请参考:$ g) u5 j; i2 w
Usage: pcout.exe [options] filename* c0 p5 c! O9 b+ Y# D
options:# W! U6 Y; J* |, e5 R* U: m; n3 d
[-r(eference) input-db-filename] include file suffix" F( K! W% S1 J3 |2 W( Y9 w3 A" L! `
(If this option is omitted, basename.pcb is used.)- Z5 a, W& f. M& K8 B
[-o(utput) output-pcf-filename] include file suffix: A) }, c1 I4 Y9 }
(If this option is omitted, basename.pcf is used.)
$ ^$ |9 p0 ^, C$ i$ C [-p(arameter):unit unit-keyword]
, ?' w" T' _7 i1 ^# c. H (specifies unit of coordinate and length.7 k& f/ n& x1 ^) V# x8 I# [/ S
Unit-keyword is one of 'mm', 'inch', 'mil', 'micron' or 'dbunit'.)
. g* p7 B0 Y6 Z6 z! z [-p(arameter):layer specifies-layers]3 n1 R* v8 x$ q, F+ Z8 y& ~
(specifies output layers.
" Z" Y/ X4 \& }% `5 d0 j specifies-layers : LAYER_TYPE[ AYER_ID],LAYER_TYPE[ AYER_ID],...
" V) ~+ i; z f- X4 O if LAYER_ID is omitted, output all of specify LAYER_TYPE.$ J% u f# b3 h2 |2 w7 E: R
LAYER_TYPE:
, X+ M6 u( @8 x8 V) ^+ W S ... System Layer$ f. n/ E. D4 Z+ h/ I
C ... Conductive Layer
) } j) I: \# L4 ?$ V) y& j8 E N ... Non-Conductive Layer' z6 ?: O3 |! z! z3 b
SD ... System Drawing Layer
0 @/ Y! \+ a( K/ ]+ w CD ... Conductive Drawing Layer2 [- ^* H9 }) x& [9 Y0 T4 S0 Z
ND ... Non-Conductive Drawing Layer6 S3 |* C* f1 H/ `5 t
ALL ... All Layer
3 t0 C2 h$ R" S& I LAYER_ID of System Layer:8 f6 M I- @ o# E0 _
BOARD,HOLE,HOLE_ONLY,LAYOUT,BOARD_ASSY,BASEPOINT
, L) k, Z8 _4 {% @ ex. -p:layer C:1,S:BOARD,N:wirelimitation-A
V O: V- ^% s* T) h$ B ex. -p:layer ALL, l+ h0 z, k% U( X, R6 M
ex. -p:layer C,N,S:BOARD ) |
