查看: 7653|回复: 10
PADS9.3转Allegro16.3报错
发表于 2011-9-15 10:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位老大,我在pads9.3导出asc文件,然后导入到allegro16.3时,出现如下问题:
9 d4 H7 z5 J/ }7 v2 J0 i2 @7 V* F9 {3 q& m2 S& T
Translating D:/Work_Dir/CNQ4205-3MB8V1.1new.asc.2 R( ~' r& n5 g! e1 w, f
Using translator version @(#)$CDS:  pads_in.exe v16-3-85D 11/3/2009 Copyr 2009 cadence DESIGN SYSTEMS.: `% e" [* h* I  T
Reading PADS ASCII file header.
' c$ d" n+ a# M. W Version = PowerPCB2005.2
0 H8 k# s% D( y- L* S Route Layers = 8
( @$ {( I) b* D( p7 y) G$ A' s Units = MILS
+ Z" d1 p) q/ X. F5 U% z Hatch mode = Vertical / Horizontal. X- o4 b0 M  g! {1 h' M( z
Hatch grid = 2.000000, angle = 0.000000, anti-pad spacing = 0.0003155 B- U: b0 l4 s  C
Initializing new database., y; c- h4 G0 u; u9 |9 n" L0 ]
Creating layers.) k  N. q& m8 U' M: D
Reading PADS ASCII file body.
/ P. A6 ?8 R3 ~5 [  C, F *MISC*
. C. q/ ?& \. H7 ^& }5 b0 R *MISC*
8 J" A  @0 z1 h *MISC*: s; T* d% G: ?! ^+ g# Z1 Z, G/ w
*MISC*9 U" t! i' B$ a- ]% X2 b- {
*MISC*
) `: F) K4 V" ?( @ *REUSE*) p2 b. f7 T$ b/ A0 u2 H; g' R# p$ P
*TEXT*
# `5 x6 x; p9 o  ]. M *LINES*' e: o) u- U! I! \
*VIA*
7 E6 [1 B. w5 R+ a& L *PARTDECAL*8 X+ m$ t* @' z8 z
*PARTTYPE*
2 a  ?0 Z/ t* \: I; ? *PART*
+ S) o& [7 U5 Z *ROUTE*# u6 d( h; i7 G! M9 W3 E9 P
Writing routes.
/ T" w& c- B0 R+ Q8 }9 q+ d1 } *POUR*
. O7 H( P6 }, p0 D4 t! a; a$ r *END*
: ~, u. o+ T) Q0 Y. T2 b
# o6 V* O, U6 N4 k- b5 y===============================================================================! i" _3 `& e) g! M: k
PADS layer usage summary:
' c: r; Q6 @, v6 j0 V  Layers 1 to 8 are route layers.% c# x. O6 m' K& {& ?2 ]9 U8 I
  LINES:% k" `+ t  S( m+ I7 T& N
     0 BOARD GEOMETRY - ALL$ C( Q2 `0 K, H& j1 r
     1           ETCH - TOP
, k% \6 B( P) t0 i" n1 ~     2           ETCH - INTERNAL1
- I# G# P  |0 Z, I# b: O+ e: [     3           ETCH - INTERNAL2
" r  A  }, f+ h* A. ~     4           ETCH - INTERNAL3
9 c$ H7 ]- d: e! ]7 Q     5           ETCH - INTERNAL41 i1 g& C! }* f7 l; e# v/ u
     6           ETCH - INTERNAL5& D6 y( T; K/ i* l: I5 z
     7           ETCH - INTERNAL65 V1 ?0 G$ d5 }. y
     8           ETCH - BOTTOM
8 X/ I* u3 y# F" G$ e. U' u     9  * Not mapped!
+ p1 P6 C* h9 `( e    10  * Not mapped!+ E3 B; P3 b  X
    21  * Not mapped!
