查看: 3863|回复: 6
求助 网表导入问题
发表于 2011-9-26 22:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
9 T- \" U1 x/ D+ p* Y1 e(        )8 \; I4 }3 l( I$ A+ s
(    allegro Netrev Import Logic                                      )3 E" I( l) y( B4 h; q
(        )( |$ Z! K$ I7 h+ e. P0 S
(    Drawing          : 112.brd                                       )3 A( g. X2 t! u6 p+ g& H- |
(    Software Version : 16.3S026                                      )5 o7 D1 d& B5 o' e
(    Date/Time        : Sat Sep 26 22:31:00 2009                      )/ {- Q: {( u6 T% \: l
: @5 a7 z" M! D$ K) J(---------------------------------------------------------------------)" Z, u3 `5 m; _4 N: x( [/ k
" g3 ~/ B9 d- x, W$ E0 v0 S3 @
, t% P1 h( z6 W8 v0 U------ Directives ------
; q% L9 \0 @9 h9 u3 y4 i# R. ?! H  \; Y& h' e0 ?" J% |+ ?, Q, m
RIPUP_ETCH FALSE;
& S" c6 i5 X! |; T2 {! [( oRIPUP_SYMBOLS ALWAYS;  d  e. p$ ~- a0 Y/ ]& T) D4 A$ c
Missing symbol has error FALSE;
* q* i% I' q  h& NSCHEMATIC_DIRECTORY 'F:/cundang/allegro';
, X4 h) F( @8 I6 k8 K/ x& FBOARD_DIRECTORY '';# m( m3 [) f+ H, ^9 \% Y
OLD_BOARD_NAME '112.brd';2 a) l' q2 P# [
NEW_BOARD_NAME '112.brd';6 |1 j% w! p" P- p1 @0 m6 `+ U
! o4 i# q8 h2 a* Y; e( J. m& [0 Q& X. b
CmdLine: netrev -$ -i F:/cundang/allegro -y 1 F:/cundang/#Taaaaaa03952.tmp1 X* ]. v) E' v
6 _) F4 P9 Y5 @* y: d/ ~4 S+ U------ Preparing to read pst files ------$ P( J; \1 x5 G
, V+ |) v) B( s; S, [+ ZStarting to read F:/cundang/allegro/pstchip.dat & p1 d  s" w& p4 h: y6 m
   Finished reading F:/cundang/allegro/pstchip.dat (00:00:00.10)
5 D1 P& ]0 Y! Z+ p& w! mStarting to read F:/cundang/allegro/pstxprt.dat
4 V0 t' r) x. u- e" X% z+ j$ Q# x   Finished reading F:/cundang/allegro/pstxprt.dat (00:00:00.00)8 j- g8 S( f2 N3 y! A0 u
Starting to read F:/cundang/allegro/pstxnet.dat 2 z7 P1 i# a7 u' Z2 e# u0 v
   Finished reading F:/cundang/allegro/pstxnet.dat (00:00:00.00)) |# T$ B; F* Y7 X
' L1 a, \. o! A5 H
------ Oversights/Warnings/Errors ------
1 E2 k" S$ d0 {* j* \8 s9 Q3 Z. z) c- n' J
  W( c% G9 J8 h4 S& W#1   WARNING(SPMHNI-192): Device/Symbol check warning detected.
) R; R5 @+ d" H+ @- ?1 J" D" `6 t! ]( {) M: z1 V7 X0 ]7 t/ M. m) V
WARNING(SPMHNI-194): Symbol 'CAPPR150-400X500' for device 'CAP_CAPPR150-400X500_470UF' not found in PSMPATH or must be "dbdoctor"ed.
0 `( p: x3 g6 U2 k6 l3 M5 A$ |2 I+ M) R
#2   WARNING(SPMHNI-192): Device/Symbol check warning detected.
