查看: 213|回复: 1
100V 输入同步降压最大5A输出电流 ZCC1005
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-9-26 18:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    5 k7 p. T6 f7 k9 A: T& w( }* A- \
    Features
    * m8 V+ {/ Y& R8 O; L* H0 L 9V to 100V input voltage range5 B! k% O: \# ?- Z9 Z4 B( U
     1.5A/5A continuous output current8 r2 i: o$ y8 A- j! h# R. `% n
     95% Peak Efficiency
    1 E1 w* X5 X0 A/ `) N; x, d 400μA operating quiescent current
      U: Y% F! X: O: x$ G% r) o! a 100V 400-mΩ high-side MOSFET: F; m  t' D9 e! b
     Peak Current mode control2 x$ x6 `& t, t3 E3 d3 u8 i
     150 kHz Fixed Frequency5 ?1 |  U5 `! J5 U. }
     Internal compensation for ease of use# G* t4 Q* p% s% b5 {/ n) f
     Up to 92% duty cycle
    " c& U! q# X7 M! A 0.8V voltage reference
    ' P! x8 w7 [4 U3 ] 1μA shutdown current2 V$ s; \0 A' V; ~* e
     3A/6A cycle-by-cycle current limit; p" I$ e6 o1 v
     150ms Hiccup mode short circuit protection
    ! B, y) [4 w, x, @( p; }2 xFunction0 |5 ?. w4 W4 F# t
     Thermal shutdown Function
    , s7 ~/ l/ h. ^! Q: I ESOP-8 package
    9 H; x* w, t. A  v( ?7 ?Applications
    0 V. n$ N+ [& i' Y; K, U% z Charger in vehicle
    . [. e* v8 U& \/ _* f1 X" w Battery Chargers
    7 Z- @0 C. y7 \$ n9 y Power adapter1 ]& |4 k3 h/ P. m. e" n
    Typical Application+ }& n7 f, W1 g: o. t2 P1 Q9 C! r
    Description
    1 j6 s5 R, E4 z% t2 t5 ^  UThe ZCC1005 is a high voltage, non-synchronous) f  \3 X, V  [% n% v/ E( ]6 N
    step-down converter operates over a wide range
    $ s6 H& L  `4 Einput voltage" d& v* r6 B: W7 p
    9V to 100V. The ZCC1005
    ; H6 K5 m# u5 ]; E+ Dintegrates a 100-V 400-mΩ high-side MOSFET.
    3 |* w" t1 ~6 x. [# v3 XThe ZCC1005 delivers 1.5A continuous load" k- m* t  G4 c6 D0 y
    current with up to 95% efficiency. The ZCC10055 a) _+ Y9 j; b; q' H9 O3 b8 [+ S
    operates with fixed frequency peak current control
    " ?4 U- ?# v$ d! Gwith built-in compensation eliminates the need for- b7 K5 R' C! T9 y5 Q
    external components.
    ) n/ ]0 C. H6 B' F1 o9 rCycle-by-cycle current limit in high-side MOSFET
      t. d# f8 S' Uprotects the converter in an overload condition.
    7 v2 ~2 v6 a7 S" ]" ]Hiccup mode protection is triggered if the
    8 ~1 ~3 o) W9 v# cover-current condition has persisted for longer than
    / f" t6 W7 h9 ~1 w1 w# e2 Othe present time.
    / q6 Y9 W. l( g1 s$ UThe ZCC1005 exhibits protection features that
    4 D/ A" u  K  Z/ J4 H2 Xprotect the load from faults like under-voltage,9 X$ k- z. |4 a; A. [! u8 ], N0 g# l
    over-current and over-temperature.9 k1 @$ B7 P0 ?! P! L
    The ZCC1005 is available in an ESOP-8 package.
    7 A3 R" u2 `/ a
    发表于 2022-9-26 18:55 | 只看该作者
    这个主要可以替代哪些芯片,还有就是有没有相应的实物图呢?5 T" @" `4 d7 c9 V. P1 g
    GMT+8, 2025-10-12 03:33 , Processed in 0.125000 second(s), 23 queries , Gzip On.
