查看: 3188|回复: 6
请教高手,出光绘遇到问题了,这是肿么了。。
发表于 2012-3-8 09:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1金币
---- Photoplot outline rectangle not found ... using drawing extents
  {' }* n$ Q4 [6 d4 L4 h. G; P/ y# l  m2 P% P- E9 X3 y
( c- p% u, a6 A' d- W% \" U% R) a: y
Results from parameter file ...
5 E) r& d8 M3 M. [3 @    DEVICE-TYPE           GERBER4X00
& i% x9 I! n9 _; H' X9 ?9 j    OUTPUT-UNITS          INCHES
+ H4 H  {: k0 ~) Y8 z8 S    FILM-SIZE             3000000 2000000) Q1 N- Q* L# q& `+ p3 R+ Q* W: W, N
    FORMAT                5.5
" P  n- q& b- O, X$ B    ABORT-ON-ERROR        NO
0 U6 V: e; @  ~$ G" X0 T    SCALE                 1
: v4 S' s5 D" h9 e4 P    G-CODES               YES
1 ~/ V) N$ b; z' A6 R0 H& V    OPTIMIZE              YES
# r2 i2 b- e. Q, v    STATIONS-PER-WHEEL    999
) k: [3 g% B; `- B    COORDINATES           ABSOLUTE
6 \( s4 Y3 x2 c( E5 E$ ]! R# F    SUPPRESS-LEAD-ZEROES  YES
- }6 f, `# \8 A0 @+ k* Y+ g4 |    SUPPRESS-TRAIL-ZEROES NO
. b) _6 l9 q, s/ M4 `: `! ?0 ]    SUPPRESS-EQUAL        YES
. s$ \% S' y' ^  e3 ]
! Y5 z, W! j. D* e- m1 ^ WARNING: database resolution exceeds the resolution of the $ y5 j% N0 Y; }, m: W2 e
      output coordinates (see FORMAT in parameter file).
& |# Z- Q  m! i7 d: X      Some roundoff of coordinates may occur unless the number! g+ @$ {& ?/ x  ~  ]& R
      of decimal places in the output file is increased.8 g% O1 P0 n; |
. E! @! j0 d$ W# o* y) e3 W* ?9 ?Thu Mar 08 09:32:46 2012                                Page     1
: P$ U. i7 `* i/ L6 l6 g
$ l- k, c$ c+ OPhotoplot log file9 c7 ~# b6 s8 y# V) g2 O, \1 F
Results from aperture table.
+ b; U# d. }. n% T7 L) s- c: V, Z" Y0 j% J& {6 _1 h
+ u; g/ M6 C) ^# U9 t
INPUT-UNITS     INCHES+ J6 ?% p7 t% I: s8 j2 z4 l5 y( F
4 }. }- R. j2 e$ r5 @WHEEL     15 t; \. R! _3 O8 l+ D+ r4 I
4 d, q3 a4 G  j* s1 ~CIRCLE         78.74            D109 J: @; Y& N6 r6 G7 \1 s) G
FLASH     F160_220_40          0.00000  D110 Y6 X0 l: E  R5 D; h9 n$ U' }
CIRCLE        62.992            D12, Z' `4 w8 A7 \5 [1 B0 a; u1 t$ N
CIRCLE        66.929            D13
  a, P6 Z! W$ r' ECIRCLE       183.071            D147 N: C! I+ Z( `8 K
FLASH     F425_515_40          0.00000  D15
* j0 [1 u3 b8 {4 B8 {$ G5 O7 ^CIRCLE       198.819            D167 }( B9 z0 d1 \  V2 ]
CIRCLE       167.323            D17& ^; F/ ^+ e- F; w
CIRCLE       202.756            D18
% q' c7 H3 R6 T, M0 A) h2 uCIRCLE        88.583            D19" v, l! R) u7 ^. x/ d0 O+ g
FLASH     F185_255_40          0.00000  D20
# l/ f5 `# ]* C5 S, v5 YCIRCLE        72.835            D21( q$ O( _$ x1 f) S9 Y  x: }
CIRCLE        76.772            D224 P; A% I7 _* b% y) h# V% n
CIRCLE            30            D23" n; N  [# p0 ]* C- f
FLASH     AB00                 0.00000  D243 i1 N. r0 U5 A
CIRCLE            24            D25
; n; R% |( E7 }) }$ OCIRCLE            44            D26
$ D# q7 g/ ]- u+ @RECTANGLE         65        16   0.00000  D27
  ^: J" _  v" ^" a! p, [, d) aRECTANGLE         16        65   0.00000  D28$ G7 y* E8 ]: Q" [% o. v) r
RECTANGLE         70        21   0.00000  D29
$ t+ M* i  T+ O+ @' pRECTANGLE         21        70   0.00000  D30
# F0 X$ N$ L2 h8 [. VRECTANGLE         30        14   0.00000  D31! \, g$ [) z& h9 e5 }# B  M' G
RECTANGLE         14        30   0.00000  D32
0 E+ K% g6 b. ?3 p% ~" gRECTANGLE         35        18   0.00000  D33) M2 w# [/ I. ^* P. o
RECTANGLE         18        35   0.00000  D34
6 x( h( x" u  Y5 v. B, J3 pCIRCLE           270            D35. p7 _! Y  ?* m
CIRCLE           266            D36
/ G9 I3 k4 g* j4 G, MCIRCLE           520            D37
# L, `* v! q6 {CIRCLE            78            D38
2 b- ^& g, T" w" P* x' B! b8 `CIRCLE            50            D390 G6 m8 {! s6 j1 Q
CIRCLE            60            D40
8 i/ R% @- d! I" t! L1 V* \1 r. ]9 Z) QCIRCLE            45            D41
  Z: \$ Q. W; g2 a4 V1 }: ^CIRCLE           198            D42, g2 W; D8 d5 x7 k9 l/ l
CIRCLE           170            D43
1 u7 P; R, T7 y1 g/ d0 v% U* _. u& bRECTANGLE         50        25   0.00000  D44
$ ]- X  b' b! ARECTANGLE         25        50   0.00000  D45/ F/ G4 |0 @! r% ~- C! u
RECTANGLE         55        30   0.00000  D46
( Y7 f  `4 ?/ E. h: NRECTANGLE         30        55   0.00000  D47+ A& P5 p7 w) @# J
CIRCLE            85            D48( `: W3 o9 A2 {2 S/ a1 f2 s% j7 m
FLASH     AB85                 0.00000  D49
1 G+ k1 W" \0 @# T( ?CIRCLE            75            D502 y2 c* [9 [5 `1 d$ ~+ K) I
SQUARE            60   0.00000            D51
. b. @1 d! ?3 t& a! HSQUARE            75   0.00000            D526 W+ U1 K( T4 l, T1 T7 H8 l  n/ }
RECTANGLE         60        13   0.00000  D53' I9 O$ N* Z$ s" h, }* c( K
RECTANGLE         13        60   0.00000  D549 R) R7 `5 y4 z6 F) M$ N+ h( X
RECTANGLE         70        18   0.00000  D550 l- U0 W9 \6 w) E5 F
RECTANGLE         18        70   0.00000  D56- o- E, j4 y4 h% Z
Thu Mar 08 09:32:46 2012                                Page     2
8 ~5 N! w1 q3 J0 \
" n8 j2 t+ D4 Y  C: R" uPhotoplot log file
; |7 Z7 x8 K; ~: h% }1 c9 C3 j( lResults from aperture table.$ z. O$ H% @5 f) F3 @
; Y' q, I/ X' o5 X4 O8 GCIRCLE            59            D574 S' }" X6 C0 N) w; O7 ?
CIRCLE            31            D58
- h: x+ ]1 X& M; Y3 m" BCIRCLE            49            D59, g: D  o: a1 O
CIRCLE            21            D60# l5 J, @3 @" H3 e6 G1 {0 \
CIRCLE            68            D617 e0 ~$ l4 d* R+ P
CIRCLE            40            D62& n+ d& d! e$ J, ~  I; t
CIRCLE            56            D634 w1 L/ X- d, a& N% g0 B
CIRCLE            28            D64
5 y& E7 z( G) x* L+ Q% \' ERECTANGLE         70       230   0.00000  D65
. i+ f5 G- u4 W  z1 n7 H" b5 LRECTANGLE        230        70   0.00000  D66# s% J2 }2 b3 T- G$ v0 P
RECTANGLE         90       260   0.00000  D67
# o, B+ G7 F: p) hRECTANGLE        260        90   0.00000  D68
+ F+ W* f6 f1 E" HRECTANGLE        235       240   0.00000  D69) ~* _+ `0 P  Q8 q- j3 `
RECTANGLE        240       235   0.00000  D70
6 p/ c: o, r! }0 {' F& |: @RECTANGLE        255       260   0.00000  D71
" m+ Q% w4 X8 Z! p5 L; m/ |RECTANGLE        260       255   0.00000  D72
8 {0 K5 Y* g: i! F# @; ACIRCLE            53            D734 J4 T0 ~6 `. L4 R; |2 H
CIRCLE            25            D74
7 K9 w  y% Y( r' M+ r2 u/ I2 NRECTANGLE         50        36   0.00000  D75
$ U3 ?9 L5 ~: E1 d4 H- x2 O/ WRECTANGLE         36        50   0.00000  D768 ~8 W7 `% C) U- G* o/ r) x3 X% h
RECTANGLE         60        46   0.00000  D77# k6 R& w- `& |- ]4 v# X) w. J
RECTANGLE         46        60   0.00000  D786 j1 R7 V" o4 \3 w; i8 ?
