5 R9 }( c8 f' z% [+ p( y
" l0 x/ j0 W ^, x- e' u7 W+ C0 ~
allegro使用技巧总結.pdf
(956.62 KB, 下载次数: 497)
: n7 m5 k( a3 J9 t) M! k
" D9 T3 v0 E l6 |
" M& z Q5 X% B' z' ?, M
allegro使用技巧總結* G1 p. M; _- K& Y0 W3 M: F4 H9 D
5 }1 C" i& q8 q" Z# d/ S$ s
" A3 Z+ u5 h% o
5 T- O. k# T4 {) V: ]1 W: E
- \6 s" L8 \+ s4 [- L; a
2 _8 a$ } g2 z5 f) v( z% E
. N8 [* D: \! c. {+ F5 M
4 j; ^# _0 J$ o: S目录
8 L, ^! x$ c: H- _- V1. Allegro颜色设定,保存,调入和显示..........................................................................................3
% Q* M) |" s) K7 p, h2. 如何加入不同的via..........................................................................................................................31 V9 C! m" T& A: v ?6 d
3. 如何让Allegro显示实心焊盘..........................................................................................................3- u' H2 H( s% s! ^3 B/ j' v4 Z3 U
4. 如何让Allegro与concept-HDL实现反向标注................................................................................37 I) w- W! |- s* i/ b6 O; O
5. 如何使用FIX.....................................................................................................................................3
' Y* {2 }" ^$ v. b6. 如何使用Sub-Drawing......................................................................................................................4
% h' B* k; P; G9 y7. 如何方便快捷的Placement...............................................................................................................4
# D4 Q& Q" L m [8. 如何使用Auto Rename......................................................................................................................4
6 D9 `/ T1 g. r2 ~/ K; |. X: z5 D) V3 X9. 如何只显示一部分飞线....................................................................................................................5$ K/ S) _7 K6 s9 y' ?% c2 R2 a
10. 如何在不同的区域设置不同的规则................................................................................................5! O* u7 t; {. l' G2 u& `
11. 如何更新pad、via............................................................................................................................5. O% N* r) |) e5 ~4 c1 ~ W' p
12. 如何设置快捷键................................................................................................................................6% Z9 |* ~- G0 P* `7 ^4 @
13. 如何在Allegro中只显示连线,不显示同一层的铺铜..................................................................6- L* S! A# q% z C# P% K
14. 倒角Manufacture-->Dimension/Draft-->Fillet..................................................................................7: s9 d3 L5 C9 ~7 |( }( [" `8 [7 r! T& {
15. 差分线的规则设置............................................................................................................................7" J4 p+ B& S( ?. P F: _, E; }
16. 关于Export Techfile...和Import Techfile...........................................................................7! B# P' z4 |' N; V Z( b# X) X3 T
17. Strokes的使用...................................................................................................................................8
4 R- v+ _' }: m18. 关于View-->Color View Save的使用..............................................................................................10
0 V: \- v* K: y- K" v8 ~8 k19. edit-->vertex的使用.....................................................................................................................10
; Z: S/ b0 |" a9 ^& u! S+ L: k20. 器件、cline、via翻转、copy等问题的解决.................................................................................10
+ w/ e& d7 R( g21. for padstack editor...........................................................................................................................10
, Y/ A! F- C& W' t22. 如何导入DXF文件..........................................................................................................................13
/ E8 }- X3 W' c% e4 U+ w23. 如何在Layout的时候动态的显示走线长度..................................................................................147 C! j; ]1 P2 U# z
24. 如何在ALLEGRO14.2中更改鼠标的"+"大小?...........................................................15
0 w5 h# a# x! j* v$ Y8 Q0 k/ e25. 如何固定Allegro中菜单窗口的界面大小?.................................................................................152 Y' ]) s( t5 s5 E- ?; d
26. 如何切换Allegro的新老版本?(含Bus走线功能简介)...........................................................15
' j' \3 |! v; @4 K27. Allegro中常见的文件格式.............................................................................................................16
: T$ t% Z! B. i3 v0 l' m! j) O28. 关于做封装的步骤..........................................................................................................................172 U% A# G( S Q( e
29. 如何在Allegro中对器件厚度设定规则?.....................................................................................172 U2 x! ^7 c0 H; x; `$ b' z
30. 如何把边框的直角变成圆弧?......................................................................................................19
. d7 L+ m1 Y0 L+ L31. 如何使用Dimension Datum标注尺寸?........................................................................................19
# f j6 g0 {3 j' h4 ?1 o2 Y32. 如何能在打开Allegro时显示空白页?.........................................................................................20
- Y3 \/ {# c0 [) i1 {. V33. 关于表层铺铜Create Pin Voids.......................................................................................................20
+ e1 i( H7 u0 Y5 G* }4 h, ? I0 Z34. 对于倾斜45度摆放的器件出Gerber的注意事项:....................................................................22
# g% M# @* K0 M+ N; p4 J- E) _35. 如何实现line和shape绘制的外框属性的转换..............................................................................22 |
