查看: 158|回复: 2
单片机4*4矩阵键盘接口电路程序 Proteus仿真图
发表于 2022-7-5 10:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
设计一个单片机键盘接口电路,实现4*4矩阵键盘,用数码管显示相应按键内容,当指定某一个按键连续被按三次时,显示“口”字符号,按键有去抖动功能,数码管可以通过清零键清零。
% z, I, v, c8 j- L1 A. K3 J! x7 e% c- K" `
仿真原理图
& ~$ w0 x- U( q" k 7 z$ n% H* s0 r. A  s
单片机源程序如下:& s- u7 j4 f6 H( _1 e' U9 O# N
  • //0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71 共阴
  • //0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E 共杨
  • #include <reg52.h>
  • #define GPIO_DIG    P0   //段选数码管
  • #define GPIO_KEY     P2      //矩阵按键
  • sbit led = P1^0;
  • typedef unsigned char uchar;
  • typedef unsigned int uint;
  • uint keynum = 0;
  • uint count=0;
  • uchar code table[]={0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71};
  • uchar code table0[]={0x5c};
  • void delay( uchar i ){
  •     while( i-- );
  • void key44scan(void)//键盘扫描函数
  • //                uint count=0;
  •     uint t;
  •     P2=0xfe;
  •     t=P2;
  •     t=t&0xf0;
  •                 if(t!=0xf0){
  •                         delay(100);
  •                         if(t!=0xf0)
  •                                         t=P2;
  •                                         count++;
  •                                         switch(t)
  •        case 0xee:keynum=1; break;
  •        case 0xde:keynum=5; break;
  •        case 0xbe:keynum=9; break;
  •        case 0x7e:keynum=13; break;
  •                                         P0=table[keynum];
  •                                         while(t!=0xf0)
  •                                                          t=P2;
  •                                                          t=t&0xf0;
  •                 P2=0xfd;
  •                 t=P2;
  •                 t=t&0xf0;
  •                 if(t!=0xf0){
  •                         delay(100);
  •                         if(t!=0xf0)
  •                                         t=P2;
  •                                         count++;
  •                                         switch(t)
  •        case 0xed:keynum=2; break;
  •        case 0xdd:keynum=6; break;
  •        case 0xbd:keynum=10; break;
  •        case 0x7d:keynum=14; break;
  •                                         P0=table[keynum];
  •                                         while(t!=0xf0)
  •                                                          t=P2;
  •                                                          t=t&0xf0;
  •                 P2=0xfb;
  •                 t=P2;
  •                 t=t&0xf0;
  •                 if(t!=0xf0){
  •                         delay(100);
  •                         if(t!=0xf0)
  •                                         t=P2;
  •                                         count++;
  •                                         switch(t)
  •        case 0xeb:keynum=3; break;
  •        case 0xdb:keynum=7; break;
  •        case 0xbb:keynum=11; break;
  •        case 0x7b:keynum=15; break;
  •                                         P0=table[keynum];
  •                                                         while(t!=0xf0)
  •                                                          t=P2;
  •                                                          t=t&0xf0;
  •                 P2=0xf7;
  •                 t=P2;
  •                 t=t&0xf0;
  •                 if(t!=0xf0){
  •                         delay(100);
  •                         if(t!=0xf0)
  •                                         t=P2;
  •                                         count++;
  •                                         switch(t)
  •        case 0xe7:keynum=4; break;
  •        case 0xd7:keynum=8; break;
  •        case 0xb7:keynum=12; break;
  •        case 0x77:keynum=0; break;
  •                                         P0=table[keynum];
  •                                         while(t!=0xf0)
  •                                                          t=P2;
  •                                                          t=t&0xf0;
  • //                        if(count==3){
  • //                                                count = 0;
  • //                                                led =~ led;
  • //                                                P0=table0[0];
  • //                                                delay(1000);
  • void main (){
  •                 led = 0;
  •     while(1) {
  •                                         key44scan();
  •                                         if(count==3){
  •                                                 //count = 0;
  •                                                 led =~ led;
  •                                                 P0=table0[0];
  •                                         //        delay(1000);
  •                                         if(count==4){
  •                                                 count = 0;
  •                                                 led =~ led;
  •                                                 P0=table[0];
  •                                         //        delay(1000);
    0 e* ]; M. w' J4 V  n( F
, k3 G: _* `* R9 c7 {( H" T& b$ {1 F8 t0 Q4 J) p4 c* t/ p% m
( O% K1 y% D  j$ ~
2 D1 K! Z1 O3 E" A4 N3 Y+ F
发表于 2022-7-5 11:05 | 只看该作者
认真学习技术上的知识
发表于 2022-7-5 13:43 | 只看该作者
帮助他人,解决问题,提升自己。
GMT+8, 2025-10-9 01:14 , Processed in 0.156250 second(s), 26 queries , Gzip On.
