% Q5 R, ~# ?5 N2 D f# u4 u' [/ Q8 [2 ^% y" M0 Z
! m% t, x6 t5 l; E4 S( H/ | m \ h
' ?3 U+ G+ r( R4 c, k
6 Z7 Z3 z! f5 s1 Z3 }( c; {5 [4 \) G2 PFixed CCRs: SPB 17.4 HF023. o/ f$ Z9 q9 T, g
11-5-2021
9 Y3 _+ P' `' Q8 R, F; s========================================================================================================================================================
7 w* Y: U: |" Q& ]4 [! _0 ~CCRID Product ProductLevel2 Title
8 p& u1 l/ V N; X U========================================================================================================================================================
1 n8 A( x7 [8 W4 o2544340 ADW ADWSERVER Databases/server/history folders keep growing in size without automatic purging of files
) c B9 b& c* T- D- u }2 `! T2490992 allegro_EDITOR 3D_CANVAS Non_Plated holes are filled with Black Material while applying custom Color Themes D+ C: \. g6 ]0 L/ C' q
2493389 ALLEGRO_EDITOR 3D_CANVAS Mounting hole appears black in 3D Canvas with custom color theme- T6 ^ |6 ]& W/ c" n2 G( ?
2502024 ALLEGRO_EDITOR 3D_CANVAS Allegro 3D Canvas Mapper issue: 3D Canvas displays large pink squares in addition to the actual part: M* y* W w( O t8 f5 Q& a+ U
2550929 ALLEGRO_EDITOR COLOR Parameter file import through axlImportXmlDBRecords not working
5 O/ z/ E! [% o2545956 ALLEGRO_EDITOR CROSS_SECTION Updating DFM rules and then checking in BRD file causes TDO to crash- V: i8 b! n) K* x; j5 c* h
2546547 ALLEGRO_EDITOR DFM Mask shape completely inside 'FILLED RECTANGLE' is not ignored for mask sliver check% Z o5 C) Q/ `& h- B, Q9 f
2554744 ALLEGRO_EDITOR DFM Unable to delete layer from Stack and PCB Editor stops responding
3 k4 Q x2 h$ ~2 E# A# r2519132 ALLEGRO_EDITOR GRAPHICS Shadow mode dims the pads & Via on the active layer
7 K# t/ A/ l7 C) C2550662 ALLEGRO_EDITOR GRAPHICS NPTH hole not displayed correctly in GPU mode
5 L, I7 q- W1 V1 l1 R V( X8 m) G2550722 ALLEGRO_EDITOR GRAPHICS NPTH not displayed if GPU is enabled( S9 I3 S. q& B
2550727 ALLEGRO_EDITOR GRAPHICS Shape boundary not visible if GPU is enabled
& k) ~. r8 V/ S# t# s2550736 ALLEGRO_EDITOR GRAPHICS Design reloaded on enabling GPU and switching thermal pads on or off. E2 [4 Q6 [! j2 O5 v! A/ E
2551623 ALLEGRO_EDITOR GRAPHICS Drill hole display flickers on enabling GPU8 }: x- ]7 J/ w0 s p9 j9 @0 N
2560233 ALLEGRO_EDITOR GRAPHICS Transparency does not work with custom colors if GPU is enabled. D% k2 q) |8 n% Z' Y& `; O4 Z! c4 r
