TA的每日心情 | 开心 2022-5-9 15:00 |
签到天数: 28 天 [LV.4]偶尔看看III
Features5 u7 U6 N" Y0 r: Z U
' D2 L( {+ U2 h/ C3 f7 \* z$ \3 |Wide Input Voltage Range from 4V to 36V
7 @3 Q& A, q4 _4 r5 I
3 D& a' O0 r. L% z2 gProgrammable VOUT Range from 0.8V to 24V
0 N) Q) @+ T0 d1 Q. x+ \
; X' G8 X% W4 e# j, YPeak Current Mode Control$ L: _/ T" ^' {- X
+ o5 R. t& y8 q
Integrated 6V/3A Peak Gate Drive
9 i$ \0 e' l7 W8 ^* m 2 Q- N6 j( V, Z4 }# M3 v! O' ]
Adjustable Cycle-by-Cycle Current Limit by ILIM
) O$ P* R4 `! o) X: F& i: u& T. A " T* N; A- J+ l! l' X: H( h# B# A
Adjustable Frequency: 100kHz~1MHz
R2 ?, e! B: D& J5 |9 m( x! @ $ @0 K# s/ F0 n8 x+ Z6 G
External Soft-Start Limits the Input Inrush Current/ `3 K; ]+ c! z9 K* D
% u. F7 _/ i+ c, b6 o0 {$ R0 F2 w# Z
Internal PMOS Driver for Bypass Mode
1 K- z# _, c6 L; x9 k
, t& D' S: k; a* D0 r) MSelectable FCCM or DCM with Pulse Skipping# H8 T( g' p6 X: ~ h
* |/ h- e& |9 s8 Q4 }; |Cable Impedance Compensation
* d1 Z' f3 n8 Y4 d1 ]- u# D
1 e/ K7 E" X$ c2 q5 ILow Dropout Operation with Maximum Duty 6 F/ b6 {: o4 v4 l) F- W
Cycle at 99.5%. V4 o+ ?& B" b5 W7 J1 I5 P
) c) f& Q, B1 O( W7 A" Z P
I2C Programmable Output Range from 3.0V to 4 [6 c$ j! q- _
21V in 200mV Per Step' d: |5 N0 T' }( G3 d) f% q. [! t9 d
6 k6 x9 D c; S. }- }Input Under-Voltage Lockout, C& q) U5 A7 {3 M7 T: b7 r! ~
# @* u* y3 H" q4 I$ vOutput OCP, SCP, OVP
' Q% p0 l/ N6 A, [( E3 R ) W% a2 H6 h% d% t8 ~. d
Thermal Shutdown
" D% X8 X7 W1 Y' d. [ . i" R4 \/ K. S: g. S: ?
QFN-20 Package, 3mm×3mm×0.75mm
& I, x! U7 M2 R+ Z8 q( D& rDescription
) z8 v. w8 j# J4 I4 _) {The ZCC7200 is a synchronous buck controller mainly . w; q9 H2 s- X5 |
for widely varying input step-down regulator8 e# a. {, @$ t2 L) x( I7 P. l- F' ^
applications. The control method is based upon m1 C! y% F$ J) M/ R {" c% D/ I
current mode control that enables maximum $ z2 l7 L& ^% X% X) f5 w; C
peRFormance under transient conditions. The output
# V i- @1 @3 U* c4 ?voltage can be either programmed by the FB pin or - a! y8 W1 N" W9 R- m
configured by the I2C interface from 3.0V to 21V in
4 V. {+ Y {/ ]6 {3 L4 y! P* j200mV per step. It operates as a Buck mode while $ q" t! S- ]& Y0 ^+ _3 k
the input voltage is sufficiently greater than the
' f* D, O/ p8 t0 Jregulated output voltage and transitions to the bypass5 |1 X9 n' O% e5 ~: p- D0 W. I8 E
mode as the input voltage very approaches the output
: f+ {" h) b+ l4 Y( k) S8 ^- {voltage. It also features an adjustable soft-start O. X; T: m" i! a* S2 ^; c6 B4 ~
function and offers protection features including input . v( o: o8 d* N$ d
UVLO, cycle-by-cycle current limit, output overload
. F+ g+ c! a# V# l, [0 M' M( N1 zprotection (OLP) or OVP and thermal shutdown. In 9 N) |* u% S7 I- W4 r/ @
addition, it features selectable Forced Continuous : R' \- Y& Z" ~1 @1 Z0 Q
Conduction Mode (FCCM) or Discontinuous 7 O5 [% G& F! c4 x# o
Conduction Mode (DCM) operation for light load.* k. O% s# U: o' A: F' T
The ZCC7200 integrates an I2C compatible interface ' @1 P. \' u" X1 A" G3 }9 w
for bypass mode selecting, output voltage setting, etc.
, {! f$ Y L) \ C! k: OThe ZCC7200 is available in compact QFN3x3-20./ V. R4 n a5 u- w& o* F }) e
- J2 f+ m5 M* X% [6 Y' r+ |
, Y8 B( m) C _ |
