4 l0 i" {! N5 T! V% n" o: t4 g0 P- ]" F0 e8 h0 ]9 c
------ Directives ------
9 ^+ ^$ Z8 r& p- x* nRIPUP_ETCH FALSE;
: q) F$ u" }" G0 V0 N# S6 @! ZRIPUP_DELETE_FIRST_SEGMENT FALSE;
; A/ m; x. K! k' S% v/ tRIPUP_RETAIN_BONDWIRE FALSE;4 w" d: ~7 d! @, y! R
RIPUP_SYMBOLS ALWAYS;
1 Y) T1 b3 ~+ s* @Missing symbol has error FALSE;( p f" H# k9 u8 i' I7 ?' X
SCHEMATIC_DIRECTORY 'D:/';
0 n; z' a$ S* t* n9 H# L( cBOARD_DIRECTORY '';
" ?, w7 t* B$ t4 [OLD_BOARD_NAME 'D:/cadence/SPB_Data/outline.brd';
$ m8 ]9 d0 Z( Q# j4 bNEW_BOARD_NAME 'D:/Cadence/SPB_Data/outline.brd';+ M r n- f o" T/ u# b( E
CmdLine: netrev -$ -i D:/ -y 1 D:/Cadence/SPB_Data/#Taaaaaa03208.tmp, j, U. q" Z* \1 D( C
------ Preparing to read pst files ------( g O* l0 h6 v
& b4 O2 ]; |8 ?' ]6 @+ p#1 ERROR(24) File not found+ F7 a$ g: w' Z
Packager files not found' R" B( w$ e) X. s; Z$ u) ?- c
#2 ERROR(102) Run stopped because errors were detected: h+ \- C6 L' b( T' Z# Z( G7 I
netrev run on Apr 8 13:44:44 2013
: x/ U. [1 i% p! e# i. n3 x- ?9 UCOMPILE 'logic'
7 |! @# W2 I) sCHECK_PIN_NAMES OFF
! M; S- K- C, b6 x3 [% qCROSS_REFERENCE OFF
1 G, M _) S# u2 A8 eFEEDBACK OFF
9 U; Q, l0 _% LINCREMENTAL OFF2 ]' t2 y0 }1 S f7 u
INTERFACE_TYPE PHYSICAL: L" `' W2 l. T) |, ]* Z+ b7 R& o" C
MAX_ERRORS 500% Q& {8 m, Y" s9 }' @- S
MERGE_MINIMUM 5* ^0 q1 k D. p( j# x
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'$ C) n" Q6 U2 E! c/ L
NET_NAME_LENGTH 24
9 {5 F4 H8 e3 K6 C9 T$ W$ N+ YOVERSIGHTS ON
0 {' s2 {% k3 A0 M( F. dREPLACE_CHECK OFF; z2 `' Q' `! ?
SINGLE_NODE_NETS ON1 y, ~7 d% D# U# L; U+ O& P% R+ s& y
SPLIT_MINIMUM 0
. D( }# b V4 L# q( D# r$ R' vSUPPRESS 20
{2 ]# o) f AWARNINGS ON
3 n1 |- S* w$ J+ Z4 Q2 O. X- R7 J2 errors detected
. R [5 j& M8 J T& PNo oversight detected- g( y! I/ V7 `
No warning detected |
