查看: 1049|回复: 6
求助,光绘输出报错,之前一直好的,突然报错
发表于 2022-11-10 09:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
SUMMARY:    *** ERROR with TOP        LAYER2 created with warnings        LAYER3 created with warnings        LAYER4 created with warnings        LAYER5 created.        LAYER6 created.        LAYER7 created with warnings        LAYER8 created with warnings        LAYER_9 created with warnings        BOTTOM created with warnings        OSP_BOT created.        OSP_TOP created.        OUTLINE created.        NCDRILL created with warnings        PASTEMASK_BOT created.        PASTEMASK_TOP created.        SILKSCREEN_BOT created.        SILKSCREEN_TOP created.        SOLDERMASK_BOT created.        SOLDERMASK_TOP created.        Assembly_TOP created.        Assembly_BOT created. ARTWORK Error
4 g- @6 I( w1 c: ?
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    推荐
    发表于 2022-11-10 17:27 | 只看该作者
    把光绘设置中Top层的这个参数设置一下
    . Y; T6 g2 i& e0 p/ ~" x& O$ k! ]0 h ) w7 E1 U2 r' {
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2022-11-10 10:09 | 只看该作者
    *** ERROR with TOP
    % u, u* Z0 Y9 Q+ S* Z检查一下报告中Top层的出错信息
     楼主| 发表于 2022-11-10 10:49 | 只看该作者
    WARNING: Film contains objects with associated DRCs (41).! z% v9 g4 b4 {2 U8 B: W
               In the design editor view this film and enable visibility for the
    , E3 O) k6 B, q! p           associated DRC layer. Verify the DRCs are approved exceptions to your rules.9 ~! L" \( ]& g
    ( s/ S8 w+ c8 Y% b# j    ERROR: aborting film - rectangle or unfilled shape composed 0 width line found at (146.4618 106.0169) in MM
    + Z4 K/ }0 c  h- q4 P           ... ignored.
    ! }3 X2 g' g3 F% X" b* y# R* p# [& e( e4 Y* I: |) v  A0 }$ j/ ?
    5 J: I4 d& H- P( S' }
        ERROR: aborting film - rectangle or unfilled shape having Multiple 0 width lines; all will be treated the same as the first.
    / H4 s0 j! r: n4 e$ r3 o* c           ... ignored.% W3 U& m2 C8 V+ G6 E; z
      o$ k- M5 e: ~6 o2 M: d8 K
    , d9 O* `$ P/ ]4 m) _# X8 k+ o, z    ERROR: aborting film - 0 width line found at (149.2618 66.6919) in MM) V. q, W( u4 [; U' a5 O" |
               ... ignored.2 _9 L1 O; ^/ Y! A% }$ W
    6 F# D2 d# S6 n, ^6 a
    & l8 u+ [" F' a7 ~4 |: N    ERROR: aborting film - Multiple 0 width lines; all will be treated the same as the first.
    5 g! P$ O& E, u1 o6 }4 d           ... ignored.
    , o1 V, S2 X& A& F$ V, u% V2 N# y6 T3 f9 R
        WARNING: Segment with same start and end points at4 ~. X" U: j7 @0 ?% Q
            (159.5413 112.8136) will be ignored. Increasing output% V% L/ _2 l/ N2 u; f, e
            accuracy may allow segment to be generated.) U' c* L8 o# R# Q% k4 ]* L( v
    & w* D( i& c1 ]$ |! V( G
        WARNING: Segment with same start and end points at$ r) j( Y5 T3 p- B1 o* E2 ?
            (160.1123 117.9824) will be ignored. Increasing output5 U8 g7 i* A+ T1 P. W1 F
    / I& f$ b1 q' L6 ?! i7 D/ e
    3 K! u( x6 W6 h: ~2 s2 t/ h  @6 ~% {    WARNING: Segment with same start and end points at" a6 u+ E) r- P" l! B
            (160.6123 118.2824) will be ignored. Increasing output
    ! V2 S) V: X  L7 U        accuracy may allow segment to be generated.
    " [# X* i8 C/ d% x
    + W; p) n; R8 }) n  ?* e) N    WARNING: Segment with same start and end points at
    ( k* R+ m6 Y$ ?, k7 m/ ~        (174.1355 117.6421) will be ignored. Increasing output1 V1 X' m: m, J. N% `0 P  k# M1 D
    8 e/ h5 g% e% ^1 s- ~% y1 C; N
    5 N( P1 O8 K; {! y9 N    WARNING: Segment with same start and end points at
    4 U+ R! |0 g/ t3 L& m' l        (193.4005 81.1726) will be ignored. Increasing output
    . [, L9 d( e* p( I4 p. X. o) F        accuracy may allow segment to be generated., p; V: o9 L' K$ E7 m3 u2 c
    2 H: E9 P; S1 A+ n; A- j: a/ m
    5 A2 M3 P/ g1 h9 f# I* n) m7 U        (197.9899 26.5434) will be ignored. Increasing output
    4 B, v- T, G* c# z# [/ ^        accuracy may allow segment to be generated.
    # g9 Q9 F6 b7 S; W5 o6 m# V1 s" E* `+ o8 ?/ c' ^% [
    : D% e4 N7 @9 `- w( O# R        (169.4665 132.6690) will be ignored. Increasing output
    6 g. I  [& H. ]/ ?& E$ {        accuracy may allow segment to be generated.; a7 H* [' S  ~! }  F
    郁闷
    2024-9-11 15:25
  • 签到天数: 82 天
    [LV.6]常住居民II
    发表于 2022-11-10 11:47 | 只看该作者
    你是不是中间修改的单位,然后精度没有最后调整到和以前一致。
    无聊
    2025-9-10 15:21
  • 签到天数: 123 天
    [LV.7]常住居民III
    发表于 2022-11-10 15:55 | 只看该作者
    database check
    目前应急找到的措施是,光绘定义线宽  详情 回复 发表于 2022-12-1 14:49
     楼主| 发表于 2022-12-1 14:49 | 只看该作者
    sdtgh 发表于 2022-11-10 15:55
    . R  l% {6 d+ n9 ?/ T, u. r/ T" Udatabase check
      C8 ]3 [6 y5 w; P6 b4 Y* o* @& Z
    目前应急找到的措施是,光绘定义线宽
    ) |2 P& q5 B( S0 s+ d
    GMT+8, 2025-11-5 18:49 , Processed in 0.171875 second(s), 29 queries , Gzip On.