1 Z/ i! C0 z6 Z( g% \/ D( b" c& U" A% N1 R
WARNING(SPMHNI-194): Symbol '254-2P' for device 'B2S_2_254-2P_B2S' not found in PSMPATH or must be "dbdoctor"ed.  i( L4 U3 o8 ^% p" \( d
' X" n) |9 p% e#3   WARNING(SPMHNI-192): Device/Symbol check warning detected.- m7 X$ D7 e4 L1 [; L! Q
5 s% h; {: d% {6 [5 v( {0 U+ }  pWARNING(SPMHNI-194): Symbol 'RES650-320X170' for device 'R_RES650-320X170_10K' not found in PSMPATH or must be "dbdoctor"ed.0 Y0 w5 c" k9 C5 i! X
; ~( U' {0 T5 q( _1 E
#4   WARNING(SPMHNI-192): Device/Symbol check warning detected.# O! v0 H  L. B6 ^+ K5 B
" s' J  p; l& d+ d5 [  P
WARNING(SPMHNI-194): Symbol 'DIP8' for device 'LM358_2_DIP8_LM358' not found in PSMPATH or must be "dbdoctor"ed.. K; J$ ]; C$ W9 K8 r3 {
9 k8 X4 m4 v2 c
    Alternatively, the JEDEC_TYPE is not defined for the device in the pstchip.dat.* K! l, F) m7 G% O: b* t! D% q
1 }/ T: @6 w0 n/ J' e9 k9 \
#5   WARNING(SPMHNI-192): Device/Symbol check warning detected.* D+ z% m  `6 `
  ?5 `- J5 V7 ]+ \- n( k  o
WARNING(SPMHNI-194): Symbol 'DIP8' for device 'LM358_1_DIP8_LM358' not found in PSMPATH or must be "dbdoctor"ed.
% l  e, g5 J# A' P8 d8 g8 |# \6 t8 q8 \7 N) {) e5 D6 j" F
4 ~2 F7 U8 i, M; i1 Q3 X4 \& l6 O* M) I2 m) L" q3 q* Z
------ Library Paths ------
  f. A) ?, m. c( wMODULEPATH =  .
- e/ Z( T" k; C1 o- I           C:/cadence/SPB_16.3/share/local/pcb/modules
! R- k5 X9 h" z* |- s0 _) \! E7 Z' `2 ]
PSMPATH =  . + n8 M3 q% i' N; K
           symbols
& ?8 I& V' x% x; M- P& g           ..   D+ N6 Y- B+ c5 ]4 a
           ../symbols
: ]/ J" K! E! P4 {+ ?8 p           C:/Cadence/SPB_16.3/share/local/pcb/symbols
6 W- K: ^; i; ?; y           C:/Cadence/SPB_16.3/share/pcb/pcb_lib/symbols
9 L4 n, g- t+ K! [( X& p$ Y& s" e# _. E           C:/Cadence/SPB_16.3/share/pcb/allegrolib/symbols 6 P! c1 C- F6 X. k
           D:\SPB_DATA\ALLEGRO LIB\
& w; ^2 ]' M7 n3 Q6 V" q; D7 r. |' p& ?9 O# l, N- T7 U
PADPATH =  . # X2 K; J& U! x" d3 ~
           symbols
- h7 c: C0 Z) Q: l! [: V- V7 a           .. 4 C" M. S: q8 D0 Y+ V  ^$ M
           ../symbols + E5 [& t( E3 ^  Q6 c: w4 p' B9 ?
