8},
0 `$ j2 k1 d6 O# V- q5 O{24,4},{22,2},{24,2},{22,4},{20,4},{15,4},{17,12},
) V% W9 E" D% ?8 S{15,4},{15,4},{15,4},{10,4},{15,4},{17,4},{20,8},2 h7 A# a) W1 a, S
{17,4},{24,4},{24,4},{20,4},{15,4},{17,12},, O# i/ t7 U4 G$ A, q; |2 u/ f
) Z* l- K' l8 ~1 f0 Z4 u2 W{29,4},{27,2},{29,2},{27,4},{25,4},{25,4},{27,12},
3 z4 j# L2 y0 f7 M* X# c{29,4},{29,2},{27,4},{25,4},{27,6},{27,2},{25,4},{24,4},' o0 g9 `' A* R# x) u3 p! w0 H
{20,4},{20,2},{17,2},{20,4},{20,2},{22,2},{22,16},4 V% I" f. d# g9 ]2 a9 h) F' K# u
{0xFF,0xFF}};0 e0 {. h$ n- {+ i* ~
void delay(uchar p)4 I1 c% g6 z* v( B0 A
{8 W( E/ C- L* M6 h
    uchar i,j; % {; ^" V0 u1 }) O, z, I4 i
    for(;p>0;p--)
5 ]2 ?# d2 k2 d0 Z    for(i=181;i>0;i--)
/ `- `: o, ~; q" ]( Y    for(j=181;j>0;j--);2 ^* r/ O: W! ^* g5 V
" u- A8 E  s* j8 v/ T) Y& p7 E4 Z/ q+ t" H( l# ~
& y' x1 w1 D0 q. W- }
void pause()6 y; Z  L/ `" C8 k+ ?
{+ B  _+ o6 k$ Q" `9 z: R3 r! U& i% u
    uchar i,j;6 G; I( o( i6 a8 u! p; S* C+ R$ i
    for(i=150;i>0;i--)
& v  d6 k! ~: Q7 b+ K& N9 m    for(j=150;j>0;j--);: m. M  r& _2 G+ u
! Z! q7 J; R1 ^. [7 [
8 N1 p3 o9 K) L. Q" K7 r
& R( c9 e1 \# f( j7 t* z0 }# b3 _5 ]: P
8 C- A) S4 ~* ]- _+ ^+ I! }
/***********************1ms延时函数*****************************/# B/ h- m' J+ `+ Q! a5 F
void delay_1ms(uint q)) ^2 i* n6 m: k) K
. c$ E8 ~3 Y1 t: Y/ g        uint i,j;- Y, X1 }7 j' {; ]1 P. a# w7 |) e
        for(i=0;i
2 s: T4 ]' I3 e3 ^8 C+ a                for(j=0;j<120;j++);/ ~$ c3 `2 ~/ {. ~7 [. s$ A
}0 i: ~, |( h8 G* X, g
+ D4 ]: f. I! R% N
, I, r$ E4 w: R8 m& k/******************按键程序*************************/
) [1 m4 W7 r) tuchar key_can;         //按键值% i+ s1 I. K- l& T- u5 f- U6 E' G' o
0 j, z3 V+ ]; Z6 i; b$ Vvoid key()         //独立按键程序" B0 k9 B1 h3 ^/ I: e
  M6 q$ P) }, ^7 N. b. L# x        static uchar key_new = 0, key_l;
4 z# Z1 b. ~8 v4 W8 I, Y        key_can = 20;                   //按键值还原1 W; e0 w2 Z! b* G, f- X4 M! ^
        P1 = 0x0f;' b7 J$ g3 w1 o+ F8 ^. N
        if((P1 & 0x0f) != 0x0f)                //按键按下7 v+ E  Y4 ?/ [" n9 x) L
        {# z) P7 r7 M; w& I0 ~4 _( h: b
                delay_1ms(1);                     //按键消抖动
/ l$ T; _% R! Y9 z# n                if(((P1 & 0x0f) != 0x0f) && (key_new == 1))6 [# N6 ?5 @4 _- L$ G7 S5 {+ @+ S
                {                                                //确认是按键按下
9 L) V; W8 f" m( V, y/ u* o                        key_new = 0;0 w& f# _3 g9 R3 z
                        key_l = (P1 | 0x0f);   //矩阵键盘扫描7 ~4 U& e% n1 V
                        P1 = key_l;
! m0 ^' q- q5 T  b7 C0 S$ S' A                        switch(P1)
  N' R# l  Z" f4 F4 J. ~* H: \                        {                                                ' l, w0 u' _3 B2 ~7 R# O7 w
                                case 0xee:  key_can = 0; m = 8;        TR0 = 1; break;  //得到按键值  //打开定时器
5 t8 x1 P# n+ R5 U3 n, ]                                case 0xde:  key_can = 1; m = 9;        TR0 = 1;   break;   //得到按键值   ^3 P/ d1 o+ D3 u( D: ]
                                case 0xbe:  key_can = 2; m = 10;        TR0 = 1;   break;   //得到按键值
