SYM_NAME | COMP_DEVICE_TYPE | REFDES |
7X5MM | OSC3_7X5MM_IC_1.8MM_230-76774_2 | Y1 |
100MIL_TH | JUMPER1X2_100MIL_TH_IO_4MM_210- | JP5;JP6;JP12;JP13;JP15;JP16 |
0603LED | LED_0603LED_IC_1.1MM_370-75143_ | D1;D6;D11;D14;D15;D19;LD1;LD2 |
0603LED | LED_0603LED_IC_1.1MM_370-75144_ | D4;D7;D8;D9;D10 |
0603LED | LED_0603LED_IC_0.65MM_370-75905 | D12 |
745X101 | NETW_B8_10P_745X101_DISCRETE_47 | RN1;RN2;RN3;RN4;RN5;RN6 |
0805_CC | CAP_NP_0805_CC_DISCRETE_1.45MM_ | C998;C999;C1001;C1002 |
9132_SOCKET | PSC9132_9132_SOCKET_PSC9132 | U1 |
BAT338A | BATTERY-B_BAT338A_IC_13.5MM_670 | BT1 |
C035S | T POINT R_C035S_IC_0.1 MM_280-7 | TP1;TP2;TP5;TP8;TP9;TP13;TP14;TP15;TP16;TP17;TP18;TP19;TP20;3 a! |" f/ C' @3 |+ y- n- g1 z
TP21;TP22;TP23;TP24;TP25;TP26;TP27;TP28;TP29;TP30;TP32;TP33;* _& o+ ~( [- [; `3 |7 Z3 r
TP34;TP35;TP36;TP37;TP38;TP39;TP40;TP41;TP42;TP43;TP44;TP45;
# n" ^6 \5 ~$ K8 N* U s' `" t7 NTP47;TP48;TP49;TP50;TP51;TP52;TP53;TP54;TP55;TP56;TP57;TP60;1 x. H: |! N/ p5 |% |
TP61;TP62;TP63;TP64;TP65;TP66;TP67;TP68;TP69;TP70;TP71;TP72;
& N$ k% W r+ j* L& bTP74;TP75;TP76;TP78;TP79;TP80;TP81;TP82;TP83;TP85;TP86;TP87;
* R4 G9 j. F7 f9 t; b7 P* ^TP88;TP90;TP91;TP92;TP93;TP95;TP96;TP97;TP98;TP99;TP101;TP103;
/ {3 |6 p5 {- X& B; j( R \TP104;TP105;TP106;TP107;TP108;TP109;TP110;TP111;TP112;TP113;
5 I F, r4 i0 WTP114;TP115;TP116;TP117;TP118;TP119;TP120;TP121;TP122;TP123;
2 h0 K" N3 k* r0 u9 B! a- XTP124;TP125;TP126;TP127;TP128;TP130;TP131;TP132;TP134;TP138;& X9 z$ O9 G9 q3 r v& C$ m
TP139;TP140;TP146;TP147;TP148;TP149;TP154;TP159;TP161;TP164;" k8 T$ M( Y0 E$ I0 S* u& l6 h
TP165;TP168;TP169;TP170;TP171;TP172;TP173;TP174;TP175;TP176;3 R3 {7 N, W8 K! P
TP177;TP178;TP180;TP181;TP182;TP183;TP184;TP185;TP186;TP187;
$ G# j0 o' j( ~. r/ aTP188;TP189;TP190;TP191;TP192;TP193;TP194;TP195;TP196;TP197 |
C197_RAD_POL | CAP_POL_C197_RAD_POL_DISCRETE_1 | C41;C193 |
C335_RAD | CAP_POL_C335_RAD_DISCRETE_12.5M | C35;C43;C171;C172 |
CAP_5P5_RAD | CAP_POL_CAP_5P5_RAD_DISCRETE_12 | C20;C167 |
CAP_12P5_RAD | CAP_POL_CAP_12P5_RAD_DISCRETE_2 | C40;C175 |
CASE403A_03 | DIODE_CASE403A_03_IC_2.62MM_480 | D16;D17;D20;D21 |
CASE403D_02 | DIODE_CASE403D_02_IC_2.3MM_480- | D5;D13 |
CASE4527_12X7 | RES_CASE4527_12X7_DISCRETE_470- | R564;R565 |
CASE_D | CAP_POL_CASE_D_DISCRETE_3.2MM_1 | C73 |
CASE_E | CAP_POL_CASE_E_DISCRETE_4.10MM_ | C841 |
CASE_G_AL | CAP_POL_CASE_G_AL_DISCRETE_10.5 | C85 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | C520;C535;C540;C551;C552;C553;C558;C564;C567;C568;C569;C570;C574;
; q! _+ T5 D, C/ c( UC575;C576;C578;C580;C581;C582;C583;C584;C586;C587;C591;C595;C596;1 l8 M( M1 J# Z- L! u
C598;C608;C609;C612;C618;C621;C623;C628;C629;C630;C633;C634;C635;( [- p) J) ~# z5 N/ i& s4 i/ S( G7 G
C637;C640;C641;C642;C643;C646;C649;C650;C651;C652;C656;C665;C666;# H$ m3 U3 n3 s% z6 M( q0 e5 E1 c
C669;C670;C682;C685;C693;C702 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_2 | C521;C697 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33 MM_ | C542;C547;C548;C554;C555;C556;C557;C559;C566;C579;C585;C588;C592;
5 O+ b, x2 H4 l% S( Q' H& H3 T* |1 ?; DC593;C594;C599;C600;C601;C602;C603;C607;C610;C611;C622;C624;C625;7 J0 i* ^& q5 X& R
C626;C631;C632;C639;C644;C645;C653;C657;C671;C672;C673;C674;C686;" i2 d/ B4 Z. [# @$ `
C692;C694;C695;C696;C700;C701;C703;C705 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | C4;C5;C23;C45;C46;C56;C57;C63;C83;C84;C97;C105;C109;C110;C111;C112;, k- I) r3 T3 G
C114;C115;C116;C117;C119;C120;C122;C123;C124;C125;C126;C130;C131;
: ?5 Y5 _2 @( ?5 `0 O- @C132;C137;C138;C140;C141;C142;C143;C145;C146;C147;C150;C151;C153;
! P. J0 D+ v; d5 B; c0 B/ dC154;C155;C156;C157;C186;C213;C214;C215;C216;C224;C225;C228;C229;
2 A" L$ n+ \) g- d6 V- p4 H8 _C230;C240;C242;C244;C246;C249;C250;C254;C255;C256;C257;C259;C263;
! s* v+ ?, K; _# vC264;C265;C266;C267;C268;C269;C270;C271;C272;C274;C277;C278;C280;
6 G9 u8 ?5 a4 G t- X+ K& UC281;C288;C289;C290;C291;C296;C298;C299;C303;C304;C305;C308;C310;
