TA的每日心情 | 开心 2022-5-9 15:00 |
签到天数: 28 天 [LV.4]偶尔看看III
General Description( p& a7 s# c6 ?
The Z CC9059 is a high peRFormance positive voltage regulator* q- V, o5 x/ w3 r4 u' G$ J
designed for use in applications requiring very low input
& a6 }1 e y" s( H( Pvoltage and very low dropout voltage at up to 3A. It operates* Q% ]; [" ]$ n5 m; r& S
with a VIN as low as 1V and VDD voltage 3V with
. o5 `# P* g+ q4 Y: L% eprogrammable output voltage as low as 0.8V. The Z CC9059
6 k, S/ j) [ W' y4 T! qfeatures ultra low dropout, ideal for applications where* p3 D) w. j$ A4 @/ a4 r0 k
VOUT is very close to VIN. Additionally, it has an enable% t3 f5 f& `1 B
pin to further reduce power dissipation while shutdown.
, J7 T! u* H" q* d- kThe Z CC9059 provides excellent regulation over variations
3 u( S% z! f& u G$ x, T, ?in line, load and temperature. The Z CC9059 provides a power7 l6 d6 a6 v; H2 l1 f3 F7 b5 l/ i
good signal to indicate if the voltage level of VO reaches4 _5 g7 g8 M& q, L
90% of its rating value.' M4 p1 F, X2 T" T0 J* r
Features% Z9 ~6 O1 l8 s- z- J0 `
% y; _: k* E( I, O/ V, N) B* f' KOutput Current up to 3A
# u8 f7 R" y# z1 y& F' \
& [& x8 j* d) l9 d+ mHigh Accuracy ADJ Voltage 1.5%
8 P/ a. @0 r6 Q V) v* J
. _) q5 ?, O# ~Dropout Voltage 350mV @ 3A Typically. j* O% X. U, B4 M( O
; K* K/ E2 ^/ Y7 J9 z2 M$ CVOUT Power Good Signal' a" ?) Z5 F0 a. h
/ t. l& ^/ o2 R+ Y) [5 ~$ ^
VOUT Pull Low Resistance when Disable9 b7 `, V _+ o% Y
7 i" Y: _3 ^: ^9 ?& @ u) VCurrent Limiting Protection% Q f4 j5 R2 I& v4 R
# s0 n9 c* y1 e( S6 }Thermal Shutdown Protection
7 S j8 D( W# `1 T1 } l + J$ ]( H9 {. S
RoHS Compliant and Halogen Free
5 e# G( |$ I8 q' S
7 m! Z4 d. n6 a# J, O1 t8 q
1 @9 \# b m* H7 t2 A |
