查看: 357|回复: 1
ZCC1001E 100V 1A降压芯片 V1.1
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-11-18 17:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    本帖最后由 Heaven_1 于 2022-11-18 18:09 编辑 2 t2 w- p/ w' S+ B- k- `
    ( ~8 S3 ^. K3 U0 E
    Features
      l! k9 C% X9 K2 F, _0 p2 K 9V to 100V input voltage range' c. p! m* Q6 P6 G/ ?
     1.5A current limit$ a3 ^  I0 y2 C5 p1 k5 H1 m
     1A continuous load current
    6 s% p+ f6 Y9 W 95% Peak Efficiency
    $ p  Z% S, M4 ?; ^8 w/ {2 o# B 400μA operating quiescent current) P. W8 v  A: ]+ g- k) \  ]
     120V 400-mΩ high-side MOSFET
    $ M/ i; w! k8 X4 s0 c Peak Current mode control
    : q( H" _2 \" V; ` 150 kHz Fixed Frequency
    0 N+ q" i$ q& ` Internal compensation for ease of use  \7 a% i, k) }( h/ W
     Up to 92% duty cycle
    . e4 k8 G6 @! h' d4 G, D 0.8V voltage reference
    " y: S; R& i, n 1μA shutdown current/ _$ Q2 Z* }1 c! K) B8 F1 A
     150ms Hiccup mode short circuit protection  V8 h# A5 Y5 _0 E7 u5 l$ G
    Function
    3 b3 G$ ], v; C& i5 T  C$ \ Thermal shutdown Function
    + V8 v) e7 N7 j% q ESOP-8 package
    7 ]6 ]" G4 V% p# d8 ^Applications4 j7 \" E; |' ~6 e6 C: U
     Charger in vehicle
    3 D% M/ [, V0 H' Z4 b  o Battery Chargers
    # y( d$ g5 ~5 t. n& |3 E Power adapter( I) b7 G7 Q6 L: G' K' \" q, `: p
    Typical Application
    ; q& U. Z9 T$ TDescription( h$ ]( A9 k9 b2 d. u1 z7 G% G
    The ZCC1001E is a high voltage, non-synchronous
    5 s' ^: D% s. p+ ~/ fstep-down converter operates over a wide range, _. ~1 d. V2 `
    input voltage 9V to 100V. The ZCC1001E" g4 f1 T+ w( S: n$ d
    integrates a 120-V 400-mΩ high-side MOSFET., H' K( K( v% F' n2 a
    The ZCC1001E delivers 1A continuous load2 [8 z+ z6 N# a  q2 ^
    current with up to 95% efficiency. The ZCC1001E
    6 {. ?7 u7 X8 Koperates with fixed frequency peak current control. C% n+ K' r" _* W
    with built-in compensation eliminates the need for
    8 a5 w+ N. B; i; Gexternal components.
    ( e5 u& K+ `0 r/ N  S, tCycle-by-cycle current limit in high-side MOSFET
    ( b) [4 a% j+ T2 Z3 d( s" Wprotects the converter in an overload condition.0 \, r8 a1 i1 C( o  S2 e6 \( B
    Hiccup mode protection is triggered if the over
    ; i( P8 a3 t. m6 I3 Wcurrent condition has persisted for longer than the
    5 k7 A0 G" {1 t" i9 X6 Lpresent time.
    - R8 U+ P; M" i* [/ zThe ZCC1001E exhibits protection features that1 e3 [% s* x- `* W$ z
    protect the load from faults like under-voltage,
    # b9 ~* q6 ]7 y) [1 L9 c' y9 uover-current and over-temperature." O' }+ L3 A  @0 F6 [
    The ZCC1001E is available in an ESOP-8 package.8 W: |1 u' o- @  S6 U1 T& d0 X
    2022-1-29 15:03
    发表于 2022-11-18 18:34 | 只看该作者
    芯片的输入范围电压范围是9V至100V。
    GMT+8, 2025-10-12 00:29 , Processed in 0.125000 second(s), 23 queries , Gzip On.
