查看: 341|回复: 2
stm32频率计源码(输入捕获模式)低频误差小,高频误差大
发表于 2021-10-9 10:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
STM32F10X频率计,分享给大家,已调试通过,好使,低频无误差,高频有些误差。
; L1 m& T( I: Z. u/ M: G5 }( C! c4 d: r+ `# ]' r* X3 ~
单片机源程序如下:' I$ `3 D% N" Q# c) f, q6 b
  • #include "counter.h"
  • #include "stdio.h"
  • #include "usart.h"
  • #include "delay.h"
  •   //上升沿捕获
  • TIM_ICInitTypeDef  TIM3_ICInitStructure;
  • void TIM3_counter_Init(u16 arr,u16 psc)
  •         GPIO_InitTypeDef GPIO_InitStructure;
  •         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  •            NVIC_InitTypeDef NVIC_InitStructure;
  •         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,  ENABLE);          //使能TIM5时钟
  •          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);   //使能GPIOA时钟
  •         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_7;              //PA7 清除之前设置
  •         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //PA7 浮空输入
  •         GPIO_Init(GPIOA, &GPIO_InitStructure);
  •         GPIO_ResetBits(GPIOA,GPIO_Pin_7);                                                              //PA7 下拉
  •         //初始化定时器5 TIM5
  •         TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
  •         TIM_TimeBaseStructure.TIM_Prescaler =psc;         //预分频器
  •         TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
  •         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
  •         TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
  •         //初始化TIM5输入捕获参数
  •         TIM3_ICInitStructure.TIM_Channel = TIM_Channel_2;                   //         选择输入端 IC1映射到TI1上
  •           TIM3_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;           //上升沿捕获
  •           TIM3_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上
  •           TIM3_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;                             //配置输入分频,不分频
  •           TIM3_ICInitStructure.TIM_ICFilter = 0x00;                                                            //IC1F=0000 配置输入滤波器 不滤波
  •           TIM_ICInit(TIM3, &TIM3_ICInitStructure);
  •         TIM_SelectInputTrigger(TIM3, TIM_TS_TI2FP2); //选择IC2为始终触发源
  •     TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);//TIM从模式:触发信号的上升沿重新初始化计数器和触发寄存器的更新事件
  •     TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable); //启动定时器的被动触发
  •         //中断分组初始化
  •         NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM3中断
  •         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占优先级2级
  •         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;  //从优先级0级
  •         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;         //IRQ通道被使能
  •         NVIC_Init(&NVIC_InitStructure);  //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
  •         TIM_ITConfig(TIM3,TIM_IT_CC2,ENABLE);//不能允许更新中断 ,允许CC2IE捕获中断
  •            TIM_Cmd(TIM3,ENABLE);         //使能定时器3
  • u32  counter=0;        // 每秒计数
  • int  Frequency=0;
  • void TIM3_IRQHandler(void)
  •         static int  i =0;
  •         if (TIM_GetITStatus(TIM3, TIM_IT_CC2) == SET)
  •       TIM_ClearITPendingBit(TIM3, TIM_IT_CC2);             //清楚TIM的中断待处理位
  •                         counter = (u32)TIM_GetCapture2(TIM3);
  •       Frequency =72000000/counter;
  •                   printf("当前频率为:%d Hz\r\n",Frequency/7200);       //打印数据
  •                         for(i=0;i<2000000;i++)
    1 ^# y" U9 m4 r9 e8 |8 M
' m/ ^2 R% l, L0 u% @3 @. g; s
; r, E! g. B) K1 |
% c# |$ R( ~9 {  l0 E1 ~2 }$ g: i
发表于 2021-10-9 11:11 | 只看该作者
有些芯片没有捕获模式
发表于 2021-10-9 13:44 | 只看该作者
学习学习  感谢分享
+ T+ f  A4 U# P- s( K
GMT+8, 2025-10-6 09:23 , Processed in 0.140625 second(s), 23 queries , Gzip On.