4 J% W7 v: ^; H( ~+ lC311;C312;C313;C319;C320;C323;C324;C325;C326;C327;C328;C329;C330;
3 n2 f8 ` R2 u% e/ W) gC331;C338;C340;C342;C343;C344;C345;C349;C351;C355;C357;C358;C364;
$ E! G' h" {6 [/ i2 uC372;C373;C380;C407;C478;C481;C494;C501;C502;C504;C525;C527;C534; U6 f9 o, _- P
C605;C690;C740;C747;C748;C752;C756;C758;C760;C762;C763;C781;C799;
' o' F1 \. N% H2 s- x8 O5 I7 T2 VC814;C822;C831;C833;C834;C835;C836;C837;C842;C843;C844;C845;C846;) j7 L; {2 X- x6 g/ o
C866;C867;C889;C892;C894;C895;C899;C900;C901;C902;C908;C909;C910;1 k+ o+ U& [' \, Y4 e! C5 p
C911;C913;C915;C917;C922;C927;C929;C946;C955;C956;C968;C969;C973;
( V+ c+ c T L' \- D6 i" tC974;C981;C982;C988;C991;C992;C993;C994;C1008;C1009;C1010;C1014;/ B$ G" F2 Z# W' B2 u$ q% ?- J* }* P
C1015;C1016;C1018;C1019;C1021;C1022;C1029;C1030;C1031;C1032;C1033;; t3 o9 a3 t/ ~0 Y, b# ?. }
C1035;C1036;C1037;C1038;C1039;C1040;C1041;C1044;C1046;C1052;C1058;
0 S) m+ r2 T# `, r0 K2 HC1060;C1061;C1062;C1063;C1064;C1067;C1068;C1069;C1070;C1074;C1075;! F! {- r* i+ F* s9 R. ]
C1085;C1089;C1093;C1094;C1100;C1101;C1112 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | C7;C10;C66;C67;C260;C315;C322;C333;C371;C383;C384;C385;C396;C402;0 {0 L! j; C& d: A$ z' x
C409;C410;C412;C413;C422;C430;C433;C434;C437;C438;C445;C446;C447;) u1 X& @; f! h) F+ o
C448;C450;C452;C454;C462;C466;C469;C471;C472;C497;C538;C539;C735;
* ?8 B' _5 ]! FC790;C791;C798;C802;C805;C808;C815;C817;C818;C820;C821;C824;C827;& r; O) U* J7 F; |1 }+ d+ m0 { _
C830;C832;C847;C848;C849;C850;C856;C858;C861;C863;C864;C868;C872;
" G9 N& Q( _$ N) `8 }C879;C880;C920;C921;C925;C941;C952;C965;C1006;C1023;C1025;C1026;- ?2 Y- D$ y. \$ H6 I! P4 ~
C1027;C1048;C1049;C1054;C1055;C1077 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | C14;C26;C30;C32;C33;C37;C38;C39;C42;C44;C48;C49;C58;C60;C62;C74;6 d# F/ j! F0 Q& {0 e% N% r
C75;C78;C80;C88;C89;C93;C99;C100;C148;C149;C160;C180;C181;C182;; D. A% s5 c* U) Q$ o# r8 I0 ^! }
C183;C210;C217;C232;C235;C236;C237;C248;C251;C252;C261;C275;C279; E; t5 y- R3 }* J; M& H
C284;C285;C287;C293;C309;C317;C334;C337;C352;C359;C360;C361;C363;
' |1 B7 A" Q0 W$ n9 Q2 FC367;C368;C369;C370;C382;C387;C388;C389;C390;C391;C392;C395;C397;( ^1 }0 F, W4 C- ?9 O) N/ u
C398;C399;C401;C404;C405;C406;C408;C411;C414;C415;C416;C417;C418;
; B |/ W( }# i- bC419;C423;C424;C425;C426;C427;C428;C429;C431;C432;C435;C436;C439;
: a @- @) e% r& c0 Y( PC442;C444;C453;C456;C458;C459;C460;C461;C463;C464;C465;C467;C468;' O+ O: ~! t. Z0 e+ z# h/ F- P
C470;C480;C482;C488;C491;C492;C493;C495;C517;C518;C519;C523;C536;
' u2 G2 A4 B6 |! G7 Y% N% g. ZC541;C560;C563;C571;C604;C606;C627;C647;C654;C658;C675;C678;C679;
1 ^' B( }. G; _+ p; OC684;C689;C717;C721;C724;C732;C733;C741;C757;C764;C767;C768;C769;1 H6 a' O9 Z! i' o9 X. Y8 h1 W
C772;C774;C775;C776;C783;C785;C786;C788;C792;C793;C794;C795;C796;
6 P0 o7 ]- A& N7 o+ Z# Z( A2 uC797;C803;C804;C806;C807;C809;C810;C811;C812;C816;C819;C823;C825;. S* V) H! N& d# r$ R5 [& O
C826;C828;C829;C853;C854;C857;C859;C860;C862;C865;C871;C873;C876;
2 j1 [8 C$ O* R3 {" L% Y- M6 mC878;C888;C905;C906;C907;C919;C943;C961;C966;C967;C1020;C1076;
7 c5 P4 Y# N+ g# Q1 \C1080;C1081;C1083;C1087;C1096;C1108;C1110 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | C18;C185 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_6 | C47;C169 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_5 | C50;C51;C53;C54;C64;C82;C118;C227;C496;C505;C522;C573;C855;C893;C945 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_4 | C70;C220;C765;C766;C778;C779;C839;C840;C851;C852;C959;C980;C990;C1028 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_8 | C76;C77;C516;C537 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_9 | C94 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6 M | C98;C103 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | C102;C231;C365;C386;C394;C400;C403;C420;C440;C441;C449;C451;C455;0 }6 h7 q# v2 x0 ?* Z4 O( P# e
C457;C615;C620;C636;C638;C659;C698;C753;C770;C771;C773;C782;C784;
