查看: 535|回复: 6
导入网表出现这个错误怎么解决
发表于 2023-2-13 10:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
4 Z; ~; G" u2 W: [3 N$ a7 A; }(        )* L6 e5 u+ }* b4 [
(    allegro Netrev Import Logic                                      )
  C% j* W2 l6 u8 D(        )# Y# k0 a5 s6 a& s
(    Drawing          : JH-7206A.brd                                  )% C( C! Y& o( V, h
(    Software Version : 16.5P002                                      )
7 y8 `" P( `+ q) F(    Date/time        : Sat Dec 14 16:26:17 2013                      )6 ^/ b; O, d! |1 z6 u' {
  C" S- N, I" p2 [  U8 u  Z. J(---------------------------------------------------------------------). d: N, L3 L( S5 l, q0 C
: _1 M; d1 b8 y6 z5 K/ {! p
- c6 L  e! A" ]& u$ X% |------ Directives ------; E5 T, }7 a, e. U/ X: T
/ u) W4 ]% E$ }; W7 C' ]RIPUP_ETCH FALSE;2 o- z  H( V4 p. b/ t' o9 i( o
RIPUP_DELETE_FIRST_SEGMENT FALSE;* G% N# a7 }6 s
RIPUP_RETAIN_BONDWIRE FALSE;
  o2 `/ X2 `" `# M( @) ~9 aRIPUP_SYMBOLS ALWAYS;& M: C3 I2 P+ v
Missing symbol has error FALSE;$ P, B/ f  l! V* P" y; l' P3 i
SCHEMATIC_DIRECTORY '.';
- a  s. V7 d& W9 ], {BOARD_DIRECTORY '';8 Y, f. H/ {. h( m$ a
OLD_BOARD_NAME 'F:/LIAN XI/cadence/JH-7206A/JH-7206A.brd';5 E  q5 v; s0 `  d
NEW_BOARD_NAME 'F:/LIAN XI/cadence/JH-7206A/JH-7206A.brd';
# ?7 {% c+ `3 e6 V; X; ?: J8 B0 l
# t) G! I7 b- CCmdLine: netrev -$ -i . -y 1 F:/LIAN XI/cadence/JH-7206A/#Taaaaaa06548.tmp
4 U9 e: I  s; w3 o8 u" _
2 v1 n: c6 {+ o8 H' J------ Preparing to read pst files ------$ w$ g+ c% T$ D' F+ ]
; X5 q: q1 D2 ]' H+ d6 W' o* w. `( d' i
#1   ERROR(24) File not found
* I7 o9 [* j. j* X3 y# f( L% y     Packager files not found
3 N4 n/ y. d# a2 j% s8 E. k+ ^
; U; i+ v, G- n( R: z/ j#2   ERROR(102) Run stopped because errors were detected
9 T! J( r* r$ s* t! C
+ f, Y8 `8 j+ _7 b$ ?( O' rnetrev run on Dec 14 16:26:17 2013" @8 C- p2 W4 }; N
' W& d! u% i: ~' C
   COMPILE 'logic'/ y, o5 Q# Q( w# G- `% i  Z( B
   CHECK_PIN_NAMES OFF* F- ^1 m8 m: V! x3 z' y5 }
   CROSS_REFERENCE OFF
' X% w* G7 `2 T1 g+ J  X0 ~6 s# y   FEEDBACK OFF# K# X, g3 v4 @; a. W$ k
   INCREMENTAL OFF' E  r1 T" A1 ~6 B0 b% N
   INTERFACE_TYPE PHYSICAL
9 ~0 V, \2 e, T   MAX_ERRORS 500
, F2 c! g  G2 }+ D8 [' L' I   MERGE_MINIMUM 5
; {7 Z+ u; W- C" \3 S2 C' T   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'+ z$ j6 L- m9 `# q  P& D
   NET_NAME_LENGTH 24* N: k. s# z8 S& H9 a
   OVERSIGHTS ON
5 O- O; `2 _# V( z- `/ _$ c( ?* X   REPLACE_CHECK OFF
+ A7 s5 h9 C& ^: g7 n, H( u6 f   SINGLE_NODE_NETS ON. F4 b0 U3 x7 S; E/ E
   SPLIT_MINIMUM 0
! u* m8 F4 D7 k% j+ l: i   SUPPRESS   20* }6 d. T' }0 _5 C. j2 J& d
   WARNINGS ON
; \) x7 A; \. _4 k$ q4 ~8 R' w
  2 errors detected
0 U6 v, H, Q& c6 p1 Q  d) R No oversight detected
4 T. \1 G* b# u0 ~ No warning detected$ E. u) q6 z) V; x: j3 \" D
2 ^" n# g4 b$ ~" i% vcpu time      0:00:50
6 E: e1 y9 A9 [0 w- w) r+ Z( velapsed time  0:00:00
! H/ G- s: ~- j7 g; ^/ j& z* i! S 3 f, y  W, k) n0 ~8 F
" g' {$ j- a- |7 F3 p
8 J0 x8 O9 N# s. R# W
推荐
发表于 2023-2-13 11:29 | 只看该作者
这个报错是没有找到网表,一般是没有生产网表或者导入网表选则的路径并不是网表实际所在的位置;
发表于 2023-2-13 11:24 | 只看该作者
原理图中有元件封装没有给。
发表于 2023-2-13 13:48 | 只看该作者
应该是这两方面问题:封装位置没指对,文件不全。
发表于 2023-2-13 14:04 | 只看该作者
软件报错是封装方面的问题,只有这两的问题的同,封装位置没指对,文件不全。: S9 K# h/ E! N2 t, _
具体你再检查仔细点看看了。 在setup中设置一下,不然没法子导入package
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2023-2-13 16:11 | 只看该作者
    要把网表路径指到网表文件所在的目录,一般是在原理图的allegro子目录下
    难过
    2025-1-20 15:39
  • 签到天数: 100 天
    [LV.6]常住居民II
    发表于 2023-2-13 16:20 | 只看该作者
    aaaaaaaaaaa
    GMT+8, 2025-11-3 22:57 , Processed in 0.140625 second(s), 28 queries , Gzip On.
