查看: 430|回复: 3
51单片机PID温度控制源程序
发表于 2022-9-2 10:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
实时温度测量及显示,超出温度范围相应的继电器工作,继电器可以驱动相应的加本数字温度报警器是基于51单片机及温度传感器DS18B20来设计的,温度测量范围0到99.9摄氏度,精度为0.1摄氏度,4 @4 F. _  F- l$ J. H
* j$ T4 Z* ~0 |4 L4 v
1 i% \5 b- ]( O$ x
( X- [$ e2 p: b$ l& `) j* g3 A5 N- o: P9 z
8 A6 B& R; _2 Z3 z- p
) U3 ]( @, `8 P! C7 z! }. W4 X( ^# n# ^( `' r3 F
元件清单9 ?  F1 L6 F6 u3 Z
2 [/ J9 i" H: A+ @. _! I+ H
' N$ B0 K- \( Z$ W4 C9 O% g& P# t
电路原理图
. e0 I7 R& h" ?) U* B' k8 w7 L: O6 e8 R
, q; I2 q4 q. Z" N
" A7 s% D+ U: x
! |, S# f' o3 c0 y
1 e2 T/ ?3 S+ ^7 Z. M  A. [
* ], w/ x# Q5 v8 ^0 x* W
8 x, `" H* F; E% A" c
1 _( i" l' b. j& ^5 V% r9 n: \4 m) E/ X* i5 W, i4 W- O* E
# k) L' [6 G' y# O' |5 Z源程序
$ [) }7 R% h  f$ g' Y" ?1 L#include<reg52.h> 2 A, O0 I$ y- u9 v3 u2 H7 m" m& m" G
. Y3 b/ T: Y, ]+ c* ^! }
#include<intrins.h>
; a  t; j; w! v9 Q/ m7 m8 Y" Q( w#include<math.h> 2 V! z, X; y0 z, S) a: W
#include<string.h>
( V# q, \7 N; Q! m1 A, Dstruct PID {
0 }  x* G2 `  S. G- v& Zunsigned int SetPoint; // 设定目标 Desired Value
( T2 M% P5 e' \. l+ h! `unsigned int Proportion; // 比例常数 Proportional Const & @) G7 U+ b/ C" \; I
unsigned int Integral; // 积分常数 Integral Const 6 F: t2 J" }+ D. B8 b; e% x7 Z
unsigned int Derivative; // 微分常数 Derivative Const 8 |+ H% `" j7 t1 b* [: [
unsigned int LastError; // Error[-1]
9 o5 [6 V" u& E; v$ ]% F5 ~- c  qunsigned int PrevError; // Error[-2] 9 ^+ v# E( {2 M9 X7 c7 @) w3 S4 i
unsigned int SumError; // Sums of Errors + x' w0 w- h/ X9 e$ w9 u6 V! v; y
% y9 A+ F1 J+ m- r$ ]struct PID spid; // PID Control Structure - ?+ f, D1 B: m1 J, O' T2 @
unsigned int rout; // PID Response (Output) 响应输出
- f1 I  K/ K$ ^8 R% J: q! r* Qunsigned int rin; // PID Feedback (Input)//反馈输入# F' @3 a( g0 \; f" l
unsigned char high_time,low_time,count=0;//占空比调节参数
1 p0 h" Y) r, W! m0 o% H/ Y6 u; l#define uchar unsigned char
- ], q/ y# P. m3 B1 h' [#define uint unsigned int" s2 }) r4 B* ~  H0 F- Y6 W5 o
sbit output=P1^0;
8 d( m! N6 w4 V3 Z0 t; ?sbit ds=P3^2;7 r6 c9 x2 A+ Z; X
sbit DQ=P3^2;//ds18b20与单片机连接口
- j( S) _- G+ qsbit lcden=P2^7;//LCE使能引脚
5 a5 j1 @0 y: h# `sbit lcdrs=P2^5;
$ E! _2 w% r+ A/ |! c9 Z  fsbit lcdrw=P2^6;# T  ~( j- f. j- U