( g1 r6 g8 W+ `) t0 e0 PC787;C789;C874;C875;C877;C953;C972;C987;C1017;C1024;C1034;C1042;
- Q, A2 B4 \5 K! |C1043;C1045;C1047;C1056;C1057;C1088;C1097 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | C107;C113;C127;C129;C144;C152;C510;C511;C512;C513;C514;C515;C530;/ Q6 Q+ d8 n8 T4 R9 L6 S, k
C531;C614;C687;C688;C691;C708;C714;C720;C736;C742;C743;C751;C800;* M% p5 A N0 i: C1 b- q
C891 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | C161 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | C194;C335 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_7 | C218;C550;C561;C590;C613;C664;C668;C715 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_5 | C241;C253;C297;C300;C341;C350;C727;C728;C737;C739 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.59M | C286;C938 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | C379;C1072 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | C543 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74M | C661 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | C729;C738 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | C996;C997;C1000;C1003 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.6_1 | C52;C168 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.6_4 | C65;C282;C295;C314;C318;C347;C348;C362;C489;C648;C869;C870;C898;4 W3 {% P5 y) F1 ~3 L
C912;C914;C923;C924;C926;C934;C940;C976;C977;C978;C979 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.6MM | C133 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.55M | C134 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.5_1 | C136;C139 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.6_2 | C170;C262 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.635 | C176;C177;C178;C179;C306;C307;C662;C890;C897;C930;C931;C983;C984;$ L) b! Z3 c) \3 e: p$ Q
C985;C986;C1113;C1114 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.6_3 | C273;C947 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.5_2 | C283;C942 |
CC0402_HD | CAP_NP_CC0402_HD_DISCRETE_0.5MM | C1109;C1111 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | C1;C104;C121;C195;C196;C223;C354;C995;C1066;C1073 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_1 | C2;C3;C13;C31;C128;C162;C192;C197 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0MM | C15;C72;C79;C198;C199;C201;C202;C204;C205;C207;C208;C473;C475; `, K$ t7 t* r: v. i
C479;C483;C484;C485;C486;C487;C549;C562;C565;C589;C616;C660;C667;/ |6 M9 }% L( w3 Q5 b" _
C723;C935;C936;C944;C948;C962;C963;C970;C971;C1053;C1090;C1091;
: O0 C% h+ q$ x, ]# N2 c* ]C1098;C1099;C1102;C1103;C1104 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | C16;C187 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | C17;C184 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | C81;C221;C222;C958;C1007 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_6 | C86;C87 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_4 | C90 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.95M | C91;C92 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_5 | C95;C718 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_2 | C135;C677 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_3 | C158;C159;C374;C375;C376;C377;C378;C503;C506;C507;C508;C509;C528;
2 C: X" O2 {9 B2 j. OC529;C617;C681;C683;C704;C709;C716;C722;C725;C755;C883;C884;C885;
3 p i; \1 {# d: d. N I$ ?) o6 i) j& {C886;C887 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_2 | C321;C366;C476 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | C356;C1065 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | C381;C443;C474;C524;C544;C663;C730;C777;C838;C896;C939;C954;C960;% a. m/ J" h/ Y5 o
C1078;C1079;C1082;C1084;C1086;C1095 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_3 | C577 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_4 | C597 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | C676;C746;C761 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | C1092 |
