查看: 6927|回复: 34
请给位大哥麻烦帮忙看看
发表于 2011-11-16 11:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请各位当大哥麻烦帮忙看看   修改了半天了始终不知道以下的警告怎么修改   小弟先谢谢了!!
* b  y) W( u4 H% }9 ]! F% TChecking Electrical Rules
% B5 O8 G* Z0 a9 ?; ^5 n4 c4 I2 f& {
4 K. R0 E% ^; M$ rChecking for Unconnected Nets, W* B9 c' w9 P% M; T. s) u
WARNING [DRC0006]   Net has fewer than two connections A16:  PAG2SH2, PAGE1SH1  (139.70, 101.60) , n7 s9 Q4 y8 D" q+ H* \1 D, i
WARNING [DRC0006]   Net has fewer than two connections N129029:  PAG2SH2, PAGE1SH1  (264.16, 12.70) ! Q) p. _* X/ {9 L% ~$ s2 V
WARNING [DRC0006]   Net has fewer than two connections N129338:  PAG2SH2, PAGE1SH1  (264.16, 15.24)
2 R3 _3 n6 w( bWARNING [DRC0006]   Net has fewer than two connections N129647:  PAG2SH2, PAGE1SH1  (264.16, 17.78)
3 p& R3 i9 M7 o: z% s, U  `, UWARNING [DRC0006]   Net has fewer than two connections N129956:  PAG2SH2, PAGE1SH1  (264.16, 20.32) 5 D8 m4 I' O1 ~5 x. g7 r
WARNING [DRC0006]   Net has fewer than two connections N130265:  PAG2SH2, PAGE1SH1  (264.16, 22.86)
! @# H' L8 \6 y6 z) |4 o这是一部分  还有几个, l7 w# g% }" d2 A, a, t
还有下面的WARNING [DRC0034]   Two wires/busses of different nets intersect visually, yet nets are not connected A[16..0]:  PAG2SH2, PAGE1SH1  (137.16, 99.06) . P; B: D& q( {3 a" i
WARNING [DRC0034]   Two wires/busses of different nets intersect visually, yet nets are not connected A[16..0]:  PAG2SH2, PAGE1SH1  (137.16, 99.06) % C- k% S# Z0 M8 Y) \; M( b
WARNING [DRC0034]   Two wires/busses of different nets intersect visually, yet nets are not connected GND:  PAG2SH2, PAGE1SH1  (137.16, 99.06) + W( \4 f; S* L" T5 `, \1 |( b
WARNING [DRC0034
) A, h9 a7 L6 l7 r: j7 \麻烦给位给看看   这是原理图 MY3.zip (178.28 KB, 下载次数: 34)
发表于 2011-11-16 11:41 | 只看该作者
先來看二個錯誤/ u! L  z) K% d  F* q0 U
BUS SHORT.png (33.86 KB, 下载次数: 21)
发表于 2011-11-16 11:56 | 只看该作者
看圖吧!