CIRCLE           160            D79
, l, m. }; E3 g0 |. b7 {CIRCLE           150            D80
6 s2 H! R4 a( C1 x" t6 fCIRCLE           108            D81
* J, z- w* ~" k9 [" b; TCIRCLE            80            D82
6 N- h* s$ k* s: Y8 c8 c9 uCIRCLE            88            D833 Z- t: s3 Q6 I1 W. {$ g
CIRCLE           100            D84
1 {' U0 z1 W' R5 QCIRCLE           550            D85& n; X3 e4 j6 `5 I
CIRCLE           540            D86) b: I4 g5 a9 b8 R7 d1 `
CIRCLE           560            D87
( @: D, q$ L4 ?9 m' ~CIRCLE            63            D886 L% [( s+ h( I
CIRCLE            35            D899 E9 A- @. A+ d4 K7 [* `- w
CIRCLE           175            D90* l; w( C' ?  [( _% k$ B9 ]* u+ Q
CIRCLE           165            D91
. `7 V2 \& I1 L  t& v! WCIRCLE           190            D92
) y# ~! b7 m5 q. ?CIRCLE            98            D93
& b( l3 q; ~$ YCIRCLE            70            D94) _% O) f# z6 ~( `1 V3 x- c
CIRCLE            90            D95
4 W2 ^) |7 s; h! NCIRCLE           180            D96
# K. q2 a5 ~5 Z* l; v: C' {. _CIRCLE           128            D978 @' W0 r% C- p+ z, S
CIRCLE           112            D98/ Q; B5 B* _. a& k  U
CIRCLE            84            D99
/ ~: H0 U' H+ L3 y" ]/ XCIRCLE           120            D1000 u/ [, r9 |3 f2 T9 ^
CIRCLE            94            D1017 ?7 H+ Y2 q  K: I0 Q* ~
CIRCLE            66            D1024 y* t' q" B  A0 p; f
CIRCLE            95            D103& C2 q+ [8 P% ~! k! r5 U- V$ v/ m
CIRCLE           130            D104
) g3 L" n+ o% e! `CIRCLE           140            D105
) D5 W* Y& b) v$ xRECTANGLE        550        60   0.00000  D106
" {1 {6 c* x: [RECTANGLE         60       550   0.00000  D1074 P; D3 M: \, {+ G' I" L6 B4 `
RECTANGLE        600       100   0.00000  D108
  Y6 {8 ~1 [$ L7 p4 b( f) c Thu Mar 08 09:32:46 2012                                Page     32 w& M7 K9 P3 s* j1 C
! \% ?3 Y3 U! p4 M7 sPhotoplot log file
2 P3 F- L& N/ [1 e# I3 Y: ^Results from aperture table.+ H6 M# R- [8 o0 n
- f/ X$ [) p  K2 h
RECTANGLE        100       600   0.00000  D109
7 E) I5 P+ V& z/ dCIRCLE           125            D110
0 u' V* O. n8 K# v5 W+ o1 jRECTANGLE         32        17   0.00000  D111
; f  C5 w( h* m% N, K# u! aRECTANGLE         17        32   0.00000  D1120 C, [/ W, h) ?5 n! V, ?; W
RECTANGLE         42        27   0.00000  D113
8 U( {2 _; I4 u9 [; X. C5 |RECTANGLE         27        42   0.00000  D114
! N* @$ l3 {% j- aRECTANGLE         60        25   0.00000  D115
* o- d; E2 |, f, h5 I5 ?! KRECTANGLE         25        60   0.00000  D116' l2 E+ {- M1 F8 Q& M& {2 Y( @/ e
RECTANGLE         65        30   0.00000  D117& ?3 ~3 c" u7 P, }9 n9 T1 D3 m; C
RECTANGLE         30        65   0.00000  D1180 Q! {" o2 k$ c" t
RECTANGLE         87        26   0.00000  D119% c$ ^% i) Q3 h) f, ?" _+ o
RECTANGLE         26        87   0.00000  D120
2 w* A: v& v$ D5 e7 yRECTANGLE        100        36   0.00000  D1215 ~0 J4 ]% c0 O3 E. |
RECTANGLE         36       100   0.00000  D122! Q; {& V8 l* n9 p, F
RECTANGLE         68        12   0.00000  D1238 n5 X7 h" D" @$ {9 M* P
RECTANGLE         12        68   0.00000  D124
! N2 ]& h* A: C, P2 w8 s1 R& ?  ?& IRECTANGLE         88        32   0.00000  D125
& \! a; G8 M* E/ b' HRECTANGLE         32        88   0.00000  D1266 U" r, ]9 E8 T) C" V2 s
SQUARE            71   0.00000            D127: ~$ I  @$ i" U9 j/ X
SQUARE            43   0.00000            D128
+ B! l& l8 z, g  [CIRCLE            61            D129
' V- _# |) r* N/ XCIRCLE            33            D130
" u* L- f2 ?1 ~2 o% aCIRCLE            81            D131
  S, z- ^' P% q  t4 g! mCIRCLE            73            D132& K' I: R+ Y4 l) b
RECTANGLE         50        40   0.00000  D133
+ X0 G0 V5 B$ G3 @- D$ c: H. }RECTANGLE         40        50   0.00000  D134
. r" s3 u8 {2 Y6 l3 k" H) a1 b. ORECTANGLE         70        60   0.00000  D135
6 ^. {& P" ^) z  J0 d, R" B; mRECTANGLE         60        70   0.00000  D136" u# @! c2 x' M) C( n
CIRCLE           810            D1374 i$ R5 V. n: D& g
CIRCLE           800            D138( E1 o- m$ ^/ V6 ~* f! o; ]7 a
CIRCLE           860            D1391 q$ Y1 M7 W3 h+ n3 _; Q8 \% I
RECTANGLE         50        12   0.00000  D140
. l" i+ }3 q* xRECTANGLE         12        50   0.00000  D1417 P2 k+ p8 T' Q$ e7 |3 ^& z9 P
RECTANGLE         60        16   0.00000  D142( }) P% Z) C  L9 F
RECTANGLE         16        60   0.00000  D143
9 E2 j1 y. k5 b0 _& e8 S! FCIRCLE            55            D144+ _2 J) S0 V& c0 t: V
CIRCLE            58            D145* t/ t# P3 S( v" M) c
RECTANGLE        120       330   0.00000  D146
. [' [& `% x; |1 g- E2 j9 ?: XRECTANGLE        330       120   0.00000  D147* X- o( I7 I$ R$ n3 s. j. P
RECTANGLE         93       300   0.00000  D148
9 \  B) c" E1 W" XRECTANGLE        300        93   0.00000  D149- g/ ?# A2 c/ q" B
RECTANGLE         80       330   0.00000  D150
6 x' Y" @6 }! q! f- {( G0 j% KRECTANGLE        330        80   0.00000  D151# a8 d$ ~4 Y2 s  d" E0 A) B# m
RECTANGLE         50       300   0.00000  D152! {5 D) m7 y2 T3 e
RECTANGLE        300        50   0.00000  D153
' Q# R1 C+ P, }" Z3 zRECTANGLE         52        48   0.00000  D154, H& Z6 o8 v" ~/ Y1 _, _
RECTANGLE         48        52   0.00000  D155
) O4 F; v4 _" y9 E* L+ I6 wRECTANGLE         72        68   0.00000  D156( Q  j$ ?: I2 `8 j1 B2 X: T7 Q' R
RECTANGLE         68        72   0.00000  D157( m& E. n% h6 R
RECTANGLE         52        32   0.00000  D158$ Y% `2 M' Y( _& `: e# J
RECTANGLE         32        52   0.00000  D159
3 s$ `" S6 {8 L* P; P/ ^RECTANGLE         72        52   0.00000  D160* O- a) ^/ S% o" ]/ Z! Q; }* _
Thu Mar 08 09:32:46 2012                                Page     4( l2 H* r) i8 b9 C
- h8 n. M/ v9 j( H$ l! e  |
Photoplot log file! ~1 Q2 M1 ?. @* y: M
; a7 C& X5 j/ z$ E3 Y5 b: w
9 i$ T; P' `7 ~+ _" l1 d5 h' I* FRECTANGLE         52        72   0.00000  D161
9 H3 m# t2 [+ I, S# H7 iRECTANGLE        435       220   0.00000  D162
; @4 Q" b+ H, P/ v' B2 }+ ^RECTANGLE        220       435   0.00000  D163
* T! x9 ?% F5 v: p/ mRECTANGLE        465       250   0.00000  D1648 p# }, M/ Z0 d& I
RECTANGLE        250       465   0.00000  D165' e2 c2 ^6 |/ V0 L1 _: Q+ Z
CIRCLE           155            D166& G5 k# B$ }' H2 D7 {2 ?% a" ~
CIRCLE           145            D167" n  U3 X0 u5 z0 P5 R6 G
CIRCLE           110            D1687 Q# @4 I" o( e* L$ u% i8 ^
CIRCLE            93            D169
2 D% I0 s  `4 |# A/ [: tCIRCLE           295            D170
& z- y2 s1 S$ g4 gCIRCLE           285            D171  ]6 D$ U; B. i! n+ p: w
RECTANGLE        300       250   0.00000  D172. ^0 ~4 C* q$ h- A: m
RECTANGLE        250       300   0.00000  D173' v* y6 V& H4 W
RECTANGLE        320       270   0.00000  D174* P5 F7 w8 k; g% S8 P
RECTANGLE        270       320   0.00000  D175
" \! |& P+ ?" S/ tRECTANGLE        140       250   0.00000  D176
5 K2 L2 H8 l# k, M+ [RECTANGLE        250       140   0.00000  D177' F  A1 M2 P1 d
RECTANGLE        160       280   0.00000  D1787 v: m7 |5 ~6 x6 d. D2 }" D1 P$ y
RECTANGLE        280       160   0.00000  D179
- x2 x. X2 U. ]9 I5 F+ {RECTANGLE         80       320   0.00000  D180( z- ^* `, b. v, G. C! ~- k4 l# s. @6 u
RECTANGLE        320        80   0.00000  D181
4 z9 `" s) w7 o2 B% jRECTANGLE        100       340   0.00000  D182
" G- e" B0 m9 T' q6 FRECTANGLE        340       100   0.00000  D183! s8 y: q: C0 D, v
RECTANGLE         80       450   0.00000  D184
4 u: I" T7 k6 i+ i$ c+ RRECTANGLE        450        80   0.00000  D1854 N- z5 ]; G" b/ g! f( t, @! O
RECTANGLE        100       480   0.00000  D186# S4 v/ W" O# K& I
RECTANGLE        480       100   0.00000  D187! q3 t% i# Q, P2 {: r$ u8 G
RECTANGLE         55       425   0.00000  D188
, ]1 {" \, N# y* I4 j# q( ?8 MRECTANGLE        425        55   0.00000  D189( Z4 w  n$ b6 i0 p
RECTANGLE         85       445   0.00000  D190
8 c9 |6 k/ l! p8 ]; cRECTANGLE        445        85   0.00000  D191
" B0 d/ j) z' {# VRECTANGLE        425        75   0.00000  D192% a: a, ?9 _) o% w4 [; `9 q
RECTANGLE         75       425   0.00000  D193# q6 u' p, c) J+ W& K: I0 a7 v! H
RECTANGLE        300        63   0.00000  D194% ]0 w$ Q( m* _# w6 R7 o' ^
RECTANGLE         63       300   0.00000  D195& `7 Z7 i$ ?% w; ]2 @- z+ b. u
RECTANGLE        262        35   0.00000  D196  g2 }) s; x2 b6 o0 J9 K
RECTANGLE         35       262   0.00000  D197& K2 }4 U7 j4 U6 o6 U5 A1 {& N
RECTANGLE        280        50   0.00000  D198
0 o5 `5 M. D' x1 f9 [: sRECTANGLE         50       280   0.00000  D199
6 H: b- M1 A' v" i2 `CIRCLE           220            D200
3 |: Y5 {* `# f& X" _/ S6 Y0 @CIRCLE           400            D201
' Z' R9 a! U' m8 g7 ~+ wRECTANGLE        330        48   0.00000  D202( z6 k" p2 i+ g' W) q. R: s
RECTANGLE         48       330   0.00000  D203  p4 d( V( b: u# T1 h* ^
RECTANGLE        360        50   0.00000  D204! l/ F* A5 u+ t! z
RECTANGLE         50       360   0.00000  D205
8 k0 r) f7 n( _' w6 zRECTANGLE         86       330   0.00000  D206: |2 F3 H$ s# W9 E, U: N
RECTANGLE        330        86   0.00000  D207
5 L4 G7 v; w0 F: |  {RECTANGLE        100       360   0.00000  D208* S. @$ S8 {8 ~4 \/ ]& V/ m' g- K
RECTANGLE        360       100   0.00000  D209. L+ I  N3 @+ s0 R& f
RECTANGLE        360       300   0.00000  D210
$ e3 O3 g7 }/ `: k, y" _RECTANGLE        300       360   0.00000  D211/ @" L: O$ L, m3 t2 v
RECTANGLE        380       320   0.00000  D2128 P! j1 W0 K5 X; j3 ?2 j- z
Thu Mar 08 09:32:46 2012                                Page     5# l+ k2 y" b- i
( ^9 A# V9 G! I: RPhotoplot log file
$ z0 H, Z- S6 e* }# Q- f+ FResults from aperture table.
