查看: 359|回复: 3
cadence HDL 16.6 总是打包不成功,提示阻容有问题!
发表于 2023-2-8 09:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
----------------------------% g3 V# \) Y0 B- q9 i/ E0 W
Running audit on all the signal models present in design.5 `% l* P7 c5 q5 H3 c9 B4 T5 V
----------------------------7 W8 `# `. s2 e! z4 `$ ^
Error:  Signal Model "R1ohms" on instance"@bridge_lib.bridge(sch_1):page1_i9"
7 u5 R9 v% t4 o% V4 W9 a( c) P5 J0 WError:  Signal Model "L10nH" on instance"@bridge_lib.bridge(sch_1):page4_i39"" j( O; M. ~( c1 \
Error:  Signal Model "L10nH" on instance"@bridge_lib.bridge(sch_1):page4_i33"8 D/ _% ]1 X5 P6 ]
Error:  Signal Model "C0.1uF" on instance"@bridge_lib.bridge(sch_1):page4_i45"
2 L$ ^8 ~0 u' C3 a6 R* k$ {Error:  Signal Model "C0.1uF" on instance"@bridge_lib.bridge(sch_1):page4_i36"
2 s% `. [7 c! ^) a& o! A. e4 b' y% V2 YError:  Signal Model "R200ohms" on instance"@bridge_lib.bridge(sch_1):page1_i12"" i& f4 O! S- t5 @! I2 r
Error:  Signal Model "C150pF" on instance"@bridge_lib.bridge(sch_1):page1_i13"
& ^2 q+ C+ d: v1 @$ g# \# X# PError:  Signal Model "R2.2kohms" on instance"@bridge_lib.bridge(sch_1):page1_i10"8 l0 c5 _9 L9 D3 U5 B
Error:  Signal Model "R200ohms" on instance"@bridge_lib.bridge(sch_1):page1_i3"
1 j) o8 F5 b* o4 N$ S* ~' B* jError:  Signal Model "C0.01uF" on instance"@bridge_lib.bridge(sch_1):page1_i15"
. U: F# A6 b; O1 ~Error:  Signal Model "C1000pF" on instance"@bridge_lib.bridge(sch_1):page1_i14"
7 M2 p2 U, r9 @( S+ O! p4 c- tError:  Signal Model "L8.2nH" on instance"@bridge_lib.bridge(sch_1):page1_i17"/ @/ c# d5 m8 W3 [" V# R" i
Error:  Signal Model "R200ohms" on instance"@bridge_lib.bridge(sch_1):page1_i16"7 m# c& I: I9 w9 B# B5 l
Error:  Signal Model "R10kohms" on instance"@bridge_lib.bridge(sch_1):page2_i18"
. O! r& u# D2 ]- J' KError:  Signal Model "C10uF" on instance"@bridge_lib.bridge(sch_1):page2_i41"6 `" W" r, i$ b
Error:  Signal Model "C0.1uF" on instance"@bridge_lib.bridge(sch_1):page2_i42"( ]* V# Y8 {1 H( [" o  k  b1 ?1 k
Error:  Signal Model "C1000pF" on instance"@bridge_lib.bridge(sch_1):page1_i20"; b% O, S8 E+ f- n; @0 J
Error:  Signal Model "C0.01uF" on instance"@bridge_lib.bridge(sch_1):page1_i22"
: g6 r0 H6 `$ U: N. m) W& `. uError:  Signal Model "C1000pF" on instance"@bridge_lib.bridge(sch_1):page1_i26"
; n! ]0 V; i$ |' OError:  Signal Model "C0.01uF" on instance"@bridge_lib.bridge(sch_1):page1_i29": [; B  C( n! P  }2 ^3 [) O
Error:  Signal Model "R200ohms" on instance"@bridge_lib.bridge(sch_1):page1_i32"/ N$ `5 c% A) P1 k) C% {9 x
Error:  Signal Model "L8.2nH" on instance"@bridge_lib.bridge(sch_1):page1_i33"% f) A& s5 i$ T4 C! j" Y  q
Error:  Signal Model "R1kohms" on instance"@bridge_lib.bridge(sch_1):page1_i53"
% {5 ~8 I: F" j8 J6 z3 PError:  Signal Model "C0.01uF" on instance"@bridge_lib.bridge(sch_1):page1_i55"
" w7 R% t. J# Q1 V0 YError:  Signal Model "C0.01uF" on instance"@bridge_lib.bridge(sch_1):page1_i59"6 \$ u9 K5 R% f/ g* M8 ^/ v+ Z. `9 v4 Q
Error:  Signal Model "R1kohms" on instance"@bridge_lib.bridge(sch_1):page1_i61"5 e' Q2 e$ w- m. O/ n( w$ T. Y& o  f, t
Error:  Signal Model "C0.01uF" on instance"@bridge_lib.bridge(sch_1):page2_i14". X1 M- J2 E3 s+ J
Error:  Signal Model "C0.1uF" on instance"@bridge_lib.bridge(sch_1):page3_i42"
. p9 [: _1 _% s+ \5 |) ?" e! T: B# RError:  Signal Model "R1ohms" on instance"@bridge_lib.bridge(sch_1):page1_i31"
) S2 e1 g4 h9 Q4 c! B" i9 pError:  Signal Model "L10nH" on instance"@bridge_lib.bridge(sch_1):page3_i41"8 K# C" L4 W0 ]# |
. d% Y. L, \: \
7 u. n4 |6 x8 P+ |* t5 j----------------------------
- \) k  b$ k& i+ f$ K/ LAudit revealed 90 instances in the design with missing model information.( R  f- Z) N4 X5 A
----------------------------9 y6 ]+ m9 {4 x! s9 f2 h, _
发表于 2023-2-8 10:47 | 只看该作者
把Signal Model去掉
发表于 2023-2-8 13:25 | 只看该作者
这些器件的封装改过了吧,重新更新一下就可以
发表于 2023-2-8 14:02 | 只看该作者
HDL原理图中点TOOLS ——Model Assignment...——然后把找到对应的器件,鼠标右键SI Model 删除即可
# T6 l& Q3 I3 f7 N+ E5 R这样就好了
GMT+8, 2025-11-3 23:11 , Processed in 0.140625 second(s), 23 queries , Gzip On.