CC0603_OV_POL | CAP_POL_CC0603_OV_POL_DISCRETE_ | C200;C393 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.2_1 | C21;C25;C28;C163;C164;C188;C191;C212 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.6MM | C106;C813 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.27M | C219;C904;C1004 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | C276;C294;C302;C498;C499;C500;C619;C712;C731;C734;C932;C933;C950 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.2_2 | C421;C744 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.7MM | C699 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9 M | C6;C55;C61;C96;C173;C174;C316;C336;C346;C477;C526;C545;C706;C707;3 n* }" ]7 B8 l+ d+ T5 w
C745;C916;C918;C937;C949 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | C19;C22;C24;C27;C165;C166;C189;C190 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.4MM | C209;C211;C226;C233;C234;C239;C951;C957;C989;C1013;C1059;C1071 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | C243;C245;C780;C801;C928;C975 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8 M | C339;C713 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9_1 | C532;C533;C680 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8_1 | C546;C572 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM_15 | C29;C34;C238;C292 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.413MM_ | C36;C59;C68;C69;C71;C101;C108;C203;C206;C258;C353;C490;C710;C719;5 P( _- h8 }; |$ A
C750;C903;C964 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.42 MM_ | C247;C332;C711;C749 |
CC1812_A | CAP_NP_CC1812_A_DISCRETE_2.79MM | C882 |
CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2.1M | C754 |
CC7343 | CAP_POL_CC7343_DISCRETE_4.3MM_1 | C759 |
CC7343 | CAP_POL_CC7343_DISCRETE_3.1MM_1 | C881 |
CC7343-38 | CAP_POL_CC7343-38_DISCRETE_4MM_ | C655;C726 |
CON5_SMA_50OHM | CON_SMA_50OHM_JACK_CON5_SMA_50O | J12;J13;J31;J35;J36;J40;J48;J49 |
CON9_MICROAB_USB_SHELL_TH | MICRO_USB_CONN_9PIN_CON9_MICROA | J1 |
CON19_SDCARD_28X16_SM | CONN_SDC013_19P_CON19_SDCARD_28 | J45 |
CON_60_QTH_0P5_SM | QTH-030-02-L-D-A_CON_60_QTH_0P5 | J37 |
CON_180S_QTH_0P5_SM | QTH-090-01-L-D-A_CON_180S_QTH_0 | J2;J18;J33 |
CON_ATXPWR_2X12_A | CONN_PWR_12X2_CON_ATXPWR_2X12_A | J20 |
CON_FTR-125-01-S-D | CONN_HDR_25X2_CON_FTR-125-01-S- | J19 |
CON_PCIE164_1_SM_9132QDS | W3GD-164AN63B52UW_CON_PCIE164_1 | J41 |
CON_RJ11_12F_50_TH_RA | RJ-11_RIGHT-ANGLE_PHONE_PLUG_CO | P2 4 |
CON_RJ45_MAG_LED_GETH | RJ45_MAG_LED_CON_RJ45_MAG_LED_G | P5 6 |
CON_SIM_CD_SW | FMS006-0001_CON_SIM_CD_SW_IO_2. | P1 |
CON_SMA_200SQ_RA | CON5_SMA_MMCX_CON_SMA_200SQ_RA_ | J21 |
CON_SODIMM144 | CONN_SODIMM_VERT_144PIN_CON_SOD | P3 |
CRA06-8 | RES_ISO4_SINGLE_CRA06-8_DISCRET | RN7;RN8 |
D2PAK_A | MOSFET_IRLZ24_D2PAK_A_IC_4.83MM | Q1;Q9 |
DIP8_4PIN_100MIL | CN4_DIP8_4PIN_100MIL_IC_4.19MM_ | J34 |
DO_VMN2 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | D2;D3 |
DUALDB-9M_RA | DUAL_DB9M_RA_DUALDB-9M_RA_IO_31 | J44 |
FBGA78_0P8_9X11P5 | 4G_DDR3_SDRAM_512MX8_FBGA78_0P8 | U30;U31;U32;U33;U34;U68;U69;U70;U71;U72 |
FBGA676_1MM_27X27 | A3PE1500-676P_FBGA676_1MM_27X27 | U19 |
FUSE_6P6X3P2MM_SM | FUSE_RESETTABLE_FUSE_6P6X3P2MM_ | F1;F2;F3;F4;F8;F9;F10;F11 |
HDR1X3_TH | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | J16 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | JP1;JP2;JP3;JP4;JP7;JP8;JP9;JP10;JP11;JP14 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_IO_ | J7;J8;J9;J10;J11;J15;J22;J23;J26;J27;J28;J29;J30;J39;J50 |
HDR203_M20 | CONN_HDR_3X2_HDR203_M20_IO_8.64 | J6;J38 |
HDR205_HTST_SM | HTST-105-01-S-DV_HDR205_HTST_SM | J14;J24 |
HDR208_HTST_SM | HTST-108-01-L-DV_HDR208_HTST_SM | J3 |
IND_0603 | BEAD_IND_0603_DISCRETE_0.95MM_1 | F6;F7 |
IND_0603 | IND_IND_0603_DISCRETE_1MM_180-7 | F12;F13;F14;F15;F16;F17;L23;L24;L29;L33;L34;L35;L36;L37;L45;L46;; A2 w1 r% \" V& C5 N! ?7 P8 |
L47;L48;L51 |
IND_0603 | INDUCTOR_IND_0603_DISCRETE_0.8M | L7;L11;L22;L31;L32 |
