Wallys industrial 2x2 2.4G&5G router/QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax
We developed and designed the industrial router/industrial moudle/industrial antenna.
The chips are mainly Qualcomm and MTK.
At the same time provide customized services
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
| Rating | Unit | | 24V~48 | V | Operating Temperature Range | -40 to +70 | oC | Storage Temperature Range | -45 to +105 | oC | | 5 to +95 (non-condensing) | % |
Symbol | Parameter | CPU | Qualcomm-Atheros IPQ6010 | CPU Frequency | Quad-core ARM 64 bit A53 @1.8 GHz processor | System Memory | 1GB (2x 512MB) DDR3L 16-bit inteRFace with 32-bit memory bus design | Ethernet Port | 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port | NGFF Slot | M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0 | SD Card Slot | 1x SD Card Slot | USB /header | 1x USB 2.0 Port | POE | 24V~48V passive POE/Active POE(Suport 802.3bt) | DC Jack | 24V power supply | LED header | FFC/FPC Connector | Serial Port | 1x Serial Port 4 Pin Connector | Wireless | On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 4 x MMCX Connectors | | Bluetooth | optional | Nor Flash | 8-32MB(normally is 8MB) | Nand Flash | 256MB | DDR | 1GB
| Dimension | 185mm x 116mm |
| Radio TX Specifications(5180MHz-5825MHz) |
Operating Mode | Data Rate | Power | Tolerance | 1 Chain | 2 Chains | 5Ghz 802.11ax HE20 | MCS0 | 20dBm | 23dbm | ±2dB | MCS1 | 20dBm | 23dBm | ±2dB | MCS2 | 20dBm | 23dBm | ±2dB | MCS3 | 20dBm | 23dBm | ±2dB | MCS4 | 19dBm | 22dBm | ±2dB | MCS5 | 18dBm | 21dBm | ±2dB | MCS6 | 17dBm | 20dBm | ±2dB | MCS7 | 16dBm | 19dBm | ±2dB | MCS8 | 15dBm | 18dBm | ±2dB | MCS9 | 14dBm | 17dBm | ±2dB | MCS10 | 13dBm | 16dBm | ±2dB | MCS11 | 13dBm | 16dbm | ±2dB | 5Ghz 802.11ax HE400 | MCS0 | 20dBm | 23dbm | ±2dB | MCS1 | 20dBm | 23dBm | ±2dB | MCS2 | 20dBm | 23dBm | ±2dB | MCS3 | 20dBm | 23dBm | ±2dB | MCS4 | 19dBm | 22dBm | ±2dB | MCS5 | 18dBm | 21dBm | ±2dB | MCS6 | 17dBm | 20dBm | ±2dB | MCS7 | 16dBm | 19dBm | ±2dB | MCS8 | 15dBm | 18dBm | ±2dB | MCS9 | 14dBm | 17dBm | ±2dB | MCS10 | 13dBm | 16dBm | ±2dB | MCS11 | 13dBm | 16dbm | ±2dB | 5Ghz 802.11ax HE80 | MCS0 | 20dBm | 23dbm | ±2dB | MCS1 | 20dBm | 23dBm | ±2dB | MCS2 | 20dBm | 23dBm | ±2dB | MCS3 | 20dBm | 23dBm | ±2dB | MCS4 | 19dBm | 22dBm | ±2dB | MCS5 | 18dBm | 21dBm | ±2dB | MCS6 | 17dBm | 20dBm | ±2dB | MCS7 | 16dBm | 19dBm | ±2dB | MCS8 | 15dBm | 18dBm | ±2dB | MCS9 | 14dBm | 17dBm | ±2dB | MCS10 | 13dBm | 16dBm | ±2dB | MCS11 | 13dBm | 16dbm | ±2dB |
Since its inception in 2010, Wallys has had a strong team, including dozens of research and development personnel, a complete set of assembly lines, they play an irreplaceable role. Under the premise of ensuring the product quality, we will deliver the goods at the fastest speed and maximize the product benefit. We are trustworthy, trust us, choose us! Wallys provides all services from r&d, design to production and post-maintenance. There can be a buyout or an unbuyout mode. China has a complete wireless communication industry group, which enables ODM manufacturers to obtain the supply of low-cost components. Years of reform and opening-up have made China an ideal low-cost manufacturing base. Compared with the rapid development of the market, ODM services which focus more on design capability and production experience become more competitive.
