查看: 1997|回复: 2
[Cadence Sigrity] 求助:IBIS转DML出错了啊
发表于 2011-10-21 14:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IBIS文件时官方网页上下载的,用PCB SI软件转为DML格式时,出错了,帮我看看,谢谢!/ i7 K+ q* T; U0 I8 Z1 X) s8 Q6 A
最后一条ERROR信息:  ~' v, D* ~' L5 }
  [5 @) R$ f  z' K- F+ B1 v
RUNNING IBISCHK COMMAND: ibischk4 "IBIS\ad9523.ibs"( `. r! P& K, s: h" F
IBISCHK4 V4.0.1
7 e9 G: _  p9 W, F. \; g* a
/ Q; c' K" Y/ z9 \2 v" S+ y' oChecking IBIS\ad9523.ibs for IBIS 3.2 Compatibility...
) ?9 G7 n* U4 E  R9 @6 T) Z6 T! c* c. G" Q, F4 E. ?
Errors  : 0; H# b5 ?+ `) ]% s8 U3 U( X- A
# q9 G4 p, H( B) |8 U
File Passed& Y& _$ h3 w4 [% t& R( x% x
: `! c/ C. x; D1 u( z
END OF IBISCHK COMMAND OUTPUT
" N4 f9 `1 d- _" {9 b" F
# R$ T1 z% C& h+ a1 CREADING IBIS FILE IBIS\ad9523.ibs
; S' D& S3 R$ V, B: [1 `$ r9 G8 P
+ _4 }3 R1 p) S& {, cINFO @line 47 --- Completed PackagedDevice AD9523
. C/ }  V5 R0 n5 vINFO @line 450 --- Completed IbisIOCell AD9523_clk_spi6 D- d( E/ m3 F. p0 i# p/ [
INFO @line 484 --- Completed IbisIOCell AD9523_in_pd' n2 Z* V/ p! ?+ }, ^6 p- T
INFO @line 522 --- Completed IbisIOCell AD9523_in_pu_10k
* ?# V2 d. R+ S& d- e3 vINFO @line 575 --- Completed IbisIOCell AD9523_in_ref3 S( e8 L2 `9 H
INFO @line 630 --- Completed IbisIOCell AD9523_io_od* g7 h0 @; F4 B  v, b
INFO @line 963 --- Completed IbisIOCell AD9523_irq_cmos
, n; J5 y; b! K! Y5 ^INFO @line 1608 --- Completed IbisIOCell AD9523_irq_nmos
# O2 x0 {5 ?2 e# tINFO @line 1939 --- Completed IbisIOCell AD9523_irq_pmos9 d2 ^: C. Z7 A
INFO @line 2270 --- Completed IbisIOCell AD9523_ctrl_io
# \  e) r6 B4 OINFO @line 2917 --- Completed IbisIOCell AD9523_ctrl_tri6 q! g% x- W$ Z5 I: s$ i
INFO @line 3564 --- Completed IbisIOCell AD9523_cmos! q: Z$ z  ]+ o1 G' u
INFO @line 4225 --- Completed IbisIOCell AD9523_lvds_3_5ma
" Z% V, f- K- G& v5 b6 f+ [* AINFO @line 4651 --- Completed IbisIOCell AD9523_lvds_7ma
0 a% s. r# S. I2 R) Z$ L1 c2 [INFO @line 5086 --- Completed IbisIOCell AD9523_pecl" N- s3 k" f* `/ v7 Z/ t1 U
INFO @line 5530 --- Completed IbisIOCell AD9523_term! }7 F. z2 z6 o1 |, o6 w% E
INFO @line 5541 --- Completed IbisIOCell AD9523_term2  m# `# K$ k  v7 `* }5 n
INFO: The following names have been changed to conform to syntax requirements:! A: j; `! m8 M+ A
OLD NAME                                NEW NAME' }) M: R6 k1 f% E7 L
AD9523_lvds_3.5ma                       AD9523_lvds_3_5ma* \7 E7 t, U1 U3 B7 b9 Q5 e
AD9523_mode_out0+                       AD9523_mode_out0_
! Z& S0 V, Z! e  g; O' [AD9523_mode_out0-                       AD9523_mode_out0_5 K* ?/ b9 D  X. ^7 }; L
AD9523_mode_out1+                       AD9523_mode_out1_( o. J* |" Y3 S+ o1 R
AD9523_mode_out1-                       AD9523_mode_out1_* P8 `- I: j8 r. b& n0 R9 H
AD9523_mode_out10+                      AD9523_mode_out10_