IND_0603 | INDUCTOR_IND_0603_DISCRETE_0._1 | L12;L27 |
IND_0603 | IND_IND_0603_DISCRETE_1MM_180_1 | L21;L42;L43;L49;L50;L52 |
IND_0805 | INDUCTOR_FERRITE_IND_0805_DISCR | F5 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05MM_1 | L25;L44 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05MM_2 | L30 |
IND_1812FS_5X4MM | INDUCTOR_IND_1812FS_5X4MM_DISCR | L4;L14 |
IND_2012 | INDUCTOR_IND_2012_DISCRETE_1.35 | L38;L39;L40;L41 |
IND_BLA31 | IND_BLA31A_IND_BLA31_1.0MM_180- | L19;L20;L26;L28 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3.0 | L3;L5;L6;L9;L10;L13 |
IND_IHLP-5050 | COIL_IND_IHLP-5050_DISCRETE_6.5 | L8 |
IND_SLF7045 | INDUCTOR_IND_SLF7045_DISCRETE_4 | L1;L15 |
IND_SLF7045 | INDUCTOR_IND_SLF7045_DISCRETE_1 | L2;L16 |
JUMP2X2-6040 | HDR-2X2_JUMP2X2-6040_IO_8.58MM_ | J17 |
LFCSP16_0P65_4X4 | ADP2118_LFCSP_16P_LFCSP16_0P65_ | U15;U23;U59;U60 |
LQFP32 | ICS83947I-147_LQFP32_IC_1.6MM_3 | U67 |
LQFP_80 | LE88266DLC_LQFP_80_IC_1.6MM_312 | U8;U93 |
MICROPAK_6P | 74LVC2G17_MICROPAK_6P_IC_0.55MM | U160 |
MODULE28_1P1_23X17 | LEA-6T_28P_MODULE28_1P1_23X17_I | U136 |
MSO8 | ADT7461_MSO8_IC_1.1MM_315-75543 | U141 |
MSOP8_0P65_3P1X3P1 | MIC47100YMME_MSOP8_0P65_3P1X3P1 | U54 |
MSOP10_60X12 | ADG804_MSOP10_60X12_IC_1.10MM_3 | U52;U64 |
MSOP_10_0P5_3X3 | INA220AIDGST_MSOP_10_0P5_3X3_IC | U25;U57;U66;U78 |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_0.05MM_28 | MH1;MH2;MH3;MH4;MH5;MH6;MH7;MH8 |
OSC4_7P2X5P2MM | OSC3_OSC4_7P2X5P2MM_IC_1.9MM_23 | Y4 |
OSC4_7P5X5MM | CLKOSC_4PIN_OSC4_7P5X5MM_IC_1.4 | X2;X4;X5 |
OSC4_7P5X5MM | OSC4_OSC4_7P5X5MM_IC_1.8MM_230- | Y2 |
PTH12050W | PTH12050L_PTH12050W_IC_8.50 MM_ | U76 |
QFN16_3X3MM | NCN4555MN_QFN16_3X3MM_IC_0.8 MM | U113 |
QFN24_4X4MM | MAX16006_TG+_QFN24_4X4MM_IC_0.8 | U17;U20 |
QFN24_4X4MM_SLUG | USB3315_QFN24_4X4MM_SLUG_IC_1.0 | U29 |
QFN26_0P5_5X5 | MC34716_A_QFN26_0P5_5X5_IC_1MM_ | U21;U84 |
QFN32_MC1320X | AD9553_LFCSP_32P_QFN32_MC1320X_ | U77 |
QFN36_0P5_6X6 | ZL2006_QFN36_0P5_6X6_IC_1MM_315 | U46 |
QFN_10_0P5_3X3 | TPS74701_SON_11P_QFN_10_0P5_3X3 | U83 |
RC0201 | RES_RC0201_DISCRETE_470-76555_1 | R584;R586;R683;R689 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | R1;R393;R396;R397;R399;R400;R401;R402;R408;R569;R937 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | R2;R3;R13;R14;R15;R16;R35;R36;R108;R113;R115;R117;R146;R171;R221;! n4 S4 N5 o2 v, K; W! r Y+ ^0 q
R378;R379;R384;R385;R403;R404;R405;R406;R496;R502;R512;R568;R594;
5 z5 w( e4 a- G, R& ?8 j1 t- P tR597;R723;R1029;R1030;R1031;R1032;R1033;R1034;R1035;R1036 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-75_1 | R5;R6;R104;R120;R324;R325;R364;R365;R367;R368;R375;R463;R482;R483;
* g5 J3 Z, {( Q: s- p6 t% x$ XR494;R495;R513;R520;R522;R527;R550;R567;R574;R577;R679;R685;R736;0 Q& N! o$ N5 r1 ?' M
R743;R780;R783;R791;R794;R795;R801;R802;R811;R876;R877;R878;R881;
4 d$ ^$ g) t G; U: I6 k+ w& F8 OR882;R883;R884;R885;R887;R889;R943;R944;R945;R946;R947;R950 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7647 | R7;R56;R57;R58;R59;R60;R61;R62;R63;R64;R70;R71;R72;R141;R142;R143;
) k; j2 o& |- {" O9 w* }7 f. eR148;R150;R152;R156;R159;R161;R164;R167;R181;R201;R205;R305;R308;% V6 @7 l& }: p% f% m1 ^
R311;R317;R363;R503;R504;R515;R547;R551;R553;R554;R555;R556;R557;
& ^' @6 R3 a" w+ JR558;R559;R560;R562;R581;R583;R607;R613;R618;R622;R627;R634;R638;
; e8 v' x! J7 Q0 i) u5 s0 |4 H ~R642;R643;R653;R655;R664;R666;R668;R674;R676;R678;R681;R684;R690;
6 W2 c0 J/ H2 zR691;R692;R693;R695;R778;R843;R844;R847;R848 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | R8;R9;R10;R11;R17;R18;R19;R20;R21;R22;R37;R38;R39;R40;R41;R42;R43;! Y+ ~! d' b7 T7 g y5 G6 K) `9 {
R44;R45;R46;R47;R48;R49;R50;R51;R52;R53;R54;R55;R83;R85;R100;R110;; V/ u/ D' n" ]( [, m
R111;R112;R114;R121;R126;R128;R178;R180;R183;R187;R191;R192;R193;+ b1 N% V& J* q5 N8 T; v4 m5 I; e0 e
R200;R202;R207;R209;R214;R220;R229;R233;R235;R237;R257;R258;R260;/ u, j9 m- ^% P6 y/ N5 j$ D1 M. ?
