Original posted by lightning at 2008-7-3 08:10 , A" ?8 i& m* @9 d, G& Y
我用POWERPCB导入DFX格式的文件,不能导入为mm,只能导入为mil,请问这是怎么回事,是哪里的设置错误?,下面有附错误提示,请帮我看看,谢谢
- \1 w3 f* [1 w7 q
- T" b% i( J6 t9 [The unit is English when exported from AUTOCAD.
3 R- _0 \/ a6 C2 b5 ~9 cSo you can only use English when importing to PADS.% L/ ?% y7 s- D! G+ t" _
Open the .DXF file, select all elements and then use direct command 'scale 39.37'. ( l! P0 T/ k, m, N1 b, S V, h
Now you can import it by 'mil'. |