  X" B1 d7 f: x! ]AD9523_mode_out10-                      AD9523_mode_out10_
. ]4 n$ B  v% a$ w  ^; ~/ V0 C' AAD9523_mode_out11+                      AD9523_mode_out11_
, O- Z( h  m# e# TAD9523_mode_out11-                      AD9523_mode_out11_
; }# p, p% U3 I  T' h+ {& M- ^AD9523_mode_out12+                      AD9523_mode_out12_
+ U+ t$ h5 i% {' o# V6 XAD9523_mode_out12-                      AD9523_mode_out12_
  ]0 r8 p- P4 c( ~# r0 j% a3 Z+ BAD9523_mode_out13+                      AD9523_mode_out13_7 O4 h- @! Y' @$ Z- m' s
AD9523_mode_out13-                      AD9523_mode_out13_' m% X" l4 I4 G  W
AD9523_mode_out2+                       AD9523_mode_out2_
" p7 o% q. t/ G) E9 W7 S7 K( WAD9523_mode_out2-                       AD9523_mode_out2_
8 N% N+ E, M+ S% G+ ?AD9523_mode_out3+                       AD9523_mode_out3_' d: C# m; n7 ~# n, K( ]1 i5 t
AD9523_mode_out3-                       AD9523_mode_out3_
0 l, c9 K5 l2 H- N# g/ kAD9523_mode_out4+                       AD9523_mode_out4_% C( s) t. O* P. M
AD9523_mode_out4-                       AD9523_mode_out4_
. z+ y7 k* n5 Y1 V3 CAD9523_mode_out5+                       AD9523_mode_out5_
7 H4 Y1 j4 l8 l6 z* N8 tAD9523_mode_out5-                       AD9523_mode_out5_( S0 H* v/ z! U. {% n7 H9 B8 O7 U
AD9523_mode_out6+                       AD9523_mode_out6_: C% H+ k/ d! n( q; u
AD9523_mode_out6-                       AD9523_mode_out6_
9 f6 r( b4 p4 O. gAD9523_mode_out7+                       AD9523_mode_out7_* w2 ?. ]  W. Y7 c& r0 y! o
AD9523_mode_out7-                       AD9523_mode_out7_
% c% G' |2 j+ N0 O: ~AD9523_mode_out8+                       AD9523_mode_out8_
( y2 y0 B* O3 WAD9523_mode_out8-                       AD9523_mode_out8_
7 f- ^7 C! y( mAD9523_mode_out9+                       AD9523_mode_out9_5 r2 m& r' i" q( o; `1 E
AD9523_mode_out9-                       AD9523_mode_out9_
; J) [5 n+ k0 f1 w0 b+ R. a; p/ X+ t
RUNNING DMLCHECK for IBIS\ad9523.dml: y" k5 F5 u9 W% S$ g! M
$ L* C- W  [# p/ g: sWARNING @line 4689: minimum Rise slew rate exceeds typical Rise slew rate $ [5 }7 r1 d4 _0 B; ~7 A+ G
WARNING @line 4689: minimum Fall slew rate exceeds typical Fall slew rate 1 r* e% y$ s) h0 S: n& w
WARNING @line 5192: typical Rise slew rate exceeds maximum Rise slew rate 4 a, w/ r) P# [" w) @- Z6 u& {
WARNING @line 5842: Missing input threshold for ModelType Input
9 C6 Q; s6 m# U# ?9 u: SWARNING @line 5858: Missing input threshold for ModelType Input 2 |. f' r9 Z$ e) }* W
WARNING @line 4: AD9523_clk_spi GroundClamp: Overall typical area exceeds overall maximum area
6 b1 q/ e; }3 v/ K4 X8 eWARNING @line 4: AD9523_clk_spi GroundClamp: Overall minimum area exceeds overall typical area % h6 q- }' c. w# R( ^7 Q7 P5 G/ r
WARNING @line 4: AD9523_clk_spi GroundClamp: Slope at end is not flat - point added " a3 g4 S% S: v2 I0 x9 r. C8 D0 W
