TA的每日心情 | 开心 2022-1-21 15:08 |
签到天数: 1 天 [LV.1]初来乍到
#include "reg51.h"" Z7 i0 p* \. V! x
. n) B) O# P" l9 p7 K
sbit KEY1=P3^1;) g! G e, b K+ b
sbit KEY2=P3^0;: R( r$ S" x4 W' F- ^; p" @
sbit KEY3=P3^2;" P, @! |1 z. z! k. V
typedef unsigned char u16;
$ S# M3 Z0 B1 X3 l- ]typedef unsigned int u8;$ I! u& }# q, _4 w: D1 c2 D' Z
sbit LED1=P2^0;$ _' h1 f' D0 k5 Y: m, P/ Z
0 X, i+ T: C1 P/ V2 P1 P _6 Z
#define KEY1_PRESS 1;0 W! ?8 l& a0 H+ M0 M- h6 I
#define KEY2_PRESS 2;: r; k* @ P7 ]6 \) X/ Z
#define KEY3_PRESS 3;8 P% n, w5 J7 ?0 X8 d. o5 K
#define KEY_UNPRESS 0;
1 j% S1 E- h5 g* q Y1 P* F- f% S" V: rvoid delay_10us(u8 ten_us)
0 j) z- k k" m0 ^4 f{
# W% S7 O, O# d( T8 l. M while(ten_us--);, y7 I3 O8 E) V/ X7 m; b
' ^! V9 `, |) W! \: d- J; w}
; t8 F* m* I, Q( q8 @6 ?+ [) Zu16 key_scan(u16 mode)
) x3 h6 w% @7 w{) Q. }8 o3 c. W# P5 o9 ?7 q" V
static u16 key=1;! ]. D1 ]. j4 z6 F; {4 m" _. I
if(mode)key=1;; H7 h+ R4 `3 I5 ~8 E
, S: O& S7 `0 G6 S& _& J9 F9 [
if(key=1&&(KEY1==0||KEY2==0||KEY3==0))
. ~' S. B, J/ } T {! g" V4 G) u- z/ ~; [& H
delay_10us(1000);0 I. H- A8 Q( r: m5 D- ]
key=0;* d4 ~1 u' j) {% L1 P* B0 W
if(KEY1==0). h+ z( ?4 O: b8 U5 }$ ` f
return KEY1_PRESS;
7 W1 o2 M/ C# Q# t3 o0 G else if(KEY2==0)1 O6 z$ j" T% }% N
return KEY2_PRESS;
5 L! j8 _6 [8 O; h9 s else if(KEY3==0)
2 a2 g6 Q$ w+ E9 ~ return KEY3_PRESS;
. J# u3 S4 x/ J# n & [ _7 h" O& L1 j6 Y
. g/ h* d: \. `/ _6 m$ Gelse if(KEY1==1&&KEY2==1&&KEY3==1)
& Q/ ^3 D5 d0 {. s# h4 I{( b+ a1 D1 Q" Z+ E8 c
key=1;7 E; E: _$ M/ ^" f( R! M3 o3 w3 L
5 i8 Y1 H/ @. a4 j
3 j( L8 p* h- [, f& yreturn KEY_UNPRESS;
- m+ M% f: w) u
- R% A; U J e1 @6 q: Y+ j 4 A0 T& C; C6 p H- E: h* l o
7 d1 E; x! F+ x% ?9 N1 N
7 b X( Q& H& j$ T
M% n, p; [4 v, ~; N) h
+ L4 O" {( K6 c3 Kvoid main()* n" t; ]( u9 O& \7 o( j
{( V$ H" q+ O* y q0 J0 j8 q! J& V
u16 key=0;
/ i: Z, X+ j0 Y& ^# T5 w
' b" I) g& U7 `$ G; Y while(1)
) o# a" I& u6 F" Z, j2 g7 c& O {
9 L4 w; \4 i5 m1 o% S' ?) r6 v3 u7 L 4 x5 a4 Y W' t u; ^- ~
key=key_scan(0);- ^% F! \/ Y+ X5 t
7 i" | S1 J) p7 u if (key==KEY1_PRESS)5 X6 a5 c# W* f& i
LED1=!LED1;
* k/ Y$ H& H( r, M+ M9 H, ^ / v; c9 W6 c! J# N1 X" @, v R7 k6 T m
% z0 q" X4 m- O$ U% S$ c+ e; Y' v }
' }2 E) W0 M9 t# k7 U5 e }
6 s+ u' O7 T/ y; i* K8 a1 e- s+ g5 j
anjian.c(32): error C141: syntax error near 'else', expected '__asm'
( C* I9 ~# b( T/ P* nanjian.c(57): error C141: syntax error near ';', expected ','
) m' k. @6 |* J5 j4 ]anjian.c(57): error C141: syntax error near ')', expected '__asm'7 x* b% p) q0 X/ ]
anjian.c - 4 Error(s), 0 Warning(s)./ o( @1 D7 ~0 C: G! w
