查看: 313|回复: 2
keil中C语言的();【】;{}三种括号的使用
发表于 2021-11-10 13:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
keil中C语言的();【】;{}三种括号的使用, ?. U  z' u7 f+ i- @: p
( I9 X9 \! g/ p! s. G
/*        名称:K1-K4 控制数码管加减演示
" u0 m8 g6 T8 s+ p        说明:按下K1后加1计数,按下K2后减1计数,按下K3后清零。
, P1 O: Y. O  y; }*/
0 Y9 t2 l* ^# g* F$ n#include<reg51.h>$ S  o0 f, a! H! A; t
#include<intrins.h>
. f$ J5 p% i/ L' P# G* {: O#define uchar unsigned char1 m: @( h& U! l/ Z2 M+ }, ]
#define uint unsigned int
4 q% A' h2 W4 ]5 r6 u7 q; [2 R//段码
' R* B4 N% l% y5 d: B" xuchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};- w" T/ Q# _% i$ Q& @: k5 b* M
//待显示的3位缓冲
8 [! {1 n& s9 i$ K2 z$ @uchar Num_Buffer[]={0,0,0};; X& S5 y0 a  J- c0 N" x
//按键代码,按键计数
/ d7 j4 b4 F- I. Quchar Key_Code,Key_Counts=0;) d3 `" p8 Z! O5 B) C; h1 A0 d
//延时8 O/ T. T$ Y/ P. h1 _, B# P
void DelayMS(uint x)9 J9 U: `+ n" _; S2 F
. y3 |" n: M/ I6 i/ r        uchar i;
" j) t# s" F8 H; a1 v& f        while(x--) for(i=0;i<120;i++);+ r6 r# a. G" C9 e  f
0 ^9 W% U# |% |* z+ h$ t! @//显示函数0 f: J+ X. R. W0 m- e, s
void Show_Counts_ON_DSY()! D  _2 ^+ s0 e7 N! |2 `$ T$ Z
8 Y8 [3 k6 k2 ~0 |7 z        uchar i,j=0x01;) {+ N( h* {, W* s6 g
        Num_Buffer[2]=Key_Counts/100;
1 e" B9 N9 T' g! X2 H        Num_Buffer[1]=Key_Counts/10%10;! W  Z4 ^$ k+ Q
        Num_Buffer[0]=Key_Counts%10;
' d; R& Q! F; k# |  J        for(i=0;i<3;i++)3 b. V* q; k- y' V* f. j/ i
        {( R  [3 y. x0 y7 N8 B% P' C/ n
                j=_cror_(j,1);
/ x, F/ A, D+ d9 t                P0=0xff;
1 X: z6 q2 L3 U0 }3 P' x                P0=DSY_CODE[Num_Buffer];  v! R/ _0 j- u: U8 _2 n! Y
                P2=j;
5 S0 N) l; z5 W                DelayMS(1);
, S7 k( E6 v7 y* B6 p; O        }
! V; ]% ~5 j* a1 w}5 n# d3 p" w1 Q8 _
//主程序4 C# W) M- X* \+ g! X$ u* ~, j
void main()
& K. r" j- S/ ?& Z: e% J6 I( S{/ x0 w4 Y2 S6 @6 n8 E3 u
        uchar i;3 d# D0 a; W" f: P% \, N! t
        P0=0xff;$ m/ V; _) x+ S, [3 L/ H
        P1=0xff;# r! A* [! X/ ?/ J! n
        P2=0x00;3 ?8 z" L( o: T9 e; v/ R
        Key_Code=0xff;  ^6 B% |3 y' |, v
        while(1)
4 p& x4 X( C- M. ^) ^7 Y. u        {
# x, L- V% v  K                Show_Counts_ON_DSY();+ `- z1 v" \6 c& o& R5 b+ J
                P1=0xff;
: z2 T* l3 S2 L6 Q: O% k: N$ O                Key_Code=P1;
. O5 y7 H! P6 e# ?% ~                //有键按下时,数码管刷新显示30次,该行代码同时起到延时作用# j' _4 ^. r9 i& N% L! o9 k
                if(Key_Code!=0xff)
3 D% T! b) e; E: C5 D                for(i=0;i<30;i++) Show_Counts_ON_DSY();, @( d0 R2 \) ~/ g/ s
                switch(Key_Code)1 ]2 w( G# K" N' ~3 h
                {2 ]% t) v! Z9 [% @( X
                        case 0xfe: if(Key_Counts<255) Key_Counts++;9 W2 W" X4 O& o) x3 C2 r
                                                break;7 `/ f7 X5 u! p$ e
                        case 0xfd: if(Key_Counts>0) Key_Counts--;
8 _# I. u( F9 V# B) |                                                break;, e, A" r- t7 R
                        case 0xfb: Key_Counts=0;  D+ i+ L( Z1 e: H4 L' k3 m
                }2 R6 w2 a: v% x8 l
                Key_Code=0xff;, s5 Z* ?/ F: H! b/ g0 [
% z( l% O7 m/ W0 F}
! n& d8 [0 u3 F; l# h9 N5 e5 L( c  X6 n7 ~( e% N
8 z2 G+ k1 P4 Q1 @8 m2 Z1.我想知道什么情况下要用空格、逗号?
4 r. ~. Y: H2 t7 ?3 f- u2.什么情况下用小括号();中括号【】;还有大括号{}?
8 f& d6 |3 q1 k  m
发表于 2021-11-10 14:04 | 只看该作者
if , for和while语句中的表达式需要括号
 楼主| 发表于 2021-11-11 17:53 | 只看该作者
ssdgh 发表于 2021-11-10 14:044 ]1 ?% z7 R/ ^9 k0 g
9 W  C$ C. w1 i7 RNum_Buffer[2]=Key_Counts/100;' @3 E$ ~. p: Z- C8 F
0 n  _! D& \9 I  d        Num_Buffer[0]=Key_Counts%10;
3 L( P8 a3 l8 c$ g是说除以100取出整数,除以10取出余数,对10取余数?
$ G! h4 _, l4 l, p/ N+ n4 s* g6 D. w% M, W6 N: C. H1 P4 x
GMT+8, 2025-10-30 17:04 , Processed in 0.156250 second(s), 26 queries , Gzip On.