WARNING @line 326: AD9523_cmos PowerClamp: Overall typical area exceeds overall maximum area
8 o4 ?3 k4 b6 M. r( C9 t' ]7 JWARNING @line 326: AD9523_cmos PowerClamp: Overall minimum area exceeds overall typical area 5 v3 S) V4 V1 a- ]9 a/ X* d
WARNING @line 326: AD9523_cmos PowerClamp: Slope at end is not flat - point added # s$ `- k' B4 c' A
WARNING @line 285: AD9523_cmos GroundClamp: Overall typical area exceeds overall maximum area % Z$ l' J3 w& |4 V5 k  X- E+ H
WARNING @line 285: AD9523_cmos GroundClamp: Overall minimum area exceeds overall typical area ) }+ }4 ~2 y0 ~: q: A0 A' y
WARNING @line 285: AD9523_cmos GroundClamp: Slope at end is not flat - point added 3 Z" T. O  D8 R  Y
WARNING @line 59: AD9523_cmos FallingWaveform fall_1 max: Non-monotonic dV = 2.59411 at time 7.575e-010 exceeds 1% of voltage span ! ^4 |6 u) [; {4 O# ~; O
WARNING @line 59: TVCurve should asymptotically approach a final value - point added
$ G5 s: D6 i, _8 U& Q; m6 SWARNING @line 1073: AD9523_ctrl_io PowerClamp: Overall typical area exceeds overall maximum area
6 _$ L$ Z: l' Z8 g" {WARNING @line 1024: AD9523_ctrl_io GroundClamp: Overall minimum area exceeds overall typical area ( O% j' e3 K, H8 N
WARNING @line 798: AD9523_ctrl_io FallingWaveform fall_1 max: Non-monotonic dV = 1.758 at time 1.445e-009 exceeds 1% of voltage span
: Z# [4 k9 T9 U* uWARNING @line 798: TVCurve should asymptotically approach a final value - point added
# S2 n0 }6 m  Y' B5 w- I- RWARNING @line 1796: AD9523_ctrl_tri PowerClamp: Overall typical area exceeds overall maximum area 0 P* I$ C3 X4 R0 ?! L" \) l) l: F
WARNING @line 1753: AD9523_ctrl_tri GroundClamp: Overall minimum area exceeds overall typical area 8 \* c2 {- m: x, _& |
WARNING @line 1527: AD9523_ctrl_tri FallingWaveform fall_1 max: Non-monotonic dV = 1.758 at time 1.445e-009 exceeds 1% of voltage span
3 K7 n2 x. Z( f% C; j3 q" I* mWARNING @line 1527: TVCurve should asymptotically approach a final value - point added
9 K+ K5 s# s6 |2 s; bWARNING @line 2241: AD9523_in_pd GroundClamp: Overall typical area exceeds overall maximum area
7 I2 b8 {: D( y, `" R' J. R0 H: {. VWARNING @line 2241: AD9523_in_pd GroundClamp: Slope at end is not flat - point added + _. g# K  l( B, x; O) d
WARNING @line 2330: AD9523_in_pu_10k PowerClamp: Overall typical area exceeds overall maximum area
9 z: i3 r; u7 Y9 B$ I; }WARNING @line 2330: AD9523_in_pu_10k PowerClamp: Overall minimum area exceeds overall typical area
" Z2 F' S4 Y- x, n  a1 \3 {. Q0 UWARNING @line 2290: AD9523_in_pu_10k GroundClamp: Overall typical area exceeds overall maximum area 1 _% ~# n( F8 S- W
WARNING @line 2290: AD9523_in_pu_10k GroundClamp: Overall minimum area exceeds overall typical area
