查看: 326|回复: 1
100V Input,10A Output, Synchronous Step-down Controller
发表于 2022-8-30 12:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Features
l 9V to 100V input voltage range
l 10A continuous output current
l 96% Peak Efficiency
l 600μA operating quiescent current
l Peak Current mode control
l 150 kHz Fixed Frequency
l Internal compensation for ease of use
l Up to 91% duty cycle
l 0.8V voltage reference
l 1μA shutdown current
l 150ms Hiccup mode short circuit protection Function
l Thermal shutdown Function
l SOP-10 package
Applications
l Charger in vehicle
l Battery Chargers
l Power adapter
Description
The MST8A100KE is a high voltage, synchronous step-down controller operates over a wide range input voltage 9V to 100V.
The MST8A100KE delivers 10A continuous load current with up to 96% efficiency.
The MST8A100KE operates with fixed frequency peak current control with built-in compensation eliminates the need for external components.
Cycle-by-cycle current limit in high-side MOSFET protects the converter in an overload condition. Hiccup mode protection is triggered if the over-current condition has persisted for longer than the present time.
The MST8A100KE exhibits protection feature
that protect the load from faults like under-
voltage,over-current and over-temperature.
The MST8A100KE is available in an SOP-10.
. b3 H3 s# n* h0 u
发表于 2022-8-30 16:06 | 只看该作者
有没有图文参数5 q6 a& P% k. P  ]
GMT+8, 2025-10-27 21:04 , Processed in 0.125000 second(s), 23 queries , Gzip On.