R276;R278;R284;R285;R286;R288;R289;R290;R291;R292;R293;R296;R297;# |! {3 u) s: u% ]8 O* ?7 y
R298;R299;R301;R304;R306;R312;R313;R314;R315;R323;R331;R332;R339;4 p2 _% A+ U+ \. T
R340;R341;R342;R343;R344;R345;R346;R347;R350;R362;R366;R369;R415;; j" A# y) e+ ?' v% k
R416;R417;R418;R419;R420;R421;R422;R423;R424;R425;R426;R427;R437;" Z/ K' ^& d% T3 o0 K$ k
R438;R451;R462;R467;R474;R475;R478;R479;R492;R535;R549;R552;R561;
1 P% S* [8 a5 M3 h wR572;R575;R579;R590;R601;R602;R606;R609;R612;R621;R626;R635;R640;3 O0 E9 u7 j1 y' |: @! m: ^. R
R645;R650;R652;R658;R667;R672;R673;R677;R682;R715;R727;R730;R748;4 f9 ~; @- W8 n4 D* f( z
R752;R756;R764;R775;R776;R777;R779;R784;R786;R793;R796;R797;R798;
7 g# w( } B" @5 \R800;R845;R846;R853;R892;R893;R895;R897;R901;R935;R948;R949;R952; Q! m: M2 R( v# W2 @( m
R953;R956;R964;R965;R966;R967;R968;R969;R970;R971;R972;R973;R974;. O" t0 L6 l& f g" z- I
R975;R976;R977;R978;R979;R980;R981;R982;R983;R984;R985;R986;R987;
; w ^' O9 }* }5 g" R, N: N- ZR988;R989;R990;R991;R992;R993;R994;R995;R996;R997;R998;R999;R1000;
5 j3 h% o" a- ~$ Y) X4 bR1001;R1002;R1006;R1007;R1008;R1009;R1010;R1014;R1027;R1028;R1037;
8 O9 w5 p7 b' n; F* kR1039;R1040;R1041;R1042 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | R12;R65;R67;R303;R307;R309;R316;R319;R348;R370;R372;R374;R380;R386;
- J, t4 }1 G( y( P( G, {R523;R548 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | R23;R27;R170 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | R24;R25;R26;R30;R939;R940;R941;R942 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | R31;R353 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | R66;R73;R144;R188;R194;R210;R212;R231;R232;R234;R355;R430;R432;R434;' f4 q8 t8 I5 u7 Q# D; I: C
R466;R481;R493;R499;R566;R591;R598;R610;R619;R633;R636;R686 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | R74;R75;R76;R78;R98;R136;R138;R140;R145;R149;R151;R153;R154;R157;R160;
6 f; D3 A! |4 Y3 o$ k7 m. B8 hR162;R163;R165;R166;R168;R169;R172;R173;R175;R176;R177;R179;R197;R199;1 X) y6 S4 w1 H1 _- l! w# ~
R204;R206;R213;R217;R236;R265;R266;R267;R269;R270;R272;R281;R282;R334;+ e8 Q9 F: O& q# w. M
R413;R440;R444;R446;R447;R449;R450;R457;R460;R465;R472;R477;R486;R488;: B! U! j: _+ S! x* S5 R. p
R497;R514;R571;R588;R589;R600;R603;R608;R616;R623;R628;R632;R639;R644;
8 ~: ]* m* }+ h5 n; E( b" xR651;R654;R656;R659;R669;R670;R675;R702;R704;R706;R707;R710;R725;R731;
: G* _" g. W g' ~R733;R734;R742;R747;R774;R782;R787;R790;R804;R826;R837;R865;R879;R880;9 m" N" b* K) V$ \- [
R886;R888;R917;R918;R919;R920;R921;R922;R923;R924;R925;R926;R927;R928;( ^% C0 X3 L! V9 f7 ?( d
R929;R930;R931;R932;R933;R934;R954;R957;R963;R1018 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | R79;R82;R90;R93;R131;R134;R505;R506;R507;R508;R509;R510;R737;R738;R740;
& x p8 U. S3 \ y* ?% t* j/ c# eR741;R744;R746;R757;R758;R759;R792;R799;R803;R805;R816;R818;R820;R839 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-31_1 | R80 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3091 | R81;R88;R94;R96;R99;R103;R109;R454;R456;R468;R469;R470 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3106 | R87 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3092 | R89 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7620 | R97;R102;R105 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | R101;R189;R333 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3093 | R107;R118;R287 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | R116;R125;R158;R185;R190;R195;R196;R251;R262;R279;R320;R321;R322;R328;, k9 W8 q* _9 |8 D8 o
R445;R452;R455;R458;R473;R501;R580;R592;R599;R687;R688;R712;R721;R785;
% d1 q9 `8 N! d, UR789;R815;R817;R819;R829;R830;R840;R912;R1005;R1013 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | R124;R225;R226;R227;R228;R268;R271;R698;R699;R722;R728;R773;R822;R827;% z, m0 F" @* m. y
R828;R834;R835;R838;R955;R958;R1004;R1012 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7669 | R129 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7606 | R132;R133 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | R135;R850 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3027 | R137;R238;R239;R377;R825;R836;R849;R864 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-76_1 | R174;R582 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_2 | R184;R203;R617 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_3 | R198;R631 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_4 | R208;R211 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.35MM_4 | R218;R219;R241;R242;R244;R245;R595;R596;R624 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_5 | R222 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_6 | R224 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_7 | R230 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | R243;R250;R442;R443;R735;R751;R831;R959;R960;R961;R962 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_8 | R246 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_9 | R247 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 _10 | R248 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 _11 | R249 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.35MM_1 | R253;R694;R696;R697 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3084 | R254;R256 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | R300;R302;R541;R543;R646;R647;R648;R649;R750;R755;R1038 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3089 | R326 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3085 | R329 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3079 | R330;R464;R498;R810 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3098 | R371 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | R381;R382;R409;R410;R411;R412 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__7 | R398;R441;R485;R545;R938 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3102 | R448;R821 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3090 | R453;R812 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-76_2 | R459;R814 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3077 | R526;R528;R530;R531;R532;R533;R534;R536;R537;R538;R760;R761;R762;
/ T. v- {- D0 DR763;R766;R767;R768;R769;R770;R771 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3016 | R529;R540;R542;R544;R745;R749;R754;R772 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3069 | R570;R593;R724;R726 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3015 | R573;R576;R614;R615;R936 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 _12 | R629 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 _13 | R630 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7623 | R660 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 _14 | R661 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | R662 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | R851;R854;R855;R856;R857;R858;R859;R860;R874;R875 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | R852;R867;R1003;R1011 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__9 | R863;R866;R868;R869 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7646 | R890;R891 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-30_1 | R894;R902 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_1 | R896;R904 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_2 | R903 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | R1019;R1020;R1021;R1022 |
RC0402_X2 | 2R3_5_RC0402_X2_DISCRETE_0.45 M | R84;R86;R283;R585;R587;R714;R717;R832 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-30_1 | R4 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_1 | R32;R33;R335;R352 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | R34;R139;R147;R252;R280;R318;R637;R657;R781 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7542 | R77;R106;R261;R263;R275;R277;R703;R716 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7666 | R91;R264;R732 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | R92;R122;R273;R274;R327;R439;R719;R753 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3015 | R123 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | R186;R215;R604 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | R216 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | R223 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7619 | R240;R898;R905;R906;R907 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3012 | R259 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3013 | R354 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | R356;R358;R487;R490 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_2 | R357;R359;R491;R511 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7794 | R433;R500;R519;R521;R525;R539;R546;R899;R900 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7801 | R461;R813 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7998 | R516 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7779 | R605;R611;R625;R641;R663;R665;R711 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7551 | R700 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3048 | R701 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-30_2 | R708 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7577 | R709;R718 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | R720;R729 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_3 | R765 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.70 MM_ | R28;R29;R351;R373;R383;R389;R390;R391;R392;R394;R407;R414;R428;2 h9 p! V) b" N) C
R429;R431;R806;R809;R823;R824;R833;R841;R842;R872;R873;R908;R909;R910;R911 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | R95;R336 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_4 | R182 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7MM_47 | R376;R387;R388;R395;R807;R808;R870;R871 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_1 | R435;R436;R861;R862 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | R471;R476;R480;R484;R913;R914;R915;R916 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7994 | R524 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.65 MM_ | R680 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-7710 | R119;R127;R130;R255;R310;R337;R489;R578;R620;R671;R788 |
