这周我做了一个用51单片机的时钟,下面介绍一下具体实用功能 。仿真一开始,时间显示的是20:30:00 ![]()
7 t, c4 B( E" V' |1 m# `* y3 ]; X当按下第二个开关时 即可调节"分"如图,按一下便调整为31分。7 \0 [; g0 w( b% z" i0 s
; Q: d. y0 ]3 n5 u再按一下第二个键,此时可调节"时"如图。
; D, ]7 S J$ I # n- X5 p6 {+ _5 z9 c
按一下以后,时间为21时。
_# a( A& A4 d: d0 X' f. N9 ] h" g1 H- ]. e
代码:
3 i) j: ~+ g9 o& G& a y
. R) g+ z$ q/ F( j$ F单片机源程序如下:8 ^9 x0 @' M6 u/ X
- #include <reg51.h>
- sbit key1 = P1^0;
- bit flag1s = 0;
- bit KeySta = 1;
- unsigned char hour = 20;
- unsigned char minute = 30;
- unsigned char second = 00;
- unsigned char mode = 0;
- void FreshTime();
- void TimeInit();
- void IntInit();
- void InitLedBuff();
- void keyscan();
- unsigned char code LedChar[] = { //共阴数码管显示字符转换表
- 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x00};
- unsigned char LedBuff[6] = { //数码管显示缓冲区
- 0xff,0xff,0xff,0xff,0xff,0xff};
- void main()
- TimeInit();
- IntInit();
- InitLedBuff();
- while(1)//显示内容处理
- if(flag1s&&!mode) //时间显示模式
- flag1s = 0;
- FreshTime();
- else if(mode == 1) //校准分钟
- LedBuff[0] = 17;
- LedBuff[1] = 17;
- LedBuff[4] = 17;
- LedBuff[5] = 17;//不显示
- LedBuff[2] = minute/10;
- LedBuff[3] = minute%10;
- else if(mode == 2) //校准小时
- LedBuff[2] = 17;
- LedBuff[3] = 17;
- LedBuff[4] = 17;
- LedBuff[0] = hour/10;
- LedBuff[1] = hour%10;
- else if(mode == 3) //校准完成重新显示
- InitLedBuff();
- mode = 0;
- keyscan();
- void InitLedBuff()//初始化时间到显示缓冲区
- LedBuff[4] = second/10;
- LedBuff[5] = second%10;
- void FreshTime()//刷新时间到显示缓冲区
- second++;
- if(second == 60)//进位
- second = 0;
- minute++;
- if(minute == 60)//进位
- minute = 0;
- hour++;
- if(hour == 24)
- hour = 0;
- void TimeInit()//定时器初始化
- TMOD = 0X11; //设置定时器为模式1
- TL0 = 0xB0;
- TH0 = 0x3C; //定时初值 50ms
- TL1 = 0x18; //
- TH1 = 0xFC; //定时初值 1ms
- TR0 = 1; //定时器0开始计时
- TR1 = 1; //定时器1开始计时
- ET1 = 1; //使能定时器1
- ET0 = 1; //使能定时器0
- PT0 = 1; //提高计时准确性,提高定时器0中断优先级
- EA = 1; //打开总中断
- void IntInit()//外部中断初始化
- IT0 = 1; //下降沿触发
- EX0 = 1; //使能外部中断0
- void keyscan() //按键扫描及处理
- static bit backup = 1;
- if (KeySta != backup) //当前值与前次值不相等说明此时按键有动作
- if (backup == 0) //如果前次值为0,则说明当前是弹起动作
- if(mode == 1) //校准分钟时,分钟加一
- minute++;
- if(minute==60)
- minute = 0;
- else if(mode == 2) //校准小时,小时加一
- hour++;
- if(hour==24)
- hour = 0;
- backup = KeySta; //更新备份为当前值,以备进行下次比较
- void Int0() interrupt 0
- mode++;
- if(mode == 4)
- mode = 0;
- void Ledfresh() //数码管显示刷新
- static unsigned char i = 0;
- switch(i)
- case 0 : P2 = ~(0x01<<i)
0 = LedChar[LedBuff];i++;break;- case 1 : P2 = ~(0x01<<i)
0 = LedChar[LedBuff];i++;break;- case 2 : P2 = ~(0x01<<i)
0 = LedChar[LedBuff];i++;break;- case 3 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff];i++;break;
- case 4 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff];i++;break;
- case 5 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff];i=0;break;
- void Time0() interrupt 1 //12MHz 50ms
- static unsigned char n = 0;
- TL0 = 0xB0;
- TH0 = 0x3C;
- n++;
- if(n==20)
- n=0;
- flag1s = 1;//1s标志位
- void Time1() interrupt 3 //12MHz 1ms
- static unsigned char keybuff = 0xff;
- TL1 = 0x18; //
- Ledfresh();
- keybuff = (keybuff<<1)|key1;
- if (keybuff == 0x00)
- { //连续8次扫描值都为0,即16ms内都只检测到按下状态时,可认为按键已按下
- KeySta = 0;
- else if (keybuff == 0xFF)
- { //连续8次扫描值都为1,即16ms内都只检测到弹起状态时,可认为按键已弹起
- KeySta = 1;
- else
- {} //其它情况则说明按键状态尚未稳定,则不对KeySta变量值进行更新
( |" b B2 r% V7 K5 x# U3 U # c9 u( g9 k0 ~# X
