TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
0 z% M7 \% X5 b% |" o/ W7 A( t3 u# f. u4 p; b7 K. G1 d1 n. j! Z
Features* b! ~ ]* k9 W. r: u
9V to 100V input voltage range
1 S( W% t1 S9 Y/ C$ m/ N6 p 1.5A/5A continuous output current
) X) j$ o; Z% O6 f9 D# B$ s 95% Peak Efficiency3 ?3 t% B2 z. |: n
400μA operating quiescent current: H+ d+ X% C) j+ c( V
100V 400-mΩ high-side MOSFET. _8 C5 R& A" ^' Y: K, P2 A: }
Peak Current mode control
* g# W. t# a6 g/ _5 j, O4 l 150 kHz Fixed Frequency
4 p- {: {$ g% m* J+ D Internal compensation for ease of use# B, v" P7 o2 N) k8 E8 u& V, a+ P' C
Up to 92% duty cycle
, C$ o3 w" |4 Q3 C$ }, g 0.8V voltage reference
2 d* d' ~. Z3 {9 Z. V 1μA shutdown current% O7 F" |* t4 ]
3A/6A cycle-by-cycle current limit( {3 x0 @' ] f$ V4 @* O7 A
150ms Hiccup mode short circuit protection
- X+ Q$ d A, O, uFunction
7 [2 Z8 u0 _4 @- [6 ~ Thermal shutdown Function; k; z) W& r5 l& l
ESOP-8 package4 e! W. e3 h0 u+ V# I
Applications5 U' L- N9 `0 Z
Charger in vehicle x S$ Y8 W2 T; u" z8 s
Battery Chargers( A& {$ b6 S" p4 r
Power adapter- S0 R. l- [# Q6 g- N3 b
Typical Application5 h6 ^% G8 I) P% t% x
Description
, r+ J$ R' I: g. g+ x, n( g$ EThe ZCC1005 is a high voltage, non-synchronous
1 C9 V/ ` e) o* n8 {step-down converter operates over a wide range6 R ~5 @8 g A. e' D
input voltage
+ @/ G6 z# ~2 _9V to 100V. The ZCC10058 }/ X+ p1 B @+ T5 k/ H* s$ d0 `# d
integrates a 100-V 400-mΩ high-side MOSFET.
- [$ |5 E" y, D! }, o _The ZCC1005 delivers 1.5A continuous load$ d4 }/ K0 w8 B) [+ q2 A! `/ `
current with up to 95% efficiency. The ZCC1005
$ g7 f4 B( j" R/ b" z, i0 Eoperates with fixed frequency peak current control6 f9 `1 ^: K% h7 N4 C# P
with built-in compensation eliminates the need for
/ G) x3 y' s: J3 c7 P8 n( O6 Pexternal components.% B1 W0 `& c. \% X/ j
Cycle-by-cycle current limit in high-side MOSFET1 ^# M. t) Y! o, E$ x1 |/ J
protects the converter in an overload condition.
2 X. c \# p% L) V1 hHiccup mode protection is triggered if the
) Q, v; P6 v" O- o1 W8 Gover-current condition has persisted for longer than9 y4 A9 F' x9 y, m* t4 H8 j
the present time.5 i- ^3 t$ H2 o" M E9 c
The ZCC1005 exhibits protection features that
% p6 w4 y, W8 t( }' qprotect the load from faults like under-voltage,5 D, ?# ~( ^+ m0 @1 P S
over-current and over-temperature.% N/ {+ M1 T0 X8 c" b
The ZCC1005 is available in an ESOP-8 package.# {! B$ T, ^, E) _3 N" p
