查看: 261|回复: 1
3节锂电池同步升压充电芯片ZCC6983
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-9-29 16:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    特性
    3 N. m; L* L: K. k9 w■ 3.0V to 9V Operating Input Voltage4 U* g9 g: h* \* T
    ■ Up to 26V Sustainable Voltage
    " b2 e9 d" k! s■ Up to 1A Configurable Charge Current for Battery2 n: I  I" S7 y, ]3 [
    with 3 Cells in Series: \& b- Y0 m& L0 L- \5 u! x" _
    ■ Configurable Input Voltage Limit
    ' r2 u2 O  _+ G4 `- e■ Charge Status Indication) v/ x3 d, m- [& A; B
    ■ Constant Voltage Selectable
    0 w9 U7 i: b; b0 W■ Programmable Charge Timeout+ H$ D. J2 J# Q5 R* f7 H$ m0 F
    ■ Thermal Regulation Protection. z  l1 }4 _  J
    ■ External Shutdown Function
    9 q. D3 Y, d( ]" h& V" z2 @■ Input Voltage UVLO and OVP/ R+ o' q3 k/ v9 @+ P+ d
    ■ Over Temperature Protection
    + M9 ?8 M, Y. ]* _8 d% W5 x) I  ?+ o■ Output Short Cir cuit Protec tion Normal$ u$ ~- p7 _& [$ ?) v* E2 t5 ^
    Synchronous Boost Operation When Battery
    8 c) M# l7 g: I9 CRemoved
      T' u  M/ E) z5 C9 w  t: y! t; a应用- Z+ Q: ~' U+ c' l  W
    ■ Power Bank7 r# L7 L: M' k4 \- ^: J: s
    ■ Cellular Telephones,MP3Players,MP4 Players
      }9 z/ S8 D  B) q/ X' ~& u+ Q# s■ PSP Game Players,NDS game Players7 Z3 m' p% _  L- S) B
    ■ Notebook
    6 R! k6 n" L! I+ E描述5 w7 C, T. d3 d3 {  h* v
    ZCC6983 is a highly integrated synchronous boost
    9 U6 |1 f0 }. l8 Zcharger IC for Lithium-ion batteries with four cells in9 j5 o& K2 G/ |7 V- [) t4 ^2 ^
    series . The charge current up to 2A can be
    ; k+ u: Y' G& N# }( Z/ Vprogrammed by using the external resistor for different8 E0 V* Y+ J! M$ ~
    portable applications.
    3 Z  u% X1 [( f) F0 l5 {Robust protections include input over-voltage
    ) W/ g* `8 K6 E5 v" i) P! ]protection (OVP), battery OVP, battery short protection,
    ' f! z/ `% P; e! ~' b1 H) {2 F2 rthermal shut down, battery temperature monitor, a- O$ K$ s( e" Y5 u9 l" r  x, q
    configurable timer to prevent prolonged charging of a+ G$ A" F  i, z% e  ]
    dead battery.( ]! d' f: a- [* ?9 H# W
    发表于 2022-9-29 17:38 | 只看该作者
    3节电池串起来,不就升压了吗?还节约了一颗芯片。
    GMT+8, 2025-10-12 05:52 , Processed in 0.125000 second(s), 23 queries , Gzip On.
