查看: 204|回复: 1
ZCC2467替代 MP2467
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-9-8 18:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    DESCRIPTION, s; I) v9 d* `4 B$ r* y/ O+ K
    The ZCC2467 is a high frequency step-down switching regulator with integrated
    6 O2 A4 m' C0 B0 y' y' einternal high-side, high voltage power MOSFET. It provides 3.0A output with
    % l- m5 R* q( l) I- fcurrent mode control for fast loop response and easy compensation.
    3 g/ `/ F6 K& h: r. T' {The wide 6V to 40V input range accommodates a variety of step-down8 O0 d% s9 S( p2 @5 I+ ]& a3 E  i
    applications, including those in automotive systems. A 100μA operational
    & ?9 Q$ O7 w2 xquiescent current allows use in battery-powered applications.& E9 |. D0 c1 _& B6 o9 x
    High power conversion efficiency over a wide load range is achieved by  |3 @5 ?* r8 c4 k5 E4 ]! U! T
    scaling down the switching frequency at light load condition to reduce the/ p! J" \: P/ |# n) _
    switching and gate driving losses.- P4 U+ y9 [1 \) S1 B0 I; r
    The frequency foldback prevents inductor current runaway during startup and) n. n: ?- j- V
    thermal shutdown provides reliable, fault tolerant operation.
    9 V! z  X9 k* L: D: C" e1 L  FThe ZCC2467 is available in thermally enhanced SOIC8 package.
    2 a' q- q& d, z2 H2 _$ RFEATURES' X1 e* ~. ]6 E! V
    • 100μA Quiescent Current
    2 J. ?4 _0 h$ ?8 o+ L- t" F• Wide 6V to 40V Operating Input Range
    ( L0 P  J8 ?4 t3 _• 150mΩ Internal Power MOSFET
    ) \; [! U- N* p2 q& W• 500kHz Fixed Switching Frequency1 _5 d0 z1 Q! U# z) x
    • Ceramic Capacitor Stable! R* B- l6 V8 C; B: c" Y8 {
    • Internal Soft-Start
    1 w& p: P: |5 y+ _, G: h  m3 n• Precision Current Limit without a Current Sensing Resistor
    5 A* N, U5 `9 N0 A6 n! e• Up to 95% Efficiency
    $ ?: ]6 d, [! A) C  @# r- \1 Q• Output Adjustable from 0.8V to 30V
    , j: a; k- S$ f4 Y  q• Available in SOIC8 with Exposed Pad Packages
    ( f4 a( S; f5 @7 R5 L7 ^+ L3 {
    发表于 2022-9-8 18:49 | 只看该作者
    朕的皇家翻译呢?O(∩_∩)O哈哈~
    , Y. P. s: ^- j: w( V. n9 H静态电流很小了。
    GMT+8, 2025-10-12 06:41 , Processed in 0.125000 second(s), 23 queries , Gzip On.