0 s0 B8 z: A5 g$ Q7 D) u  n
- X9 Y6 V# u7 z$ {# zRECTANGLE        320       380   0.00000  D213
( {8 M* i, Z  ^CIRCLE           200            D214
) P! \5 t5 ~2 S/ o& ICIRCLE           135            D2151 N# r8 l) s, `$ S0 m/ R; B
CIRCLE            65            D216
+ E) B: K9 v! NRECTANGLE         25        48   0.00000  D217
1 T5 S& P8 S5 e+ `& E  q# |9 HRECTANGLE         48        25   0.00000  D218* }4 B% a2 `# u8 B) [
RECTANGLE         45        68   0.00000  D219
1 M7 b4 f8 M) F& q1 URECTANGLE         68        45   0.00000  D2200 ^/ B5 g, H: P9 ?
RECTANGLE         25        94   0.00000  D221) {9 R6 O/ z0 u3 x2 G
RECTANGLE         94        25   0.00000  D2229 l" Q9 n* e6 `- C- V' T
RECTANGLE         45       114   0.00000  D223+ ^+ I! M* m9 x" \" e( H; _
RECTANGLE        114        45   0.00000  D224
! J9 S/ T. }  l7 `, F" l, C6 |; q$ c1 {RECTANGLE         30       115   0.00000  D225
, [0 f2 ?+ M: p0 bRECTANGLE        115        30   0.00000  D226
' K$ _4 w  O* ^RECTANGLE         50       135   0.00000  D227
* `* I* X+ e; x' {7 h# ?RECTANGLE        135        50   0.00000  D228
0 p+ t8 j  m' d# k* G6 D8 SRECTANGLE         30        94   0.00000  D229% O2 g3 }/ w# K
RECTANGLE         94        30   0.00000  D230' _* r- V( l9 S4 c6 P, L
RECTANGLE         50       114   0.00000  D231
; H+ W- O! }/ q" `+ N1 w" kRECTANGLE        114        50   0.00000  D232
- N; }( w$ b' Q& z$ @RECTANGLE         50        75   0.00000  D2333 u" |8 w7 ]5 V* m2 G# h  g. k8 |
RECTANGLE         75        50   0.00000  D234
  \* F$ M" |4 s  C0 ~RECTANGLE        180        40   0.00000  D235
& W, A* \* |* Q' v6 g$ `RECTANGLE         40       180   0.00000  D2362 M" N4 u" A9 d2 g6 v& w5 _: p
RECTANGLE        220        60   0.00000  D2377 [& J+ Y1 P0 T. a! J& C- ?
RECTANGLE         60       220   0.00000  D238; V' p: r2 D# h% \1 [, [
RECTANGLE         80       180   0.00000  D239
4 T/ k7 g3 |6 M3 B/ g' lRECTANGLE        180        80   0.00000  D240
; G3 c1 `- [, K  i; `9 Y! ?1 S5 t7 rRECTANGLE        100       210   0.00000  D2416 h& l9 d1 p; y
RECTANGLE        210       100   0.00000  D242
4 T, R3 |% l3 U  LRECTANGLE         65        13   0.00000  D243) r( E( f3 W  U/ i# k
RECTANGLE         13        65   0.00000  D244
' Q+ R& x* a2 w7 kRECTANGLE         75        18   0.00000  D245
; R6 |5 d- C  |/ O7 z) ^RECTANGLE         18        75   0.00000  D246
5 P+ w; i% }6 RRECTANGLE         60        19   0.00000  D2476 c7 E  j2 X4 ~& t
RECTANGLE         19        60   0.00000  D248  ]6 `% n: C& w  d9 K! Q
RECTANGLE         70        23   0.00000  D249
$ f6 G) |" P$ c! Z8 ^# @) KRECTANGLE         23        70   0.00000  D2503 g* t% w- m% z% ]
RECTANGLE         25       360   0.00000  D2510 _& K6 S& I5 K4 }1 N" e& g" v
RECTANGLE        360        25   0.00000  D252
7 k8 I% [/ x/ t# MRECTANGLE         45       380   0.00000  D253
4 Y2 ?" F0 |5 ~$ V8 \RECTANGLE        380        45   0.00000  D254
" w% b$ t+ ~' K" s6 |+ tRECTANGLE         25       400   0.00000  D2552 g1 w+ Q4 t! R: p+ K% R
RECTANGLE        400        25   0.00000  D2566 Q* k) J, f0 b
RECTANGLE         45       420   0.00000  D257# ^! V1 L, c. z
RECTANGLE        420        45   0.00000  D258
' \! ?# U9 x1 E% }7 _! l9 VCIRCLE           300            D259  @6 d+ |) s8 Y% j1 A8 o; B& i
CIRCLE            83            D260
2 b/ |7 A4 _' v& x* ISQUARE            80   0.00000            D261, K) h: a) X" s- v. Q7 k
SQUARE            83   0.00000            D262
; y6 x0 N0 K- p9 G& [& lSQUARE            55   0.00000            D263
+ y2 ~" R. K5 A& w2 ~6 C" r* rCIRCLE           290            D264
4 O* W- J( n  U' x; y Thu Mar 08 09:32:46 2012                                Page     6
! W' G! u7 n* ~9 J$ _6 Y9 \# ~3 Z/ W8 v. X" @
Photoplot log file
# K6 H0 O/ u  j; S7 P7 CResults from aperture table.
2 X" d/ r, m- Q) |" \; [
$ u, _' |, R, y" A! m( O2 N7 L1 hCIRCLE           280            D2651 T# Y: k1 l$ v# I. u
CIRCLE           240            D266+ m" z1 J7 I, f" m" j. E
CIRCLE           230            D2676 `9 Y% K% O5 h( P! y) m' W9 {
CIRCLE           260            D268
7 N3 e7 M8 M4 ~" p) kSQUARE            90   0.00000            D269
% T% G0 j' ^' FCIRCLE            62            D270
% L2 @7 @7 Z+ }8 o. W8 b% oSQUARE            62   0.00000            D271( r+ b, Y$ u4 E5 z% U  b7 `' J6 A
SQUARE            93   0.00000            D272
3 |6 U5 o; h% T/ @) O% uSQUARE            65   0.00000            D273
$ Q# S  i7 ]6 m' m+ \' `SQUARE            98   0.00000            D274
$ b" X5 M6 N% Q& QSQUARE            70   0.00000            D275
1 p2 h* L8 c. o& k2 c$ ^7 ^CIRCLE           103            D2764 C; Z9 z; L4 g$ ]
RECTANGLE         50        19   0.00000  D277
2 A1 [1 ]& {7 S3 }RECTANGLE         19        50   0.00000  D278
9 V9 l% o4 u0 D: t( CRECTANGLE         60        23   0.00000  D2792 s; t# \" F- K" r$ R: j, A
RECTANGLE         23        60   0.00000  D280
; w! Y; F' C- \4 P& E2 _  IRECTANGLE        110        19   0.00000  D281
" I3 n" D* `; ~! F" GRECTANGLE         19       110   0.00000  D282+ w! t0 v# o- H- |7 n  \2 E
RECTANGLE        120        23   0.00000  D2833 e& s4 N* w' T5 d& ^, q
RECTANGLE         23       120   0.00000  D2840 _# ]8 H+ P2 b
SQUARE            50   0.00000            D285
% E5 ^: ^5 j; h& l1 A' DRECTANGLE         85        13   0.00000  D286
9 ^3 f2 u! h: u! I  i+ p/ qRECTANGLE         13        85   0.00000  D287) t. }7 }) P/ {4 N/ f6 W* U, C
RECTANGLE         95        18   0.00000  D288
! L* W4 x) _, y: p9 IRECTANGLE         18        95   0.00000  D289: F! n  f0 M1 e- S
CIRCLE           210            D290' P+ l- D7 ?; r5 ~: [, g  i7 @
RECTANGLE        335       350   0.00000  D291* f+ J; [6 o0 N4 o% \! f
RECTANGLE        350       335   0.00000  D292+ {% a' G5 g$ ~1 _5 M, a4 S: f
RECTANGLE        355       365   0.00000  D2930 Y7 c) V0 I: }
RECTANGLE        365       355   0.00000  D294! k. [1 {( m# o! ~) f
CIRCLE         0.039            D295
  M6 C" J( L' C; @9 B8 tRECTANGLE        130       120   0.00000  D296
, [  ?! T/ x) b+ I. z9 @' mRECTANGLE        120       130   0.00000  D297
5 x1 |3 [" r; ?$ [RECTANGLE        110       100   0.00000  D298
, y% f7 l# O- Z. `0 F( J% jRECTANGLE        100       110   0.00000  D299
$ ~  v+ k! Y7 vRECTANGLE        118       108   0.00000  D3003 K( I) O( H7 K: I2 V
RECTANGLE        108       118   0.00000  D3013 q; S# O' X+ m/ z
RECTANGLE        250        46   0.00000  D302% e- Y/ D# |  S- @
RECTANGLE         46       250   0.00000  D303
* |1 R: @6 ?" G/ F* `RECTANGLE        270        82   0.00000  D304  v+ \' o4 s* C' F7 B5 b
RECTANGLE         82       270   0.00000  D3058 U( _" o7 S7 \" s3 S4 N
SQUARE            66   0.00000            D306( P( G$ q! @5 h9 }
RECTANGLE         60        50   0.00000  D307
" {: m/ X9 q+ Y& KRECTANGLE         50        60   0.00000  D3088 }% {: p7 Y8 U7 E
RECTANGLE         66        56   0.00000  D309, Y% U% f4 R4 P
RECTANGLE         56        66   0.00000  D310, {# a! L  Z1 B, y* H; D! |& k
CIRCLE            26            D311
2 k6 o2 K4 b1 r5 d( k% `4 nCIRCLE            18            D312( @8 N% G& @( P  N6 r; k
RECTANGLE         40        30   0.00000  D313
& H0 k: o- k0 ~  h. g& s" r* ORECTANGLE         30        40   0.00000  D314
( R1 v  t+ U7 \) tRECTANGLE         46        36   0.00000  D3155 f" g4 J8 O- ?0 B& z8 ]6 M
RECTANGLE         36        46   0.00000  D316
& O0 [9 `! L0 w( X1 Q Thu Mar 08 09:32:46 2012                                Page     70 i7 H5 C$ x8 R) L0 {
% ]; h' ]; g6 X  x4 ^: w& a
Photoplot log file
2 u& A! [1 @6 ?6 k) `Results from aperture table.
