8 x0 s2 D, a U3 Q- w一、简介
. S; P6 g7 w' t3 U4 @8 u7 h/ W基于matlab GUI银行贷款计算系统
2 N4 ~% E1 T7 N: J; E/ p
( r4 d4 L0 j$ h/ `$ M3 l- F( i$ `' f
二、源代码$ Z P6 ?( z5 X, ~) @: F N& G
! P8 }: a4 G W- function varargout = untitled4(varargin)
- % UNTITLED4 M-file for untitled4.fig
- % UNTITLED4, by itself, creates a new UNTITLED4 or raises the existing
- % singleton*.
- % H = UNTITLED4 returns the handle to a new UNTITLED4 or the handle to
- % the existing singleton*.
- % UNTITLED4('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in UNTITLED4.M with the given input arguments.
- % UNTITLED4('Property','Value',...) creates a new UNTITLED4 or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before untitled4_OpeningFunction gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to untitled4_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- % See also: GUIDE, GUIDATA, GUIHANDLES
- % Edit the above text to modify the response to help untitled4
- % Last Modified by GUIDE v2.5 25-Jun-2021 08:16:21
- % Begin initialization code - DO NOT EDIT
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @untitled4_OpeningFcn, ...
- 'gui_OutputFcn', @untitled4_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
- if nargout
- [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
- else
- gui_mainfcn(gui_State, varargin{:});
- end
- % End initialization code - DO NOT EDIT
- % --- Executes just before untitled4 is made visible.
- function untitled4_OpeningFcn(hObject, eventdata, handles, varargin)
- % This function has no output args, see OutputFcn.
- % hObject handle to figure
- % eventdata reserved - to be defined in a future version of MATLAB
- % handles structure with handles and user data (see GUIDATA)
- % varargin command line arguments to untitled4 (see VARARGIN)
- % Choose default command line output for untitled4
- handles.output = hObject;
- % Update handles structure
- guidata(hObject, handles);
- % UIWAIT makes untitled4 wait for user response (see UIRESUME)
- % uiwait(handles.figure1);
- % --- Outputs from this function are returned to the command line.
- function varargout = untitled4_OutputFcn(hObject, eventdata, handles)
- % varargout cell array for returning output args (see VARARGOUT);
- % Get default command line output from handles structure
- varargout{1} = handles.output;
- % --- Executes on selection change in listbox1.
- function listbox1_Callback(hObject, eventdata, handles)
- % hObject handle to listbox1 (see GCBO)
- % Hints: contents = get(hObject,'String') returns listbox1 contents as cell array
- % contents{get(hObject,'Value')} returns selected item from listbox1
- % --- Executes during object creation, after setting all properties.
- function listbox1_CreateFcn(hObject, eventdata, handles)
- % handles empty - handles not created until after all CreateFcns called
- % Hint: listbox controls usually have a white background on Windows.
- % See ISPC and COMPUTER.
- if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
- set(hObject,'BackgroundColor','white');
- end
- % --- Executes on selection change in listbox2.
- function listbox2_Callback(hObject, eventdata, handles)
- % hObject handle to listbox2 (see GCBO)
- % Hints: contents = get(hObject,'String') returns listbox2 contents as cell array
- % contents{get(hObject,'Value')} returns selected item from listbox2
- function listbox2_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on selection change in listbox3.
- function listbox3_Callback(hObject, eventdata, handles)
- % hObject handle to listbox3 (see GCBO)
- % Hints: contents = get(hObject,'String') returns listbox3 contents as cell array
- % contents{get(hObject,'Value')} returns selected item from listbox3
- function listbox3_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on button press in radiobutton1.
- function radiobutton1_Callback(hObject, eventdata, handles)
- % hObject handle to radiobutton1 (see GCBO)
- % Hint: get(hObject,'Value') returns toggle state of radiobutton1
- function d_edit1_Callback(hObject, eventdata, handles)
- % hObject handle to d_edit1 (see GCBO)
- % Hints: get(hObject,'String') returns contents of d_edit1 as text
- % str2double(get(hObject,'String')) returns contents of d_edit1 as a double
- function d_edit1_CreateFcn(hObject, eventdata, handles)
- % Hint: edit controls usually have a white background on Windows.
- end
- function edit2_Callback(hObject, eventdata, handles)
- set(handles.edit2,'string');
- % hObject handle to edit2 (see GCBO)
- % Hints: get(hObject,'String') returns contents of edit2 as text
- % str2double(get(hObject,'String')) returns contents of edit2 as a double
- function edit2_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on button press in pushbutton1.
- function pushbutton1_Callback(hObject, eventdata, handles)
- x1=str2num(get(handles.d_edit1,'string'));
- x2=str2num(get(handles.edit2,'string'));
- x3=get(handles.listbox2,'value');
- x3=x3*12;
- x4=get(handles.listbox3,'value');
- x4=x4/12;
- x5=[x1*x4*(1+x4)^x3]/[(1+x4)^x3-1];
- x6=x5*x3;
- x7=x6-x1;
- set(handles.text13,'string',num2str(x6));
- set(handles.text14,'string',num2str(x2));
- set(handles.text15,'string',num2str(x5));
- set(handles.text16,'string',num2str(x1));
- set(handles.text17,'string',num2str(x7));
- set(handles.text18,'string',num2str(x3));
- % hObject handle to pushbutton1 (see GCBO)
- % --- Executes on button press in pushbutton2.
- function pushbutton2_Callback(hObject, eventdata, handles)
- set(handles.d_edit1,'string','');
- set(handles.edit2,'string','');
- set(handles.text13,'string','');
- set(handles.text14,'string','');
- set(handles.text15,'string','');
- set(handles.text16,'string','');
- set(handles.text17,'string','');
- set(handles.text18,'string','');
- % hObject handle to pushbutton2 (see GCBO)
1 X% r% e6 U+ X; W$ ~9 {9 D3 A' T & Q" U" I% U. c+ R' m& z d' R
# h! T/ V- q& t6 j1 S$ w8 I
$ `. a; [: P2 ~$ [
' r8 y' i# |1 r6 Z U三、运行结果! ^5 d# A& A& a3 I( k
. d# p( k. V" w
: e$ k: {: ]# Y' n2 R# F; f
e! I" y* o% M9 W, i! I
* V6 m) t4 l( k! } o3 ^
) @6 K5 j I) R$ B1 ~9 T4 Q. W