RC1206_OV | RES_RC1206_OV_DISCRETE_0.7MM_47 | R155 |
RC2010 | RES_RC2010_DISCRETE_0.7 MM_470- | R68;R69;R338;R349;R361;R518 |
RC2512 | RES_RC2512_DISCRETE_1.1 MM_470- | R360;R517 |
RES_4P_9X9MM | RES_4PIN_RES_4P_9X9MM_0.889MM_4 | R713;R739 |
S08_1P27_4X5 | M95640-W_S08_1P27_4X5_IC_1.75 M | U47 |
SC70-5 | 100201_SO_10_SC70-5_IC_1.1MM_31 | U16;U89 |
SC70-5_A | 1G125_SC70-5_A_IC_1.1MM_312-301 | U96;U99 |
SC70-5 | ONE_AND_SC70-5_1.1MM_312-30302_ | U131 |
SC70-6 | NC7SB3157_6P_SC70-6_IC_1.1MM_31 | U41;U42;U43;U56;U62;U102;U103;U142;U143;U155;U156;U161;U162 |
SC-70 | SN74LVC1G04_SC-70_IC_1.1MM_312- | U24 |
SIG_TIE_100X200 | SIG_TIE_100X200_SIG_TIE_100X200 | J25;J46;J47 |
SLP1616P6 | RCCLAMP_SLP1616P6_IC_0.65MM_312 | U104 |
SO6_A | 1T45_SO6_A_IC_1.1MM_312-75172_S | U123;U124;U132;U137;U139;U150 |
SO8-25X75-200 | AT45DB081D-SU_SO8-25X75-200_IC_ | U48 |
SO8 | ICS553_8P_SO8_IC_1.75MM_312-765 | U61;U87;U88;U159 |
SO8-25X75-200 | W25X80V_SO8-25X75-200_IC_2.16MM | U138 |
SO8_1P27_4X5 | TISP61089H_SO8_1P27_4X5_IC_1.75 | U106;U107;U152;U153 |
SO16 | ICS307M-02_SO16_IC_1.75MM_312-7 | U86;U90;U119;U120 |
SO16 | LCDA15C-8_TBT_SO16_IC_1.75MM_31 | U100 |
SO20W | DS3232S_SO20W_IC_2.67MM_315-767 | U114 |
SO-8 | SI4850EY_SO-8_IC_1.75MM_480-774 | Q2;Q3;Q5;Q6;Q7;Q13 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1.35MM_ | CR1 |
SOIC8 | PI90LV179-8P_SOIC8_IC_1.75MM_31 | U166 |
SOT23 | DUALDIODE_CA_SOT23_SOT23_IC_1.1 | D18;D22 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | Q4 |
SOT23 | 2N7002_SOT23_IC_1.3MM_480-75159 | Q10;Q16 |
SOT23 | PNP_SOT23_IC_1.1MM_480-76358_MM | Q11;Q17 |
SOT23 | DS1818_SOT23_IC_1.12MM_312-3003 | U118 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | U2 |
SOT23-6 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | U3;U5;U6;U9;U10;U11 |
SOT23-6_A | SN74LVC2G07_SOT23-6_A_IC_1.45MM | U58 |
SOT23-40X40 | FDV301N_SOT23-40X40_IC_1.3MM_48 | Q8;Q12 |
SOT223-6 | TPS73701_SOT223-6_IC_1.8MM_312- | U163 |
SOT-23-5 | SN74LVC_SOT-23-5_IC_1.45MM_312- | U126;U127;U128 |
SOT_C8140_10P | C8140_FLYBACK_XFRM_SOT_C8140_10 | T1;T2 |
SO_8 | AT24C64AN_SO_8_IC_1.75MM_334-76 | U7;U117 |
SSOP-28 | HIN211_0_SSOP-28_IC_2MM_312-758 | U101;U140 |
SSOT6_1P7X3 | FDC6330_SSOT_6P_SSOT6_1P7X3_IC_ | U40;U135 |
SUBASSY_SFP-CAGE | CON_CAGE_SUBASSY_SFP-CAGE_IO_9. | J42;J43 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | SW13;SW14;SW15;SW16;SW17 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_IC_2. | SW1;SW2;SW3;SW4;SW5;SW6;SW7;SW8;SW9;SW10;SW11;SW12 |
TDFN_8_0P65_3X3 | MAX3394E_TDFN_9P_TDFN_8_0P65_3X | U14;U26;U28;U55 |
TDSON8_1P27_6X5MM | MOSFET_N_8P_TDSON8_1P27_6X5MM_I | Q14 |
TDSON8_1P27_6X5MM | MOSFET_N_8P_TDSON8_1P27_6X5MM_1 | Q15 |
TESTPOINT_079_051MIL | TPS_RECT_TESTPOINT_079_051MIL_2 | MP1;MP2;MP3;MP4;MP5 |
TESTPOINT_100_050MIL | TESTLOOP_TESTPOINT_100_050MIL_I | TP94;TP100;TP167 |
TEST_LOOP | TESTLOOP_TEST_LOOP_4.8MM_210-75 | TP11;TP12;TP102;TP137;TP144 |
TFBGA100_0P8_9X9 | VSC8221_TFBGA100_0P8_9X9_IC_1.1 | U97;U98 |
TO263_DPAK | RES_3P_TO263_DPAK_DISCRETE_470- | R563 |
TP_PTH | T POINT TH_TP_PTH_IC_0.1 MM_210 | TP73;TP77;TP84;TP89;TP135;TP136;TP141;TP142;TP143;TP145 |
TQFN28_0P5_3P6X5P6 | PI2DBS212ZHE_TQFN28_0P5_3P6X5P6 | U63;U65;U73;U74;U80;U81;U144;U145;U146;U147;U148;U149 |
TQFN42_TAB | PI2PCIE2422_TQFN_42P_TQFN42_TAB | U165 |
TSM2X7_SMD | CONN_HDR_7X2_TSM2X7_SMD_IO_9.65 | J5 |
TSOP48_18P5X12P4 | MT29F2G16AADWP_TSOP48_18P5X12P4 | U157 |
TSOP48_SKT | 980020-48-P2_TSOP48_SKT_IC_5.33 | U50 |
TSOP56 | S29GL01GP_TSOP56_IC_1.2MM_342-0 | U158 |
TSOP56_SK | S-TSO-SM-056-C1_TSOP56_SK_IC_5. | U38 |
TSSOP8 | ATMEL_SERIAL_EEPROM_64K-1_TSSOP | U4;U115 |
TSSOP8 | TPS2115_TSSOP8_IC_1.20MM_315-76 | U27;U151 |
TSSOP8 | ICS83052I_TSSOP8_IC_1.2MM_312-7 | U91;U92 |
TSSOP16 | IDTQS3VH257_16P_TSSOP16_IC_1.2M | U18;U22;U44;U45;U94;U95;U116;U129;U130 |
TSSOP16 | PCA9546A_B_TSSOP16_IC_1.1MM_312 | U36;U85;U125 |
TSSOP16 | 83052I_TSSOP_16P_TSSOP16_IC_1.2 | U37;U154 |
TSSOP16 | ICS557_03_TSSOP16_IC_1.2MM_312- | U53 |
TSSOP16 | 83054I_TSSOP16_TSSOP16_IC_1.2MM | U82 |
TSSOP16 | AD7993_16P_TSSOP16_IC_1.2MM_315 | U121;U122 |
TSSOP48_PH | 74ALVCH16373DGGRG4_TSSOP48_PH_I | U134 |
TSSOP56_0P5_14X6P1MM | SN74CBT16214D_TSSOP_56_TSSOP56_ | U35 |
TSSOP56_0P5_14X6P1MM | 74AVC20T245_TSSOP56_0P5_14X6P1M | U39;U49;U133 |
TSSOP_8 | M24C01_8P_TSSOP_8_1.2MM_334-774 | U12;U13 |
TVSOP24_0P4_5X6 | 74AVC8T245_24P_TVSOP24_0P4_5X6_ | U79 |
WSON_8 | S25FL128P_WSON_8_IC_0.8MM_334-7 | U51 |
XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | Y3 |
XTLOSC4_5X7_5 | SG8002_XTLOSC4_5X7_5_IC_1.8MM_2 | X3 |
XTLOSC4_JXS75_SM | XTAL_13Y_A_XTLOSC4_JXS75_SM_IC_ | Y5 |
XTLOSC4_SM | CLKGEN-SM_XTLOSC4_SM_IC_1.75MM_ | U75 |
XTLOSC4_SM | CLKGEN-SM_XTLOSC4_SM_IC_1.75M_1 | X1 |