           C:/Cadence/SPB_16.3/share/local/pcb/padstacks
' Q3 |3 a, w- V- Y1 Z' q- D/ o           C:/Cadence/SPB_16.3/share/pcb/pcb_lib/symbols
. d0 @4 m( M/ U) \  _           C:/Cadence/SPB_16.3/share/pcb/allegrolib/symbols
- p% {0 S; a0 I, |5 @1 y" n           D:\SPB_Data\allegro lib\ 5 L' _' H+ O9 |  H
4 J* E8 b* x. ]% z3 t% ]4 l9 f) k4 N% \, n) u: [4 V
------ Summary Statistics ------2 e" Z- ^4 w! ^) p& A$ y) ^7 {) Q
7 b4 B2 M* y: Y% }
- u1 C- n* B6 \netrev run on Sep 26 22:31:00 2009
# p# ^4 D# X) P- ]3 o0 j   DESIGN NAME : '123': |8 E. |: j6 Q, ^* |1 [( _0 J& Y( l  i
   PACKAGING ON Jan  3 2011 16:39:28
6 n5 K7 q4 P4 ]/ @6 g% I
+ N( a; W3 G' Y; ^( M6 Y   COMPILE 'logic'8 `3 w2 g- v: e, j* w
   CHECK_PIN_NAMES OFF% K5 G4 l2 ~8 U
   CROSS_REFERENCE OFF
' h+ F- M7 u3 N0 Q4 C+ d   FEEDBACK OFF3 H4 P" u+ t6 `6 l
   INCREMENTAL OFF
5 H$ H) i2 ?& R! }( j8 `* \   INTERFACE_TYPE PHYSICAL
/ q. {4 B' C4 m1 j+ K4 y   MAX_ERRORS 500
: Q# a+ }* {# s3 k! h5 d   MERGE_MINIMUM 5, U$ u2 R4 ~3 N- q' S0 p" b, \
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
7 E2 L+ [* k  z- u% @- c   NET_NAME_LENGTH 24
# D4 b- p7 n/ Q+ n' S" C! r   OVERSIGHTS ON2 f8 ~2 i0 D( s# f9 H# i
   REPLACE_CHECK OFF& }4 ?7 J& `. X9 ^# |
   SINGLE_NODE_NETS ON
& Z3 w" ^# C8 o, B1 y8 l   SPLIT_MINIMUM 0
: ^; V' \" _: e2 b0 y4 P   SUPPRESS   20
2 Y1 D, a1 E; k0 R( D! f' h  @# M   WARNINGS ON
! Q4 x  M8 |; z$ u5 q( G& l  k) U( m9 Z% T; Z8 \6 n) W
No error detected
, r$ g4 I6 W* w! ^8 w- i No oversight detected0 }' N2 K. M* c; [9 W6 _: H3 \
  5 warnings detected9 N7 \2 P; e7 a+ E9 h
, N. Y0 E$ n+ l. w8 S
cpu time      0:01:00
' I* C" B+ R! ]elapsed time  0:00:007 ?+ G" J5 W3 w1 Z
发表于 2011-9-26 23:21 | 只看该作者
库路径不对!找不到封装
发表于 2011-9-27 08:51 | 只看该作者
可能是你的库没设置好。你看一下User Preferences Editor下的Design_paths是否有设库文件路经
 楼主| 发表于 2011-9-27 12:30 | 只看该作者
pengsandy 发表于 2011-9-27 08:51
9 ?% j  n" L# x6 e% q可能是你的库没设置好。你看一下User Preferences Editor下的Design_paths是否有设库文件路经
+ j2 Z; t1 I2 u( |+ B, c9 ~已经设置了路径,   出现这样的问题不会是网表生成不对的问题吧?
    2021-11-3 15:21
  • 签到天数: 56 天
    [LV.5]常住居民I
    发表于 2011-9-27 15:53 | 只看该作者
    我也碰到过两次这种问题,库路径都正确,后面好像是在数据库中删除,然后再重新增加一次又好了,没搞明白为什么?
    发表于 2011-9-27 16:03 | 只看该作者
    沒有找到device文件!!
     楼主| 发表于 2011-9-27 19:35 | 只看该作者
    我用db doctor 修复了遍文件  就好了  谁帮忙解释下
    GMT+8, 2025-11-4 08:49 , Processed in 0.156250 second(s), 25 queries , Gzip On.