+ k1 i+ ?8 J2 A' k* H* r3 u  e. X: f+ M
CIRCLE        74.799            D317
; B  q4 g) Y6 pCIRCLE        70.902            D318
+ T* E% D) h* l5 m- L# eCIRCLE        53.902            D319
& @# i( [( k) `% l* {+ U4 kFLASH     TR30_20              0.00000  D320
9 @# x) D& h% d% F- C1 x5 [8 N- TRECTANGLE    118.098   118.098   0.00000  D3219 M0 c! r( E* Y# G  F2 U
RECTANGLE        122       122   0.00000  D322
' @4 s8 Q: J  o. x1 U/ c  BCIRCLE        88.201            D323
1 Y# L, c: e2 C( p/ J, QCIRCLE        59.799            D324- y, @9 ^& B2 v9 V  o* v
CIRCLE        55.098            D325
0 y* W; g! j+ y# y$ R' _9 hCIRCLE        70.098            D326
" k1 o, N+ O/ GRECTANGLE     66.902   118.098   0.00000  D327
3 L/ q. U% m3 N. Q0 f. u9 cRECTANGLE    118.098    66.902   0.00000  D328
, s" r) @& g* M. }/ K" _% j- Q$ cRECTANGLE     70.902       122   0.00000  D329' C; i  l3 ^; e" u8 j
RECTANGLE        122    70.902   0.00000  D330; Y8 M; P! j# j& R
RECTANGLE     43.299    70.902   0.00000  D331. h6 F1 J& z7 U( F" m2 r
RECTANGLE     70.902    43.299   0.00000  D332
. S/ U$ `: q# V' ^+ FRECTANGLE     47.201    74.799   0.00000  D333
. G+ a  ]; t' _+ y$ F. Z& f/ MRECTANGLE     74.799    47.201   0.00000  D334
3 q" m3 G" d* f% HRECTANGLE     78.701      31.5   0.00000  D335' w/ ~8 J* U$ @$ q# i+ f: t
RECTANGLE       31.5    78.701   0.00000  D336
) ]) V2 h6 Y" N5 ]8 V; TRECTANGLE     82.701    35.402   0.00000  D337
0 b: X% d4 i) a6 ]; yRECTANGLE     35.402    82.701   0.00000  D338" T1 F8 [: A8 X3 f) F' f7 U
RECTANGLE     21.701    11.799   0.00000  D3390 u! f" u0 [# l; T* J8 j
RECTANGLE     11.799    21.701   0.00000  D340
0 V. P9 M$ }/ i) Y, [" hRECTANGLE       29.5    19.701   0.00000  D341) Q! {4 T! X( K0 h1 j8 B' h3 R
RECTANGLE     19.701      29.5   0.00000  D342; S. N% y# |, b3 i
RECTANGLE    109.799    31.902   0.00000  D343
; G1 r4 z2 z2 ~3 s$ {/ ERECTANGLE     31.902   109.799   0.00000  D344
! s( z% I) Y1 [* [; lRECTANGLE    117.701    79.098   0.00000  D345
8 K" @4 n; Y0 M# N& O' ORECTANGLE     79.098   117.701   0.00000  D346+ I; O( L; H3 e  C6 H- P# f
CIRCLE       157.098            D347
5 e! C# J! G5 G4 vCIRCLE       146.902            D348
* O3 J0 Z- |  o" Y6 ~& h8 q4 tCIRCLE       118.098            D349: D2 ]* V& Q$ A& U3 o" Q
CIRCLE        90.201            D350
9 b$ {* F5 x1 J6 I4 i" `) lCIRCLE       120.098            D351; ]3 R- z9 [. \% q/ g
SQUARE       105.098   0.00000            D3525 W# k; E- M" y4 K/ Y, |( O
SQUARE        61.799   0.00000            D3533 z8 Z, c9 z5 z* M
SQUARE        79.902   0.00000            D354
) w, ?' j( D' Q+ J# ISQUARE        55.098   0.00000            D355
/ `; J/ Y/ @% o4 `  ^SQUARE            72   0.00000            D3564 o" R5 j! ]  q' d+ `- \
CIRCLE        35.799            D357
$ C, S* }' k% p* mCIRCLE            74            D3586 _' m9 g  C( D1 |, U
RECTANGLE     57.902        24   0.00000  D3592 ^% V$ a0 S6 U; b7 r
RECTANGLE         24    57.902   0.00000  D360
% c* U' s! E% e" d* KRECTANGLE         50    16.098   0.00000  D361
1 z, T* G. i0 T2 p7 s% t  `RECTANGLE     16.098        50   0.00000  D362
: E8 X; t$ v' |! f7 I8 y  iRECTANGLE         35     9.799   0.00000  D363% x- T* U0 l" m  m" j
RECTANGLE      9.799        35   0.00000  D364; B1 Y& G4 `2 \* [3 t7 X
RECTANGLE     42.902    17.701   0.00000  D3650 S! U5 S, c. t, S( C
RECTANGLE     17.701    42.902   0.00000  D366
! e9 s! D4 S. D2 u( {0 KRECTANGLE     23.598    16.098   0.00000  D3677 p/ p1 i- X7 }2 F8 d8 G9 y8 R% C
RECTANGLE     16.098    23.598   0.00000  D368
0 w$ j5 [" c9 E: ~- D1 u/ m4 u6 o7 l+ b Thu Mar 08 09:32:46 2012                                Page     8
! ?  F# a% e8 \
; e( _. b; u+ [  K1 F3 ~Photoplot log file; _2 P1 p) V% f' ]1 G0 j: y
Results from aperture table.; P0 r# |6 e4 t( x9 R1 a
- \8 h: ~  i+ `' L( P
RECTANGLE       31.5        24   0.00000  D369+ |8 D2 d5 }' P
RECTANGLE         24      31.5   0.00000  D370# G1 r9 p0 J; b4 T3 t4 S! l2 x
RECTANGLE     24.402    13.799   0.00000  D371
# F0 z; g( g- |RECTANGLE     13.799    24.402   0.00000  D372
! j+ J2 E# B, {5 @RECTANGLE     28.299    17.701   0.00000  D3731 G& s4 W  ~# _( {2 `. R/ A$ E; M2 t. [
RECTANGLE     17.701    28.299   0.00000  D374
( h8 z7 e5 h1 D. s7 @RECTANGLE       29.5     8.701   0.00000  D375
9 y( t% S1 K4 Z; K; SRECTANGLE      8.701      29.5   0.00000  D376
2 s- O# {; v& J" dRECTANGLE     37.402      16.5   0.00000  D377. f: p+ r/ W5 Q% ^6 P' s0 a
RECTANGLE       16.5    37.402   0.00000  D378
) c- X- o& z' f; y+ fRECTANGLE     35.402    35.402   0.00000  D379: H! U4 S5 `4 _0 v( {
RECTANGLE     39.402    39.402   0.00000  D3801 E2 e1 s% p4 ^0 O$ u
CIRCLE        92.902            D381
; ^$ o3 E7 {# W% OCIRCLE        79.902            D382
7 f& _* _2 w9 w: N* s# ^; QSQUARE            78   0.00000            D383- D  A; A; g* A* L% u' q% r2 v
CIRCLE        40.201            D384
1 x+ r- x! ?5 E- CSQUARE        70.098   0.00000            D385
5 h( B: K. e6 y% Q! n" F* m5 q; PCIRCLE        72.799            D386
3 a: E. _3 h5 L2 W/ w  s  h5 MCIRCLE        44.902            D387
5 g# d% i% {' I) kCIRCLE           250            D388: W+ G+ s! G% z" b; Z7 M1 Y
CIRCLE       129.902            D389, @4 A! r* `; L+ w
CIRCLE       259.799            D390; @$ {1 H: H" ^) }9 p/ G
SQUARE        88.201   0.00000            D3913 n, V! x- \7 i9 w6 F% q0 S
SQUARE        59.799   0.00000            D392
; M1 s# v; H* y! G& G8 m& u2 d% LSQUARE        74.799   0.00000            D393
5 H# K* v/ ?# ]) F6 Q0 ~3 nRECTANGLE         50    35.799   0.00000  D394
: ]1 }+ w' r5 H6 Z" GRECTANGLE     35.799        50   0.00000  D395
3 _7 Z0 E& [6 s2 c" LRECTANGLE     59.799    46.098   0.00000  D396, G/ v3 J! ]& y5 b
RECTANGLE     46.098    59.799   0.00000  D397. d  J. D4 J: S8 z) I3 L  b
RECTANGLE         50    25.201   0.00000  D398
' L6 P6 [+ @% B$ |# \RECTANGLE     25.201        50   0.00000  D399" @) z: D$ b& n' o! w
RECTANGLE     55.098    29.902   0.00000  D400
3 s! J/ X/ X; ~: [6 l" m1 m2 @- iRECTANGLE     29.902    55.098   0.00000  D401
6 z- L$ V7 m8 b6 L) S; _( t; }RECTANGLE     35.799    11.799   0.00000  D4021 {7 q  F+ z6 I$ n; o% e2 s
RECTANGLE     11.799    35.799   0.00000  D403- D# D, e7 \, T4 M/ U
RECTANGLE     44.098    18.098   0.00000  D404: X. U3 v* {' h1 S& ~* h5 c
RECTANGLE     18.098    44.098   0.00000  D4058 m( y, }+ i, W4 ], E2 n8 p
LINE           3.902            D406  M, P6 w6 X6 u
LINE           5.906            D4075 {. K3 v5 K1 v' \0 \1 l6 y4 |3 W, J
LINE               4            D408
6 u9 z" }$ l- c' [1 S5 |2 h- FLINE               6            D409$ n+ T8 F/ C+ e- {6 K# U
LINE               8            D410
, h# F$ P$ Z  Z- ]4 O0 S0 oLINE              10            D411
% a! ^7 ?/ I/ `9 N/ W1 V  m1 N" SLINE              25            D4125 }) n; r& G- T* z
LINE           7.902            D413
, f/ F% c7 a) r- HLINE           7.874            D414
- w7 R+ q# Y6 H' v6 T7 _LINE              12            D415
7 N4 `& `& @1 Q0 KLINE           5.098            D416
5 s4 N, N- m  H0 Y& h, LFLASH     F185_255_40               90  D417
7 g: R% i) n' X5 K# L# vFLASH     F425_515_40               90  D418
$ V) w2 a9 [2 P% Y5 c. f8 _1 GFLASH     F160_220_40               90  D419
* b( t" j" `! _5 w+ Q
* ?6 H: v7 n" J; y. V
