查看: 200|回复: 1
Wallys industrial wifi5 router/IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5G
    2023-2-7 15:43
    发表于 2022-9-21 17:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    APPLICATIONS
    Profi WiFi hotspot coverage
    Commercial radio coverage
    Hotel Wireless application
    Country coverage
    Internet for passengers (bus, train, plane, …)
    Security Surveillance
    Some special scene application
    Featuring with industrial-grade IPQ4019/IPQ4029 chipset
    Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
    Support 4.940GHz to 5.825GHz Frequency Range
    Support 2.400GHz to 2.482GHz
    Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
    Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
    Support 11ABGN/AC
    Support fixed data rate
    RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
    Our Firmware supports all the modules of Quectel
      Absolute Maximum Rating
      Parameter
      Rating
      Unit
      Supply Voltage
      24V~48
      V
      Operating Temperature Range
      -40 to +70
      oC
      Storage Temperature Range
      -45 to +105
      oC
      Operating Humidity Range
      5 to +95 (non-condensing)
      Storage Humidity Range
      0 to +90 (non-condensing)
      Hardware Specifications
      Symbol
      Parameter
      CPU
      IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
      Antenna Connector
      2 x 5G MMCX connectors;2x2.4G MMCX
      10/100/1000Mbps Gigabit Ethernet
      2xRJ45
      SFP connector
      1xSFP fiber module connector (optional)
      3G/4G connector
      1xminipcie 3G/4G connector support with two sim card
      USB connector
      1xUSB 3.0 connector
      POE
      24V~48V passive POE
      DC Jack
      24V~48V power supply
      ROHS Compliance
      YES
      Dimension
      115mm x 105mm x 16mm
      Max Power
      48.1V x 0.180A= 8.658W
      Nor Flash
      2MB~32MB
      Nand Flash
      128MB
      DDR
      256MB~512MB
      Radio TX Specifications(5180MHz-5825MHz)
      Operating Mode
      Data Rate
      Power
      Tolerance
      1 Chain
      2 Chains
      802.11a
      6 Mbps
      27dBm
      30dbm
      ±2dB
      54 Mbps
      23dBm
      26dbm
      ±2dB
      802.11n HT20
      MCS0, MCS8
      26dBm
      29dbm
      ±2dB
      MCS7, MCS15
      22dBm
      25dbm
      ±2dB
      802.11n HT40
      MCS0, MCS8
      25dBm
      28dbm
      ±2dB
      MCS7, MCS15
      21dBm
      24dbm
      ±2dB
      802.11ac
      MCS0, MCS10,MCS20
      25dBm
      28dbm
      ±2dB
      MCS9,MCS19,MCS29
      19dBm
      22dbm
      ±2dB
      Radio RX Specifications(5180MHz-5825MHz)
      Operating Mode
      Data Rate
      Sensitivity
      802.11a
      6 Mbps
      -96dBm
      54 Mbps
      -78dBm
      802.11n HT20
      MCS0, MCS8
      -93dBm
      MCS7, MCS15
      -73dBm
      802.11n HT40
      MCS0, MCS8
      -90dBm
      MCS7, MCS15
      -70dBm
      802.11AC HT40
      MCS0, MCS10,MCS20
      -90dBm
      MCS9,MCS19,MCS29
      -67dBm
      802.11AC HT80
      MCS0, MCS10,MCS20
      -88dBm
      MCS9,MCS19,MCS29
      -62dBm
    Stable networks guarantee for the ongoing continuity of your video surveillance. Our boards could establish a stable connected wireless environment which is critical for a security surveillance system.
    Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We’re a supplier to Facebook.
    发表于 2022-9-21 17:56 | 只看该作者
    有没有中文呀
    GMT+8, 2025-11-6 11:20 , Processed in 0.156250 second(s), 26 queries , Gzip On.
