查看: 202|回复: 1
同步升压双节锂电池充电芯片带NTC-ZCC6982
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-10-9 18:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    ; Z8 n+ f6 s9 D6 L+ ^. g! V+ R6 ^
    6 ]- K* L; u' M$ ]) }特性
    , A9 n( f+ z/ t7 H) v4 ]■ 3.0V to 5.5V Operating Input Voltage' l/ O8 e6 [$ b
    ■ Up to 26V Sustainable Voltage
    * k+ d" t% F, Z) ?5 |9 n■ Up to 2A Configurable Charge Current for Battery0 k. `, j; h% H
    with 2 Cells in Series+ L. @! O% ^; d* [7 H* \; G) M
    ■ Configurable Input Voltage Limit. V( U* F' F/ Y" q) |6 g: _* a4 l
    ■ Charge Status Indication
    0 W( H6 S* e5 v, A1 j■ Constant Voltage Selectable
    9 J( s# ^, Q8 D( I4 a! y■ Programmable Charge Timeout
    ! r$ l  y9 P3 V2 s6 @■ Thermal Regulation Protection
    9 `! k4 B# v0 ^/ i2 Z/ O■ External Shutdown Function. c% F$ j* a6 c- s
    ■ Input Voltage UVLO and OVP
      [, B- u3 c7 s& \+ |( D; g2 N■ Over Temperature Protection+ l) H8 P+ J& q' ?. I
    ■ Output Short Cir cuit Protec tion Normal
    - g! q& j' y6 w5 ASynchronous Boost Operation When Battery
    " h4 u/ p7 R. r3 v! N% CRemoved4 u) K  Q+ n/ O# x2 Z7 O. R
    应用
    ' P8 S0 z: k0 h; R, P4 F8 i. H* k■ Power Bank1 j! p2 }1 i" r0 F' u- t* @
    ■ Cellular Telephones,MP3Players,MP4 Players
      p! `; z8 [! J! {2 |, ~■ PSP Game Players,NDS game Players
    ; l; o9 E7 r2 i: t■ Notebook
    + \0 {1 t5 E* Q描述
    ' c( g2 m5 l) h, H, [* ?# @5 |* X8 EZCC6982 is a highly integrated synchronous boost
    3 A9 [; s: e% y' Rcharger IC for Lithium-ion batteries with four cells in
    3 o5 f# H5 e" S" }0 @2 g, tseries . The charge current up to 2A can be
    4 c6 ]; O0 X$ [& c. l4 L; vprogrammed by using the external resistor for different- ]" l1 q" O* f5 L' T
    portable applications.) O& I. Q3 V& U( ]
    Robust protections include input over-voltage
    : N2 D/ R  ^% ~2 Z  rprotection (OVP), battery OVP, battery short protection,
    5 b) C2 z7 ]8 U' w, F; Fthermal shut down, battery temperature monitor, a( Q: \6 \* Q3 ~
    configurable timer to prevent prolonged charging of a
    * A. J! w( s0 i# v/ [# X* ddead battery.
    " {# ?6 V1 z3 v( V3 w
    发表于 2022-10-10 15:43 | 只看该作者
    主要适用于哪些领域
    7 F3 I$ C( b8 H% Y
    GMT+8, 2025-10-11 23:51 , Processed in 0.140625 second(s), 23 queries , Gzip On.
