查看: 607|回复: 1
[毕业设计] 基于单片机的信号发生器设计
发表于 2021-11-4 10:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
摘要此函数信号发生器是基于单片机AT89C51设计而成的,能够产生频率范围在0Hz—535Hz的锯齿波、正弦波、三角波、矩形波四种波形,并且能够通过液晶屏1602显示各自的波形类型以及频率数值。首先,单片机AT89C51经过程序设计的方法生成各种数字信号,再通过D/A转换器DAC0832将数字信号转换成模拟信号,滤波放大。接着,通过按键来控制四种波形的类型选择、和频率数值选择,并由液晶屏1602显示其频率数值和波形类型 。总的系统包括信号发生部分、数/模转换部分以及液晶显示部分三大部分,其中尤其对数/模转换部分和波形产生和变化部分进行详细论述。
' b$ u5 G# j/ p2 b$ u) n
关键词:AT89C51DAC0832  液晶屏1602
Title : Design of signalgenerator based on mcu
) z; A2 R. s& a0 B6 e
Abstract:This function signal generator is based on the AT89C51 microcontrollerdesign, capable of generating frequency range 0Hz-535Hz sawtooth, sine,triangle wave, square wave, four types of waveforms, and each type of waveformand frequency can be displayed by the LCD screen 1602value. First, AT89C51microcontroller programming method to generate a variety of digital signalthrough the D / A converter DAC0832 converts the digital signal into an analogsignal, filtered and amplified. Then, the key to control the four waveform typeselection, and frequency selection of values​​,the value of its frequency and waveform type is displayed by the LCD screen1602. The total system including a signal generating part of the digital /analog converting section and a liquid crystal display section of three parts,wherein in particular for the digital / analog conversion part and the waveformgenerating and changing part discusses in detail.
& t3 j& ?. U, p/ y
keywords:  AT89C51 DAC0832  LCD in screen 1602
# V2 |+ Y: e+ [& J, {  G附件: 基于单片机的信号发生器设计.zip (213.11 KB, 下载次数: 2) 5 x; F2 f2 o; m$ }
1 ]8 x! A0 W0 c: N3 C1 M
发表于 2021-11-4 13:25 | 只看该作者
GMT+8, 2025-10-5 17:56 , Processed in 0.140625 second(s), 26 queries , Gzip On.