0 ]0 o, l7 g4 Q3 U! t
发表于 2011-11-16 11:59 | 只看该作者
2 n3 V+ X. M& p' s6 G  e3 B2 s$ y6 _
喔~~~~3 ]' _& A+ C! E! Z
 楼主| 发表于 2011-11-16 12:02 | 只看该作者
嗯嗯   太粗心了  居然没看到  谢谢   这两个我已经改过来了  真的谢谢
发表于 2011-11-16 12:08 | 只看该作者
有些貼圖,要點選圖片放大來看。
发表于 2011-11-16 12:26 | 只看该作者
原理圖上沒有 D16 啊~~~~
0 k6 a& ^  z3 k/ ~+ N- ]
 楼主| 发表于 2011-11-16 14:03 | 只看该作者
jacklee_47pn 发表于 2011-11-16 12:26
4 @0 |" d1 u, Z2 d7 r, e+ ~原理圖上沒有 D16 啊~~~~
* N: D  V8 ^7 H' ?# Y) o( `e恩 是的   我是写错了  我应该是记得有A16  所以把d16写上去了  所以这个A16一直都还是警告
 楼主| 发表于 2011-11-16 14:14 | 只看该作者
哈哈  我知道怎么改啦  刚才终于对了  真的是太谢谢你了
 楼主| 发表于 2011-11-16 14:29 | 只看该作者
jacklee_47pn 发表于 2011-11-16 11:59 : \0 u$ Q  I/ k$ g' ]8 m2 J
喔~~~~
' \( s' ~; m* z. g+ n' ~- Q3 `. ?这样好像不行  如果加上GND这个端口    那么2个74hc373的OE端就会有冲突了
发表于 2011-11-16 15:04 | 只看该作者
把 74hc373 OE 管腳屬性改成<被動>
- S, `' P2 q/ p
 楼主| 发表于 2011-11-16 15:12 | 只看该作者
jacklee_47pn 发表于 2011-11-16 15:04
5 x2 Y( \' O/ _. K% N把 74hc373 OE 管腳屬性改成
8 s3 T$ ^; f1 y+ r: R  k3 _$ [' U哦   我知道了   但是那个阶层电路图连接的时候  老是出现这样的WARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,LCD EL1:  SCHEMATIC1, PAGE2  (256.54, 106.68)
: _7 P0 O7 Z8 G5 c3 RWARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,LCD RST1:  SCHEMATIC1, PAGE2  (256.54, 116.84)
! |4 d# O1 B% f' l: Q/ F5 lWARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,IDE RST1:  SCHEMATIC1, PAGE2  (256.54, 127.00) $ {- `9 Q& @! s! e, e
WARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,VCC:  SCHEMATIC1, PAGE2  (256.54, 86.36) ' T& B$ W) ]! |1 _) w' C
. y* K& U5 M# b2 G1 Y( G! F0 f
还有这个[DRC0026]   This reference has already been assigned to a different package type. U6:  PAG2SH2, PAGE1SH1  (99.06, 93.98) ! c8 `6 k- ^( `7 S
[DRC0026]   This reference has already been assigned to a different package type. U6:  PAG2SH2, PAGE1SH1  (127.00, 175.26)
* s* w/ k: @" D
  u1 Q4 v8 o% k- I+ b请问这是什么原因呢    $ |) f1 s0 d2 J- R; }& h: S8 B& A. h
   是不是端口没用好呢
6 _4 Z* ~7 @. Q
13#
发表于 2011-11-16 15:33 | 只看该作者
9 }7 ^  z) q+ K0 |3 u) o8 E5 r; ?* N$ E
你的 ORCAD 是幾版的? 你的原理圖經上面修改之後,已經沒有問題了啊。 我這邊 DRC 結果如下1 L: d  ^; @7 d. Q+ W/ P7 K
+ S, k. t; D0 I. A  ^- h
6 n; l6 n: L# J: l% P1 g4 FDate and Time : 11/16/11 15:02:57$ A6 i6 l4 K, M0 u
6 t  @3 l0 |5 E2 L8 W9 \--------------------------------------------------
' a" c# L! n  c9 S4 p' _Checking Schematic: PAG2SH2$ v- I7 ], Y' f3 k0 N
  J; h6 z( x9 i3 ?7 uChecking Electrical Rules # E+ `0 I, H" R9 l2 H9 c$ L  J- ]
1 r, p  V. Z/ l6 N+ v" X
Checking For Single Node Nets
" T* H5 \, _2 o# ?! S) R$ z5 {
- |' c1 N' b; t" R! Z& |$ aChecking For Unconnected Bus Nets8 n+ I) }/ a% D- p' \
# R9 v3 ^- D0 r4 W. B" }0 W
6 ]1 ?9 R- d2 c5 nChecking Schematic: SCHEMATIC1
& |( r# i: |2 F$ q! H7 i--------------------------------------------------4 c, P" D( j1 ^
