查看: 258|回复: 2
单片机按键控制流水灯程序 不能切换方向的问题
发表于 2022-3-8 08:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3 j3 e" {0 r5 h8 n- k( h为什么只能右移不能左移啊,暂停也有用,但不能切换方向这是为什么?难道和定时器有关?6 P3 ~- n+ y2 s
6 b( d" Q* ^9 n9 ^单片机源程序如下:
' M3 @3 c8 O( a9 b3 t, b" J. k#include <reg52.h>. `2 F; N+ d( z% c7 K
#include "intrins.h"8 V9 s6 i& U8 c; `9 e
" B2 p3 |0 v: ], j1 R) Q+ V5 \
typedef unsigned char uchar;
" B$ G# A) }" v8 j% H! Ctypedef unsigned int uint;
% |4 p, q& G5 o9 U- u, W; ?; O2 |0 ?
uint i = 0;
) d2 n6 C4 h7 k, e0 ?uchar led = 0x01;
" c( U/ e5 V: M2 N. |$ X1 Bint flag = 1;
! L% W; ?: y. K$ W# E/ Q) S% \3 P4 k
" [' n/ m' |" ^& s- O, Jsbit key1 = P1^0;  3 z8 Y8 j5 R. ]- m3 w- b. g7 V
sbit key2 = P1^1;  \( T: M' M& H
sbit key3 = P1^2;3 ^* _( r1 j& b5 s
2 J/ S2 L* J# N8 _" i- |void delay(uint z) {  //1ms) Q5 r; c1 t# X4 G* h$ z
        uint y;
* g& }0 _9 i7 l! |        for (;z > 0; z--) {+ P  w* V/ {( H9 X% n
                for (y = 0; y < 110; y++){
$ i: i6 I9 _) y1 S" q                }
8 Q0 {3 k- J* I2 Q& o7 }        }6 F3 K+ c; J6 J1 P" }: n
}, T7 q- N# P. E: j* y
; |# ]& H+ \- e9 G" Y% A
void DelayInit() {
8 @% R* {8 \2 K% A% b' P9 @         EA = 1;
6 ?8 E+ Y! e& v4 v4 D        ET0 = 1;   //开定时器/计数器T0中断        EX0 外部中断0;EX1 外部中断1;ET1 定时器/计数器1;ES 串行口中断;
, E) D/ W9 }6 D  w, z        TMOD = 0x01;          //Gate = 0, C/T = 0(定时模式) ,M1M0 = 01 方式一16位定时' F$ x. k7 Y! Q0 E  S
        TH0 = 60;  //初值高八位    (65536 - N) / 256/ R" e- y: E: ]2 L* E6 r4 ^
        TL0 = 176;        //初值低八位    (65536 - N) % 256   N = 50000时 50ms 12Mhz时 计数一下正好1us+ g/ z2 I) r: e# M/ `* i, C& ^$ W
        TR0 = 1;   //开启定时器/计数器0, L5 T0 a9 B) W! W9 O
2 E& K! h2 H- G8 J  y# N5 f" H% Y7 M3 n7 S" q. g+ c
void Delay50ms() interrupt 1 {# f9 F) @% B8 Z, {2 g* S- \
        TH0 = 60;
2 X; _2 w3 S" {) F! a7 T/ Z/ j        TL0 = 176;) G# f! W/ O* @; X- s/ f
, T2 W% t1 Z7 E& V9 d
        i++;, y6 `# O4 m2 E& E/ G. Z8 e
        if (i >= 20) {
5 T9 \! K' G4 }* W/ U                i = 0;
: F* _: @& G8 }8 Q2 O2 {5 R                if (flag == 1) {        ' \! C/ E. j9 c5 v  j1 Y( W
                        led = _crol_(led,1);. @! C4 ?, @: R: x' N# H
3 Q1 S& Y- l+ N( V8 O8 L& B                if (flag == 0) {
9 i# X8 Q* ~0 d. Y7 V' U                        led = _cror_(led,1);
; X5 R; z6 B, H& J, M/ }) ^4 w5 W2 W                }
& L% t) d) F% B: x' s        }. R/ f( ]/ b* [
}% a; g( \( T( `
2 T* |3 h& M3 }) i, W6 Yvoid keypros() {
; s5 F/ V: l2 R: U! \. k        if (key1 == 0) {
3 r. w" l) F' p8 r* V( j% G                delay (10);   //消抖10ms
8 k5 I: k8 k8 m2 {                if (key1 == 0) {& J9 e9 V0 v, r7 C& H# t8 o8 W4 x
                        flag = 1;        . D0 ?2 [' f4 E& e
/ R2 X/ d4 W3 Z' h                //while (!key1);
0 p+ N$ P) F& Y        }) r! k! K. H& N7 R0 T+ E; ^
        if (key2 == 0) {
0 d9 U: {8 P' a$ Z; `% {                delay (10);   //消抖10ms' b. l7 t" n" C$ E  u) g
                if (key2 == 0) {! B5 N5 I# [- x8 [! F- ]. H
                        flag = 0;        5 Z% v% ~* G" {4 ?( o
                }        % }4 ?+ _2 L! u* S6 O
                //while (!key2);
; X; j' e7 @# q* l        }: {. ^' Y. m% T/ z
        if (key3 == 0) {
: P- G8 ]4 h% b* v0 }5 j8 k                delay (10);   //消抖10ms5 _7 W. N. n  m4 K% b& `9 L
                if (key3 == 0) {/ C, C* ]1 Z% x* ^. A5 k( \
                        flag = -1;        ) I: Y* Y7 S3 B' g" t+ A/ Z
4 s# H8 M3 S# q6 v1 d4 Y# x                //while (!key3);- J8 ~  v: E* e- Q0 g) u) x
8 L  s& T* U: v; l}
, `) O4 z/ T; V- n# f0 s$ x. u: R1 Z# U5 O9 `( v6 |& I
void main () {
9 j  m% u9 O, p        DelayInit();
; X7 y8 ?" l: }, I9 B; U        while (1) {1 K' R! B4 ^+ \# G
                P0 = led;% d8 E  Q' p6 l
                keypros();4 a* Q) ~* f- M* ?; {
+ z3 L& w) f' x# [1 D9 H) f8 j$ j; C- H+ J
发表于 2022-3-8 09:14 | 只看该作者
while(1)循环里面的语句P0=led;取消就可以了。
发表于 2022-3-8 09:22 | 只看该作者
3 Y5 A! d# X  }取消循环里面的语句:P0=led;
GMT+8, 2025-10-9 09:44 , Processed in 0.171875 second(s), 23 queries , Gzip On.