$ V+ {# X+ I5 c2 N2 r" A1 cWARNING @line 2290: AD9523_in_pu_10k GroundClamp: Slope at end is not flat - point added 1 Z( u4 L; f1 \5 [; W: ~6 ^
WARNING @line 2407: AD9523_in_ref PowerClamp: Overall typical area exceeds overall maximum area
1 K3 s) ^. Y) {6 UWARNING @line 2407: AD9523_in_ref PowerClamp: Overall minimum area exceeds overall typical area
3 \6 ]) x$ V5 |WARNING @line 2368: AD9523_in_ref GroundClamp: Overall typical area exceeds overall maximum area
  ~+ E7 ?. v6 _8 v* S+ m$ zWARNING @line 2368: AD9523_in_ref GroundClamp: Slope at end is not flat - point added
% ~7 \8 x7 F. y1 n! A* d9 dWARNING @line 2568: AD9523_io_od GroundClamp: Overall minimum area exceeds overall typical area
2 g* ~6 H7 Q" ]" s+ cWARNING @line 2724: TVCurve should asymptotically approach a final value - point added
& `/ N0 F, I' R$ S2 K5 }( [* ~2 y8 P3 oWARNING @line 2455: TVCurve should asymptotically approach a final value - point added
7 v7 W$ X6 m7 H# EWARNING @line 3120: AD9523_irq_cmos PowerClamp: Overall typical area exceeds overall maximum area
4 C6 T6 w* C2 n, g  AWARNING @line 3077: AD9523_irq_cmos GroundClamp: Overall minimum area exceeds overall typical area
+ w* y7 J$ E2 pWARNING @line 2851: AD9523_irq_cmos FallingWaveform fall_1 max: Non-monotonic dV = 1.758 at time 1.445e-009 exceeds 1% of voltage span 0 c. o! ]$ ]4 M% Y9 \
WARNING @line 2851: TVCurve should asymptotically approach a final value - point added
! T; R: J0 x" b' V: {7 \WARNING @line 3687: AD9523_irq_nmos GroundClamp: Overall minimum area exceeds overall typical area . U# `- ?+ d% K1 M9 M" M" b' X. m
WARNING @line 3837: TVCurve should asymptotically approach a final value - point added
5 M) H- v- h1 n$ o  ?/ HWARNING @line 3574: TVCurve should asymptotically approach a final value - point added
& \: ^( b/ T/ _" @/ B+ bWARNING @line 4083: AD9523_irq_pmos PowerClamp: Overall typical area exceeds overall maximum area 4 E( L1 U& J+ V- Q0 g
WARNING @line 3964: AD9523_irq_pmos FallingWaveform fall_1 max: Non-monotonic dV = 1.758 at time 1.445e-009 exceeds 1% of voltage span
4 y) Z# n, ~/ y: b- p, G% m: cWARNING @line 3964: TVCurve should asymptotically approach a final value - point added $ E1 C# `) c& P$ J6 P1 E1 k6 S
WARNING @line 4508: AD9523_lvds_3_5ma PowerClamp: Overall typical area exceeds overall maximum area % Q  r7 p# t8 z; k  A0 ?; o- J
WARNING @line 4508: AD9523_lvds_3_5ma PowerClamp: Overall minimum area exceeds overall typical area " y, K! s5 e: ?/ y4 Q7 h2 s7 t
WARNING @line 4508: AD9523_lvds_3_5ma PowerClamp: Slope at end is not flat - point added
) a4 M9 r4 ^; h; e( D! V0 n9 e1 GWARNING @line 4712: AD9523_lvds_3_5ma RisingWaveform rise_1 max: Non-monotonic dV = 0.006 at time 1.86e-010 exceeds 1% of voltage span
4 M! `9 W3 M1 X; |8 a+ t3 u! H8 h. NWARNING @line 4712: TVCurve should asymptotically approach a final value - point added 5 P9 ~. w3 x9 E' U