sbit ledred=P1^6;
) o( N8 E5 z2 Z& vsbit ledgreen=P1^7;$ s/ _$ j7 R5 ~8 }* s
sbit key0=P2^0;//按键引脚
" y  ~2 Q7 {; [$ n7 d: D% K2 T7 t, Asbit key1=P2^1;
. @, K/ [' m6 P; k: |- R+ h; ouchar set[2]={0};
. p, n  i" V# {6 a* a7 Duchar code str1[]="now temp:      C";
, T% v9 U' f, }: d6 `8 X) Ouchar code str2[]="set temp:      C";
0 c6 U. w: d8 h" b: z+ H9 Duchar code table[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};, I4 Y$ [) l$ H" [
uchar n,num;
: x1 h- j! E0 G1 `% Nint set_temper=30,temper,temp; //温度变量定义" c4 F4 t: T1 M6 L% j
unsigned int s;+ P0 G9 @5 x; c
float  f_temp;//转换后的温度2 C5 @( w* Q1 G1 H! ~6 C8 v! R8 d
uint tvalue;         2 w2 R9 v4 F' y, l3 Q9 G6 n
uchar tflag;//温度正负标志4 q& {0 K1 x, R4 V: ?5 q- r
void delay(i)//延时函数
% ~: W2 o' r1 I/ D, r: N# U{
$ V: G8 P$ a& w- p! v( O uint j;7 Y5 M8 \! D$ y% L; r& |
for(i;i>0;i--)7 n( x! _5 S( F- P4 R  g8 X$ F
for(j=110;j>0;j--);
$ |5 P/ B9 e! j+ l# g. s7 M}
- i1 _! w* k( [, q  o, a6 A& Z. p. L
5 Z  y7 c6 r0 B4 ?void wr_com(uchar ml)//写命令
" X, k( g4 _' O! g# ^{
" j6 C- r( t0 r$ d( ?9 x- U lcdrs=0;* u8 i4 j8 r4 ^
P0=ml;! U9 j+ I- {- f1 W
delay(5);
" j9 y7 Q# r; J7 e( D- C lcden=1;
4 p: X) d6 d; F- A$ r delay(5);
' Z) a- a( E! J0 M% ?9 f" ]% K. X lcden=0;
8 A/ Z* |4 T( J; z}6 K' R# W9 L7 b
+ |$ y6 o7 i' |' U
void wr_data(uchar shuju)//写数据
( j! v) S( ?- }7 k{
  B; r. @& }* G: `1 X$ V, p  X lcdrs=1;; {7 Q9 Q, l* D4 {8 o/ L
//lcden=1;
) i: d+ [, ]: O. ]0 P9 [ P0=shuju;$ X! L- o$ L4 b+ K" [: i
delay(5);* v* {: Z" Q. x2 c  u2 A5 F, c
lcden=1;
% h2 [; J) {$ o0 Y( Q8 ~6 V delay(5);, Q3 R, z, {/ s2 B5 E- X' {
lcden=0;4 |  h7 @4 h" A7 J  F
}$ \7 Y# d; ^1 l' ~! o+ ~5 j
void init()  //按照时序操作的初始化
# S( e/ N/ ]2 }* _9 A) C{
2 H9 s- i7 @# Q4 d9 E; V lcdrw=0;9 b3 t; }2 K( L: `1 r8 i  l
wr_com(0x38);//显示模式设置,设置为16*2显示,5*7点阵,八位数据口
$ Z$ X7 }: I- e( {( h2 a wr_com(0x0c);//开显示,但不开光标,光标不闪, n* T  D9 F1 S: d6 Z
wr_com(0x06);//显示光标移动设置4 e5 u+ H5 N' P' R0 }* d: }- H0 ?( L
wr_com(0x01);// 清屏
& ^+ _0 D9 x" g2 ]1 u wr_com(0x80); // 数据指针初始化
: g/ y' t3 p7 v5 b for(num=0;num<16;num++)( G8 c3 l* l3 q/ G6 S
1 W9 u& y7 K$ z  W4 k' S+ V   wr_data(str1[num]);//now temp
% }' B1 x8 }% s" P- I  }
