查看: 213|回复: 1
ZCC5160 Synchronous Step-Down 60V 3A V2.0
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-9-7 18:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Features/ C' e! K1 B: D% u$ x& \
    ' Q& g0 O  \( D# `- M8 o. D20-μA Quiescent current in regulation; C3 q" B* W0 d4 y5 K, r* \
    6 @+ B. E4 G1 j" xInput voltage range: 4V-60V* C$ i& q9 v& \4 h  J8 A
    7 ~  F( b0 o  c) U0 l2 K$ c  H& h) ]) A
    Output voltage range: 1V-VIN
    5 p" J( k0 a: i' Y7 Q( k9 Q, k
    1 ]8 X+ F) [$ UIntegrated upper and lower power MOSFET2 X  d3 w' M0 c2 x- }  L! n  N4 [3 _
    maximum current: 5A9 m+ _/ ]# Q* u9 C7 Z, n
    5 ~) F0 D! U! Z3 x: w) G4 PAdjustable frequency range: 200KHz~2MHz
    % F9 w( u9 h9 f8 M: E5 a( p( P4 r# e3 w0 @
    Automatic switching of CCM/DCM/PFM mode
    ' R: I+ v4 W- s7 y  {" ?/ b0 e: C2 ]: u0 O& a. d
    Adjustable soft-start time and Output voltage7 L& j+ V/ X/ E7 d3 o$ k) u
    tracking capability) _* S2 r1 a4 t( k9 A
    0 [' k9 F" ^1 r5 `, EAutomatically switched bypass linear power
    ; B4 S" i+ {2 u+ ~8 Q, W& E5 }supply/ p+ d* }7 G! a
    0 L# w7 X' I" R7 Y
    Provides ultra-low input and output dropout0 q, R  D# Q. T3 @7 c- P
    voltage close to 100% duty cycle
    2 j+ @! q' R+ S6 u/ Z' M' A  k+ y
    6 L/ H# K5 m9 z$ P* G  D. cInternal Compensation
    8 n$ L& ]7 X! X+ R
    2 |) j- h8 f' L. q. `0 L/ LPower-good flag! b% Z, h/ Z# j0 ]4 e
    4 l5 C+ F2 a# S+ U: M
    Dynamic Frequency Stretch Technology/ }( }3 |; v" j5 r
    4 Z$ B" q$ E/ z4 Q5 l$ w) f
    Support large capacitive load start-up% H% v5 B$ I0 h' B5 N! z) y
    2 }+ h5 k+ U8 }Protection function: UVLO/OCP/SCP/OTP/OVP
    + o7 H! Q8 K, A, m
    " ^( n$ T3 m6 R; w  {- hOperating junction temperature range: -40℃ to) }% o; X" x! N
    +125℃9 u; e, _' g% o2 m# ]
    5 I9 v% r  V: tAll pins have ±2000V (HBM) ESD protection2 Z( H  l& z: `" Q$ q
    , p6 Q8 o/ v* P( O# ?' I. K
    ETSSOP 16-Pin Exposed Pad Package7 C; B1 |& w5 t( D' t& G
    Applications& |) T9 {* V$ J" Q4 ^
    ' q  b4 U" ]# A5 g* z* Z- b
    Industrial power supply
    5 o) y1 F3 T# q; ^. H/ _) Y% F2 I+ t% \! @
    Wide voltage input range power supply' d9 h: V2 z: f% X; T! M: t
    9 }' G' D3 V1 b  D* G( u
    Low ripple low noise power supply& J# ?* x! D: `
    ( U" k* m) J( X; X9 s5 ^
    Automotive electronic power supply
    3 ^2 Q4 X3 W" S0 c2 o$ sFigure. 1 Typical Application Circuit
    6 F. i4 ^, C! D+ o. RDescription  n, p; O' ^9 V
    ZCC5160 is a step-down DC/DC regulator with an
    $ a+ s/ o4 _; L: Z9 zinternal switch, featuring SKIP control mode, which
    ' t/ c; o2 _7 a1 h7 G" tcombines low quiescent current with high switching
    7 h. g8 V$ W7 W" X: \( _frequency to achieve high-efficiency regulation over a& ^- d( h& m& l
    wide range of load currents. SKIP mode uses a short4 [5 i/ r2 S9 S* e3 g* Z% h5 _' A
    "burst" cycle to switch the inductor current through/ b7 |8 u7 X4 m0 }/ [/ y
    the internal power MOSFET, followed by a sleep
    , y$ ]0 E0 i6 t; R0 x4 ^2 X4 scycle in which the power switch is turned off and the( f* e5 k# a/ P7 }
    load current is provided by the output capacitor. At
    8 ?" I9 Z7 G! O) T- a( q; `1 L) d) Slight loads, burst cycles are a small fraction of the
    7 V8 r6 g0 s. J0 C. p1 btotal cycle time, minimizing average supply current
    6 I: L" C* U2 i: o/ ?6 b1 n! eand greatly improving efficiency at light loads.
    ' F, S( l7 K: U  I' d* _7 k2 lZCC5160 has a wide input voltage range of 4V-60V,5 {& b% P: g& N7 N! Y. L
    thus minimizing the need for external surge
    6 l4 Z. Q& [7 D; H+ i& ^# esuppression components. Making it the best choice
    . X9 g1 o5 G2 v* Z) bfor wide input power range industrial and high cell
    ( C# Y5 g% c# ?3 U9 v; t( K8 k9 I2 @count battery pack applications. ZCC5160 is ideal for
    * g7 V0 C1 |, U' O: Guse in the 48V automotive power bus range., d) w1 P$ T, c- \" v+ c. G
    ZCC5160 features low-value 100mΩ high-side and
    ! Y. k, X" Z7 ^. A80mΩ low-side MOSFET that provide at least 3A9 E1 F; q. ~% G# P8 n3 n0 ?
    output current capability with excellent load and line
    7 p& P' I5 l1 @. [, q7 Itransient response.  L1 G! d  I2 e& j& N
    Additional features include: soft-start, thermal( X8 M2 H0 A* ]3 G
    shutdown, UVLO undervoltage lockout, gate driver0 z( ?* z( A0 w3 l
    undervoltage lockout, maximum duty cycle limit timer,, B2 A# k8 ^( M- G
    and current limit shutdown timer. It also integrates, ]$ G5 v& R/ B
    output short-circuit protection, providing HICCUP
    ( D2 K- e; X! a# c: x3 T9 w: Gmode when the FB voltage is low to avoid
    1 m- d0 c& J6 P! m* g# ^overheating during short-circuit.
    5 Y7 {8 X+ X0 U2 P0 b% H
    发表于 2022-9-7 18:26 | 只看该作者
    你能不能翻译翻译,能有更多的人受益
    GMT+8, 2025-10-12 08:57 , Processed in 0.125000 second(s), 23 queries , Gzip On.