9 v0 M. y8 S, G* e- I
. O; K' N, _  w, T/ I, |================================================================) h6 r0 C# P4 K) c/ y4 w, I, u$ Q
     PROCESSING FILM < TOP >: ?3 H1 p5 y$ c% e0 h; ^
     TO FILE < C:/aaa/TOP.art > ...9 l6 V' }2 W" v; x/ b
1 K5 s* u; S/ c5 O" n  `* K- {. C1 Y9 F/ G) y
  FILM PARAMETERS :
' |  o+ i( H! T, o1 N3 B  ---------------------------------------------------------
! _! @% m9 i: b2 v4 _      undefined line width ... 0.000! D& Y& G( R, s5 O/ S4 M$ o( a
      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10
  \6 }" R$ R- I; I+ i% u# w- z      mirror code ..... NONE
* J2 G4 P* T$ @9 }8 c2 l      rotate angle .... NONE4 r6 g, r6 U6 o8 q) P
      offset X: 0.000     Y: 0.000! D, H3 G+ A: B+ Z: G7 `! L, e
      plot negative ... NO! L7 k' G4 h3 u! D. K/ r9 c) @
      draw (fill) pads lacking apertures .. NO
+ ^+ v9 ], `6 v; E5 Y% g+ Q      suppress unconnected internal pads .. NO
1 M! C& x# D0 D  ?      make use of rotated apertures ....... NO) P9 X8 Q% q+ }9 p1 u5 }! r
9 Q' v' i) ], u+ r# D
3 E" ^& ]. W9 i8 T# n' L8 w, X
' |5 q8 \; p; L; y% L: m7 `( G' A5 A
) n: v: q- |# N1 s2 B1 N7 Z====>     TOP created with warnings) K3 @1 U7 \* I
9 W* U. ?8 n9 w0 @9 k3 z) N5 C
- ~/ {  [9 B- \7 _     ..... USED APERTURES .....6 M) P4 P8 E* O" Z) F
  ^& v+ ?% A- a2 ?' C, m   Wheel number - 1
( @! D. N) I. `7 g$ l# `! ]# I8 V' q1 x9 E
    TYPE          SIZE/FLASHNAME        ROTATION    STATION
6 m: F, c* K$ Y: W    ----          --------------        --------    -------             & F  M1 q9 Q: M
    LINE           5.098                           D416                # y$ i9 M4 z! ]
    LINE              12                           D415
) _4 z, F/ [% y$ B, T2 {    LINE               8                           D410                7 w4 ^1 Y2 c$ N6 N( B7 d. g, Z6 X
    LINE           3.902                           D406                6 y/ v9 Q0 K; |3 I! _2 k8 G( U
    RECTANGLE     11.799 35.799                    D403
4 z! f: K, ~: X& v( E5 w    RECTANGLE     35.799 11.799                    D402
" R& Q, e. h/ y; V) [, |6 R    RECTANGLE         50 25.201                    D398
+ Z0 [' U$ \7 {    CIRCLE        44.902                           D387                / U* ?) [, |4 _
    RECTANGLE      8.701   29.5                    D376                0 ?% r+ Z3 ?/ a
    RECTANGLE       29.5  8.701                    D375                # y1 j& `7 i6 N
    RECTANGLE     24.402 13.799                    D371                1 e* x3 X: _  u1 x  A* D. H" P
    RECTANGLE     23.598 16.098                    D367                & r& D9 N1 ^$ l
    RECTANGLE         35  9.799                    D363
. J$ V0 E2 R9 `# v6 Z7 k    RECTANGLE         24 57.902                    D360                . j7 _6 ^. G; h) u5 U9 g" ?
    RECTANGLE     57.902     24                    D359                . u( z  |+ p, r8 _; W
    SQUARE        61.799                           D353                3 r0 w& v+ z( t  G2 L. G+ G
    CIRCLE        90.201                           D350                7 N8 M4 U9 f( ]1 A" c) u3 S
    CIRCLE        146.902                          D348
  d  O7 s$ X9 d0 S+ T0 f    RECTANGLE     109.799 31.902                   D343                9 w3 {& k, q6 D
    RECTANGLE     21.701 11.799                    D339                3 C2 ~) C. _' U, ~, m% h9 e
    RECTANGLE     78.701   31.5                    D335                9 N" Q: F, I' C9 x1 f1 r) n
    CIRCLE        59.799                           D324                1 U  p" \4 d! h9 @' ^( R% T+ D' ~" q0 E
    RECTANGLE     118.098 118.098                  D321                3 N/ m8 n1 R$ K6 u
    CIRCLE        70.902                           D318
, f5 Z" A- ~, P8 R$ v    SQUARE            50                           D285                % [) r& _! X; R/ v
    CIRCLE            65                           D216
: ]6 R, X2 J" r; H7 s" x$ I    CIRCLE            35                           D89
+ f( I- S6 M* i% _) D    CIRCLE            24                           D25
, m, F4 Y* J# B, n6 R$ Y. P    CIRCLE        72.835                           D21
- P: H; ?3 I# h# N, w8 ]0 K    CIRCLE        198.819                          D16                 2 T2 c! O7 P# Z5 o6 J+ \1 g
    CIRCLE        62.992                           D12                 & H! P" Y2 q2 L9 C
8 A: s- h% M6 k4 D6 w7 m4 M; e
' E) k2 Y) Z! b( L
================================================================- s* S0 u# {' h
     PROCESSING FILM < POWER >
/ u3 G* L% ]+ X9 o     TO FILE < C:/aaa/POWER.art > ...
$ G9 L; T$ `. B7 A3 M================================================================6 ~' `, I# f" U5 L+ p( I. y
/ z1 F. G9 v" \
  FILM PARAMETERS :
+ S) q6 f5 V8 z% Q  ---------------------------------------------------------: O( q& f* @# Y3 j: J: F/ \
      undefined line width ... 0.000) U+ e0 }' f* A/ [
, A2 `* @" m! c0 T      mirror code ..... NONE$ g( ?5 h. _; n& e2 c1 o
      rotate angle .... NONE6 D7 N# ]. K& \" U; z  g7 R# C
      offset X: 0.000     Y: 0.0008 m; C! \3 p+ c) c8 U
      plot negative ... YES
$ q2 N- F& ~" @6 F6 U% p% w( N      draw (fill) pads lacking apertures .. NO: w) v4 u. f/ N
, ~6 [7 O" {0 }! X1 e$ S% w      make use of rotated apertures ....... NO6 X! g) a0 R2 K3 \6 f
" V  L, `1 G! ]+ s6 b* y* Y1 ]
& |- u. e5 q/ e6 X# Y4 q
4 r$ k7 t- p0 w* F8 p- {: M8 H& j2 |, x, p
  PADSTACKS MISSING THERMAL/ANTIPAD DEFINITIONS:' V; `8 |' D( F1 C" m( v
        PAD45CIR30D
% V5 z" v( y% ^8 C8 W        PAD60CIR36D
7 H* @" p' H8 S" V/ G3 @0 R        PAD35CIR25D# x0 c: U" ?6 k8 O5 ?
& f% O5 I- z' N0 M- z
0 j) F6 w! ^+ I. Z* J% Y, p, q ... error in film, proceed to next.
. M& b2 ]6 P, K0 Z *** ERROR with POWER9 F  Z/ y# E) Z% j
- T4 `. S1 L2 |# u2 b+ u
. ~" B2 ?5 [6 I" a9 G& }( _& c================================================================: C& C! E$ s$ X
     PROCESSING FILM < GND >
4 B, K8 _; t" M; q, i" _     TO FILE < C:/aaa/GND.art > ...
; K! h* Z" v& q9 g5 z+ M4 C2 L================================================================
8 ?9 G% g7 ^3 u8 ^
; K' u( v( O- H  FILM PARAMETERS :: w+ |" `# w7 v# S
  ---------------------------------------------------------( _" P/ f( z. U( g* |- f$ N+ C
2 q6 m5 l6 H, h      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10
; }, J* F, L9 r      mirror code ..... NONE+ J) ~  h  ~( d9 K5 j. b
      rotate angle .... NONE, V9 a% u/ u" ]# }  Q; Q9 ?
      offset X: 0.000     Y: 0.0008 ~' u5 g% ^+ ]- @5 T! N
  p- R+ f9 c% C4 i0 F+ l2 {      draw (fill) pads lacking apertures .. NO% T( q. `7 `! K: j. g
' [  U& Q1 Y$ y: b      make use of rotated apertures ....... NO8 }# t- [, P5 n6 K9 V; I$ B
5 E6 j  B. ]6 f: H! Z5 |
$ ?6 x1 v& o  g7 g7 [
' c- o8 ?+ l  T! m3 f6 n; s) w( b% |3 p
  WARNING: The following padstacks and their flashnames have various
+ `( a+ C( n$ T3 f2 x# Z; r5 L      rotations, but will be flashed using the non-rotated0 H+ U& _6 }! ]8 [4 Y6 Q9 O
      aperture, due to the ROTATE APER param being turned OFF.& J. {/ C" o+ ]
      Check each flash for symmetry to insure that its 7 s8 P) a7 x* w: h" b3 }* q' d; }$ z
      appearance is the same at each rotation.! L" b' r- w+ C
(FLASHNAME)            (ROTATION)   (PADSTACK NAME)
( q; ~; n) z+ E" f% i F185_255_40                90.000   PAD1_85D1_10          t' E3 k* c! D" B+ h( H
: Y; R/ @  j) O$ ?