' C$ y" Y$ ], i. a3 y wr_com(0x80+0x40); //地址初始化
  H" ~, X) i/ B) J$ i  m' X for(num=0;num<16;num++)
/ B. t' }2 j* ~  {; {, {* G* k; z! t
   wr_data(str2[num]);//set temp/ c$ x0 O$ K+ \% o2 U* [3 z
6 U/ a$ b) d# r* x8 y+ a- M4 c}
9 f, ~3 T7 N* ~9 ^! k. p6 j# p/*************************DS1820程序****************************/! L: c$ Y, ]. w6 G* N! U
void delay_18B20(unsigned int i)//延时1微秒7 h* o2 _0 F' L! _0 z5 k
& O* g7 U& _, S9 T4 Z# _6 v   while(i--);* u  k' v* q7 V
}# m4 \' ]; z$ D& ]
void ds1820rst(void)/*ds1820复位*/+ H' h3 L, Q/ W$ j  L
% m8 Q, V- }5 j9 S1 f/ c, h unsigned char x=0;
& |# U# {& ?; k% D0 Q DQ = 1;          //DQ复位
1 O5 B& S: a+ h9 T/ U delay_18B20(4); //延时! s% w5 w# E' _. [3 V# B
DQ = 0;          //DQ拉低7 B* E# z# ~5 M/ y
   TR0=0;: N  s9 [& `9 w- L3 w* T2 H
delay_18B20(100); //精确延时大于% a5 z# b1 h- v2 z! [2 _; }8 Q
   TR0=1;
8 s4 x9 J' v. T5 ` DQ = 1;          //拉高; c& c" w- n/ e/ d( E+ w% d& K5 o
delay_18B20(40); * ?# L$ n( J; d& e5 D" O- ^
/ `  l) r6 i5 _' K4 l; P) Y, Tuchar ds1820rd(void)/*读数据*/" O3 g' G2 S+ A; i
{   @# y- n  n% u- e0 n% @# L
unsigned char i=0;: `4 X" x+ u! I: g/ K& _: H
unsigned char dat = 0;
! {7 \- F9 @' y  g: w+ B+ {" D* p   TR0=0;  l5 x1 j/ H' ]
for (i=8;i>0;i--)
+ @; A6 Z- ?3 k {   . F9 A* G6 {) @2 Y& @/ _
  DQ = 0; //给脉冲信号1 y( {1 `  Y/ ?& B
  dat>>=1;
% E4 G) B( E9 f6 j* G, f' s  DQ = 1; //给脉冲信号4 x/ P) b. K7 Z2 z
  if(DQ)
( ]! f* b0 t" ?5 T* Q  dat|=0x80;
, a" A" j" h& w! y3 G  delay_18B20(10);
4 }) U7 F& h8 c" h. X7 b1 R }" z/ F9 X- n: B/ i$ s8 n0 T- {
   return(dat);
1 g8 ?  ?% ]1 a# H}
8 t8 l* a/ e# F2 B  Ovoid ds1820wr(uchar wdata)/*写数据*/5 `. p! x! z$ |/ T  u& H
: u7 }+ G% V' ~5 V+ y6 C unsigned char i=0;# T' s2 I% Z4 `) t/ e
   TR0=0;
4 K: u. \, _, J* |# q6 D   for (i=8; i>0; i--)
2 |! i3 [0 D) K0 L7 H   {
/ [0 _- O& I+ S, O  DQ = 0;8 J, _$ F/ D3 X2 e3 y( @
  DQ = wdata&0x01;
( x' x$ \, H2 C2 G  delay_18B20(10);! {! M3 D5 h: ^+ \9 U
  DQ = 1;+ @: E8 g' V4 j; F9 u8 f
  wdata>>=1;
) u4 O5 G1 m& o4 l, B+ H4 e# A   }0 o4 B, U; G7 v$ |
}$ T+ q: P1 C3 x2 S
! }( i& f9 m# w5 p# I! x4 C. ~uint get_temper()//获取温度9 |/ I4 O  f' s! |" Y
/ O% \* s' i& j7 k! r% n$ W) J     $ j" c0 Q# y. ]# a# |% i9 |3 G
