查看: 229|回复: 1
ZCC5160 同步降压 60V 3A
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-10-8 18:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    本帖最后由 Heaven_1 于 2022-10-8 18:31 编辑 - a, I% b+ j0 s5 O
    $ k, P4 Y2 {4 a7 y9 N# S2 j  YFeatures$ |( y' F* P! Y: p3 U6 h; q1 m1 a
    & b/ z# m. v% E2 Y& }2 z
    20-μA Quiescent current in regulation
    ) R# b# C5 C# c# h+ A6 w  X% V' H+ i8 N  l3 x& y; o: x  k
    Input voltage range: 4V-60V) T1 ^# f' Y8 @" _! ?, y! s* }
    ; A" N, k, T3 `) O
    Output voltage range: 1V-VIN: J4 A3 m7 T0 \* @2 p' ~
    3 _% {2 ]& Y1 F, K$ m# Z
    Integrated upper and lower power MOSFET* u8 E% X. r( `1 o2 t6 ~: _
    maximum current: 5A/ [; ^7 P9 E+ u" d2 T
    : z3 M# {# [5 }, }1 R4 b
    Adjustable frequency range: 200KHz~2MHz
    ' j/ C+ P( Q6 N; |4 Q# P/ g0 e( A; O* _& C" \, ?$ h' t- H
    Automatic switching of CCM/DCM/PFM mode- l. R: E( z/ Z, f( F8 q" R. s$ k
    & ^2 v6 m5 z+ M+ _' g! O5 p" o0 l, Z, ?
    Adjustable soft-start time and Output voltage/ D$ H' B8 U2 B8 s
    tracking capability- T0 A0 Y/ b" Q9 i" @+ c, W# `) i
    1 p: Y; n/ S( q$ R8 T4 H, mAutomatically switched bypass linear power
    % \0 T7 K! T9 n3 Nsupply+ v2 u  A* J, d6 n; s
    9 T3 j5 s  x, z9 |/ `Provides ultra-low input and output dropout
    4 S& }& W7 T  z+ u8 m1 gvoltage close to 100% duty cycle
    & B2 W1 g( G' d9 R+ d
    . f* s/ H5 `) w# IInternal Compensation) j( s. z" o/ y* @8 F( @0 ~
    ) W; g5 ?: F& _4 P/ X4 x1 c8 i
    Power-good flag
    6 u+ e* N+ O. L7 `3 J+ s6 j7 k* ?
    + i( B$ w$ |9 s. FDynamic Frequency Stretch Technology2 {+ \' W( V+ T0 C
      W4 `) t+ V) P! `: y! T
    Support large capacitive load start-up
    ( E& y& N5 p1 q( L" t* ~. x2 Y1 m. I8 I6 V, l0 |/ g3 I' H
    Protection function: UVLO/OCP/SCP/OTP/OVP
    , N' p2 h# C5 e. w6 w
    : z8 a) Q& R# n; G+ oOperating junction temperature range: -40℃ to
    % e4 H. o6 p" l: ~8 n+125℃* Z2 X* _  ^6 {/ f
    " e, v. F- D) R4 [$ N, a8 A4 U$ W
    All pins have ±2000V (HBM) ESD protection0 y( K- q7 K3 _, Y. _8 |
    " q7 r# Z3 t$ J) UETSSOP 16-Pin Exposed Pad Package: a9 h: s- k) f/ ~2 b% F- a
    Applications4 V4 \- D' u, f$ G! }
    % U+ A2 K1 Z% z# W# S/ j
    Industrial power supply
    3 b- M9 a# X# ?; ]& a4 a. i. ^9 S' b' s/ j" y" B% ?
    Wide voltage input range power supply
    * C0 Y0 j4 y9 c; K* j5 v6 x3 h9 f7 Y& M9 x% i. g
    Low ripple low noise power supply
      l0 S* c4 q! B+ Y; k1 h7 p" ]) R. j  i( [
    Automotive electronic power supply* W6 c+ f* k, Q. w2 C( K5 O  E
    Figure. 1 Typical Application Circuit: A2 |& K- G  f* p9 y
    Description
    7 [3 a% l7 J, E9 vZCC5160 is a step-down DC/DC regulator with an
    7 S3 a% L- H/ j6 Yinternal switch, featuring SKIP control mode, which) r- K3 R$ j5 @' c# j  O
    combines low quiescent current with high switching
    2 b; |2 n/ x" N. Dfrequency to achieve high-efficiency regulation over a
    9 l+ E; `' N9 V  \0 \9 Gwide range of load currents. SKIP mode uses a short
    1 T$ }- k* Z. |"burst" cycle to switch the inductor current through0 G1 U: k  y; F; r- t
    the internal power MOSFET, followed by a sleep$ V9 E7 f. \( N, f) o
    cycle in which the power switch is turned off and the, J6 @9 w  _% X9 I+ ]
    load current is provided by the output capacitor. At
    - x6 k5 D3 c7 g. y) p* C7 d# Wlight loads, burst cycles are a small fraction of the
    + v: l; }7 N* c; e3 F, ototal cycle time, minimizing average supply current
    5 v& I* e' h& G5 v/ x8 W8 N0 ]1 `and greatly improving efficiency at light loads.) f1 V9 Z6 A5 n% o3 }; q+ i
    ZCC5160 has a wide input voltage range of 4V-60V,1 x$ M: D! U/ P( _5 R" u
    thus minimizing the need for external surge
    ' Q5 l( X8 L7 Z8 _suppression components. Making it the best choice2 l1 t* Q+ a6 e: u, x6 N
    for wide input power range industrial and high cell
    9 Z/ K! L, ]' y$ y& [7 {count battery pack applications. ZCC5160 is ideal for
    & G0 O2 z# a3 v8 C, d' c8 Duse in the 48V automotive power bus range.+ `+ f. z% ?% c. ~% P3 W
    ZCC5160 features low-value 100mΩ high-side and
    : o9 W8 k5 p, i0 q+ _80mΩ low-side MOSFET that provide at least 3A
    % W$ H  R3 N* g5 L+ o) h# M! ^output current capability with excellent load and line( [- V+ r+ N+ s5 ]/ q9 d
    transient response.: |, e! ~8 n1 r. e- P- ^5 @
    Additional features include: soft-start, thermal3 \, n( [) N' w0 T  `
    shutdown, UVLO undervoltage lockout, gate driver+ l! h3 s1 ]. V6 h& n0 I
    undervoltage lockout, maximum duty cycle limit timer,
    $ m9 K9 e2 t8 ~, w$ `: }% T2 dand current limit shutdown timer. It also integrates
    3 I3 K  s& j; W, R# h) _output short-circuit protection, providing HICCUP
    / @6 G$ k; l: E! v7 mmode when the FB voltage is low to avoid  w2 [+ l0 |. O. N( q2 C9 y
    overheating during short-circuit." J; `; }' X' O' _
    发表于 2022-10-8 18:32 | 只看该作者
    ■ZCC5160 是一款带内部开关的降压DC/DC稳压器,具备SKIP控制模式,将低静态电流与高开关频率相结合,可在广泛的负载电流范围内实现高效率的稳压。SKIP模式使用短的“突发”周期通过内部功率MOSFET切换电感电流,然后是休眠周期,在休眠周期中,电源开关关闭,负载电流由输出电容器提供。在轻负载时,突发周期占总周期时间的一小部分,使平均电源电流最小化,大大提高了轻负载时的效率。
    GMT+8, 2025-10-12 05:48 , Processed in 0.125000 second(s), 23 queries , Gzip On.