6 p. q; F, ^& K; L* }5 D- c  PADSTACKS MISSING THERMAL/ANTIPAD DEFINITIONS:
% N" B2 K1 g7 k: U. ^0 P        PAD45CIR30D
* a% \& l9 X) B$ S, D        PAD60CIR36D# d) F( q9 g, ~) r
        PAD35CIR25D! L. m0 x. G& w4 Q: t) \3 h
7 ^# @5 c1 S2 O' @+ |  {! q. ^+ x2 N" L8 W5 H
... error in film, proceed to next.* D' P2 h+ T5 U3 g9 F, Y4 U
*** ERROR with GND9 m% O$ [+ A! b/ O* v/ c& b
! n- Z. Q1 R1 Z. ~( `* C& H8 }
* S  k( ~* p: ]* p$ m3 T================================================================
9 a" P* @! X& f$ K7 k! F& \2 Q     PROCESSING FILM < BOTTOM >
2 a3 a& B9 c  C3 {  k8 f# M     TO FILE < C:/aaa/BOTTOM.art > ...1 ?% l4 a' ~, W# K
================================================================7 N: O& W' a- @& s- j/ g- L
$ C3 M; n) e' e$ h
  FILM PARAMETERS :! J8 Q8 L/ b, }, W% F8 L
  ---------------------------------------------------------- Y7 ~: w4 X. f# s6 y3 U, Z
      undefined line width ... 0.0005 h' p+ k* \5 W) G! M! k
      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10  / B. C  {2 h% n, r" v9 g% ?9 @
      mirror code ..... NONE  A( C: {# {4 P6 G& a
, O: b* d  g3 L- s      offset X: 0.000     Y: 0.0009 p! |8 R+ p3 X3 W
  ]' x1 C  p! M4 |: D4 f, i6 Z* ?  I      draw (fill) pads lacking apertures .. NO, l1 s4 D- w3 c5 }# R
      suppress unconnected internal pads .. NO" {5 l8 _, q/ c* l5 W
* B, K! X7 x; T, z" y( Q! C& H5 l" W" z( i$ q
+ c4 P3 Z& }& z1 x( p
3 _( V4 O5 o) e+ Z0 c
0 M3 j5 C# C; _4 Q0 v$ N; \8 x====>     BOTTOM created with warnings
6 B4 ]: F) K! ~
' b+ b/ ^- Y7 g' o: T& O' p8 B3 X
! z9 B0 [/ z% `, `, K     ..... USED APERTURES .....
' U9 N8 N8 l' Z. u4 _( q. t3 {$ F) f  F. Q# ~
   Wheel number - 1 1 i) p4 |# X* X' R" f/ B! `$ r9 _
. T4 w& U+ e% x# A7 U, h    TYPE          SIZE/FLASHNAME        ROTATION    STATION             - ^6 g  m% o% X9 K
' |; l; e6 A4 T2 E1 i3 @; L6 O2 s    LINE           5.098                           D416
. W! h+ h  E9 i' Z    LINE              12                           D415
8 a- u3 L' O) B% H    LINE               8                           D410
7 q: j" v2 G6 r/ [( D    LINE           3.902                           D406                " b" }" k4 M9 T$ [
    RECTANGLE         50 25.201                    D398                9 F3 _9 m2 z6 ?  Q# U) j
    CIRCLE        44.902                           D387                : ~' i. N7 `( y9 b
    RECTANGLE     57.902     24                    D359                8 r) Y9 y/ O5 ^9 @
    SQUARE        61.799                           D353                9 `6 D( P, Y4 z% n" [
    CIRCLE        90.201                           D350
7 q7 w$ _) b! Q$ b1 r0 W. }    CIRCLE        146.902                          D348
0 B& L" J, G9 x: A  S  N8 G    CIRCLE        59.799                           D324                * D  O' u9 ^0 b
    CIRCLE        70.902                           D318
0 g0 r8 u9 \- _    SQUARE            50                           D285                " e3 i% C" b; p
    CIRCLE            65                           D216
, d5 p' p  ^2 D    CIRCLE            35                           D89
4 x  G/ ]+ e. @& o+ r, K! k    CIRCLE            24                           D25
8 J" c: {+ }% Q- W& X# E* W    CIRCLE        72.835                           D21                 # {8 e5 m7 l0 I9 p0 I5 p- n- `* E
    CIRCLE        198.819                          D16
2 \, {# I2 U, v( G* f& Q" J    CIRCLE        62.992                           D12
. L; Y" w! D2 E  F. h
# B" T9 E2 C! o' E& d8 h6 L1 W8 w2 {
+ D; k+ t' w3 ~( B9 W( ?% o/ s================================================================
- Y& V& S7 O+ A/ E     PROCESSING FILM < SILKSCREEN_TOP >
/ p& K7 F7 n) s9 q3 X: \4 r) J3 }     TO FILE < C:/aaa/SILKSCREEN_TOP.art > ...
" X/ U# P. _1 Q1 j* a# A* R. c================================================================% ?5 f) ]! p! G2 a
( h7 H. e( R, C& c8 z! ?
  FILM PARAMETERS :: c: H/ [  y& ], a' g6 n
" J! i) V7 L! `+ }/ J- t      undefined line width ... 0.000! O) o7 c8 z2 S' P+ x8 W/ N
! y1 U, L9 [6 t" y# e: O- `      mirror code ..... NONE) s0 Z( {: Q( j4 t/ t3 u
* J. d) a" ~$ _0 I/ v+ j( `" \      offset X: 0.000     Y: 0.000
* X* N2 t/ \' K$ K; T% n9 c; z      plot negative ... NO
: S9 s+ B$ E6 I& ?3 P      draw (fill) pads lacking apertures .. NO
- v0 K: A. u: j, P* o/ M2 |      suppress unconnected internal pads .. NO
: Z4 u! t5 m& e2 h' `/ z- j& B" W      make use of rotated apertures ....... NO3 [5 D9 H) h. I7 k- z& Q8 k8 Q7 W" q/ c
; Q  z& I! b/ e8 w
1 K3 t/ P' c% x% J- U4 Y) C
WARNING: 0 width text line found at (-313.567 -23.409)
& S; Y" T8 R0 i' z0 r6 V, W) f+ [         ... ignored!1 g1 @' `) `2 g+ }
WARNING: 0 width  line found at (-458.567 10.591)
- s2 R& a2 W5 ?. I  o; N         ... ignored!
9 q! c: z+ z! }  Multiple 0 width  lines; all will be treated the same as the first.
6 J7 n7 P2 g; ~/ T& }7 @5 ^) ~! r4 Q4 ]- ?0 l. W
  Multiple 0 width text lines; all will be treated the same as the first.
; e% l: N9 V0 @- b" ~: @- K
# ?! a( z/ Z3 I- c% ^* B; `
9 J& z& ?2 n" E; Q8 b% N& H. K6 ~; b0 r4 q. W) p  X8 }6 d0 j, j
====>     SILKSCREEN_TOP created with warnings
9 _6 e: ^6 y7 ~& ]# p1 _2 _9 E ( ]% J3 s3 }$ V
4 \5 w; o) {- p9 |4 [
& q1 w$ O, G, I9 P  H
. F4 Q2 h3 Q; [+ i' M1 h, k- x3 r   Wheel number - 1 2 o. B) h3 V* ~5 i* I
4 U7 p/ q2 Q0 {5 w6 M9 l
0 ]/ Z' P1 m; p/ e) ^! |/ |    ----          --------------        --------    -------
! Z& r* \2 h7 p8 i2 S    LINE           7.874                           D414                8 Z! K6 h" g! d7 y6 e& C' M# H
    LINE           7.902                           D413
& u, O. x& R! C, z    LINE           5.906                           D407
8 m8 p0 ^2 h8 ?, s    LINE           3.902                           D406                - q" q  U# d0 {3 n
% O0 B# h3 e, R  ^, W. w
# R5 h- v( }; R================================================================2 c* ^7 A3 b1 I' ?- b9 M4 D7 S
     PROCESSING FILM < SILKSCREEN_BOTTOM >
1 |/ A5 `& m: ^  K; |     TO FILE < C:/aaa/SILKSCREEN_BOTTOM.art > ...
' n6 m/ c# E7 j; z+ p, p. V================================================================' H# y* J4 D" V8 _
8 Y9 P+ k- s0 E( y+ K1 ]  FILM PARAMETERS :8 H3 M* G3 A) \0 Z
) j2 j/ I, |3 ]4 p' l, s/ ^7 O7 I( U7 Q      undefined line width ... 0.000
$ e$ x" l! f5 A: l& V3 D      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10  , R, O7 ~1 \2 X3 T! {7 B
* Z0 S! {* J! F6 j      rotate angle .... NONE
& B( w4 Z7 n9 f) J      offset X: 0.000     Y: 0.000
' _0 d9 _& q' s      plot negative ... NO
: P! Q9 u: \  J      draw (fill) pads lacking apertures .. NO; Z2 W6 x. w" L- i
/ p( d! \- ]9 j      make use of rotated apertures ....... NO) {! w# B, Y) r& X4 g: t# m
  B- T! Z4 {) U* @$ M
% a6 B6 G, ~6 ]
: g  \. L1 b+ r% M$ ^; }
& D! L) r  E9 w- H1 f: a
====>     SILKSCREEN_BOTTOM created with warnings* Z; F/ ^6 a( Z( F+ A8 Y4 }
$ }2 v* g8 d7 \# b
+ n7 B+ w' A0 Y1 Z- [     ..... USED APERTURES .....! ^0 t+ k8 b% _4 S/ |* P/ j. o+ a8 a
  O5 G; A4 F, k   Wheel number - 1
5 W5 s* [  F9 L" K( ^& Z. A
+ Q3 ^" r0 R+ q$ q- A    TYPE          SIZE/FLASHNAME        ROTATION    STATION             / J) r* P& I0 B6 a% B5 S) B
( E- s* l% k4 i& v4 m    LINE           7.874                           D414                ; S' f/ o. [1 }; O/ H8 w) e6 y
    LINE           5.906                           D407
% y1 ~+ R' o0 Q/ [: U! x0 U& Q5 r% s9 {7 h4 ~6 E4 |, a
! ^9 \) g6 e9 X+ g================================================================
- o1 U2 K. y. S8 h     PROCESSING FILM < SOLDERMASK_TOP >6 T3 W! d, h. |, z
     TO FILE < C:/aaa/SOLDERMASK_TOP.art > ...
