查看: 2766|回复: 6
allegro 15.5导入netlist文件出现下面情况,请高手门帮帮忙啊。谢谢啦
发表于 2011-7-21 13:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
cadence Design Systems, Inc. netrev 15.5 Thu Jul 21 12:30:24 20115 u1 J' ^5 r* s3 B$ j
(C) Copyright 2002 Cadence Design Systems, Inc.9 @/ A" }! t/ U) {$ ^7 X
4 M. V( m3 H; R9 j4 U$ _------ Directives ------
: G+ z, e6 p  S/ |1 i3 g8 W' e3 d0 ^7 @6 e" L
RIPUP_ETCH FALSE;) f0 M/ S* q# j  @
RIPUP_SYMBOLS ALWAYS;2 e1 s) W% a: ]+ S& }# v) r; G& C
MISSING SYMBOL AS ERROR FALSE;
1 i% ^& Z7 O' d0 [) B0 T( W" |SCHEMATIC_DIRECTORY 'E:/allegro_0711';) ?9 B  C9 Y) k/ J
BOARD_DIRECTORY '';. ]0 r4 a' l* y5 z7 h5 d, [. v! |
OLD_BOARD_NAME 'E:/chenjian/unnamed.brd';
( o: f) w# H4 i- w& GNEW_BOARD_NAME 'E:/chenjian/unnamed.brd';3 }4 X; q6 m* g6 r; v! Y
" F6 E3 x* I/ G
CmdLine: netrev -$ -5 -i E:/allegro_0711 -u -y 1 E:/chenjian/#Taaaaaa01980.tmp9 K9 m  Z$ l( _; V& z$ F" {
. w# M, a: o8 }6 M9 V! w------ Preparing to read pst files ------
  J$ }6 u/ e- q: i- f
3 q, s0 V" U% V! F4 FStarting to read E:/allegro_0711/pstchip.dat 7 m, u& F( m7 c4 [0 ~& y; j4 V
   Finished reading E:/allegro_0711/pstchip.dat (00:00:00.00)
2 T4 A$ E# ?5 v) i3 tStarting to read E:/allegro_0711/pstxprt.dat / R9 w1 d0 ]0 U2 H
   Finished reading E:/allegro_0711/pstxprt.dat (00:00:00.00)# }/ g. D0 j. E# s$ e
Starting to read E:/allegro_0711/pstxnet.dat
( J& ?& W+ w) E7 q* F6 S   Finished reading E:/allegro_0711/pstxnet.dat (00:00:00.00)
7 f8 j4 C( E* b2 ^; H
8 e% U! M" n% X/ a2 B  h------ Oversights/Warnings/Errors ------3 u% l6 k& R: V3 I# l6 U* S
. T  A* J) S$ U+ s( y/ c- X. X5 F2 q& ~, M- h) E, Q3 W, n; D' y
#1   WARNING(304) Device/Symbol check warning detected.
: _: ]& X8 v. |5 \- _# s& B4 g, j7 h/ J$ V& v7 N7 j6 s# k
Symbol 'CC0402' for device 'CAP NP_CC0402_DISCRETE_@10PF' not found in PSMPATH or must be "dbdoctor"ed.
8 ~$ J4 h3 U. R' R2 `7 p
; }/ a5 F/ }: g/ _' U#1   ERROR(305) Device/Symbol check error detected.) E' E6 f; s9 E: e/ t; q% ~4 G! F
# c! w+ p7 p( ~* f" X+ l
Unable to load symbol 'LED3MM_2D54_2DP_4D05W' for device 'Y/G LED * 4_2_LED3MM_2D54_2DP_4': Couldn't find padstack: TH45S28D; H% r3 m* S) s- x' |8 u
    due to Unable to load Flash symbol TR45C55-15D4.+ T2 ~- ~6 b  C& u( U3 X5 f$ m: c
& B; d$ c' |" O! N& j+ _
#2   WARNING(304) Device/Symbol check warning detected./ f' D4 M7 N* J( y# w  t7 d1 P9 M9 O5 ^
7 i6 a+ w/ }: Y9 u! K+ iSymbol 'SOIC_1D27X5D16_16SP_10L' for device 'ADM3202ARU_2_SOIC_1D27X5D16_16S' not found in PSMPATH or must be "dbdoctor"ed.* D2 e- y3 L4 R7 N
& x2 G7 Q( _+ r( I0 O
#3   WARNING(304) Device/Symbol check warning detected.4 `; K: a( B2 Q( B
$ \- ~( r5 i9 u6 b! {/ s) P5 n9 O) `Symbol 'HEADER5X2_40D' for device 'RS232 4P_0_HEADER5X2_40D_IO_5PX' not found in PSMPATH or must be "dbdoctor"ed.
. T  j% i; d! f; O! L  d& u4 T8 m: v2 B% J/ K4 c- {
#4   WARNING(304) Device/Symbol check warning detected.5 g* f# }- e. S) e  Q% G5 l: J
9 O4 o" o' p" n3 i3 ~
Symbol 'RJ45FS_1X8DP_KINSUN' for device 'RJ45_0_RJ45FS_1X8DP_KINSUN_IO_8' not found in PSMPATH or must be "dbdoctor"ed.
1 |- B1 R" z9 H6 |5 k, D! F0 x8 q9 n+ \% |$ v, g
" `: M" ]( b: X! r7 V) j0 t5 aNote: SECTION property definition created
, h6 M  e" i& V+ n5 K* u: ?
4 z6 x3 S9 C6 t/ F2 ~------ Library Paths ------
, }  d! B( r2 I: v& H/ y* q0 a0 M" }MODULEPATH =  .