2044946 ALLEGRO_EDITOR INTERACTIV "Property Edit" not available in popup menu of text objects- _4 }* Y1 h3 L& N, P
2340000 ALLEGRO_EDITOR INTERACTIV 'Undo' not available for aliases or funkey commands if another command is run
4 L7 o/ Y; n: c2539453 ALLEGRO_EDITOR INTERACTIV Issue with Padstack Replace not obeying Fixed property for Vias.
, l3 V: F$ g5 i2552776 ALLEGRO_EDITOR OTHER Creating new drawing in orcad PCB Designer: Extent width and height changes2 e6 V( V7 D2 i2 @7 d! B+ [
2554023 ALLEGRO_EDITOR OTHER New BRD or DRA using templates creates blank files in release 17.4-2019
* P) v% }& a: c( l6 D2561124 ALLEGRO_EDITOR OTHER New BRD file does not inherit from browsed Template
# U1 l0 C2 `+ m; E% t0 @2476133 ALLEGRO_EDITOR PLACEMENT Rotate command is inactive after first application of 'replicate circuit'
8 f8 ?! d O8 n. N4 g% ]2529943 ALLEGRO_EDITOR PLACEMENT 'Place > Via Array> Surrounding' on cline segment places via on whole cline2 U; P! G1 I5 p+ g
2558718 ALLEGRO_EDITOR PLACEMENT Colon in page name breaks the 'Place by schematic page number' flow with PCB Editor& \( | b- S/ t. C! m6 T2 W q1 `! C( r
2546914 ALLEGRO_EDITOR UI_GENERAL Popup window for 'add via' with working layers option displays incorrect layer name+ J4 l! ^, g: z* S! z S4 R
2554145 ALLEGRO_EDITOR UI_GENERAL "Last" button on Visibility Pane not opening expected view
4 Q" Y/ \ j ~2 P% b7 A' x1949297 APD DIE_STACK_EDI Embedded layers not correctly represented in the cross section( d8 F' ?5 G5 d& d2 O3 U0 u3 Z
2554163 ORBITIO DESIGN_STACK Integrity 3DIC shows inconsistent data between Scale Factor value and die size on canvas- J5 q+ Y7 P6 p5 v8 j, T$ b/ s
2545904 ORBITIO LEFDEFINTERFA System Planner cannot load die area of polygon in DEF
/ C+ x2 I" O, O9 K; ~7 H: F2551405 ORBITIO LEFDEFINTERFA Grid Setting in System Planner for shrunk die: Manufacturing grid does not match
T, q H8 V& Y: g, u8 j2548144 PULSE R2PLM-WC PFM should honor the BOM component type defined in server config while deleting usage links
2 o4 D* T" G. p9 p0 p+ u9 N2507942 PULSE UNIFIED_SEARC Filter button moves to next line in some versions of Firefox
7 O! w; U6 |2 g2 @2545123 SCM COCKPIT SCM crashes when doing Replace Component the second time
9 @ f. e9 s' z& Y( i. u$ W9 Y# f2519244 SYSTEM_CAPTURE PACKAGER Reassign Ref Des has designators starting with 0 (zero)
# X+ z' p" f6 }2558242 SYSTEM_CAPTURE PACKAGER Assign pin number on part with multiple sections is not working in System Capture in HotFix 021% c$ B& H2 ]" i m
2535420 SYSTEM_CAPTURE PART_MANAGER Run Part Manager on project load does not work. I" \& J' {) a6 c' l+ ]8 W
2554911 SYSTEM_CAPTURE PART_MANAGER Replace component from search results does not replace part6 C* i# l5 f3 ?1 d7 T
2550993 SYSTEM_CAPTURE PERFORMANCE System Capture works slow when working with attached design
3 P( U) X0 w; j- R2550247 TOPXP SSIVIEWER Topology Explorer PBA Report Generation Section 2.2 is incorrect; O% g" H1 Y s$ U% H; n) h( R; r2 E
2550840 TOPXP SYSTEMPI SystemPI quits unexpectedly on creating new topology or opening existing topology& Y- T, ^ }9 _' i3 M* f) e) C
2553854 TOPXP SYSTEMPI Topology Explorer crashes on creating or opening a project0 [& f9 K% H9 Y- g
2551380 TOPXP TRACE_EDITOR Comma as delimiter causes problem for regional settings requiring comma instead of dot for decimal delimiter
3 f9 Q$ a% a3 \% x6 Z
% l4 r x6 A4 t! E& |; n8 j( d0 S7 Z6 u' f! A8 l% b
6 n+ q: \" b' X9 d, |: _ |