, V% @' p0 T4 `% J/ ?8 f1 ~5 f7 Y================================================================
& @  J% F+ B" x7 W  z7 d. K! n
( J$ V" L& `$ v" v  FILM PARAMETERS :
9 c* g( h8 W! @  ---------------------------------------------------------7 T% Q" ]" Q) S. g9 Q
: X0 g! Q% a# S4 F      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10
7 F! H9 F) B  t" s  E      mirror code ..... NONE2 z0 B6 j0 W, A: B: a
; a  e% x9 C6 T      offset X: 0.000     Y: 0.000
2 M) k5 d, j; o5 j/ I      plot negative ... NO- `" ~; J+ a0 U1 o1 O# U
      draw (fill) pads lacking apertures .. NO0 I# r( M1 g% H
      suppress unconnected internal pads .. NO/ x1 t( H1 O; `# ^- x
      make use of rotated apertures ....... NO* F& s: ]. \1 n  ~
- ]) ?' ~$ N* Z) c* l
5 w* A8 m/ A9 \' q1 u3 b- ?2 p9 \( {  b& U' N- m; t
1 @8 h& v3 P0 Q/ ^: b; Q====>     SOLDERMASK_TOP created with warnings2 t" A7 r. b3 t/ r6 }
2 S/ b/ Q2 q2 W6 O$ o2 F
% g6 l0 T7 x6 x( ?8 G
; \1 K9 A: ]2 o
8 t7 z' ?% Z5 q   Wheel number - 1 / `6 I% p) p6 c& @3 U6 K
' S6 s  e4 V$ S8 b3 s) t, j5 h    TYPE          SIZE/FLASHNAME        ROTATION    STATION             4 l4 B& S5 E; S; D) ]
    ----          --------------        --------    -------             ' }- x8 D) ?: r, d# o/ g% u
    LINE           3.902                           D406
% n- b) e: T) U% S( z    RECTANGLE      8.701   29.5                    D376
/ J' D& }+ J6 v% e- m) A3 L& f    RECTANGLE       29.5  8.701                    D375                : p7 ?1 D+ @  a% O, G3 l
    RECTANGLE     24.402 13.799                    D371                : h6 V/ R5 Q2 O& M% s
    RECTANGLE     23.598 16.098                    D367                * ]7 O( h* t  b; T3 {$ \
    RECTANGLE         35  9.799                    D363                , b, F1 v  F! D
    RECTANGLE     16.098     50                    D362
  l/ V7 Q- U2 Z/ m    RECTANGLE         50 16.098                    D361
; c, L# O& |, \  B    RECTANGLE     109.799 31.902                   D343
4 K( F* N; M% K/ W  I7 f    RECTANGLE     21.701 11.799                    D339
1 T+ K* {8 ~0 }/ G    RECTANGLE     78.701   31.5                    D335                : \- ]- Q0 U. n1 g4 v
    RECTANGLE     118.098 118.098                  D321                ' E+ j# [" d: c1 u9 x0 @
    CIRCLE        70.902                           D318
, F* k7 o  B6 K; ~7 Y6 e
- r- y+ ]! q" y1 B! e$ j+ h' J; E
: F. w; Z7 q4 @2 B# R================================================================
5 t7 W6 L- }+ G5 E" _8 ~     PROCESSING FILM < SOLDERMASK_BOTTOM >% y5 d3 s, q& G" S5 c: F
     TO FILE < C:/aaa/SOLDERMASK_BOTTOM.art > ...
0 T$ M: f2 n$ V" F( F) D4 ~9 w================================================================% p) a0 d; J; ~7 m/ P
! j9 c6 q2 @! e* \, d" z
  FILM PARAMETERS :# S0 t' H% x5 c* t0 f6 F
; z" F2 ~3 ^; e( s' R8 u      undefined line width ... 0.000
% P7 Z- ^6 \! f; ^9 v      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10  # v$ a8 \* K7 s$ `( C, `, d/ [' J* p
      mirror code ..... NONE  I5 X9 V3 Z; w3 u6 S! r. T; a
      rotate angle .... NONE# _' z1 v3 f' N+ s5 x
5 s/ v% Z2 }  @: C' _* M/ p      plot negative ... NO
+ _" \2 l# d, U: |7 q      draw (fill) pads lacking apertures .. NO' {/ d' ^) {7 ]) S( T, i$ k8 }- M2 N
      suppress unconnected internal pads .. NO7 h' Z9 O' h4 @& x, Q
      make use of rotated apertures ....... NO. e6 B3 q. g4 d9 n0 o
* P3 Q) M, C4 G5 r8 w) O
: i0 V  d0 }8 e) y. F1 w3 o9 J
7 ]; V7 E/ M+ G# d; r( I& o$ s
3 @3 y+ K5 `: |& ^====>     SOLDERMASK_BOTTOM created with warnings8 D+ O4 I$ N0 m; N, K( q
. }* t1 n/ ~! t" [  S5 Q" @+ H
3 i* x/ v/ b8 ]. O# f/ g4 n" D, @
     ..... USED APERTURES .....2 b9 Q( r8 ~: y' A
) W2 d- D0 r0 O. y; R8 B   Wheel number - 1 * L/ S# ^6 t# F0 Z2 s; Y
7 ]" h( H  ~+ {
    TYPE          SIZE/FLASHNAME        ROTATION    STATION             ' F+ R) V( t0 t: f7 B( B
* g- c( L3 w* F# H  c2 x    LINE           3.902                           D406                , s8 m+ i4 s6 b/ V% ]  b0 L+ U
    RECTANGLE     55.098 29.902                    D400                + u/ o/ D0 ^* q
    SQUARE        70.098                           D385                ) e; b6 q. X- ~& o: v8 g1 c0 T
    CIRCLE        79.902                           D382                5 ]( O8 s5 p$ Q! ]
3 h( D6 I3 R/ Q& k: o9 h    SQUARE            72                           D356
/ q# ^1 w* P9 c- z    CIRCLE        157.098                          D347
" c+ U5 @2 Q* W' |: S! `6 ^) Z    CIRCLE        70.098                           D326                $ m% R  i/ a, u, \- V
    CIRCLE        74.799                           D317                - l% B! g4 T' N" G
    CIRCLE            65                           D216                , G3 T1 N- M, g5 Q. T
    CIRCLE            45                           D41                 $ S7 G9 q- p" q) y: [
    CIRCLE            44                           D26
: [# r, J$ N# b. {    CIRCLE        76.772                           D22                   T" {" T2 P4 U3 z4 C- E
    CIRCLE        202.756                          D18                 3 e; }' }1 X) O
    CIRCLE        66.929                           D13                 3 ?. T6 i! @  D$ F6 i# O6 ]
9 r9 {. K" `* q7 V' Z6 {
# m; m8 v$ {' _( e9 A4 m================================================================
" J3 S7 T/ [3 Y# H* ^0 @3 f     PROCESSING FILM < PASTEMASK_TOP >) \3 n5 D2 [8 h1 N# p5 l
     TO FILE < C:/aaa/PASTEMASK_TOP.art > ...
. e/ _' t' J, u% J1 @) [( A================================================================
% C( {6 ~9 m/ u! j% R8 P) {6 J4 w3 x3 G4 w0 v% N2 z' a
  FILM PARAMETERS :) Z6 B  N6 @1 l& r( p
5 D! v" P& e3 o- Y& |8 Z      undefined line width ... 0.000
1 i9 |! I6 [" ^. G( n      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10
. q2 _! W$ R* D- |+ I& u4 C/ W! A/ f      mirror code ..... NONE$ |; K$ z" S3 |( a2 f& ^: G
      rotate angle .... NONE' z* |3 W! h! X3 K: n1 M
" I! F  E( h' g$ q# }( U      plot negative ... NO1 N2 v, S0 I. t: _0 ?
0 ^" u& i) I* Y- [. I4 R$ D" z3 U5 e      suppress unconnected internal pads .. NO
2 y; G9 ]- J: S3 }! l* ?      make use of rotated apertures ....... NO* c/ q( t4 s3 \! ~, ^
0 ~0 p, v1 C4 f5 A# s9 P  B( V2 F; t/ u
! r% U* n1 t' f6 [# l
: S9 x5 k) S3 O0 }, j* z
====>     PASTEMASK_TOP created with warnings
: J1 M+ ~0 b3 Y, A
* [6 M1 v- @% z9 w. n
! ~, f  Y- _2 q! X, `! ^) w* R     ..... USED APERTURES .....
% Z3 q9 S$ E  s$ @" Q/ \) [5 L8 A, F. N
   Wheel number - 1
; L; ]3 T2 x) m$ G
" ?3 C! M9 R1 h" ?( G8 \    TYPE          SIZE/FLASHNAME        ROTATION    STATION
+ w! Y( }' F8 ^0 B2 h/ b' A7 [% `    ----          --------------        --------    -------             9 k% s/ D! k. U0 s  V
    LINE           3.902                           D406
) M- i% ?+ K9 v) C+ k1 z3 X/ p* s    RECTANGLE      8.701   29.5                    D376                % z6 v7 h. n- @
    RECTANGLE       29.5  8.701                    D375                ; S3 u& H7 l- R0 r; {- r
/ h3 @" `/ u. J/ p. Y$ Z    RECTANGLE     23.598 16.098                    D367                ) a4 I! x( P7 X* P& K& g& |4 W
    RECTANGLE         35  9.799                    D363                * F' A1 w9 c* ~  V9 u; \! O( `( u" t
5 d2 e  ~- [+ S1 Z- R2 L  o    RECTANGLE         50 16.098                    D361                + Z5 q1 G9 p, z9 s% c
    RECTANGLE     109.799 31.902                   D343                . D3 L$ F. L! L
    RECTANGLE     21.701 11.799                    D339                . p4 C0 B5 m8 E* k
, c3 Y( p' \9 `1 e* K$ V    RECTANGLE     118.098 118.098                  D321
% D' ^. |! ?. k' k. D    CIRCLE        70.902                           D318                0 {" X' F6 R' P8 {9 j; ~2 k& ]
1 w) C3 c8 R* v6 h0 D$ I* ~- Y8 L
/ G; n' \" ]6 B0 d================================================================
1 x2 K( H7 L. x1 T     PROCESSING FILM < PASTEMASK_BOTTOM >/ A) s+ ~1 x" m
     TO FILE < C:/aaa/PASTEMASK_BOTTOM.art > ...! F2 z$ k# M4 N4 L, G4 w) C
================================================================2 e+ p' A" F5 u; e2 ^) w( t) w
. W  Y) R8 j4 w' K- U( b# e) z5 }
  FILM PARAMETERS :
7 R6 M5 F. ?) s, m5 ^5 ^  ---------------------------------------------------------
3 S! j6 Z8 F$ `7 R0 H5 O" i      undefined line width ... 0.000
8 t) r; q) x6 f( T) a+ r2 }      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10  6 @0 ^, Y$ F; ]
      mirror code ..... NONE2 W; L4 F9 n* k3 F6 _% h# P
      rotate angle .... NONE. T* a+ w7 E5 q- a; n7 E8 k- U) z
      offset X: 0.000     Y: 0.000  y- L; w8 U( X% k
2 n- `: j0 J% V, z. J1 D+ n& t      draw (fill) pads lacking apertures .. NO' ]5 [# j& R# U2 A* ?; B
7 p( K; I4 H( P3 g      make use of rotated apertures ....... NO
* G" O2 D9 d2 u
; D3 t' `1 e7 g; N  ?