WARNING @line 4345: TVCurve should asymptotically approach a final value - point added . _( x2 W! A3 I# x) G
WARNING @line 5002: AD9523_lvds_7ma PowerClamp: Overall typical area exceeds overall maximum area ' t; p' q2 ~- P
WARNING @line 5002: AD9523_lvds_7ma PowerClamp: Overall minimum area exceeds overall typical area ( }$ {) L5 l% X2 c
WARNING @line 5002: AD9523_lvds_7ma PowerClamp: Slope at end is not flat - point added
& Z7 g, v6 N% {" D* N) @WARNING @line 4952: AD9523_lvds_7ma GroundClamp: Overall minimum area exceeds overall typical area ; C* @  A5 L- Y9 X
WARNING @line 5215: TVCurve should asymptotically approach a final value - point added / Z0 z( l" K- I7 J4 S
WARNING @line 4839: TVCurve should asymptotically approach a final value - point added
. @# v4 ^! W1 V0 E( bWARNING @line 5506: AD9523_pecl PowerClamp: Overall typical area exceeds overall maximum area / c! ]9 ?8 q! |6 U8 C
WARNING @line 5506: AD9523_pecl PowerClamp: Overall minimum area exceeds overall typical area
; y' X( L; E( Q2 q1 _6 ?WARNING @line 5506: AD9523_pecl PowerClamp: Slope at end is not flat - point added
, n( n& G7 x$ G! \: ]; pWARNING @line 5725: TVCurve should asymptotically approach a final value - point added
- X% B- {, h6 w0 o8 M2 s6 ^+ @WARNING @line 5342: AD9523_pecl FallingWaveform fall_1 typ: Non-monotonic dV = 1.10206 at time 7.46e-010 exceeds 1% of voltage span - l* }5 A, I% t. ]$ {. E
WARNING @line 5342: TVCurve should asymptotically approach a final value - point added
- S2 O3 r) s& ^$ e, R( ]  v0 bWARNING @line 5900: AD9523_term2 PowerClamp: Overall typical area exceeds overall maximum area
+ B3 Z# D& A6 i3 JWARNING @line 5900: AD9523_term2 PowerClamp: Overall minimum area exceeds overall typical area ! C, F1 B9 T/ o; I
WARNING @line 5900: AD9523_term2 PowerClamp: Slope at end is not flat - point added 9 g+ k% e" P+ J3 |6 x! x7 i
WARNING @line 5859: AD9523_term2 GroundClamp: Overall typical area exceeds overall maximum area
( N. s1 E2 ?7 n" o; x: dWARNING @line 5859: AD9523_term2 GroundClamp: Overall minimum area exceeds overall typical area ( V. w/ r* ]8 u0 {3 g( \
WARNING @line 5859: AD9523_term2 GroundClamp: Slope at end is not flat - point added
5 h1 y* ~/ L( _2 HERROR @line 6775: Syntax error after parsing the token <cmos out 0110,0111,1000,1011,1100,1101 > :
# a% @: X. _8 _! H3 Q) Q2 l* e" ]) ~    The previous token began on line 6775 and was <cmos out 0110,0111,1000,1011,1100,1101 > ; P  h! `7 p1 B% e% G# g! Z8 j9 n
+ f" \; I+ {$ R" m
Translation failed due to DMLCHECK errors.
( K4 F0 m5 E, sOutput saved as IBIS\ad9523.dml.txt for examination.
发表于 2012-11-13 10:11 | 只看该作者
可能是中文文件名的原因吧,我的就是
发表于 2013-3-18 13:17 | 只看该作者
最好把IBIS文件也上传了!!
GMT+8, 2025-7-27 13:41 , Processed in 0.109375 second(s), 23 queries , Gzip On.
