TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features+ d1 s ?* Z8 v' ]
9V to 100V input voltage range
; d6 }: Q v1 K/ n! j* h" T' h; i 1.5A current limit! ?* e# T4 v j% y$ T- D! Y& ^
1A continuous load current+ L$ c& e4 @$ K: `0 C1 U+ M/ F
95% Peak Efficiency7 O9 Z& }/ x9 {4 |9 O! M* Z/ p
400μA operating quiescent current& E8 ^0 I+ L( R. c- O" W9 c f
120V 400-mΩ high-side MOSFET
. m5 M! J- w: J Peak Current mode control
7 M% v+ ?9 J" r+ _& D: a 150 kHz Fixed Frequency
0 g6 J3 Y6 r* z1 W4 g, o' a2 ~ Internal compensation for ease of use- N1 s9 i5 E7 E. _8 N' o
Up to 92% duty cycle
B$ a8 ~' z$ d/ [) Y! K 0.8V voltage reference; W7 m( q; h9 E8 F4 r5 n! ~
1μA shutdown current6 u1 I* B }9 n' a1 f# m: I
150ms Hiccup mode short circuit protection
# z: A8 |3 L/ M& `Function: K# Z' T* F5 X
Thermal shutdown Function
, s# h# d7 D y0 q& O ESOP-8 package% x+ m- x" S& t" e! G- C
Applications2 J5 [ [1 F! O, E m! V
Charger in vehicle
) F# |7 G7 ~" F Battery Chargers' r3 w; N$ G# V8 q# j: c& |3 t
Power adapter
- v- d! n: X: ?# P. X* f- M7 i& K+ qTypical Application+ C7 b9 F! ~& Q! i0 {
Description
! p% n! E( c* m- WThe ZCC1001E is a high voltage, non-synchronous
5 X( S+ x7 M* a* ?# V2 Y4 estep-down converter operates over a wide range$ `2 s7 j! ^. h6 D A% y
input voltage 9V to 100V. The ZCC1001E
- f7 f$ p: o/ j- i4 f7 D$ aintegrates a 120-V 400-mΩ high-side MOSFET.
( N- N' c3 N: R' cThe ZCC1001E delivers 1A continuous load' p7 O4 r6 S' c: Q$ P2 y
current with up to 95% efficiency. The ZCC1001E
' g. Q8 E6 z5 X; C) {operates with fixed frequency peak current control7 Y5 }$ E7 u% w# a
with built-in compensation eliminates the need for
n# d9 m* h/ qexternal components.6 R- E9 R# x5 G Z
Cycle-by-cycle current limit in high-side MOSFET
4 c& Z1 _" S6 w3 b4 m; `) pprotects the converter in an overload condition./ P3 W' p5 g! k. c4 `
Hiccup mode protection is triggered if the over
" `! M" O9 B0 L- _8 ?current condition has persisted for longer than the
6 U# Y& n% W% bpresent time.( f1 i" n6 F* \, p! ?+ `8 }8 \4 g
The ZCC1001E exhibits protection features that/ I L2 U! u0 ~4 N0 x
protect the load from faults like under-voltage,
6 G, `: x0 [$ k2 z: Q6 T0 G( Aover-current and over-temperature.
" P* h# ]) `. H, @: l% k) yThe ZCC1001E is available in an ESOP-8 package.
( U% B2 x. b; L9 Q- Z. e, [5 s1 E. k |