uchar a,b;1 z& H9 F6 {; ^1 f- L1 v9 l/ r! z- w
ds1820rst();    + r9 O5 g* g) j( q6 Z+ g
ds1820wr(0xcc);//*跳过读序列号*/
+ P, E% F* Z$ _" }) i8 I ds1820wr(0x44);//*启动温度转换*/, C3 @9 \" X9 k) G0 Z8 e; s: {* W% L
ds1820rst();
2 v, M" y& J. B: O6 [ ds1820wr(0xcc);//*跳过读序列号*/
9 X) N# G9 r3 t ds1820wr(0xbe);//*读取温度*/ , b  q- }# H' R( ^$ g# d
a=ds1820rd();
( v; u% K% ~! O2 ~( ~: m b=ds1820rd();
2 G* X  _' Z6 g! D3 _6 c9 v   ! s0 L7 d% H+ P- x4 n# _( `
tvalue=b;
: e; P7 q, O) \! y; c tvalue<<=8;( m6 E" Y, V( h
tvalue=tvalue|a;$ E5 M, w# i) h
   TR0=1;: p0 I* P1 ~3 w4 V  ~3 f) Q
   if(tvalue<0x0fff)   tflag=0;
$ m8 \( ^! z7 f0 ]# O8 R   else {tvalue=~tvalue+1;tflag=1;}4 }: Q! M8 b1 i- y
tvalue=tvalue*(0.625);//温度值扩大10倍,精确到1位小数4 L$ {* Y7 L2 w9 C
temp=tvalue;! O+ J+ L0 D+ _' {; b; O+ Y
return temp;
- A9 d/ u) s! ^, `}" P9 B& p& Q" b5 [& N% @: j
7 |5 K( ^+ |. Z" yvoid dis_temp(int t)//显示温度
1 e3 g) j1 K) v4 \- n! Q# ~; H{
$ ~, x1 x, u' i2 c$ F uchar d0,d1,d2,d3;
, e1 W6 m, U# _' t" I+ R& S. l- H7 [% ] //t=26;+ l. i* ]. [8 g' r2 d- `
if(tflag==0)
1 p2 w% ~# i! N/ n3 q {
& d# u! J$ j: g( u  d0=t/1000+0x30;
. f5 r5 M2 S* Z8 A  d1=t%1000/100+0x30;& {( H/ P5 m+ z* M2 Q+ `/ h) U
  d2=t%100/10+0x30;- S6 Z# y9 q* p2 l* U2 K0 p
  d3=t%10+0x30;+ E0 ~0 O' @; S) o
  if(d0==0x30)- T+ ~, `8 ?  F8 A4 R6 t
  u# B, x* D+ q+ {   wr_com(0x80+9);
3 a  `3 O% o4 e- u   wr_data(d1);
) L: P1 o. m1 y& i( }0 y   wr_com(0x80+10);$ R6 ~! B: y5 o. K5 T. j
   wr_data(d2);
" p8 w/ O* ]% r   wr_com(0x80+11);0 o# E) n- e$ y+ j# k9 N# T( f
   wr_data(0x2e);$ A0 S' \( }  |/ v" u, k2 @
   wr_com(0x80+12);
0 ^1 R0 h3 E2 z9 t! A: S& G   wr_data(d3);. E/ d5 X# Y: d! B
  }( |. S1 E. o$ n  V
  else
$ P3 v- k, j% r  {
+ B9 w; l1 M. q/ t! u; i   wr_com(0x80+9);
9 e7 u; ]* F2 l9 q+ b6 B   wr_data(d0);
% b& t, l$ ?& t4 \; I7 |   wr_com(0x80+10);; F5 X: }' v" Z* h; s* Y9 E) F: u7 s
   wr_data(d1);+ ^4 r) h0 S/ {. C) z! O3 `) V! F, q
   wr_com(0x80+11);$ T, @- m4 H: z8 D
   wr_data(d2);
. }. W4 B8 V" N5 l; I3 p4 o, N& G   wr_com(0x80+12);
8 a6 ^. v3 _, D   wr_data(' ');
! r9 N& D* w3 L5 b' y" ]  }  t5 j+ J! |! _9 n+ W
  # j6 p) V0 ?1 {2 B# ~! A2 W
}( n5 m) i% q; Z4 E
else& X3 _: Q$ `3 ^9 P1 g1 D7 B8 C9 ?
