查看: 241|回复: 1
全志A40i开发板PWM 的应用-飞凌国产芯片系列干货
发表于 2021-11-18 16:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本文讲解了国产[color=inherit !important]A40i [color=inherit !important]开发板PWM的应用,本篇文章主要适用于[color=inherit !important]飞凌 OKA40i 平台 [color=inherit !important]Linux3.10.65 操作系统,其他ARM 平台也可以参考,但是不同平台之间会存在差异,请自行修改以适应自己的使用。 写本文章的主要目的是协助客户加速产品的研发速度,由于水平有限, 不提供任何的完整性、可靠性等保证,软件版本更新之后,有些位置名称等内容可能会及时更新,修改方法请参考使用。
一、PWM的应用1、pwm的添加
9 x) I+ K! s0 s" S$ |0 T& s* \
增加一路 pwm,以 pwm4 为例说明,其他方法类似,只做为参考。
arch/arm/boot/dts/sun8iw11p1.dtsi6 v4 ~! F6 C. N  J" _1 `' A# h0 N+ f4 O
中添加
* e$ Z! y9 k0 z& S! X3 y& \pwm = &pwm;pwm0 = &pwm0;pwm4 = &pwm4;pwm: pwm@01c23400 {         compatible = "allwinner,sunxi-pwm";        reg = <0x0 0x01c23400 0x0 0x154>;        pwm-number = <1>;         pwm-base = <0x4>;         pwms = <&pwm4>; };pwm4: pwm4@01c23400 {        compatible = "allwinner,sunxi-pwm4";         pinctrl-names = "active", "sleep";         reg_base = <0x01c23400>;        reg_peci_offset = <0x00>;         reg_peci_shift = <0x04>;        reg_peci_width = <0x01>;         reg_pis_offset = <0x04>;        reg_pis_shift = <0x04>;        reg_pis_width = <0x01>;        reg_crie_offset = <0x10>;         reg_crie_shift = <0x08>;         reg_crie_width = <0x01>;        reg_cfie_offset = <0x10>;         reg_cfie_shift = <0x09>;         reg_cfie_width = <0x01>;        reg_cris_offset = <0x14>;        reg_cris_shift = <0x08>;        reg_cris_width = <0x01>;         reg_cfis_offset = <0x14>;        reg_cfis_shift = <0x09>;        reg_cfis_width = <0x01>;        reg_clk_src_offset = <0x28>;        reg_clk_src_shift = <0x07>;        reg_clk_src_width = <0x02>;        reg_bypass_offset = <0x28>;        reg_bypass_shift = <0x05>;        reg_bypass_width = <0x01>;         reg_clk_gating_offset = <0x28>;         reg_clk_gating_shift = <0x04>;         reg_clk_gating_width = <0x01>;         reg_clk_div_m_offset = <0x28>;        reg_clk_div_m_shift = <0x00>;         reg_clk_div_m_width = <0x04>;        reg_pdzintv_offset = <0x38>;         reg_pdzintv_shift = <0x08>;        reg_pdzintv_width = <0x08>;         reg_dz_en_offset = <0x38>;        reg_dz_en_shift = <0x00>;        reg_dz_en_width = <0x01>;         reg_enable_offset = <0x40>;        reg_enable_shift = <0x04>;        reg_enable_width = <0x01>;         reg_cap_en_offset = <0x44>;         reg_cap_en_shift = <0x04>;         reg_cap_en_width = <0x01>;         reg_period_rdy_offset = <0xe0>;         reg_period_rdy_shift = <0x0b>;        reg_period_rdy_width = <0x01>;        reg_pul_start_offset = <0xe0>;         reg_pul_start_shift = <0x0a>;         reg_pul_start_width = <0x01>;         reg_mode_offset = <0xe0>;        reg_mode_shift = <0x09>;         reg_mode_width = <0x01>;        reg_act_sta_offset = <0xe0>;         reg_act_sta_shift = <0x08>;        reg_act_sta_width = <0x01>;         reg_prescal_offset = <0xe0>;         reg_prescal_shift = <0x00>;         reg_prescal_width = <0x08>;        reg_entire_offset = <0xe4>;        reg_entire_shift = <0x10>;         reg_entire_width = <0x10>;         reg_active_offset = <0xe4>;         reg_active_shift = <0x00>;         reg_active_width = <0x10>; }. m% c' \* J/ g
按手册 PWM 修改对应的寄存器。
修改 sys_config.fex 中 twi2_used=0 且增加
' W% x9 X6 f$ n. u+ N
[pwm4]pwm_used = 1pwm_positive = portB20<4><0><default><default>[pwm4_suspend]pwm_positive = portB20<7><0><default><default>
3 i$ z  l7 L+ o- m
编译镜像并烧写
2、PWM的测试
* Y5 u2 O2 C# n) O+ L8 Pecho 0 >/sys/class/pwm/pwmchip4/exportecho 1000000 > /sys/class/pwm/pwmchip4/pwm0/periodecho 500000 > /sys/class/pwm/pwmchip4/pwm0/duty_cycleecho 1 > /sys/class/pwm/pwmchip4/pwm0/enable
9 K% K( j, F; X6 R
测量得到频率为 1K 方波
% d( g+ J' G: |( _# X) o5 D
echo 0 > /sys/class/pwm/pwmchip4/pwm0/enableecho 208333> /sys/class/pwm/pwmchip4/pwm0/duty_cycleecho 416667 > /sys/class/pwm/pwmchip4/pwm0/periodecho 1 > /sys/class/pwm/pwmchip4/pwm0/enable0 N. Y/ d$ ?2 p( F! s0 |
测量得到频率为 2.[color=inherit !important]4K 方波
  ~: y1 W3 N. l5 G5 s/ D- c
发表于 2021-11-18 17:36 | 只看该作者
PWM测试的方法是什么
GMT+8, 2025-10-13 00:06 , Processed in 0.125000 second(s), 23 queries , Gzip On.
