我是用capture作的原理图,在开始画板后,在allegro添加了四个定位孔,定义了这四个孔的参考名M1-4,封装(MTG240_600),引脚(pin number=1)又给它们GND的网络属性。5 ]; G9 q/ T! J) p5 Q! O8 S
. [2 l% M# \2 K5 m
现在板子画完了,我想backannotate回去到capture 里看看,结果我在capture 里的SWAP报告如下:
/ D+ K# V0 b% A& g& g5 B9 q#99 No library part exists for COMP_DEVICE_TYPE=MTG240_600, please add Design Entry HDL Component in Allegro SI.
( d" V6 m4 ^ @- ]- t% w [ Line Number: 4/ g5 q0 ]2 ]( i: J( G
) S4 K Y. {* t% n2 c, V+ W7 E% W Line Number: 59 J9 } ~) J) J$ P
#99 No library part exists for COMP_DEVICE_TYPE=MTG240_600, please add Design Entry HDL Component in Allegro SI.9 `5 `3 C$ K" S- a; W; ~
Line Number: 6/ w% \" ?) @$ R/ H" v# R) G
, A3 i1 @3 }# o Line Number: 7; F! u/ y7 B3 L1 i, t( U: q6 s& ~' x
#1 Error [ALG0037] Unable to read physical netlist data.6 f6 U8 C' J2 A4 x
#2 Aborting Swap file creation... Please correct the above errors and retry.5 Z5 h' C/ K6 l$ {: u" i8 {8 [# `: Y) t7 X
下面是我的其中一个定位孔的element2 W, D. q2 o" l0 c0 y- j: y; |
pin number: MTG1.1
4 a& N, p. L8 `6 K: Q! y Y pinuse: UNSPEC# w4 F+ M1 o4 _; E) i: T6 Z: @8 e1 N+ s
`5 v0 D, K! a( O; u location-xy: (-48.3870 35.8140)
: W* s' r% K; W1 K2 M4 P1 R part of net name: GND
! L+ x3 u7 _& }5 K, @7 O
- _3 t; Z( w; q1 d Connected lines: 1 ( BOTTOM ). g: W9 e5 ]' U2 P) e, @
Connected shapes: 2 ( TOP BOTTOM )
) q6 L( F h- p9 N
" {7 e% E) l; ]8 ~( V padstack name: PAD_MTG240_6006 s- J y9 }8 }1 S
; j; ?* Q9 O- w0 w0 v7 u padstack defined from TOP to BOTTOM
1 d4 t! n7 o: s padstack rotation: 0.000 degrees
6 B- J$ l& _* Q }$ K+ f1 w7 v& \! d" J2 x T6 T! ?. C
Attached text:9 @3 e2 g2 L4 M3 ?+ o ^) V" H
class = PACKAGE GEOMETRY
/ O( z" s6 ^2 z x" g" o# |) f6 r subclass = PIN_NUMBER, ?1 o8 N8 `/ I/ B
value = 1 _5 Z( I1 P; c4 x
不知道capture里面这个错误该怎么办。这四个定位孔在原来的原理图里是没有的,也不具备网络属性,我直接在allegro给加上的。 S2 Q2 T9 ~& h$ o
$ s& ]! }) s3 T
[ Last edited by jasonzou at 2008-6-28 20:21 ] |