$ s, V8 r/ G5 e! H, e: H0 w8 q% N           C:/Cadence/SPB_15.5/share/local/pcb/modules
- R/ C' r5 \% P& a* A
4 k2 j% f- k3 d, ]( s! V0 j; R) LPSMPATH =  .
% [% V) R1 Z  Y1 M1 {           symbols
5 F  b  R: R3 P/ o( J6 f           ..
# a8 L3 P9 v  f; W           ../symbols # [* n' k4 P6 U  a* o, z
           C:/Cadence/SPB_15.5/share/local/pcb/symbols
+ x) c, h3 o" X           C:/Cadence/SPB_15.5/share/pcb/pcb_lib/symbols 3 @2 n2 T1 O7 J1 E9 x" d) g
           C:/Cadence/SPB_15.5/share/pcb/allegrolib/symbols
" N; S/ J, z8 o6 O) ^$ |" g) h' o; j
PADPATH =  .
9 u0 Q. s3 S% i5 Q5 u" `. |  ?           symbols 2 t7 z+ C1 p( P0 A) c! H
7 |* H' V; V- }: M' `           ../symbols & z3 J& t  B6 ]1 |6 }" h; }/ e
           C:/Cadence/SPB_15.5/share/local/pcb/padstacks
2 j' H" ]/ x/ K# l2 Y  ^  T           C:/Cadence/SPB_15.5/share/pcb/pcb_lib/symbols . o; W2 {' R$ B9 ~# Q/ J& ?
7 t" H0 v  S9 m0 W& j+ E* v7 m0 @* j. C7 K' s
! ^5 k4 p: i9 _) E------ Summary Statistics ------
0 K1 }9 e; q  e$ k. d4 e# u, x9 U9 x" \
! p9 E6 j. D% `. m#2   ERROR(102) Run stopped because errors were detected
* D( Y2 v5 W/ {5 W& |, M. U1 j  }7 ^: i: K2 }; i+ k
netrev run on Jul 21 12:30:24 2011& Z/ ?1 G0 g5 D" B
   DESIGN NAME : 'RJ45 CONSOLE_0709'
) J6 z7 Y/ Q) A/ U8 s9 F   PACKAGING ON Jun 17 2005 00:56:10: }- Q. y0 s6 g% p' L  p
# D, L9 a! t: b   COMPILE 'logic'
/ w2 p" E" C0 K5 |4 [# Z   CHECK_PIN_NAMES OFF4 }. A& P) B8 ~) E7 p
   CROSS_REFERENCE OFF
7 r1 R0 l. s  J7 I   FEEDBACK OFF
! ?$ U* o) ]0 i6 M* i& p   INCREMENTAL OFF7 P) O2 v5 ^6 G/ I
   INTERFACE_TYPE PHYSICAL
0 o3 V2 k" G7 A& `3 M0 ?   MAX_ERRORS 500
% @4 H, r( ~+ ^, Y9 e   MERGE_MINIMUM 5
8 L& X" N3 `9 s, l, N   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
' A* O4 d0 l/ x" d7 x1 q! W   NET_NAME_LENGTH 24, Q9 R! m, h9 M3 T# E6 T
   OVERSIGHTS ON
7 K2 }; ?& P# o& [- k" F8 E. a! h   REPLACE_CHECK OFF
- b% d/ s7 m4 W; p& h' p   SINGLE_NODE_NETS ON
, M2 q, n6 K% t" j) \& S0 o   SPLIT_MINIMUM 04 q9 g2 H7 E  F% s" D  e5 T
   SUPPRESS   20
6 a( q* |5 F* M, J6 S   WARNINGS ON
; ^1 D9 B8 R( W4 g: ?0 |+ I* Y: I
  2 errors detected2 z4 T" G1 }0 j; _4 q) B% G) {  {) O
No oversight detected5 g' ~: x9 n' f. C
  4 warnings detected8 X5 Q1 W; ~4 o! }8 u- f
, G9 R' Z2 @( x- X8 L0 s
cpu time      0:00:12  q" J" i4 P1 a; `% }4 y$ b
elapsed time  0:00:00
 楼主| 发表于 2011-7-22 17:37 | 只看该作者
怎么没人帮忙啊~~各位哥哥,姐姐们,大侠们帮帮忙哈。4 ~- B6 ^0 {$ C
     要不真石沉大海了。。
    2025-7-28 15:25
  • 签到天数: 475 天
    [LV.9]以坛为家II
    发表于 2011-7-23 10:52 | 只看该作者
    我也静待高人指点/ a) ^0 j- s& a; ~
    2023-10-12 15:00
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2011-7-23 14:11 | 只看该作者
    找不到封装库
    擦汗
    2020-1-21 15:53
  • 签到天数: 8 天
    [LV.3]偶尔看看II
    发表于 2011-7-23 16:24 | 只看该作者
    重新设置封装库路径
    发表于 2011-7-23 17:31 | 只看该作者
      k9 d8 q6 [. L& T5 H; ~  jUnable to load symbol 'LED3MM_2D54_2DP_4D05W' for device 'Y/G LED * 4_2_LED3MM_2D54_2DP_4': Couldn't find padstack: TH45S28D3 $ `+ L5 s1 p. x- h) C: g6 L
    ----------------------TH45S28D3 ,焊盘没有找到。
     楼主| 发表于 2011-7-28 16:48 | 只看该作者
            封装库路径也是设置好的,  K/ u' Q, U) H) _
    封装等等都是从原PCB源文件中导出来的,然后在用别人的PCB文件模块就能导入Netlist文件就可以,用自己新建的就是不行,& \! D- J! t6 x. g9 e
    GMT+8, 2025-10-9 04:54 , Processed in 0.125000 second(s), 24 queries , Gzip On.