( x# T8 \6 p: B) v9 I  n, X    26  * Not mapped!* m# q; |' y& u! S8 o
    28  * Not mapped!& Y+ e* V& y/ o# f& B8 I
    29  * Not mapped!* Y* A) u- r9 r
  COPPER:
! m# b1 b8 \/ n1 W4 ]     1           ETCH - TOP' N: }5 b; M7 y- I6 g) f8 o( x
     2           ETCH - INTERNAL1+ d3 E) W0 ]# A$ t2 n' _' d0 o
     3           ETCH - INTERNAL2, M/ l- I) g" j) t: ^& a& m
     4           ETCH - INTERNAL36 U  q  V# m- B
     5           ETCH - INTERNAL4& }5 _9 Q% u9 z4 A8 a! k
     6           ETCH - INTERNAL58 N9 o( Q7 w. p
     7           ETCH - INTERNAL6  c, f+ A4 ]) q0 \! f2 e
     8           ETCH - BOTTOM5 }+ ?4 e5 x0 T
  TEXT:
, ?7 I7 I1 r' h4 ^2 |# y9 \    250  * Not mapped!
4 r9 Y; U8 `0 N2 c; }: f* u  DECALS:0 ^1 D9 B& ~2 W' [0 o. s9 I, b
     0 PACKAGE GEOMETRY - SILKSCREEN_TOP
7 Z9 a. Z3 ^8 k" e" O" W     1 PACKAGE GEOMETRY - SILKSCREEN_TOP
6 _6 D0 G# V. @! B, L    20  * Not mapped!4 o0 ~7 T8 S5 w8 O* ?5 _8 b+ b: k
    21  * Not mapped!9 k* W* w# e3 z( X( q# M2 Y$ X
    27  * Not mapped!
; ]  m, i& _$ ^( j    28  * Not mapped!/ ^0 t8 J9 T9 m& J
  PADS:% {, V% c, w$ b( `$ U
     0           ETCH - internal_pad_def
' S. Q! X( t; u' ?% k0 I     1           ETCH - TOP
: X% b# N: G" J. b! O! _; ]: E     2           ETCH - INTERNAL1% Z$ L, m- S5 d3 q$ h$ Q3 \
     3           ETCH - INTERNAL2! c! C5 Z0 P$ y& ?8 u
     4           ETCH - INTERNAL3
; V" i9 b% }8 I6 H* i/ }* @     5           ETCH - INTERNAL4
, R$ \) `& ^# L; t' F$ E0 u% x     6           ETCH - INTERNAL59 ]" j1 `" L# m6 H$ p0 Z! p/ \
     7           ETCH - INTERNAL62 w4 z% i& ?1 n8 w: G% U
     8           ETCH - BOTTOM; W. ^2 Z: ^' l( ], N: w: L
    21  * Not mapped!4 c. ?1 w6 M( k
    23  * Not mapped!5 o5 r9 E% _. |7 ?. t5 V1 [; M
  VIAS:
) @9 u0 N, r$ g* h9 X+ i5 u4 X     0      VIA CLASS - internal_pad_def# q5 E8 t- r- u( {8 Z
     1      VIA CLASS - TOP
* ]  @4 V& ~" x8 n$ P. F     2      VIA CLASS - INTERNAL13 u9 @9 ~% D' T/ s
     3      VIA CLASS - INTERNAL25 L) i# W9 x( s" I1 l) U0 e8 X
     4      VIA CLASS - INTERNAL3
! P7 s1 l' [: G) D     5      VIA CLASS - INTERNAL4
: q$ h* \, Z* `     6      VIA CLASS - INTERNAL5
6 ]3 a: n# I% R     7      VIA CLASS - INTERNAL6
$ D7 N0 E  g5 Y, J7 z     8      VIA CLASS - BOTTOM
; s7 |2 n- ]: k7 v/ V- v
% i. q5 ^5 s# W/ p# G! M3 t WARNING: 3104 data objects mapped to the UNUSED class were ignored.
