 本帖最后由 yulizi 于 2011-12-22 11:18 编辑 0 e, d, ], }% f+ @8 [: x
  r( q& _* ]: e, z
http://kuai.xunlei.com/d/DGOHIFKLICUP
+ X& b4 _  y+ B) g/ Q  N* k: }* [$ A0 b# K3 m6 ]4 S$ ]
. T1 |2 u; _1 ]$ v3 sDATE: 12-16-2011   HOTFIX VERSION: 013
4 Z3 @% F2 d) Y3 p, a===================================================================================================================================3 a- b/ y+ n9 `* b1 V6 l+ c9 k$ a
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
( V& D& O  ?8 S; H# }, t===================================================================================================================================- W4 q8 S* T( z: r) Y1 U
875695  SIG_EXPLORER   INTERACTIV       Enforce Causality check box doesn't work.
4 A8 }  b& `/ M- w9 u927148  CAPTURE        PROJECT_MANAGER  Capture crashes on creating scehmatic folder with name which already exists in design, R% g! G/ N! U5 ^
938013  CAPTURE        NETLIST_OTHER    The netlist in RINF Format contained two identical lines for PCB FOOTPRINT* Z  c; _+ J9 e) l# [$ T( V
941409  Pspice         PROBE            BUG : Search accuracy wrong in new cursor window2 c% \$ ?3 ~4 d! g' [) B/ z% r
945242  SIG_INTEGRITY  SIMULATION       Unable to select "shapes" in find filter for 'show parasitic ' command; }  y- F+ s; p/ x5 s
946293  concept_HDL    ARCHIVER         Archiver hangs if there is a whitespace at the end of the path of cref.dat
1 x& I3 D6 j9 @& U- |946770  CONCEPT_HDL    CORE             揤iew Design?function is missing in Windows Mode after reseting the menus.
, z0 I" h1 ]- O) u  R7 }950994  CAPTURE        NETGROUPS        Problem in expanding the netgroup in Auto Connect to Bus function
4 z! E. r$ f/ _- e6 X+ J% O7 W953530  SIG_INTEGRITY  GEOMETRY_EXTRACT Display Parasitics is displaying wrong results for EMS2D Field Solver compared to topology extraction using Probe.0 @+ s$ t$ b  r0 P7 w  q" j& u+ E: V! ~
953713  CONCEPT_HDL    PAGE_MGMT        Random page replacement/duplication in block/ T* V5 s& c' [8 ?: W
953917  CONCEPT_HDL    ARCHIVER         archcore should handle errors correctly4 z# d5 B" d9 Z) H  ]
953971  allegro_EDITOR MANUFACT         NC Drill files not generated correctly when using the option "搒eparate files for plated/nonplatedholes?
" x8 {) i- v8 r9 F9 G+ z954400  CAPTURE        NETGROUPS        BUS members of NetGroup are getting converted to Scalars in Export-Import NetGroup.
$ {/ @+ e$ E0 k" b9 E954498  SCM            B2F              SCM crashes when importing physical
1 _/ j; k3 q3 J4 l! o954623  ALLEGRO_EDITOR EDIT_ETCH        Unable to complete connection with Add Connect - related to soldermask to cline check?( p: ~3 A8 B+ N2 ~$ H- J4 f3 c9 ^
954894  ALLEGRO_EDITOR MANUFACT         Dimensions disappear when opening database in v16.5 from v16.3
- ^+ F3 O- d* E955029  CONCEPT_HDL    CORE             custom text font size not recognized in symbol view. u8 y% A; W, t
955133  SIG_INTEGRITY  FIELD_SOLVERS    The Field solver creates the differential trace model which is reversed T(D1) and T(D2) of bottom side.; L$ X$ V/ v; s1 v: B+ U
955290  CAPTURE        DRC              Description for UPD0014 missing in the Browse DRC markers window, J/ P; d2 O. x
955299  ALLEGRO_EDITOR DRC_CONSTR       drc text to smd pin does not work any more on this database in 16.3 S039
0 c2 T* V* N  e! |/ i5 Y, ^4 C955338  CONCEPT_HDL    CHECKPLUS        Need to change PART_NAME
" d! V  Y. B, }3 ^; M. W955447  SIG_EXPLORER   OTHER            Model path set in DE HDL Model Assignment not used by SigXP from CM in DE HDL' [# U9 E% h$ F+ Q2 g
955740  SIG_INTEGRITY  GEOMETRY_EXTRACT Crosstalk with Timing Windows does not work correctly
% n6 P$ g* F- B  F2 z8 g! J+ z955749  ALLEGRO_EDITOR MANUFACT         show element Info shows symbol dimensions on incorrect subclass
' E2 p7 a, J$ p& k( I3 A955912  ALLEGRO_EDITOR OTHER            Shapes with voids that are exported to PDF have gray filled area over the void. u( r& F  j  ]/ l# }! q
956129  CONCEPT_HDL    INFRA            DEHDL uprev hierachical design from 16.2 to 16.5 packaging failure.! Z' k' [1 `5 S' i% v' Y
956373  ALLEGRO_EDITOR NC               drawing name doesn't display in the log file
  T, A: I( M: q4 C956393  CAPTURE        PROJECT_MANAGER  "GENERAL" and "TYPE" tabs are missing from "Properties" dialogue box.