- I/ c/ x; Z+ ~5 z# B                                case 0x7e:  key_can = 3; m = 11;        TR0 = 1;   break;   //得到按键值 , ?7 ^/ v/ W+ X! c- i3 _0 @
2 s$ ?5 ?, b! M" I                                case 0xed:  key_can = 4; m = 12;        TR0 = 1;   break;  //得到按键值 $ U0 |; [( ~* F& N0 ^
                                case 0xdd:  key_can = 5; m = 13;        TR0 = 1;   break;   //得到按键值 * N+ o" v8 J# J+ @, K2 H  d
                                case 0xbd:  key_can = 6; m = 14;        TR0 = 1;  break;   //得到按键值 . \7 b  r: d2 |$ v3 j
                                case 0x7d:  key_can = 7; m = 15;        TR0 = 1;   break;   //得到按键值
; r' I0 F* X# x  h" R        2 k8 O& o$ d0 k$ C5 E0 M
                                case 0xeb:  key_can = 8; m = 16;        TR0 = 1;   break;  //得到按键值
5 k6 J' X' b% i5 U8 j                                case 0xdb:  key_can = 9; m = 17;        TR0 = 1;   break;   //得到按键值 1 R1 O4 u# \# S4 Y/ T* b' Y6 N
                                case 0xbb:  key_can = 10; m = 18;        TR0 = 1;   break;   //得到按键值 + J  @% x2 S5 h, j$ Z; E# a5 R
                                case 0x7b:  key_can = 11; m = 19;        TR0 = 1;   break;   //得到按键值
6 I4 W# }0 \6 E  d6 Q7 [
% A! r+ @+ P! _* B  S6 h                                case 0xe7:  key_can = 12; m = 20;        TR0 = 1;   break;  //得到按键值
; o+ T& D: j( h9 @. I                                case 0xd7:  key_can = 13; m = 21;        TR0 = 1;   break;  //得到按键值 $ Q+ X) O$ e: n
                                case 0xb7:  key_can = 14; m = 22;        TR0 = 1;   break;   //得到按键值
' `$ [# }; o; D" q0 G                                case 0x77:  key_can = 15; m = 23;        TR0 = 1;   break;  //得到按键值
1 j. O; \5 @5 ~8 _/ y% y                        }        / @5 }2 u4 g, R' n' U" ]4 L
                        P0 = smg_du[key_can];          //显示
& [+ }4 F. C+ b" h                        while(P1 != 0x0f), ^" z1 F' |9 X. U6 `
                                   P1 = 0x0f;5 p# d2 E. ?' ~1 i7 a
                        TR0 = 0;              //关闭定时器( e- g  U& b% V# B  J) u8 A
                }                        9 C: t* O/ X1 F! s" N$ s5 i  ]! u# l
! c9 r& V$ b* f# \        else                   //按键松开
1 T# j! A' C8 a& l2 ~+ M9 Z" F        {
# }+ ^6 m0 J0 C, d( o# O                P0 = 0xdf;          //显示小数点1 R5 ~0 Q5 a5 G% ^+ U
                key_new = 1;
9 z# M0 B7 C( G7 h: w( E* |8 C        }
8 Q( Q( E+ |$ ?, }5 M4 V- c0 W
( F( E  q8 ^, j  J% v
1 E' C3 z! k" p$ [2 V) ^  f/*********************歌曲播放*********************/( W) {! r$ n' G+ d
        K1=1 ;
" e1 }$ y8 f. |; I        if(K1==0)2 t( a  g) H$ ?1 K5 M/ F& x
. g9 }0 W$ \% u$ m4 u; i                delay_1ms(10);         //按键去抖动
0 {. k1 ?$ \6 j" i" A, x9 ]                if(K1==0)$ E0 L& P2 Q4 e- ]6 J$ o
6 X% i5 \$ [" h' v( z                        num=8;
+ ?# |9 F! P* F, U//                        P1=smg_du[num];//使数码管显示该音调的字符! s8 o4 X3 D6 d
                        flag_en ++;
" i- S( d0 P2 R' }# V- Y                        flag_i = 0;
) D) Z  w9 l: ?7 ^+ M# y                        if(flag_en > 3)$ w* q. z5 [# C" W( c3 K0 ?" {