Checking Electrical Rules ) M7 B  V( L3 a
* C2 H; g( e$ h- k
Checking For Single Node Nets1 x. C, t. O- M) [! B1 I
/ z3 L0 E0 M. |# q8 q0 D
14#
发表于 2011-11-16 15:37 | 只看该作者
我已經從 ORCAD 16.5 降成 16.2 。應該大多數的 ORCAD 都可以打開。
MY3MP4A.rar
49.52 KB, 下载次数: 13, 下载积分: 威望 -5
15#
 楼主| 发表于 2011-11-16 15:48 | 只看该作者
jacklee_47pn 发表于 2011-11-16 15:33
  _! i/ Z  d3 U& n) [你的 ORCAD 是幾版的? 你的原理圖經上面修改之後,已經沒有問題了啊。 我這邊 DRC 結果如下
9 s9 n  [  o+ o# P7 _: ~! A' K% {我的是9.2的  我的检查是这些
* e7 \6 h! X. ^3 q) B) S: N********************************************************************************
5 V1 C. J9 e( J6 i, ]" z*  H; V$ O, W9 z% n1 J
*  Design Rules Check1 ^+ O" n) K8 k7 J, f
/ f) g: E% i, T********************************************************************************
6 t$ F: q( b' \; ~2 X% @( L% ~3 K7 f: ^, x) B. {( a
Checking Pins and Pin Connections
/ }% {( r7 t' @" K9 b
$ c  }; [9 J3 t6 f0 z: ~--------------------------------------------------( `& z, X, Y; k6 z  d
Checking Schematic: PAG2SH29 s) B. v  @' v0 S3 r2 @2 d7 [
' ]1 H) V" U' I, d, y" FChecking Electrical Rules
: K7 U5 U- X3 v+ \' J3 B. i8 {0 p( c
' A2 s4 p( v8 B  [) i# v" T. _2 v/ M2 R! X
Checking Pin to Port Connections
  T( K( B! A* B
2 k8 y5 p% W) p: `; mChecking for Invalid References2 L6 q. L: n! Q: L  Y) t3 P; u
' r" w2 w1 h* \/ M[DRC0026]   This reference has already been assigned to a different package type. U6:  PAG2SH2, PAGE1SH1  (127.00, 175.26)
# H# p9 R+ R6 `% i9 _" j
' U" @. v. y& s. `' u+ ^0 h5 A, SChecking for Duplicate References9 }- `* P- w# t8 d/ Z
9 d1 Y, o' {: \--------------------------------------------------
9 b8 b( I! \+ G: DChecking Schematic: SCHEMATIC1
; b$ r3 q# _5 D--------------------------------------------------/ c- W. |$ b( w2 F6 h
Checking Electrical Rules $ S3 E/ H+ f4 g
& o1 q+ ~+ }, ~3 p) |$ x
Checking for Unconnected Nets1 o9 P! R' @5 c2 l% ^; L6 V, F4 p0 n
  A& d6 x' p8 ^! X" g* P$ J
Checking Pin to Port Connections0 c. r8 p8 X1 t, i6 s
WARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,LCD EL1:  SCHEMATIC1, PAGE2  (256.54, 106.68) , ^, K2 F* v4 D6 ?
WARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,LCD RST1:  SCHEMATIC1, PAGE2  (256.54, 116.84) & P9 }% q3 Q4 C1 L
" h  d1 x1 h$ O" jWARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,VCC:  SCHEMATIC1, PAGE2  (256.54, 86.36)
; {" R0 y: C1 y- q) N3 _' I% Q+ ^; D9 DWARNING [DRC0014]   Type of pin above does not match the pin type of corresponding port below SH2,GND:  SCHEMATIC1, PAGE2  (256.54, 132.08)
/ @1 ~! T$ G5 N! u2 s8 e+ _4 h3 W3 b8 l# _6 ]# z
, @+ o" P+ [' \  M( w3 h% e' c* h7 F! r$ O# w7 O
. j* A6 `: V0 L( R
GMT+8, 2025-10-27 05:49 , Processed in 0.156250 second(s), 28 queries , Gzip On.