{4 {* ~1 Y- @  ^- q/ I; w
  wr_com(0x80+9);
1 B/ F4 T$ r. \8 a# N  wr_data('-');
" L0 [9 h7 ~# Q/ c$ ^* a  wr_com(0x80+10);
6 j; T1 x* c% K3 ^0 @  wr_data(d1);, ?- w" _$ Q# `2 I. z
  wr_com(0x80+11);
' Q# x& A4 s- y5 O  wr_data(d2);. T% A, u/ X; r7 Y) W7 T! L
  wr_com(0x80+12);- \$ R' q& a* h* D! r
  wr_data(' ');! {! F$ l0 U  I9 a0 l* S3 j
  //wr_com(0x80+12);' n" ]1 G: o5 @$ E
  //wr_data(d3);; f4 d$ e- T0 m2 H, J- z: w
7 q$ }8 U3 y" L% A$ n# V+ X2 a wr_com(0x80+14);
1 U+ k# P4 E, N1 J- i+ X# Y wr_data(0xdf);5 p5 H/ D9 [4 F5 ^
temper=t/10;' e/ B& k8 B3 [4 W: B$ P
; W2 J$ \/ E* D# E5 ~
4 k& `4 o, J4 F- d% S% q$ ?void keyscan()//键盘扫描
; ?  v9 @& x0 U8 ~' n' P" ?{
0 v7 V. J) N2 W0 j* Q2 M   if(key0==0)) R7 O7 r3 z! Y: X
9 T5 P, F* |3 o  delay(1);% V! ]$ J' t- t. w6 P  q
  if(key0==0). |: f5 ~9 w+ A% Q& ^. W. o, O
  {9 K, {9 c. D% K) \/ e: N& c
   while(!key0);- t" h0 P/ _( ]. N0 `7 S
   delay(1);
3 d: T. N: d4 G8 ?   while(!key0);
) t" _7 a3 f0 {   set_temper++;
8 H) p& }& G1 c3 N, M% R8 Q  }
! i* [1 ?4 @5 J% r& ]  set[0]=set_temper/10; //获得设置温度显示值* g4 s/ V6 q) T/ d7 v5 C
  set[1]=set_temper%10;
0 _8 ~2 n6 Z& }1 n6 [: u  wr_com(0x80+0x40+9);( t# w# U8 {! q& V; c8 ~
  wr_data(table[set[0]]);
" U4 W! Z& [0 [. }$ p  delay(1);$ ^7 ]/ }0 |) N( N
  wr_com(0x80+0x40+10);: N3 V9 F+ t3 K1 @- T
  wr_data(table[set[1]]);
' X8 z! s8 v& j! I  delay(1);6 ^3 \0 X3 Y, a; W4 Z
  //wr_com(0x80+0x40+11);
! {' I+ w  b9 i  a" L8 p" K  //wr_data(0x2e);) d8 i" E' L" ~9 T8 N" e
  //wr_com(0x80+0x40+14);
" [# c" t; Q9 f; v. ~: L  //wr_data(0xdf);! i0 n; R5 g7 g- j) J' x9 K
  delay(1);9 }9 ]" `8 }  X, w/ C5 J
}" Q1 t/ C# W+ _# U
if(key1==0)
8 e8 v4 l9 M% _" f7 G   {- t$ A0 a) D9 ?8 Q; Y. k7 f9 K3 O+ E
  delay(3);//延时去抖# O# u/ V9 j7 S) z' r; J
  if(key1==0)3 L3 E) D, {" p) p
  {  C$ Q) ]' R* Y% B. `. `
   while(!key1);
! Z% L; q  j" s2 F4 N7 o+ R   delay(3);
% V4 C$ q# x: B$ }+ D) p) k   while(!key1);
5 D$ d7 q5 B' m. T, |* L   set_temper--;//温度减3 X0 w* K& m3 F9 a4 V0 J
   if(set_temper==0)) C+ ^3 D! X3 Q/ k, t5 W$ k
   {set_temper=0;}
! q9 E: i5 L' z! Q8 I3 Y  }
% J$ w0 A' s% T8 z
; @: A3 H: }  ^  set[0]=set_temper/10; //获得设置温度显示值
