查看: 1680|回复: 0
xdjm们帮我看看这个问题是怎么回事,谢谢了
发表于 2008-5-30 16:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在logic与pcb同步的时候出了一堆这种错误,为什么呢?
  B, g5 X7 I& B7 q$ u1 a6 w
- r9 Y& `* E* F  wLine 702 , Section *SET_ATTRIBUTE*9 _& l( ]: L: W3 O' h5 D, C  H+ K2 n3 [
"Voltage" 25V2 O% w6 S# K4 ^5 Y8 R2 m
* WARNING: Attribute "Voltage" in dictionary is not allowed for PART objects  W! b! H. Z4 M, X
*          Dictionary is modified to allow attribute for PART# g# K1 K3 J5 g
Line 721 , Section *SET_ATTRIBUTE*: d- S6 r# c* X8 u  B& X" y
"Voltage" 50v+ Q, E; Z: \& Q. Y2 ?3 d
* Voltage 50v: Error:   String v is treated as Volt but such treatment is prohibited
, C1 B- _+ C: _- ]  A. MLine 982 , Section *SET_ATTRIBUTE*# ^; K4 Z9 z2 L) E1 V+ ~- V
"Voltage" 50v
( H, h3 F3 g/ B* Voltage 50v: Error:   String v is treated as Volt but such treatment is prohibited
GMT+8, 2025-10-12 21:19 , Processed in 0.109375 second(s), 24 queries , Gzip On.