8 X& \9 z) g0 f, c0 U7 \===============================================================================
% H# C) I* }2 i. o. f
) ~* r4 Z% c; ^- C& M/ KCreating D:/SPB_Data\CNQ4205-3MB8V1.1new.brd.
' v' A: N2 y0 j0 \Loading netlist:
5 K  F% U) p# K3 b" mD:/SPB_Data\CNQ4205-3MB8V1.1new.TXT
# A) w8 s( H, \7 m0 l4 v- f
0 t# B8 \1 K( h3 F. T9 gTotal Combined Netlist and Device File Warnings =  13.% V* _* Q9 O- J' g0 S2 t! c
Total Combined Netlist and Device File Errors   =  0.9 q  B3 P- h5 T9 d$ |! j
See netin.log for details
, D. m: j/ Q1 A) |# O8 B8 ?" v+ ?
Writing database." [. G1 c  {9 v: ~6 ^  h( T
( O$ X, y7 A* e/ g) H1 |
Creating padstack definitions.
- n0 u% G! H/ l7 G* _2 Z Creating symbols.
/ e7 _, w+ I4 p3 i# E9 S9 f Creating independent data.
  S  O. D8 p/ x0 y. G WARNING ERROR(SPMHDB-205): VOIDs must have same width as their parent SHAPE.  Can't create void of shape. iges id 34738. Continuing." J$ [5 G5 A) h/ U" W6 ]
WARNING ERROR(SPMHDB-205): VOIDs must have same width as their parent SHAPE.  Can't create void of shape. iges id 34821. Continuing.$ w/ f" k  \3 T! G
WARNING ERROR(SPMHDB-205): VOIDs must have same width as their parent SHAPE.  Can't create void of shape. iges id 34893. Continuing.) [- }: ~4 |/ l  z& K" t
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 35311. Continuing.
8 L. i9 h  w. T' g" f( i WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 38537. Continuing.
: I) w' ~) x0 ~0 E3 h WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 39292. Continuing.
3 x) k8 f* z! P+ z/ n2 g$ F WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 40031. Continuing.0 P8 Z: [# C. g0 u
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 40475. Continuing.
% f( Y+ b# x9 i5 P; r% \: @ WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 45063. Continuing.
8 r6 m7 a2 N7 g5 Z5 e1 ` WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 50542. Continuing." G! t0 H4 R) v
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 53651. Continuing./ v% y' n! H7 I- T
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 53690. Continuing.0 [7 a, l$ F7 A+ s$ `- v
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 53763. Continuing.
: f3 k- v, u1 ^6 p8 j, | WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 55481. Continuing.- o) I* D/ s' L8 t& ^
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 57565. Continuing.. S3 X2 v2 Z+ w% i! d  g
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 57606. Continuing.
9 I1 k; p1 U. Z" O  T. p WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 57666. Continuing.
4 ^/ _& m3 z5 \! w WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 57853. Continuing.: p- R% [. v; Z4 J
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 59305. Continuing.* _! W5 `: X$ T/ h, B
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 61472. Continuing.8 T# \2 X" w+ T, V* H* |; N
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 61943. Continuing.
/ S$ N$ f% k% z& S3 \1 C4 ~9 n& x WARNING ERROR(SPMHDB-187): SHAPE boundary may not cross itself.  Can't create shape/polygon. iges id 62099. Continuing.
, m& K) }  n2 B- J! A WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 62176. Continuing.
+ _$ U3 N! s) x& h+ ^3 z WARNING ERROR(SPMHDB-67): The coordinate buffer is incomplete.  Can't create shape/polygon. iges id 62357. Continuing.1 b2 |( J) `- f; _4 O! W) E# V3 M& n
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 64372. Continuing.
& \6 v7 Z! B( [% Q WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 66868. Continuing.
* P, v1 _3 q9 k! o WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 71682. Continuing.
: V3 D4 I8 A. l/ A: X7 ^ WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 76723. Continuing.+ d5 P  F- B" s0 b1 h
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 81048. Continuing.
