TA的每日心情|  | 开心 2024-7-8 15:48
 签到天数: 37 天 [LV.5]常住居民I |
| 该芯片采用FPGA+SOC架构,支持Quad-core Arm® Cortex®-A53 MPCore™ up to 1.5GHz;L1 Cache 32KB I / D per core, L2 Cache 1MB, on-chip Memory 256KB;Dual-core Arm Cortex-R5F MPCore™ up to 600MHz;x16: DDR4 w/o ECC; x32/x64: DDR4, LPDDR4, DDR3, DDR3L, LPDDR3 w/ ECC;NAND, 2x Quad-SPI;PCIe® Gen2 x4, 2x USB3.0, SATA 3.1, DisplayPort, 4x Tri-mode Gigabit Ethernet;2xUSB 2.0, 2x SD/SDIO, 2x UART, 2x CAN 2.0B, 2x I2C, 2x SPI, 4x 32b GPIO;Full / Low / PL / Battery Power Domains;RSA, AES, and SHA;10-bit, 1MSPS – Temperature and Voltage Monitor |
