查看: 274|回复: 1
allergo-pcb导入网表报错求解?感谢
发表于 2022-7-11 22:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 JianMo 于 2022-7-11 22:44 编辑 9 i" O9 X! {# m% @
9 e5 L! k, k$ x6 D+ q在alergo-pcb中导入网表后就报下面的错误,路径检查过了没有中文和特殊字符,原理图导网表没有问题,有人遇到过这种问题吗?求解答,万分感谢!(用的allergo16.6版本)8 B# J+ D$ b; X+ _$ L
* N# B( p2 p$ x------ Directives ------RIPUP_ETCH FALSE;RIPUP_DELETE_FIRST_SEGMENT FALSE;RIPUP_RETAIN_BONDWIRE FALSE;RIPUP_SYMBOLS ALWAYS;Missing symbol has error FALSE;SCHEMATIC_DIRECTORY 'G:/allegro';BOARD_DIRECTORY '';OLD_BOARD_NAME 'G:/unnamed.brd';NEW_BOARD_NAME 'G:/unnamed.brd';CmdLine: netrev -$ -i G:/allegro -u -y 1 -z G:/#Taaaaad00852.tmp------ Preparing to read pst files ------Starting to read G:/allegro/pstchip.dat    Finished reading G:/allegro/pstchip.dat (00:00:00.07)Starting to read G:/allegro/pstxprt.dat    Finished reading G:/allegro/pstxprt.dat (00:00:00.03)Starting to read G:/allegro/pstxnet.dat    Finished reading G:/allegro/pstxnet.dat (00:00:00.01)------ Oversights/Warnings/Errors ------#1   Run stopped because errors were detectednetrev run on Jul 11 22:25:28 2022   DESIGN NAME : 'CAMERA20220707PM1'   PACKAGING ON Sep 10 2012 04:46:09   COMPILE 'logic'   CHECK_PIN_NAMES OFF   CROSS_REFERENCE OFF   FEEDBACK OFF   INCREMENTAL OFF   INTERFACE_TYPE PHYSICAL   MAX_ERRORS 500   MERGE_MINIMUM 5   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'   NET_NAME_LENGTH 24   OVERSIGHTS ON   REPLACE_CHECK OFF   SINGLE_NODE_NETS ON   SPLIT_MINIMUM 0   SUPPRESS   20   WARNINGS ON  1 errors detected No oversight detected No warning detected$ m6 ~0 ~, C- K# X" d) M
发表于 2022-7-12 11:11 | 只看该作者
是不是哪里没有设置好呢. c3 Y$ I- P$ x+ i0 Z
GMT+8, 2025-11-4 14:11 , Processed in 0.125000 second(s), 24 queries , Gzip On.