! m8 y( m! ^& j WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 81365. Continuing.' Q6 x4 l5 S1 t7 I1 p2 R  h
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 81584. Continuing.
  a/ G: Y  {& q# g WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 82211. Continuing.7 s, @9 @7 l9 z% ~
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 82304. Continuing.$ {5 K* Y; }- U
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 82929. Continuing.5 _7 R* d: m- ?; W, v
WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create void of shape. iges id 83160. Continuing.
* o- h) ?# a' @4 r) S WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 83680. Continuing.  Z) _/ S: Q' Z
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 83692. Continuing.
0 ]- t' z% m8 {1 Z) c! H# o WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 83708. Continuing.
, {% m' p. h& [5 I% S WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 84332. Continuing.
" l' r" v. r7 N WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 84425. Continuing.% _. z3 m( d& O9 W
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 84484. Continuing.
  K) G$ {  \1 O( U" e+ c4 K WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 84713. Continuing.3 {+ Q5 `- {# t# I- e9 x, H% I
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 85439. Continuing.
" }) T; ~5 S! I: z4 O) M% ? WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 85452. Continuing.
7 ^  d! K, t6 m WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 85453. Continuing.
  f) {# ]  V. v  ~: d4 z WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 85458. Continuing.6 u5 F' F* y+ U4 `9 H' T
WARNING ERROR(SPMHDB-187): VOID boundary may not cross itself.  Can't create void of shape. iges id 85558. Continuing.
: L. I) B' D5 S: }0 G0 N WARNING WARNING(SPMHA1-310): Illegal segment endpoint.  Can't create shape/polygon. iges id 86074. Continuing.
4 @8 T1 ~9 w. a) B. ^# [' u- A  P6 }4 P' i, G" L0 J4 C
Closing database.
. g: S, ?' j4 B# qLoading constraints...
0 V- \6 l# |* \0 y5 w8 B. ETranslation complete.% O9 X- ~( ~. K+ L# h+ d
Finished reading input file with no errors.
" G6 i: A6 ^4 t) s0 H8 x, e  S9 `+ q, G& @
pads里的铜皮都删除了,而且转出的asc文件各个版本都试过了,都是类似问题。请各位老大帮忙一下。谢谢了!
    2023-10-12 15:00
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2011-9-15 11:24 | 只看该作者
    强扭的瓜不甜……
    : F8 {* Q1 x* d& M9 Q' A0 d8 R4 g
    0 n% C0 q9 M8 }* G2 Z& H何必强求……
     楼主| 发表于 2011-9-15 12:46 | 只看该作者
    应该可以转的吧
    2021-9-26 15:08
    发表于 2011-9-15 17:44 | 只看该作者
    2楼的回答好经典。
    2 Y. ?1 o1 D' S, F& D9 L! M9 k我用cadstar转pads也老出错,出来的图只能看看,不能用的。
    发表于 2011-9-16 09:05 | 只看该作者
    即使转换成了,也需要大量的修改。
    头像被屏蔽
    发表于 2011-10-11 14:58 | 只看该作者
    提示: 作者被禁止或删除 内容自动屏蔽
     楼主| 发表于 2011-10-11 20:26 | 只看该作者
    哎,可悲呀
    发表于 2011-10-12 11:21 | 只看该作者
    铜皮是不识别的
    发表于 2013-3-13 11:26 | 只看该作者
    转时需要一个 pads_in.log 不知道那个在哪里
    发表于 2013-3-13 12:06 | 只看该作者
    同楼上,转换时弹出“unbable to open the log file”,不知哪位高手可以解决!
    发表于 2013-3-13 14:47 | 只看该作者
    在安装路径下:Cadence\SPB_16.3\tools\pcb\bin\pads_in.ini
    GMT+8, 2026-5-7 20:05 , Processed in 0.156250 second(s), 23 queries , Gzip On.