9 \) b/ K$ w5 c* o5 U8 T956448  PSPICE         MODELEDITOR      Can not generate a DEHDL symbol from Model Editor, because no Capture license found
6 Q- N% o. }! R3 j' f0 w956456  CAPTURE        NETLIST_OTHER    OrTelesis netlist not transferring user properties defined under combined& i9 n  [  x8 M- \: G
956489  ALLEGRO_EDITOR MANUFACT         dimensions lost when symbol with diemnsions attached to symbol origin placed on board
/ ]3 k/ w# k6 J' |! H956603  CONCEPT_HDL    OTHER            Part Manager "has stopped working" after changing a component
6 \6 ]2 C- J* N5 p( I956751  ALLEGRO_EDITOR ARTWORK          Import Gerber command does not work correctly- I4 v0 i# {1 j1 L3 h1 P
956847  PCB_LIBRARIAN  METADATA         PDV - Partdeveloper symbol to function linkage broken/changed in 16.5" |* [3 i6 G/ A1 p; X! }
956987  CAPTURE        OTHER            Find from "Search toolbar" doesn't gives complete results
9 |3 y2 Y1 ^" n1 {# a" K956996  CONCEPT_HDL    INFRA            Correction to ERROR(SPCODD-7): Following Primitive instance causes CM to empty
  c* h; c# S+ g" r) ^957009  CAPTURE        NETLIST_OTHER    Problem getting database property in mentor pads PCB netlist, _0 K$ [9 Z1 K6 ?5 ?- a2 t* Y+ O
957137  APD            DXF_IF           DXF out  command dose not work correctly.3 r# L: n8 [. U
957167  APD            GRAPHICS         Highlighting for Static shape with display_nohilitefont environment variable.; j1 V& w+ A0 {
957232  SIG_INTEGRITY  OTHER            Allegro crash during Model Assignment.
5 h- M/ m. w& C0 c957267  CONCEPT_HDL    INFRA            Packager Error after Import Design
. ^7 Y* p8 H# ~8 S6 E957866  SIP_LAYOUT     DATABASE         Cavity outline is not getting deleted from symbol file
1 f2 S3 |- p, Y( x0 p958010  ALLEGRO_EDITOR REPORTS          Wants the ability to extract "Batch"  reports from Partition ".dpf" files.
5 X) a& Y4 k# F958252  ALLEGRO_EDITOR TESTPREP         Resequence testprep with the option - Delete probes too close crashes the design
5 D6 l8 M2 c8 Z% L958253  ALLEGRO_EDITOR REPORTS          Shape did not have thermal relief connected to pin but unrouted nets still shows zero.
2 f$ ]& F6 K, [4 Z$ q: y3 Y/ M4 S7 ^958433  ALLEGRO_EDITOR DRC_CONSTR       False embedded component DRCs
9 T" e$ }. M4 Y5 {2 }0 \- h958753  ALLEGRO_EDITOR SHAPE            Dynamic shape is getting corrupted in 16.5
! w  G+ r/ f1 c! m) ]959011  ALLEGRO_EDITOR OTHER            copy problem of via and cline
4 J9 M8 Q; L. ?9 R959101  ALLEGRO_EDITOR EXTRACT          Using extracta with excluding Thermal reliefs" g, R& f8 c2 T
959253  CONCEPT_HDL    INFRA            Design will not open: {0 Z) J6 Q0 A4 Q& k2 I# n# p9 v
959299  APD            MODULES          Getting ERROR(SPMHDB-279) when trying to update modules placed on the Top side% g) w" t* O0 U7 h1 a
959884  CONCEPT_HDL    INFRA            Design Uprev/concept2cm crashes with Application Error/Out of Memory Error.
: X) V2 u8 `# G' ^959909  ALLEGRO_EDITOR SCHEM_FTB        Site level propflow.txt file is ignored property is transferred
3 y2 K1 y, |% t$ M960067  SIP_LAYOUT     PLATING_BAR      Creation of plating bar removes "NODRC_ETCH_OUTSIDE_KEEPIN" property from the clines.1 j/ d- G9 g7 t4 y; b+ \5 J
960126  SIG_EXPLORER   EXTRACTTOP       Allegro PCB SI license is used automatically at Topology Extraction of Allegro Physical Viewer.. j6 m; }8 D# L. ]6 v% s9 @+ Z# n
960143  SIG_INTEGRITY  GEOMETRY_EXTRACT Running simulation in Bus sim happened crash while enable Coulpled Via model to S parameter
0 M! ~) n2 j; o, Y4 K) `2 F961349  CONCEPT_HDL    HDLDIRECT        Motorola designs have broken connectivity compared to 16.3+ U8 n1 z1 F' a2 [1 K) u1 _
961816  ALLEGRO_EDITOR INTERFACES       Normal Export > DXF fails and offsets  the pins of the BGA symbol- K2 U& e# m* G9 H! t: W9 Y
962519  SIP_LAYOUT     WIREBOND         Align option doesn't work for wb_tackpoint fingers |