                        {1 t& _; v5 y/ F/ Y) }
                                flag_en = 0;
# r& J8 h1 r& r" H/ m7 p5 V0 I                                TR0 = 0;
) d7 J* I4 a; g) Z                        }
1 E5 [9 q8 V1 z6 s" |$ _, X3 E; J                        while(!K1)% p, G) l# x" J# m; {
# h# `; }& \8 ~3 ~                        }//使蜂鸣器发出相应频率的声音;5 f0 V, m! Z3 j! `
& m' U3 u7 H. x4 V+ l: C" ^        }6 Q; E! w  a" q5 O3 Y
}' C; j& |2 Z/ K# K1 ]# g! |
% R$ L+ y' `( T8 k1 ~
4 U, \8 K7 g& q' `. N2 S' V  v) F6 V# ]1 G: {( w
  P  J7 _0 d2 [  S
/******************主程序**********************/           6 N/ ]  q: r7 C
void main()
3 Y& d4 m7 z4 ^  F% L. G{        5*++++++++++++++++, P0 G3 s* a5 s2 Z8 T
  P0=P3=P2=P1=0xff;
! W/ O9 p( Y; Z& O          : O3 v, \* W- H" z( i; m
        TMOD=0x01;  EA=1; ET0=1;    //定时器0初始化
7 l! s, {7 j) Q        while(1)
; l: S6 G: o- X( O! q- V5 z        {- D  A7 Z  J1 w
                P0 = 0xdf;          //显示小数点7 p5 h  _) A/ i1 Y# a* N
                key();          //按键程序
" t# s: F0 n+ Z- |4 c4 t& m. y                if(flag_en == 1)         //爱情买卖
* F! Y' I, R. d                {
( k; y( g8 w- G2 ~  c1 S                        m=music1[flag_i][0];n=music1[flag_i][1];            //放歌 2 l( Q- s3 `- N( {. H
                        P0 = smg_du[m % 16];          //显示
, S5 X9 u( H1 ?2 a+ U                        if(m==0x00). A) i6 y' ?. ]- g2 Q& m8 g9 Z
                        {9 l0 W( G/ v- u! g: W
                                TR0=0;0 _9 M! j' X( C3 L$ F, x
                                beep = 1;) [! Q7 e# G+ W
                                delay(n);: i5 r0 [) @+ f
                                flag_i++;( ^$ u& O( y; Y7 k( h
  ~/ s, L/ `9 |* ~                        else if(m==0xFF)                                 //放歌结束
, m% V$ M0 r* C, h$ ^                        {
9 d9 x$ y) `1 j" M/ f                                TR0=0;beep = 1;delay(30);flag_i=0;flag_en = 0;} 6 c% Q" Z$ E& y: M
                        else if(m==music1[flag_i+1][0])   t* N" n6 f; ]& v
                                {TR0=1;delay(n);TR0=0;beep = 1;pause();flag_i++; }% c4 j+ h' \" L* S. s7 i' O
                        else
$ V' r0 C. `, a) h! t0 ?6 S& U- b                                {TR0=1;delay(n);flag_i++;}
4 U4 K$ U$ R/ L' d                }1 O3 P7 y9 o; t4 W3 o; l# ~
                else
: _# n2 [* D' p+ K* p" n                        beep = 1 ;9 R! [& x. D0 G9 b6 ^/ c
  ]' U# V$ f9 I
" z; q  U+ w. V3 q' u& o                if(flag_en == 2)         //生日歌* ]# ?9 ?. r! O  X/ v
                {' ^, Q: x6 K1 W1 {
                        m=music2[flag_i][0];n=music2[flag_i][1];            //放歌
& \- W( q2 W- L* E( B( Z                        P0 = smg_du[m % 16];          //显示
* s+ d( l- p8 \                        if(m==0x00)
  @6 c% p7 T+ F6 J' A4 y% Y                        {6 G8 d4 ~7 i5 L6 Z
                                TR0=0;
2 h) \! S# ~7 T; K  ?                                beep = 1;. C' C5 s% ^+ Z' j
                                delay(n);; h6 c0 H2 O  H4 A7 Q9 Y( e
