查看: 173|回复: 2
在windows7上编译rtt遇到了arm-none-eabi-gcc的问题如何解决呢
发表于 2022-7-4 14:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
+ Q$ y- ]) V& D
( `" |# \2 d! z# e$ v- I最近在windows7上编译rtt,考虑到用cygwin上的git,svn同步代码方便,希望把scons编译方式也加到cygwin上,遇到了一个
. q" D: ?: N$ y, D' Lsh: ARM-none-eabi-gcc: command not found0 V. k7 S2 S, X- s  a+ `! f
的问题$ K0 W, ^$ C, V
具体步骤如下:
6 E) ]  w7 y. c) P6 m0 J1 安装cygwin,选择full install(带有python)
# q/ J5 A) G- Q* ^5 B2 安装scons (python setup.py install)
; ]7 N2 g) Q& C  ~5 i  {+ V' A1 h! l3 安装arm--none-eabi-i686-mingw32.tar.bz2 (tar -jxvf arm--none-eabi-i686-mingw32.tar.bz2)
/ x' i3 g$ X1 E" p- G# N& x' S4 将arm-none-eabi-i686-mingw32解压后的路径export到PATH里2 F' s  O3 P1 |! h6 F
在wh44b0下做scons提示如下. j( }" e1 t9 N4 E9 ^- W
$ scons scons: Reading SConscript files ... /opt/CrossCompile/CodeSourcery/Sourcery_CodeBench_for_ARM_EABI/bin:/cygdrive/c/linux/rt-thread/tool/arm-2012.09/bin/:/home/dillon.min/bin:/cygdrive/c/software/jd-gui-0.3.5.windows:/usr/local/bin:/usr/bin:/cygdrive/c/Program Files (x86)/CodeSourcery/Sourcery_CodeBench_Lite_for_ARM_EABI/bin:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Old-Pc-bak/d/share/android-sdk_r10-windows/tools:/cygdrive/c/Old-Pc-bak/d/software/java反编译:/cygdrive/c/Program Files/7-Zip:/cygdrive/c/Python25:/cygdrive/c/Python25/Scripts:/cygdrive/c/Program Files (x86)/Beyond Compare 3:/usr/lib/lapack scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build arm-none-eabi-gcc -o build/application.o -c -mcpu=arm720t -D__FLASH_BUILD__ -O2 -Ibuild -I. -I/cygdrive/c/linux/rt-thread/rt-2457-git -I/cygdrive/c/linux/rt-thread/rt-2457-git/build -I/cygdrive/c/linux/rt-thread/rt-2457-git/include -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/s3c44b0 -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/common application.c sh: arm-none-eabi-gcc: command not found scons: *** [build/application.o] Error 127 scons: building terminated because of errors.9 d. X0 d2 z8 X) ?
但是我手动执行
  ^" {" A) C, g0 x; c+ h: ?3 darm-none-eabi-gcc -o build/application.o -c -mcpu=arm720t -DFLASH_BUILD -O2 -Ibuild -I. -I/cygdrive/c/linux/rt-thread/rt-2457-git -I/cygdrive/c/linux/rt-thread/rt-2457-git/build -I/cygdrive/c/linux/rt-thread/rt-2457-git/include -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/s3c44b0 -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/common application.c
, ~2 Y9 M3 M% c" B4 S# O是可以把application.o生成到build下的  e, g. d, }8 B# b' q2 l& g
* v: [: b; q' z可能问题就出在scons里对arm-none-eabi-gcc查找上出了问题,在building.py里加了一个 print os.environ[‘PATH’]1 e" A8 w  W/ y7 u$ ~3 t& H+ D
说明gcc的工具是在路径里的,就比较迷惑了
6 I/ o- q7 C/ L9 e3 V" m' x/ @& A5 }
发表于 2022-7-4 15:20 | 只看该作者
scons用的路径是和系统中的PATH变量指向的路径是不一样的,需要在rtconfig.py中指定
2 m" w8 [4 `% F
发表于 2022-7-4 16:18 | 只看该作者
我觉得不是arm-none-eabi-gcc的问题,我试过在cygwin下单独编译一个c文件,只要设置了CYGPATH环境变量,就可以正常编译,但是到了scons里面,就不行了,后来debug了一番,也没找到原因为什么scons调用的arm-none-eabi-gcc找不到头文件,就放弃了。+ V' I! M% ?* g! R9 }
$ L# k  U( B$ K% p
我觉得用Makfile方式编译linux应该是没有问题的话,一直没有实验过,回头有空试试看。/ J% Y3 u8 J) [- y
GMT+8, 2025-10-11 22:54 , Processed in 0.125000 second(s), 23 queries , Gzip On.
