$ a2 Q% k7 J$ @: S- q( ~
一、源代码
9 f" o7 N' _( f' _- function varargout = GUI(varargin)
- % GUI MATLAB code for GUI.fig
- % GUI, by itself, creates a new GUI or raises the existing
- % singleton*.
- % H = GUI returns the handle to a new GUI or the handle to
- % the existing singleton*.
- % GUI('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in GUI.M with the given input arguments.
- % GUI('Property','Value',...) creates a new GUI or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before GUI_OpeningFcn gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to GUI_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @GUI_OpeningFcn, ...
- 'gui_OutputFcn', @GUI_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
- if nargout
- [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
- else
- gui_mainfcn(gui_State, varargin{:});
- end
- % End initialization code - DO NOT EDIT
- % --- Executes just before GUI is made visible.
- function GUI_OpeningFcn(hObject, eventdata, handles, varargin)
- % This function has no output args, see OutputFcn.
- % hObject handle to figure
- % eventdata reserved - to be defined in a future version of MATLAB
- % handles structure with handles and user data (see GUIDATA)
- % varargin command line arguments to GUI (see VARARGIN)
- % Choose default command line output for GUI
- handles.output = hObject;
- % Update handles structure
- guidata(hObject, handles);
- % UIWAIT makes GUI wait for user response (see UIRESUME)
- % uiwait(handles.figure1);
- % --- Outputs from this function are returned to the command line.
- function varargout = GUI_OutputFcn(hObject, eventdata, handles)
- % varargout cell array for returning output args (see VARARGOUT);
- % Get default command line output from handles structure
- varargout{1} = handles.output;
- % --- Executes on button press in pushbutton1.
- function pushbutton1_Callback(hObject, eventdata, handles)
- str1=sprintf('思路\n\n');
- str2=sprintf(' 1.视频分帧\n');
- str3=sprintf(' 2.人脸定位\n');
- str4=sprintf(' 3.人脸定位\n');
- str5=sprintf(' 4.灰度积分投影,定位黑色眼球面积\n');
- str6=sprintf(' 3.判断睁眼,闭眼,利用perclos定理判定疲劳与否\n');
- str7=sprintf(' 3.时间仓促,未尽事宜,可联系Q1321-8148-23\n');
- string=[str1 str2 str3 str4 str5 str6 str7];
- msgbox(string,'温馨提示','none');
- % hObject handle to pushbutton1 (see GCBO)
- % --- Executes on selection change in listbox1.
- function listbox1_Callback(hObject, eventdata, handles)
- % hObject handle to listbox1 (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns listbox1 contents as cell array
- % contents{get(hObject,'Value')} returns selected item from listbox1
- % --- Executes during object creation, after setting all properties.
- function listbox1_CreateFcn(hObject, eventdata, handles)
- % handles empty - handles not created until after all CreateFcns called
- % Hint: listbox controls usually have a white background on Windows.
- % See ISPC and COMPUTER.
- if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
- set(hObject,'BackgroundColor','white');
- end
- function edit1_Callback(hObject, eventdata, handles)
- % hObject handle to edit1 (see GCBO)
- % Hints: get(hObject,'String') returns contents of edit1 as text
- % str2double(get(hObject,'String')) returns contents of edit1 as a double
- function edit1_CreateFcn(hObject, eventdata, handles)
- % Hint: edit controls usually have a white background on Windows.
- end
- % --- Executes on selection change in listbox2.
- function listbox2_Callback(hObject, eventdata, handles)
- % hObject handle to listbox2 (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns listbox2 contents as cell array
- % contents{get(hObject,'Value')} returns selected item from listbox2
- function listbox2_CreateFcn(hObject, eventdata, handles)
- end
- function edit2_Callback(hObject, eventdata, handles)
- % hObject handle to edit2 (see GCBO)
- % Hints: get(hObject,'String') returns contents of edit2 as text
- % str2double(get(hObject,'String')) returns contents of edit2 as a double
- function edit2_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on selection change in listbox3.
- function listbox3_Callback(hObject, eventdata, handles)
- % hObject handle to listbox3 (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns listbox3 contents as cell array
- % contents{get(hObject,'Value')} returns selected item from listbox3
- function listbox3_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on button press in pushbutton2.
- function pushbutton2_Callback(hObject, eventdata, handles)
- % hObject handle to pushbutton2 (see GCBO)
- function edit3_Callback(hObject, eventdata, handles)
- % hObject handle to edit3 (see GCBO)
- % Hints: get(hObject,'String') returns contents of edit3 as text
- % str2double(get(hObject,'String')) returns contents of edit3 as a double
- function edit3_CreateFcn(hObject, eventdata, handles)
- end
6 f% N/ ^ g2 N0 F+ ^& P. [0 C , ?" ]# M ]* E" k5 y/ l
$ I' g. x- X& b! }, b2 v
- ^$ `. w6 h& D. k' S( C/ D二、运行结果3 s( K; i# M* |! K+ p0 e
9 g7 K- ]) t% V9 L W! V+ {
0 _7 y( ~: v" p& ^
3 \4 k4 Q% o2 |# C: C. ^/ f