0 J7 q1 s) }+ B- F$ H4 [  set[1]=set_temper%10;
# x$ W- K" Y/ G" S3 l  wr_com(0x80+0x40+9); //显示设置温度值
: M, h: G8 y* N5 \4 I  wr_data(table[set[0]]);+ m; F! k0 B: M' d' P+ g
  delay(1);
' Y1 }3 l' L9 N2 ]; ~5 Y  wr_com(0x80+0x40+10);
* _6 r# m7 R# K' [/ x& J  wr_data(table[set[1]]);
  Z3 S" X! j- \" J  delay(1);" E  V+ T$ @. y) ~
  //wr_com(0x80+0x40+11);5 U; ]$ T* |$ W  X* B
  //wr_data(0x2e);1 b5 r7 H; N! v) W0 N$ ^" y
* ~, A- x1 L* q/ E  wr_data(0xdf);
. |3 A* S5 V; `5 c) R7 i* J  delay(1);, C. A% g/ n$ B2 G2 Q( x' E# u' r
, m9 [- g1 U& Q: g% Q}# v" s, \+ R0 o
void PIDInit (struct PID *pp) , v3 W" T4 q3 q- ~) ]4 r
- b8 R: P4 h( A memset ( pp,0,sizeof(struct PID)); //用参数0初始化pp
0 L2 h7 S6 ], Q) w9 ^8 p7 {} : X& o0 V3 v# j% `* ^. ^" W
8 w$ `' f$ x) f3 I( f* aunsigned int PIDCalc( struct PID *pp, unsigned int NextPoint ) //PID计算; h/ i+ ~( o0 ], c  u$ x0 G
{ 0 p2 l" s( ^# n. r; o& Y
unsigned int dError,Error; 2 y( E8 R" z# U6 _! w( q5 h7 a
Error = pp->SetPoint - NextPoint; // 偏差 5 F( \# x# P: Z# {* b9 u
pp->SumError += Error; // 积分 8 @1 `/ h. L$ h5 C" ~- ~& e* X
dError = pp->LastError - pp->PrevError; // 当前微分 9 i: l  B$ }( T
pp->PrevError = pp->LastError;
- c% Q- I; K" f. ~% {/ K pp->LastError = Error;
, ?& S. M% @# P return (pp->Proportion * Error//比例
# l# U$ Q' i7 T- X + pp->Integral * pp->SumError  //积分项
- P& z' l/ A: z/ L4 @! J; O! ?% l8 u + pp->Derivative * dError); //   微分项
8 Z* q2 J# {' a" |! _}
1 W, G7 I9 ~& @5 J" V; t/***********************************************************
( K) B3 h' {: u% m温度比较处理子程序
8 \  Z  b* H" }! _/ J***********************************************************/
3 h: W, n* x2 k% `# U8 ~" x& L* q0 C6 _& ~void compare_temper(void)
7 U/ s6 p& E( L; S1 {2 `6 F, t# x{
  y. J+ U% x. D! x. u* N( E unsigned char i; # R$ g/ D; J% g  ?5 y% E2 i
if(set_temper>temper)  //设置温度大于当前温度
/ E* n' L+ m  |" j4 ]' | {
& b0 y2 Z. y; h9 d2 q# @  ledred=0;& ?& X4 D) {+ }5 t
  ledgreen=1;: X( N9 y" j+ G4 A# E6 I
  if(set_temper-temper>1)  //温度相差1度以上
1 s; O& o, }3 [  {
. Z9 S$ I' v5 M1 s+ b   high_time=100; + U7 ]- u" b" S& {+ `
   low_time=0;* V* D4 j( A$ @' h0 \+ N, }
1 w+ ]" B" K) i+ [8 k  else  //设置温度不大于当前温度
