查看: 328|回复: 0
ZCC2785 (500V线性稳压器芯片,替代NCP785)
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-9-18 15:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    The ZCC2785 is a high−peRFormance linear regulator, offering a very wide
    $ O6 P! d* _6 b6 R/ R( aoperating input voltage range of up to 450 V DC, with an output current of up to7 [' I+ Y- e7 @* a8 }
    10 mA.
    4 @' D) W0 o8 S2 U" h& nIdeal for high input voltage applications such as industrial and home metering,
    " T2 ]$ a( B! t0 _+ u8 r  Z7 @, z1 khome appliances. The ZCC2785 family offers ±5% initial accuracy, extremely
    ' b5 t  T& r% H9 K' ~. Whigh−power supply rejection ratio and ultra−low quiescent current. The& T; u8 b3 }9 V8 Y
    ZCC2785 is optimized for high−voltage line and load transients, making this0 ^1 m. F3 P! L$ j( r3 e; z& E9 }! r
    part ideal for harsh environment applications.
    9 U. `" y) r( u1 p: cThe ZCC2785 is offered in fixed output voltage options 2.7V,3.3 V, and5.0 V.: T, s" I) ?3 o' \. V- I
    package offers good thermal performance and
    ! B4 I0 c5 d; R( H" B. r4 Rhelp to* W8 @4 b# ]& N) J" @
    minimize the solution size.5 @8 \/ o: e! c, {, P
    Features
    1 N" S  j' |7 F& z6 i8 u2 a( Q● Wide Input Voltage Range:$ Y3 z4 ^" q0 s# x+ c
    DC: Up to 450 V% C& Y4 n1 M7 `( @9 t3 R- T
    AC: 85 V to 260 V (half−wave rectifier and 2.2 μF capacitor)
    ! I7 q0 `. s0 e& P' V  w●10 mA Guaranteed Output Current
    8 A8 j6 u8 n$ N8 e4 Q7 e  g& n●Ultra Low Quiescent Current: Typ. 10 μA (VOUT ≤ 5 V)
      m& H" S6 i5 C; Q% z+ X●±5% Accuracy Over Full Load, Line and Temperature Variations
    ; m+ Z7 j5 O1 t$ m●Ultra−high PSRR: 70 dB at 60 Hz, 90 dB at 100 kHz1 g/ j7 P5 d  j6 w9 m0 |
    ●Stable with Ceramic Output Capacitor 22 μF MLCC
    2 r6 |0 b9 V8 K; ~- Q; ^' a●Thermal Shutdown and Current Limit Protection
    1 Q0 ?+ F4 M5 M7 o/ \●Available in Thermally Enhanced ESOP8 Package
    $ p$ K' N+ x  Q7 L0 F" P5 ?●This is a Pb−Free Device
      M1 }2 w! M* R$ N: |8 T: O% F- s+ K3 L0 W$ ^( N/ Z3 Y6 h+ U  j1 Y
    GMT+8, 2025-10-13 05:54 , Processed in 0.125000 second(s), 24 queries , Gzip On.
