查看: 313|回复: 1
100V Input,10A Output, Synchronous Step-down Controller
发表于 2022-8-29 15:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Features
l 9V to 100V input voltage range
l 10A continuous output current
l 96% Peak Efficiency
l 600μA operating quiescent current
l Peak Current mode control
l 150 kHz Fixed Frequency
l Internal compensation for ease of use
l Up to 91% duty cycle
l 0.8V voltage reference
l 1μA shutdown current
l 150ms Hiccup mode short circuit protection Function
l Thermal shutdown Function
l SOP-14 package
Applications
l Charger in vehicle
l Battery Chargers
l Power adapter
Description
The MST8A100KD is a high voltage, synchronous step-down controller operates over a wide range input voltage 9V to 100V.
The MST8A100KD delivers 10A continuous load current with up to 96% efficiency.
The MST8A100KD operates with fixed frequency peak current control with built-in compensation eliminates the need for external components.
Cycle-by-cycle current limit in high-side MOSFET protects the converter in an overload condition. Hiccup mode protection is triggered if the over-current condition has persisted for longer than the present time.
The MST8A100KD exhibits protection feature
that protect the load from faults like under-
voltage,over-current and over-temperature.
The MST8A100KD is available in an SOP-14.
) P4 F1 I- S5 V+ H' z- @, B# V( M
发表于 2022-8-30 10:35 | 只看该作者
产品图片有没有
' Z  @7 I. H, U' E& f5 w/ [3 A
GMT+8, 2025-10-27 23:34 , Processed in 0.140625 second(s), 24 queries , Gzip On.