                                flag_i++;* S4 ^5 K- C0 R, Z
5 H. D' h0 x0 V2 d' Y0 n2 w                        else if(m==0xFF)                                 //放歌结束
* w- B5 M; G5 v( A- F- ~. m                        {
; Y2 c$ d# ?4 O9 W3 w1 ~$ z2 `: v                                TR0=0;beep = 1;delay(30);flag_i=0;flag_en = 0;}
' q% y0 G3 d# {/ s0 j6 g- L  D3 _                        else if(m==music2[flag_i+1][0]) 1 \( O7 ?2 w' Y; Y
                                {TR0=1;delay(n);TR0=0;beep = 1;pause();flag_i++; }+ r  \! r& x( u; T& P
                        else7 Q; |/ e3 I7 g* V6 @; w* ?& X
( `1 `8 R0 Q0 i9 I5 |0 `+ `                }- ^' @& M7 g; U+ P6 e7 u3 |
                else
0 Z2 W6 {6 H& W' F0 G! C- Q                        beep = 1 ;( ?4 b! w& g" W' i  O/ F5 d' Y0 ]
# g1 \& `: g7 g
* m( Y+ D+ A  k  U1 ]% m" U7 @                if(flag_en == 3)         //新年好* o7 E* }7 q) V
                {, d9 F+ ~1 m7 `
                        m=music3[flag_i][0];n=music3[flag_i][1];            //放歌 % f9 B! X7 ^3 j
                        P0 = smg_du[m % 16];          //显示+ e! p( ?6 n, |9 L1 P+ ]8 `
                        if(m==0x00)- m3 ^9 r- c* G) \4 L
                        {9 v7 g( w8 T/ z: K  r) ~& g. l4 h
                                TR0=0;$ Q) {/ L1 w# L& `2 P$ N1 h
                                beep = 1;
  f9 I# U. F& J- {                                delay(n);( Y3 V& T' A/ q% w. s
                                flag_i++;
. r/ E, y3 |& x. I2 U" y                        }
6 j' [% T) F+ c& L4 g! I                        else if(m==0xFF)                                 //放歌结束
: \$ E! N% h- f+ z' F                        {
. V' H0 T' V( I) o: n, ?6 x                                TR0=0;beep = 1;delay(30);flag_i=0;flag_en = 0;} 7 J( M5 k( M5 R9 o/ v& I+ V; l
                        else if(m==music3[flag_i+1][0]) 5 s2 d5 d4 N7 `8 H
                                {TR0=1;delay(n);TR0=0;beep = 1;pause();flag_i++; }% T( ?) r1 b% z  ?: C( ]
                        else
, d" t1 ~0 P7 V                                {TR0=1;delay(n);flag_i++;}
! E; s, i5 t6 J  v( ^                }, P& ^( I! J$ I$ u! H
                else   c( \2 G# b& R) t6 j0 ^1 _
                        beep = 1 ;# O* }4 \# _9 L0 l0 m1 P7 ?
% J, _5 c& Q  U# j, W}
4 m) {1 q% N+ ?1 t, p. c) g. O( i3 n8 B9 O4 n
0 L' k  U. j' a8 c8 D7 p' r
/*****************定时器0中断*********************/           . t* ]2 m# q$ F0 Z# R
void T0_int() interrupt 1
' O, \+ ^- \  E& {$ i, v2 w3 G{
, z7 z' ^( E+ K& [( v* T        beep=!beep;
$ [- h9 g0 q! S        TH0=T[m][0];
3 @' \( j) e4 w5 R9 _/ u        TL0=T[m][1];
+ {( P3 r3 _: y3 q}# t% ~0 T( u7 i2 l5 S3 s
发表于 2023-3-15 15:11 | 只看该作者
先看明白那句话是什么错误,然后跳到相应的行,基本你就明白了
发表于 2023-3-15 15:59 | 只看该作者
主程序第一行的5*++++++++++++++++是什么鬼,把它删了。
应该是不小心按上的吧,谁会搞这么多符号。  详情 回复 发表于 2023-3-15 16:07
发表于 2023-3-15 16:07 | 只看该作者
Terran 发表于 2023-3-15 15:59# D# o5 S+ h3 K# V- C9 o. i
7 s$ p) l8 s; k8 J2 D应该是不小心按上的吧,谁会搞这么多符号。' ~* Z, ]. L; m3 {4 D; F
GMT+8, 2025-10-8 07:25 , Processed in 0.171875 second(s), 27 queries , Gzip On.