: D. q+ s' R) ?* K7 A  j9 u$ b
5 q2 ^5 g/ A$ R3 a- B% n/ }! ]( p  Q! u, P6 u7 d6 |
====>     PASTEMASK_BOTTOM created with warnings' m) Z# [: v/ T1 x
. Q  D2 f1 F) D/ {9 u1 B% e- d# y
9 K- T4 H6 q( ~* E. @  V9 \     ..... USED APERTURES .....
; j2 ?( X: V/ e+ O; Q4 I2 d
# T8 R$ ^  g# e  N1 |4 H" `   Wheel number - 1 " z) R: Q- }; Q7 j; V% o& h. L" b
/ z) i, U) a2 U3 V' G    TYPE          SIZE/FLASHNAME        ROTATION    STATION
& }2 D: g4 K9 Z    ----          --------------        --------    -------             8 A( R( ?: E- H
    LINE           3.902                           D406
3 t; L1 C, S, p+ s) N/ B/ K* F! U& l    RECTANGLE         50 16.098                    D361
4 U4 B& K3 `9 X+ A! x) [( F! L    CIRCLE        70.902                           D318
! G3 E6 ?$ b6 w2 U( o- \0 v9 S* c3 S: i& a" d9 M2 A
0 v) L8 V% P, E  C( k) r================================================================
4 T# [  L- p2 d6 \5 k) ^5 c     PROCESSING FILM < DRILL >
3 N6 `# V6 \% n4 @/ J( I5 J     TO FILE < C:/aaa/DRILL.art > ...* C4 N; w4 h, w7 |4 L
================================================================7 g+ J0 [1 P6 l
0 G0 Q: Q. z: |- U  FILM PARAMETERS :
- F5 \6 b; ^4 M. {' t  ---------------------------------------------------------
& P9 E0 e* @2 n8 r! m      undefined line width ... 0.000
$ L7 ?) O) ?) R( X7 W      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10
4 @" n9 Z$ o4 z% g7 q9 T      mirror code ..... NONE
% _4 E; ^2 K# B: R$ T  d      rotate angle .... NONE9 \! \2 n0 D; I4 ^- c$ ]
) d8 P( l& s* u2 e      plot negative ... NO
! m% ?5 {( v+ _0 _      draw (fill) pads lacking apertures .. NO+ B# ?) \1 u% |: N6 ^- ]
- `& L; n0 A6 x% d$ Q$ H      make use of rotated apertures ....... NO% P# `* Y/ n) l  `6 m& |
5 n$ Z) U& w) u3 }; ]
8 B2 t; t+ k1 H6 h
ERROR: Can't draw shape at (0.000, 0.000).8 c8 ?7 N. u& A! @! \. J. @
% o4 ?/ M# ~2 z" o ERROR: Can't draw shape at (0.000, 0.000).
2 `) m8 a) b8 q& N* f4 _0 s ERROR: Can't draw shape at (0.000, 0.000).
5 q! b2 l  S! J3 l ERROR: Can't draw shape at (0.000, 0.000).1 Q" F$ m$ z/ b9 _. i. x' f* c
- P& C) c! a8 s* J% |; E
1 o: e1 _2 O1 |% \4 v
# X- `% g& w4 h! d ... error in film, proceed to next.1 R$ B; c& W! G! S/ ?! Q4 i1 P8 k% A
*** ERROR with DRILL
! ^0 o+ V# K) s( S$ |5 e- x3 b. Z9 P+ i
' H3 e3 k3 g% p; ^6 |5 M  ~7 W* I& i8 _1 e% \) u) g6 e9 x
    TOTAL APERTURES USED& W+ f0 W$ j8 D% _
/ s( f7 |! J+ Q7 k    CIRCLE        66.929                           D13
9 |/ Y$ c' V3 |  h# q  ?    CIRCLE        202.756                          D18
# Z) t; P) z1 L9 a" O    CIRCLE        76.772                           D22
) j! N: @7 D# ^    CIRCLE            44                           D26                 4 [+ P2 H- Y& K
    CIRCLE            45                           D41
- z5 t1 w# c, C" [5 W9 F7 c; B2 |    CIRCLE        74.799                           D317                $ A7 a# ?6 P6 L- ^) i
    CIRCLE        70.098                           D326
$ P- [  W# u% D" B# [& E! C    CIRCLE        157.098                          D347                8 L. S9 v; v: k) N' v( x
    SQUARE            72                           D356
( c4 Z2 E6 ?. M) B5 t5 H  r0 o    CIRCLE        79.902                           D382                6 O6 W% x0 z; F- G
    SQUARE        70.098                           D385
* U! h6 z( d% I) _  S    RECTANGLE     55.098 29.902                    D400
% j* s. @& t% F4 B    RECTANGLE         50 16.098                    D361                " Q! ~- s/ l7 c7 D5 H* W
    RECTANGLE     16.098     50                    D362                6 r2 w( M0 j/ i! [5 v5 j
    LINE           5.906                           D407
# Z/ B7 z3 X: I7 i  X    LINE           7.902                           D413                9 ^6 R1 g& k! s
    LINE           7.874                           D414
# ~" Z, V) G& b    CIRCLE        62.992                           D12                 0 i' Y& |5 R6 T8 t
    CIRCLE        198.819                          D16
5 M' `3 b3 c; ~' h$ V9 u# V4 U) Y, m    CIRCLE        72.835                           D21                 6 t8 R- y7 j+ j+ a$ Z$ r* j
    CIRCLE            24                           D25                 7 X6 G  m  \, W% `, G
    CIRCLE            35                           D89                 2 j7 O, }/ I2 k& N6 A
    CIRCLE            65                           D216                4 B, r. ?# ], Z( F6 v3 f. \
    SQUARE            50                           D285
0 u$ G7 N2 A+ O' y; z    CIRCLE        70.902                           D318
7 M3 R9 l+ n; g8 _    RECTANGLE     118.098 118.098                  D321
+ N( I' H" O* C$ U' X. L" s  ^    CIRCLE        59.799                           D324
! ~4 V. V* L, Z* r) E0 C9 ]: M    RECTANGLE     78.701   31.5                    D335
% m( q% O' n' X" z$ e4 o    RECTANGLE     21.701 11.799                    D339
3 v/ N" u# \2 I    RECTANGLE     109.799 31.902                   D343
" @- F9 {# ?- T& q) n    CIRCLE        146.902                          D348
$ Q, I* u- j9 m$ X: I) [$ ], q    CIRCLE        90.201                           D350
( j0 _! n! Z% m    SQUARE        61.799                           D353
6 n: Y2 _  O% ^+ T    RECTANGLE     57.902     24                    D359                ! h$ P! W- {4 A. W* `; D
    RECTANGLE         24 57.902                    D360                ( Z' V, R" V2 o
    RECTANGLE         35  9.799                    D363                1 f) f- ^% _' f4 U
8 w" Y$ D$ V$ T: \+ v9 B- g    RECTANGLE     24.402 13.799                    D371                & i) a6 x; }/ c3 g/ [
) a/ B" n: e/ d+ y1 O, o    RECTANGLE      8.701   29.5                    D376                9 t5 T2 N4 k9 h
    CIRCLE        44.902                           D387
0 e. ]8 _+ L; T8 N9 U2 H    RECTANGLE         50 25.201                    D398                + d! R, S# a/ w% Y  {7 f6 h0 y, [& ?( d
( I; s4 L2 u8 Y9 e    RECTANGLE     11.799 35.799                    D403
$ K6 p( Z5 ]" R) t8 j, h    LINE           3.902                           D406                ) c2 k1 O# a* Q) r; S+ R: ^  L
    LINE               8                           D410                7 }0 I1 A8 U1 O& u0 S: A
    LINE              12                           D415
6 Q& W# o5 g3 l% B    LINE           5.098                           D416                  q; Y/ b9 ^0 k7 H# {1 E' W+ \( X- [% g1 P
! }3 q5 k: n1 _& L; _* n+ f
1 q" E8 w8 W( P0 x6 E1 q  @% a% f/ ?5 B* Y' l% Y) {
; Y+ u+ M, P! J3 s  C( I SUMMARY:
0 j, U& r( y% G8 [8 X        TOP created with warnings& E+ L$ L3 P- f# @3 @) ~* Z
7 H" T9 O1 |" \  n1 B* w    *** ERROR with GND
  K; g4 v% C, e5 x' |. H        BOTTOM created with warnings  k2 \( ?4 C7 X6 ?
        SILKSCREEN_TOP created with warnings" z5 G" p5 y& l6 r
/ r; y: q' n- c- a8 }, E0 R2 K7 K! H        SOLDERMASK_TOP created with warnings& h( \* T) G, H% m" ^
) y* H4 b9 [: w9 t9 y0 `8 h        PASTEMASK_TOP created with warnings
# n3 `, A" n  D" P. [        PASTEMASK_BOTTOM created with warnings
( T$ c5 X+ _# R9 x+ n    *** ERROR with DRILL
; I: a' _6 `8 t* o! j5 J4 r7 q% R, r' M6 _; s1 t
ARTWORK Error processing film.
+ j( `5 h6 J/ I
 楼主| 发表于 2012-3-9 09:56 | 只看该作者
怎么删帖子啊,我想删了,问题没这么复杂。。。
发表于 2012-3-12 20:21 | 只看该作者
就是少了一层Photoplot outline   你画个Photoplot outline  把 所有信息包括进去就行了 ,  这个就是你出光绘的范围,
发表于 2012-3-12 23:00 | 只看该作者
楼上正解
 楼主| 发表于 2012-3-14 10:02 | 只看该作者
这个选项在哪里找啊?没找到。。。。
 楼主| 发表于 2012-3-14 10:23 | 只看该作者
WARNING: No thermal flash for padstack "PAD60CIR36D", regular pad used.
$ _2 [3 d, M# _9 i. O    WARNING: No thermal flash for padstack "PAD35CIR25D", regular pad used.
' F7 ^, v% T* X8 Y# t  p错误还在。。。
    2019-11-27 15:19
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    发表于 2014-7-11 14:02 | 只看该作者
    光绘里的undefined line width 的值设置的不对
    GMT+8, 2026-5-7 20:24 , Processed in 0.234375 second(s), 23 queries , Gzip On.