. ^, c$ T# a+ F  {
# M: v, C2 D. a+ Y7 O0 f' j   for(i=0;i<10;i++)
: e7 A' t6 z" s  x   { % S! U4 C% b3 Z& q
    get_temper(); 6 i# u% a; Q+ h
    rin = s; // Read Input
: U5 p+ l' F3 o( c0 A    rout = PIDCalc ( &spid,rin ); // PeRForm PID Interation ) x0 `/ W$ F6 Z. `' X
, y! L; R- \% k, [! W' M/ u5 j' q0 O   if (high_time<=100)  high_time=(unsigned char)(rout/800);
+ q) U& }0 g$ x   else high_time=100; ! h0 _- `. c: G9 b0 U, k0 I
   low_time= (100-high_time); ; i+ d+ X* ~7 }' {8 s
  } ! J9 j7 F  y' v& O6 `% R
1 _% G/ _. V* ]. q9 T- ~7 r/ K else if(set_temper<=temper)  //设置温度不大于当前温度
" j* A. P, m, e) A7 O7 o! ^ {
* A' x+ ~6 h- X5 ^9 J1 t" Z  ledred=1;
" E' C& w% z2 T# ^9 Q7 l  ledgreen=0;0 v9 n( r' `" N5 V
  if(temper-set_temper>0) //温度相差0度以上* M' ~, T+ o- d0 n
  { & _% _3 e" ], r$ X$ p+ V
   high_time=0;
$ L( j/ l  e/ Z   low_time=100; ( C; T! ~4 A: K0 e( K! N( H) j" G
  } % V1 P. s2 Z3 K. Z9 F- N
  else
9 H3 m8 P* z2 f+ Q5 D& ~4 }  { # `, j$ }4 n9 Z) T
   for(i=0;i<10;i++) / r. ~7 `; X2 s  s
   { : Z5 \4 |6 u  O! ^9 ]; u1 r: E
    get_temper(); 3 r( j% i3 x9 d( R
    rin = s; // Read Input ) d( H# k0 `* |* C
    rout = PIDCalc ( &spid,rin ); // Perform PID Interation + p  K6 i0 C  H
   } / }1 w$ M4 u6 M$ `$ F* m5 w/ n( [0 H
   if (high_time<100) high_time=(unsigned char)(rout/10000); ' [1 [) B* y3 n2 x6 K1 V7 l# ?& {
   else  high_time=0;
3 T  j' u4 G  ], N, F6 E   low_time= (100-high_time); - V$ N8 C% `: \1 U% p
  } / t3 N( a' F6 z* |, _: y
, V' _4 o; a+ u. T: l} * W! H, N  s' R4 D
; I3 }* ^$ {( t& B8 D2 h6 N* H: j* ]T0中断服务子程序,用于控制电平的翻转 ,40us*100=4ms周期 ( s# B9 |2 A2 ~0 o7 O( Z' f, r0 B
1 J. s. W# v5 \7 ~  h$ P8 M% Wvoid serve_T0() interrupt 1 using 1
7 k; P. u$ h8 n, K/ d% m{
* t1 I+ d0 b, J9 t3 n2 B% Q- c if(++count<=(high_time))  output=0;1 u) ^, h( _/ P9 B1 w# ]5 |
else if(count<=100)
) {. J( s' P2 K' G; H- I* i( G/ H8 I { & O: w( R# j( J* G8 t$ u$ q
  output=1;
& ]( V$ x$ Y0 _, p }
9 t' K, Z+ c8 n! Q else count=0; ( x9 ~* i% e6 }
TH0=0x2f;
4 r& b4 `, \: j7 b. Y: n/ ^ TL0=0x40;
; }' q3 w) w0 i+ W% Z& U/ w" e; D}
+ Z1 T# R0 m! J. ]& ?" ^1 Y9 A& V8 X; }9 `
/***********主函数**********/8 F" j1 x0 z8 r" j( z
void main(void)7 z! d/ I, {5 O3 o. S) ~
{1 L+ u" F8 t* b! Z8 p
unsigned char i;
+ y* V- ~8 ?' L init();//LCD初始化# y; L* X6 @1 M0 d
TMOD=0x01;
6 ~( F) v. s. _+ }  z TH0=0x2f; # `2 W- `% c4 W4 F6 }/ l( Y5 c- v
TL0=0x40;2 W9 ~1 ?: N4 _! O
EA=1;
* J) s7 h  G- y* V ET0=1;
2 p; u1 E7 K  y2 Z TR0=1;
: V7 n& x- T" j/ p high_time=50;
0 q+ s% ~9 Z: Y6 f" L, s8 j( S+ D low_time=50; $ J+ h% E, @4 G$ H" C: e
PIDInit ( &spid ); // Initialize Structure
. j  _7 Q, R1 ^& o  ^( C+ d1 ~2 b: n spid.Proportion= 10; // Set PID Coefficients
  z0 E+ ^7 ^# J4 y& F, N spid.Integral = 8; 2 S7 B5 `0 ]9 Q  A2 B6 e
spid.Derivative =6; . H+ Y$ d, v% x% V, P! D
spid.SetPoint =100; // Set PID Setpoint . j. u: U7 h' I1 D! S! ^& [5 A3 e
4 X. H( w* n& W8 J set[1]=set_temper%10;2 n; t* u4 O4 N7 L( h7 t
wr_com(0x80+0x40+9); //显示设置温度! C+ m6 v& p1 b) k9 \+ [1 G
wr_data(table[set[0]]);& I/ p; M/ T2 b. I6 W
   delay(1);
' z% {  x) S5 N" H; B wr_com(0x80+0x40+10);/ h& q5 w( v4 Q4 |! c* c
( t/ ~5 U/ W) b# H2 ^6 o delay(1);  t" _6 V7 T& S" a
wr_com(0x80+0x40+14); //显示温度符号
4 m9 Y" p* w$ I0 U4 w$ S6 b1 ] wr_data(0xdf);; {3 |. A% C# J  W1 S5 o% @
delay(1);/ \+ g- J# o# F* b9 Z- ?
while(1): R+ B4 v) l) R. V- W" Y
{- |8 e" {2 A& F* O7 G8 y
  keyscan();  //按键扫描- k- A, _/ s+ i0 n" Y
  for(i=0;i<10;i++) //循环10次# @1 c5 y1 l; [8 b' a
  {' r" U) X$ o9 h+ w8 u  ^: |% z
   dis_temp(get_temper()); //显示温度值
9 F1 a6 y' d* x  J! R- h   if((key0==0)||(key1==0)) break; //如果有按键退出显示循环
6 A0 h$ ^. Z% F* u, `. n4 X% Y2 G  }
: ]* A( w& T* t$ v  if((key0!=0)&&(key1!=0))  compare_temper();  //比较温度
$ B% r: V  ^" Z7 X# s1 v- z+ e }, }1 ^6 a4 Q; X) o
}; q& Q5 s+ V, Q/ U# Y. R2 x
" q8 o. k5 B( E9 H+ S; \! {8 J9 h5 o% Z% T4 H/ A
! \8 z- Q) H$ z" @
  a( z4 D2 o; {4 e$ g- l
3 ?2 o% f% b, g$ a- f* V
) Y4 J0 P4 N, q2 Y
- }9 J! L$ i6 o, _4 i, a6 E$ \; T
9 x- ]1 ]7 i) L
7 G8 X& w3 e6 F5 `1 z
发表于 2022-9-2 11:00 | 只看该作者
对知识渴求与热爱,学习学习,(*^▽^*)
发表于 2022-9-2 13:11 | 只看该作者
感觉很厉害,很棒。O(∩_∩)O哈哈~
    2025-8-14 15:01
  • 签到天数: 630 天
    [LV.9]以坛为家II
    发表于 2023-2-2 15:54 | 只看该作者
    用NTC读取温度好象不能控温,NTC读出并显示出来的数据是正确的,不知是哪出了问题。
    GMT+8, 2025-10-8 05:44 , Processed in 0.140625 second(s), 23 queries , Gzip On.
